  3. Adding sensor to controller when it's part of gateway
6 Posts 2 Posters 1.6k Views 2 Watching
  • HomerH
    HomerH
    Homer
    G'day everyone
    I'm trying to merge some of my sensors so I can save a little money. I know I'm not going to save much, but every dollar counts lol anyways what I've done is merged my RF433 Hub with my Ethernet gateway. My Vera controller seems to see the gateway, but how do I get it to see the child devices of the hub?
    • HomerH
      HomerH
      Homer
      I have been working on this for most of the day, but haven't got far :-(
      A search found that I am not the only person to experience this issue, but unfortunately I couldn't find a fix. I found this thread where someone was having the exact same issue, so I did what it was suggested and downloaded MYSController and followed the instructions. MYSController showed me some cool stuff, and it seems to see that I have created 6 RF433 devices, but I don't know what to do to make them show up on my Vera controller.
      Below is a screenshot of MYSController. There are no sensors attached in any way to the Gateway, apart from the 6 RF433 devices that I created in the sketch.
      In case it's the sketch where I made the mistake, I will include it below. I have read through it over and over and I just can't seem to find why the sensors won't show up.
      #define MY_RADIO_RF24
      //#define MY_RADIO_NRF5_ESB
      //#define MY_RADIO_RFM95
      #define MY_GATEWAY_W5100
      //#define MY_W5100_SPI_EN 4
      // radio on the same spi bus.
      #define MY_SOFTSPI
      #ifndef MY_RF24_CE_PIN
      #define MY_RF24_CE_PIN 5
      #ifndef MY_RF24_CS_PIN
      #define MY_RF24_CS_PIN 6
      // Enable UDP communication
      //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
      #define MY_IP_ADDRESS 192,168,0,100
      //#define MY_IP_GATEWAY_ADDRESS 192,168,0,100
      #define MY_PORT 5003
      #define MY_GATEWAY_MAX_CLIENTS 8
      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
      //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
      // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
      // Enable inclusion mode
      // Set blinking period
      // Flash leds on rx/tx/err
      //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
      //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
      //#define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
      #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
      #include <Ethernet.h>
      #include <RCSwitch.h>
      #define NUMBER_OF_PLUGS 6 // Total number of attached plugs
      #define SHORTPULSE 316
      #define LONGPULSE 818
      #define CODE_1On 4072574
      #define CODE_1Off 4072566
      #define CODE_2On 4072572
      #define CODE_2Off 4072564
      #define CODE_3On 4072570
      #define CODE_3Off 4072562
      #define CODE_4On 1386894
      #define CODE_4Off 1386886
      #define CODE_5On 1386892
      #define CODE_5Off 1386884
      #define CODE_6On 1386890
      #define CODE_6Off 1386882
      RCSwitch mySwitch = RCSwitch();
        mySwitch.enableTransmit(4);
        mySwitch.setRepeatTransmit(15);
        sendSketchInfo("Gateway & 433mhz Hub", "2.0");
        for (int sensor = 1 ; sensor <= NUMBER_OF_PLUGS; sensor++) {
          present(sensor, S_LIGHT);
          int incomingLightState =  message.getBool();
          int incomingOutlet = message.sensor;
          Serial.print("Outlet #: ");
          Serial.println(message.sensor);
          Serial.print("Command: ");
          if (incomingOutlet == 1) {
            if (incomingLightState == 1) {
              // Turn on  socket 1
              Serial.println("Turn on Socket 1");
              mySwitch.send(CODE_1On, 24); // These codes are unique to each outlet
              delay(50);
            if (incomingLightState == 0)  {
              // Turn off socket 1
              Serial.println("Turn off Socket 1");
              mySwitch.send(CODE_1Off, 24);
              delay(50);
          if (incomingOutlet == 2) {
              // Turn on  socket 2
              Serial.println("Turn on Socket 2");
              mySwitch.send(CODE_2On, 24);
              delay(50);
              // Turn off socket 2
              Serial.println("Turn off Socket 2");
              mySwitch.send(CODE_2Off, 24);
              delay(50);
          if (incomingOutlet == 3) {
              // Turn on  socket 3
              Serial.println("Turn on Socket 3");
              mySwitch.send(CODE_3On, 24);
              delay(50);
              // Turn off socket 3
              Serial.println("Turn off Socket 3");
              mySwitch.send(CODE_3Off, 24);
              delay(50);
          if (incomingOutlet == 4) {
              // Turn on  socket 4
              Serial.println("Turn on Socket 4");
              mySwitch.send(CODE_4On, 24);
              delay(50);
              // Turn off socket 4
              Serial.println("Turn off Socket 4");
              mySwitch.send(CODE_4Off, 24);
              delay(50);
          if (incomingOutlet == 5) {
              // Turn on  socket 5
              Serial.println("Turn on Socket 5");
              mySwitch.send(CODE_5On, 24);
              delay(50);
              // Turn off socket 5
              Serial.println("Turn off Socket 5");
              mySwitch.send(CODE_5Off, 24);
              delay(50);
          if (incomingOutlet == 6) {
              // Turn on  socket 6
              Serial.println("Turn on Socket 6");
              mySwitch.send(CODE_6On, 24);
              delay(50);
              // Turn off socket 6
              Serial.println("Turn off Socket 6");
              mySwitch.send(CODE_6Off, 24);
              delay(50);
        delay(50);
      I am guessing from the thread that I linked to, that there is something I can do from within MYSController to have the child devices show up; am I right?
      Looking forward to hearing back from someone! I currently have the flu and I am sick of being in bed and resting! :-)
      • skywatchS
        skywatchS
        skywatch
        @homer You talk about RF433 devices and yet you...
        Maybe that is where the problem lies? I am not sure though as I haven't done anything the way you are.
        HomerH 1 Reply Last reply
        • skywatchS skywatch
          HomerH
          HomerH
          Homer
          @skywatch I appreciate your response!
          You can ignore any reference to rf433 devices. All I've really done is created a sensor within the gateway sketch. That sensor happens to control 6 rf433 plugs, that's all.
          So what I have is my Arduino Uno with Ethernet setup as the standard gateway but I've added the sensor to the sketch, and I can't seem to add the sensor part to my controller. The windows program MYSController sees everything on the gateway including the sensor; I just need to know how to get my controller to see it.
          • skywatchS
            skywatchS
            skywatch
            @Homer I am no expert in this but I have thought of something that you could try.
            If I understand correctly you have added one RF433 transmitter to the GW node? This then sends data (On/Off) to the 6 RF433 sockets.
            If so then the gateway only has one child, the RF433 transmitter, the sockets are not 'attached' to the GW.
            So instead of presenting all 6 sockets, just present the one RF433 transmitter and see if that helps? All the code for the actions is in the receive section anyway.
            This is how I did it with IR blaster and it works fine, changing IR for RF should not make a difference in the structure.
            Hold on - I think I got it.....!!!!
            You are using S_LIGHT in presentation - that is no longer supported.
            Change S_LIGHT to S_BINARY.
            Another thing is that although you are presenting your child(s), you do not define the type. I would expect a MyMessage in there somewhere at the start.
            So add MyMessage msgyourmessage (child_id, V_STATUS);
            And finally change V_LIGHT to V_STATUS in the receive function.
              HomerH
              HomerH
              Homer
              @skywatch said in Adding sensor to controller when it's part of gateway:
              Thanks! Yes, you got it lol!!
              The thing that is weird is that all I did was add the rf433 controlled devices from a working sketch to the gateway sketch, so why does it work when it's separate but not when it's part of the gateway sketch? If S_LIGHT is no longer supported, why does it work on a standalone sensor?
