  3. BH1750 Lux Sensor Problems
6 Posts 2 Posters 4.5k Views 2 Watching
  • T
    Toine33
    Hey Guys,
    I am trying for an while now but i cant make it work.
    The problem is that when i use this sketch i cant get usable data out of the BH1750
    #define MY_RS485
    #define MY_RS485_DE_PIN 2
    #define MY_RS485_BAUD_RATE 19200
    #define MY_RS485_HWSERIAL Serial
    #define MY_NODE_ID 5
    #include <BH1750.h>
    #include <Wire.h>
    #define CHILD_ID_LIGHT 25
    BH1750 lightSensor;
    // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%.
    // If your controller supports the new V_LEVEL variable, use this instead for
    // transmitting LUX light level.
    // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL);
    uint16_t lastlux;
      lightSensor.begin();
    void presentation()  {
      sendSketchInfo("Node 5", "1.0");
      uint16_t lux = lightSensor.readLightLevel();// Get Lux value
      Serial.println(lux);
      if (lux != lastlux) {
          send(msg.set(lux));
          lastlux = lux;
      wait(SLEEP_TIME);
    The output i am receiving is 65534 LUX and it never changes..
    The weird part is when i use this sketch without changing wiring i am receiving good changing data like 110 Lux etc etc
    #include <Wire.h>
    #include <BH1750.h>
    BH1750 lichtMeter;
    void setup(){
      Serial.begin(9600);
      lichtMeter.begin();
      uint16_t lux = lichtMeter.readLightLevel();
      Serial.print("Licht: ");
      Serial.print(lux);
      Serial.println(" lux");
      delay(500);
    #include <Wire.h>
    #include <BH1750.h>
    BH1750 lichtMeter;
    void setup(){
      Serial.begin(9600);
      lichtMeter.begin();
      Serial.print(lux);
      delay(500);
    Hardware:
    Arduino nano - Node - RS485
    Nca78N 1 Reply Last reply
    • T Toine33
      Hey Guys,
      #define MY_RS485
      #include <BH1750.h>
      #include <Wire.h>
      BH1750 lightSensor;
      uint16_t lastlux;
            send(msg.set(lux));
            lastlux = lux;
        wait(SLEEP_TIME);
      #include <Wire.h>
      #include <BH1750.h>
      BH1750 lichtMeter;
      void setup(){
        Serial.begin(9600);
        lichtMeter.begin();
        Serial.print(lux);
        delay(500);
      #include <Wire.h>
      #include <BH1750.h>
      BH1750 lichtMeter;
      void setup(){
        Serial.begin(9600);
        lichtMeter.begin();
        Serial.print(lux);
        delay(500);
      Hardware:
      Nca78N
      Nca78N
      @toine33 said in BH1750 Lux Sensor Problems:
      V_LIGHT_LEVEL
      Hello, do you get this with the serial print or in your controler from MySensors ?
      Because the light level in Lux should be with a V_LEVEL message and not V_LIGHT_LEVEL which expects a value from 0 to 100%. This could mess with the value reported on the controller side.
      • T
        Toine33
        @Nca78
        I have tried both and still no luck, the weird part is that it is working without the MySenors part.
        When i am adding Mysensors libary it stops working.
        The node can present itself succesfull on the gateway and also creates the child ID 25 (LUX Sensor).
        • Nca78N
          Nca78N
          I'm not familiar at all with RS485 but are your sure this is not messing up with the MY_DEBUG and the Serial.println() in the code ?
          T 1 Reply Last reply
          • Nca78N Nca78
            Toine33
            @nca78
            I Realy have no clue at the moment, i have tried almost everything for what i can think of.
            Also removed the serial print but still no luck.
            For the rest of the node's i never had issues.
            I have tried different sensors / Different arduino's but as soon when i am activating the mysensors part it stops responding.
            • T
              Toine33
              I guess i found it now,
              Looks like that V_LEVEL and V_LIGHT_LEVEL are both not behaving as expected,
              I have changed these now to V_TEXT after that the sensors was finaly working within domoticz.
              Also i had some cabeling issues, looks like the sensor doesnt like an cable length off 2 meter on 4x 0,44mm2 wire..
              Tommorow i am going to place the arduino closer to the weather station and i guess everything would be fine again then !
              Here my latest sketch:
              #define MY_RS485
              #include <BH1750.h>
              #include <Wire.h>
              unsigned long SLEEP_TIME = 25000; // Sleep time between reads (in milliseconds)
              BH1750 lightSensor;
              // MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
              MyMessage msg(CHILD_ID_LIGHT, V_TEXT);
              uint16_t lastlux;
                present(CHILD_ID_LIGHT, S_BINARY);
               // Serial.println(lux);
               // if (lux != lastlux) {
                    send(msg.set(lux));
                   // lastlux = lux;
                wait(SLEEP_TIME);
              @Nca78
              Thanks for your help !
