  3. iTead Studio iBoard MySensors Edition
10 Posts 8 Posters 5.9k Views 4 Watching
  • R Offline
    R Offline
    Robin Laurén
    Hello folks!
    Long story short, i've mailed with Jerry from iTead Studio and he said he could create a MySensors compatible iBoard. It seemed like no biggie, in fact, that it wouldn't cost extra, and that he might even sell it to anyone who asks.
    These were his words:
    Well, it's quite simple change.
    We can provide you Mysensors.org version at the same price if you need in small batch.
    I shall consider selling the modified version publicly.
    How's that sound to you? I just think i might ask him for a board or four.
    Here's the original one: http://imall.iteadstudio.com/development-platform/arduino/arduino-compatible-mainboard/im120410001.html
    R 1 Reply Last reply
    • R Robin Laurén
      Hello folks!
      R Offline
      R Offline
      RJ_Make
      @Robin-Laurén I would buy one.
      RJ_Make
      • K Offline
        K Offline
        korttoma
        I could have one or two allso.
        • Tomas
        • M Offline
          M Offline
          marceltrapman
          I might buy four...
          Fulltime Servoy Developer
          • F Offline
            F Offline
            filipq
            I will go for two.
            • R Offline
              R Offline
              Robin Laurén
              His minimum order size is 50 units. Maybe if the owners of Mysensors would like to organise something, or if I could make it happen on Tindie?
              • 5546dug5 Offline
                5546dug5 Offline
                5546dug
                I could do one also
                • H Offline
                  H Offline
                  hugob
                  You can use the unmodified iBoard with a few simple changes in the pin definitions in the RF24_config.h and the sketch. Use the full constructor (not the shortcut with less parameters that will use defaults for missing parameteres and neglect your definitions).
                  See my post
                  http://forum.mysensors.org/topic/224/iboard-cheap-single-board-ethernet-arduino-with-radio/47
                  • greglG Offline
                    greglG Offline
                    gregl
                    Nice work Hugo. Ive just ordered another iboard so will try the software method over my h/w one.... but might it still be good to have a mysensors version which also has the ATSHA204 chip integrated....
                    Also, does anyone have a tricky way to choose a different "RF24_config.h" file when compiling for an iboard and then for a sensor node?
                    • H Offline
                      H Offline
                      hugob
                      My unmodified iBoard is working for months now as a gateway without problems. Initially I had some problems with hanging connections. But these problems disappeared after replacing my 1$ power supply with a 3$ one. The iBoard needs a decent power supply.
