  3. Domoticz
  4. Domoticz crashes using MySensors gateway after update
7 Posts 2 Posters 2.3k Views 2 Watching
  • dzjrD
    dzjrD
    dzjr
    Hello everyone at MySensors,
    I have crosspost this also at the domoticz forum
    I use Domoticz 4.11062 Beta as controller.
    After the last update I have a problem with receiving data from one of my MySensors Ethernet gateways.
    It has worked well for months, only since Monday does domoticz get stuck, and I get the error:
     2019-07-31 21:05:05.638 Error: Domoticz(pid:22708, tid:22844('MySensors')) received fatal signal 11 (Segmentation fault)
    2019-07-31 21:05:05.638 Error: siginfo address=0x58b4, address=(nil)
    2019-07-31 21:11:25.298 Error: Domoticz(pid:23643, tid:23706('MainWorker')) received fatal signal 11 (Segmentation fault)
    2019-07-31 21:11:25.298 Error: siginfo address=0x76d49af4, address=0x27e828
    If I look in the test software "MySController" the data does come through well from the gateway.
    From the fault log I understand that it would be a database error.
    I also tried to completely set up the gateway in domoticz, then the data comes in properly, only after a reboot does domoticz crash again.
    I have connected a self-built weather station to this MySensors gateway with, among other things, a rain sensor which sends the status as "TEXT".
    The reason I use the Beta version of Domoticz is because the Tradfri plugin did not work well with the build version, and it is not advisable to restore from beta to stable.
    I hope one of you wants and can help me.
    thanks in advance
    • MasMatM
      MasMatM
      MasMat
      I have also had a perfectly working system (beta as well) for a month (no Domoticz updates during this time, only apt-get update+upgrade for Rasbian) that stopped working suddenly. The problem has occured sometime between sunday and wednesday (today).
      I didn't have time to troubleshoot today, but I did a reboot but no change.
      dzjrD 1 Reply Last reply
      • MasMatM MasMat
        +1
        dzjrD
        dzjrD
        dzjr
        @masmat
        I now have setup a second domoticz server whit the stable version and there is domoticz working fine whit the same gateway....
        MasMatM 1 Reply Last reply
        • dzjrD dzjr
          @masmat
          MasMatM
          MasMatM
          MasMat
          @dzjr Yeah, I have another beta running at another house. It's working fine, so not a global issue.
          I updated my raspberry software as well (running DietPi though). Still works.
          I will be troubleshooting this latest on sunday and hopefully figure it out. Or someone else has by then..
          • MasMatM
            MasMatM
            MasMat
            wrote on last edited by MasMat
            So, strange one this: ssh to Pi and ran update & upgrade again. Reboot and everything came back.
            I have a watchdog running that should reboot if Domoticz hangs etc but it wasn't reacting. I will update if I get more failures. This was not network etc related. That I was able to troubleshoot from outside.
            Update: it reoccured after I backed up my sd. Domoticz process was "exited". systemctl restart and it works fine again. Will examine the logs.
            • MasMatM
              MasMatM
              MasMat
              Spoke too soon. It seems to die after a while. Here's my log. I don't know how fluent you are with Domoticz but this goes over my head. I also posted to Domoticz forum for help. The log seems fine until this part.
              RasPi Zero W / Stretch / v4.10717 stable
              2019-08-05 06:07:22.325  Error: Stack frame for all threads:
              2019-08-05 06:07:22.325  Error: > [New LWP 457]
              2019-08-05 06:07:22.325  Error: > [New LWP 460]
              2019-08-05 06:07:22.326  Error: > [New LWP 461]
              2019-08-05 06:07:22.326  Error: > [New LWP 481]
              2019-08-05 06:07:22.326  Error: > [New LWP 484]
              2019-08-05 06:07:22.326  Error: > [New LWP 485]
              2019-08-05 06:07:22.326  Error: > [New LWP 488]
              2019-08-05 06:07:22.327  Error: > [New LWP 490]
              2019-08-05 06:07:22.327  Error: > [New LWP 491]
              2019-08-05 06:07:22.327  Error: > [New LWP 492]
              2019-08-05 06:07:22.327  Error: > [New LWP 493]
              2019-08-05 06:07:22.328  Error: > [New LWP 494]
              2019-08-05 06:07:22.328  Error: > [New LWP 550]
              2019-08-05 06:07:22.328  Error: > [New LWP 551]
              2019-08-05 06:07:22.328  Error: > [New LWP 552]
              2019-08-05 06:07:22.328  Error: > [New LWP 557]
              2019-08-05 06:07:22.329  Error: > [New LWP 577]
              2019-08-05 06:07:22.329  Error: > [New LWP 578]
              2019-08-05 06:07:22.329  Error: > [Thread debugging using libthread_db enabled]
              2019-08-05 06:07:22.329  Error: > Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
              2019-08-05 06:07:22.329  Error: > 0xb6e96d60 in nanosleep () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.329  Error: > 84../sysdeps/unix/syscall-template.S: Tiedostoa tai hakemistoa ei ole.
              2019-08-05 06:07:22.330  Error: >   Id   Target Id         Frame
              2019-08-05 06:07:22.330  Error: > * 1    Thread 0xb6f72a60 (LWP 456) "domoticz" 0xb6e96d60 in nanosleep () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.330  Error: >   2    Thread 0xb5f62430 (LWP 457) "Watchdog" 0xb6e9751c in __waitpid (pid=647, stat_loc=0xb5f61598, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29
              2019-08-05 06:07:22.330  Error: >   3    Thread 0xb5761430 (LWP 460) "SQLHelper" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.331  Error: >   4    Thread 0xb4f60430 (LWP 461) "PluginMgr" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.331  Error: >   5    Thread 0xb43b8430 (LWP 481) "InfluxPush" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.331  Error: >   6    Thread 0xb3bb7430 (LWP 484) "Webem_ssncleane" 0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.331  Error: >   7    Thread 0xb33b6430 (LWP 485) "WebServer_8080" 0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.331  Error: >   8    Thread 0xb29ff430 (LWP 488) "Webem_ssncleane" 0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.332  Error: >   9    Thread 0xb21fe430 (LWP 490) "WebServer_443" 0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.332  Error: >   10   Thread 0xb19fd430 (LWP 491) "Scheduler" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.340  Error: >   11   Thread 0xb0fff430 (LWP 492) "TCPServer" 0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.341  Error: >   12   Thread 0xb07fe430 (LWP 493) "MainWorker" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.341  Error: >   13   Thread 0xafffd430 (LWP 494) "MainWorkerRxMsg" 0xb6e92d3c in __pthread_cond_timedwait (cond=0xb9ce20 <m_mainworker+3720>, mutex=0xb9ce08 <m_mainworker+3696>, abstime=0xafffcdc8) at pthread_cond_timedwait.c:200
              2019-08-05 06:07:22.341  Error: >   14   Thread 0xaf7fc430 (LWP 550) "MySensors" 0xb6cde740 in __pselect (nfds=35, readfds=0xaf7fbca8, writefds=0xaf7fbd28, exceptfds=0x0, timeout=<optimized out>, sigmask=0x0) at ../sysdeps/unix/sysv/linux/pselect.c:69
              2019-08-05 06:07:22.341  Error: >   15   Thread 0xaeffb430 (LWP 551) "Domoticz_HBWork" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.342  Error: >   16   Thread 0xae7fa430 (LWP 552) "MySensorsBase" 0xb6e92d3c in __pthread_cond_timedwait (cond=0x2b62c90, mutex=0x2b62c78, abstime=0xae7f9de8) at pthread_cond_timedwait.c:200
              2019-08-05 06:07:22.342  Error: >   17   Thread 0xadff9430 (LWP 557) "PluginMgr_IO" 0xb6e929a4 in __pthread_cond_wait (cond=0x2aeb488, mutex=0x2aeb464) at pthread_cond_wait.c:188
              2019-08-05 06:07:22.342  Error: >   18   Thread 0xad7f8430 (LWP 577) "EventSystem" syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.342  Error: >   19   Thread 0xacff7430 (LWP 578) "EventSystemQueu" 0xb6e92d3c in __pthread_cond_timedwait (cond=0xb9c0b8 <m_mainworker+288>, mutex=0xb9c0a0 <m_mainworker+264>, abstime=0xacff6d0c) at pthread_cond_timedwait.c:200
              2019-08-05 06:07:22.343  Error: >
              2019-08-05 06:07:22.343  Error: > Thread 19 (Thread 0xacff7430 (LWP 578)):
              2019-08-05 06:07:22.343  Error: > #0  0xb6e92d3c in __pthread_cond_timedwait (cond=0xb9c0b8 <m_mainworker+288>, mutex=0xb9c0a0 <m_mainworker+264>, abstime=0xacff6d0c) at pthread_cond_timedwait.c:200
              2019-08-05 06:07:22.343  Error: > #1  0x00267e1c in CEventSystem::EventQueueThread() ()
              2019-08-05 06:07:22.343  Error: > #2  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.344  Error: > #3  0xb6e8bfc4 in start_thread (arg=0xacff7430) at pthread_create.c:458
              2019-08-05 06:07:22.344  Error: > #4  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.344  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.344  Error: > Thread 18 (Thread 0xad7f8430 (LWP 577)):
              2019-08-05 06:07:22.344  Error: > #0  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.345  Error: > #1  0x009ced5c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
              2019-08-05 06:07:22.345  Error: > #2  0x0025e40c in CEventSystem::Do_Work() ()
              2019-08-05 06:07:22.345  Error: > #3  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.345  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xad7f8430) at pthread_create.c:458
              2019-08-05 06:07:22.345  Error: > #5  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.346  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.346  Error: > Thread 17 (Thread 0xadff9430 (LWP 557)):
              2019-08-05 06:07:22.346  Error: > #0  0xb6e929a4 in __pthread_cond_wait (cond=0x2aeb488, mutex=0x2aeb464) at pthread_cond_wait.c:188
              2019-08-05 06:07:22.346  Error: > #1  0x003f338c in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
              2019-08-05 06:07:22.347  Error: > #2  0x003f4180 in boost::asio::io_context::run() ()
              2019-08-05 06:07:22.347  Error: > #3  0x008a3c5c in thread_proxy ()
              2019-08-05 06:07:22.347  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xadff9430) at pthread_create.c:458
              2019-08-05 06:07:22.347  Error: > #5  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.347  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.348  Error: > Thread 16 (Thread 0xae7fa430 (LWP 552)):
              2019-08-05 06:07:22.348  Error: > #0  0xb6e92d3c in __pthread_cond_timedwait (cond=0x2b62c90, mutex=0x2b62c78, abstime=0xae7f9de8) at pthread_cond_timedwait.c:200
              2019-08-05 06:07:22.348  Error: > #1  0x004d94d0 in MySensorsBase::Do_Work() ()
              2019-08-05 06:07:22.348  Error: > #2  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.348  Error: > #3  0xb6e8bfc4 in start_thread (arg=0xae7fa430) at pthread_create.c:458
              2019-08-05 06:07:22.349  Error: > #4  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.349  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.349  Error: > Thread 15 (Thread 0xaeffb430 (LWP 551)):
              2019-08-05 06:07:22.349  Error: > #0  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.350  Error: > #1  0x009ced5c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
              2019-08-05 06:07:22.360  Error: > #2  0x00437e28 in CDomoticzHardwareBase::Do_Heartbeat_Work() ()
              2019-08-05 06:07:22.360  Error: > #3  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.361  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xaeffb430) at pthread_create.c:458
              2019-08-05 06:07:22.361  Error: > Backtrace stopped: Cannot access memory at address 0x1076f776
              2019-08-05 06:07:22.361  Error: > Thread 14 (Thread 0xaf7fc430 (LWP 550)):
              2019-08-05 06:07:22.361  Error: > #0  0xb6cde740 in __pselect (nfds=35, readfds=0xaf7fbca8, writefds=0xaf7fbd28, exceptfds=0x0, timeout=<optimized out>, sigmask=0x0) at ../sysdeps/unix/sysv/linux/pselect.c:69
              2019-08-05 06:07:22.362  Error: > #1  0x008d6240 in mosquitto_loop.part ()
              2019-08-05 06:07:22.362  Error: > #2  0x004cd428 in MQTT::Do_Work() ()
              2019-08-05 06:07:22.362  Error: > #3  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.362  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xaf7fc430) at pthread_create.c:458
              2019-08-05 06:07:22.362  Error: > Backtrace stopped: Cannot access memory at address 0x4
              2019-08-05 06:07:22.363  Error: >
              2019-08-05 06:07:22.363  Error: > Thread 13 (Thread 0xafffd430 (LWP 494)):
              2019-08-05 06:07:22.363  Error: > #0  0xb6e92d3c in __pthread_cond_timedwait (cond=0xb9ce20 <m_mainworker+3720>, mutex=0xb9ce08 <m_mainworker+3696>, abstime=0xafffcdc8) at pthread_cond_timedwait.c:200
              2019-08-05 06:07:22.363  Error: > #1  0x002af548 in MainWorker::Do_Work_On_Rx_Messages() ()
              2019-08-05 06:07:22.363  Error: > #2  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.364  Error: > #3  0xb6e8bfc4 in start_thread (arg=0xafffd430) at pthread_create.c:458
              2019-08-05 06:07:22.364  Error: > #4  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.364  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.364  Error: > Thread 12 (Thread 0xb07fe430 (LWP 493)):
              2019-08-05 06:07:22.365  Error: > #0  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.365  Error: > #1  0x009ced5c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
              2019-08-05 06:07:22.365  Error: > #2  0x002abf5c in MainWorker::Do_Work() ()
              2019-08-05 06:07:22.365  Error: > #3  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.365  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xb07fe430) at pthread_create.c:458
              2019-08-05 06:07:22.365  Error: > #5  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.366  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.366  Error: > Thread 11 (Thread 0xb0fff430 (LWP 492)):
              2019-08-05 06:07:22.366  Error: > #0  0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.366  Error: > #1  0x003f1f64 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
              2019-08-05 06:07:22.367  Error: > #2  0x003f3218 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
              2019-08-05 06:07:22.367  Error: > #3  0x0065db80 in tcp::server::CTCPServer::Do_Work() ()
              2019-08-05 06:07:22.367  Error: > #4  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.367  Error: > #5  0xb6e8bfc4 in start_thread (arg=0xb0fff430) at pthread_create.c:458
              2019-08-05 06:07:22.368  Error: > #6  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.368  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.368  Error: > Thread 10 (Thread 0xb19fd430 (LWP 491)):
              2019-08-05 06:07:22.368  Error: > #0  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.369  Error: > #1  0x009ced5c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
              2019-08-05 06:07:22.369  Error: > #2  0x002cf0b0 in CScheduler::Do_Work() ()
              2019-08-05 06:07:22.369  Error: > #3  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.369  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xb19fd430) at pthread_create.c:458
              2019-08-05 06:07:22.369  Error: > #5  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.370  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.380  Error: >
              2019-08-05 06:07:22.380  Error: > Thread 9 (Thread 0xb21fe430 (LWP 490)):
              2019-08-05 06:07:22.381  Error: > #0  0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.381  Error: > #1  0x003f1f64 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
              2019-08-05 06:07:22.381  Error: > #2  0x003f3218 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
              2019-08-05 06:07:22.381  Error: > #3  0x00698a4c in http::server::server_base::run() ()
              2019-08-05 06:07:22.381  Error: > #4  0x0031a848 in http::server::CWebServer::Do_Work() ()
              2019-08-05 06:07:22.382  Error: > #5  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.382  Error: > #6  0xb6e8bfc4 in start_thread (arg=0xb21fe430) at pthread_create.c:458
              2019-08-05 06:07:22.382  Error: > #7  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.382  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.383  Error: > Thread 8 (Thread 0xb29ff430 (LWP 488)):
              2019-08-05 06:07:22.383  Error: > #0  0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.383  Error: > #1  0x003f1f64 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
              2019-08-05 06:07:22.383  Error: > #2  0x003f3218 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
              2019-08-05 06:07:22.383  Error: > #3  0x003f4180 in boost::asio::io_context::run() ()
              2019-08-05 06:07:22.384  Error: > #4  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.384  Error: > #5  0xb6e8bfc4 in start_thread (arg=0xb29ff430) at pthread_create.c:458
              2019-08-05 06:07:22.384  Error: > #6  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.384  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.384  Error: > Thread 7 (Thread 0xb33b6430 (LWP 485)):
              2019-08-05 06:07:22.385  Error: > #0  0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.385  Error: > #1  0x003f1f64 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
              2019-08-05 06:07:22.385  Error: > #2  0x003f3218 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
              2019-08-05 06:07:22.385  Error: > #3  0x00698a4c in http::server::server_base::run() ()
              2019-08-05 06:07:22.386  Error: > #4  0x0031a848 in http::server::CWebServer::Do_Work() ()
              2019-08-05 06:07:22.386  Error: > #5  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.386  Error: > #6  0xb6e8bfc4 in start_thread (arg=0xb33b6430) at pthread_create.c:458
              2019-08-05 06:07:22.386  Error: > #7  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.386  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.387  Error: >
              2019-08-05 06:07:22.387  Error: > Thread 6 (Thread 0xb3bb7430 (LWP 484)):
              2019-08-05 06:07:22.387  Error: > #0  0xb6ce5704 in epoll_wait () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.387  Error: > #1  0x003f1f64 in boost::asio::detail::epoll_reactor::run(long, boost::asio::detail::op_queue<boost::asio::detail::scheduler_operation>&) ()
              2019-08-05 06:07:22.387  Error: > #2  0x003f3218 in boost::asio::detail::scheduler::run(boost::system::error_code&) ()
              2019-08-05 06:07:22.388  Error: > #3  0x003f4180 in boost::asio::io_context::run() ()
              2019-08-05 06:07:22.388  Error: > #4  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.388  Error: > #5  0xb6e8bfc4 in start_thread (arg=0xb3bb7430) at pthread_create.c:458
              2019-08-05 06:07:22.388  Error: > #6  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.388  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.389  Error: > Thread 5 (Thread 0xb43b8430 (LWP 481)):
              2019-08-05 06:07:22.389  Error: > #0  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.389  Error: > #1  0x009ced5c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
              2019-08-05 06:07:22.389  Error: > #2  0x003c1574 in CInfluxPush::Do_Work() ()
              2019-08-05 06:07:22.390  Error: > #3  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.400  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xb43b8430) at pthread_create.c:458
              2019-08-05 06:07:22.400  Error: > #5  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.400  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.401  Error: >
              2019-08-05 06:07:22.401  Error: > Thread 4 (Thread 0xb4f60430 (LWP 461)):
              2019-08-05 06:07:22.401  Error: > #0  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.401  Error: > #1  0x009ced5c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
              2019-08-05 06:07:22.401  Error: > #2  0x0060f1c4 in Plugins::CPluginSystem::Do_Work() ()
              2019-08-05 06:07:22.402  Error: > #3  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.402  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xb4f60430) at pthread_create.c:458
              2019-08-05 06:07:22.402  Error: > Backtrace stopped: Cannot access memory at address 0x65732f5a
              2019-08-05 06:07:22.402  Error: > Thread 3 (Thread 0xb5761430 (LWP 460)):
              2019-08-05 06:07:22.403  Error: > #0  syscall () at ../sysdeps/unix/sysv/linux/arm/syscall.S:37
              2019-08-05 06:07:22.403  Error: > #1  0x009ced5c in std::__atomic_futex_unsigned_base::_M_futex_wait_until(unsigned int*, unsigned int, bool, std::chrono::duration<long long, std::ratio<1ll, 1ll> >, std::chrono::duration<long long, std::ratio<1ll, 1000000000ll> >) ()
              2019-08-05 06:07:22.403  Error: > #2  0x002f0c94 in CSQLHelper::Do_Work() ()
              2019-08-05 06:07:22.403  Error: > #3  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.403  Error: > #4  0xb6e8bfc4 in start_thread (arg=0xb5761430) at pthread_create.c:458
              2019-08-05 06:07:22.404  Error: > #5  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.404  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.404  Error: > Thread 2 (Thread 0xb5f62430 (LWP 457)):
              2019-08-05 06:07:22.404  Error: > #0  0xb6e9751c in __waitpid (pid=647, stat_loc=0xb5f61598, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29
              2019-08-05 06:07:22.405  Error: > #1  0x002d8840 in dumpstack_gdb(bool) ()
              2019-08-05 06:07:22.405  Error: > #2  0x002d8d64 in signal_handler(int, siginfo_t*, void*) ()
              2019-08-05 06:07:22.405  Error: > #3  <signal handler called>
              2019-08-05 06:07:22.405  Error: > #4  raise (sig=<optimized out>) at ../sysdeps/unix/sysv/linux/raise.c:51
              2019-08-05 06:07:22.405  Error: > #5  0x002d9028 in Do_Watchdog_Work() ()
              2019-08-05 06:07:22.406  Error: > #6  0x009f18fc in execute_native_thread_routine ()
              2019-08-05 06:07:22.406  Error: > #7  0xb6e8bfc4 in start_thread (arg=0xb5f62430) at pthread_create.c:458
              2019-08-05 06:07:22.406  Error: > #8  0xb6ce5038 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:76 from /lib/arm-linux-gnueabihf/libc.so.6
              2019-08-05 06:07:22.406  Error: > Backtrace stopped: previous frame identical to this frame (corrupt stack?)
              2019-08-05 06:07:22.406  Error: > Thread 1 (Thread 0xb6f72a60 (LWP 456)):
              2019-08-05 06:07:22.407  Error: > #0  0xb6e96d60 in nanosleep () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.407  Error: > #1  0x00278548 in sleep_seconds(long) ()
              2019-08-05 06:07:22.407  Error: > #2  0x001f6620 in main ()
              2019-08-05 06:07:22.407  Error: > Main thread:
              2019-08-05 06:07:22.408  Error: > #0  0xb6e96d60 in nanosleep () at ../sysdeps/unix/syscall-template.S:84
              2019-08-05 06:07:22.408  Error: > #1  0x00278548 in sleep_seconds(long) ()
              2019-08-05 06:07:22.408  Error: > #2  0x001f6620 in main ()
              2019-08-05 06:07:22.842  Status: Closing application!...
              2019-08-05 06:07:22.842  Status: Stopping worker...
              2019-08-05 06:07:22.843  Status: RxQueue: queue worker stopped...
              2019-08-05 06:07:23.328  MySensorsMQTT: Topic: domoticz/in/MyMQTT/18/1/1/0/17, Message: 2681
              2019-08-05 06:07:23.345  Status: WebServer(HTTP) stopped
              2019-08-05 06:07:23.349  Status: WebServer(SSL) stopped
              2019-08-05 06:07:23.361  Status: TCPServer: shared server stopped
              2019-08-05 06:07:23.361  Status: Stopping all hardware...
              2019-08-05 06:07:23.364  Status: MQTT: Worker stopped...
              2019-08-05 06:07:23.376  Status: Scheduler stopped...
              2019-08-05 06:07:23.378  Status: EventSystem: Stopped...
              2019-08-05 06:07:23.379  Status: EventSystem: Queue thread stopped...
              2019-08-05 06:07:23.526  Status: EventSystem - Python stopped...
              2019-08-05 06:07:23.541  Status: PluginSystem: Exiting work loop.
              2019-08-05 06:07:23.681  Status: PluginSystem: Stopped.
              2019-08-05 06:07:23.682  Status: Mainworker Stopped...
              • MasMatM
                MasMatM
                MasMat
                Check out the reply I got. Hope it helps you too.
                https://www.domoticz.com/forum/viewtopic.php?f=6&t=28925&p=220914#p220916
