BH1750 Lux Sensor Problems
Hey Guys,
I am trying for an while now but i cant make it work.
The problem is that when i use this sketch i cant get usable data out of the BH1750#define MY_DEBUG #define MY_RS485 #define MY_RS485_DE_PIN 2 #define MY_RS485_BAUD_RATE 19200 #define MY_RS485_HWSERIAL Serial #define MY_NODE_ID 5 #include <SPI.h> #include <MySensors.h> #include <BH1750.h> #include <Wire.h> #define CHILD_ID_LIGHT 25 unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) BH1750 lightSensor; // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%. // If your controller supports the new V_LEVEL variable, use this instead for // transmitting LUX light level. MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL); // MyMessage msg(CHILD_ID_LIGHT, V_LEVEL); uint16_t lastlux; void setup() { lightSensor.begin(); } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo("Node 5", "1.0"); // Register all sensors to gateway (they will be created as child devices) present(CHILD_ID_LIGHT, S_LIGHT_LEVEL); } void loop() { uint16_t lux = lightSensor.readLightLevel();// Get Lux value Serial.println(lux); if (lux != lastlux) { send(msg.set(lux)); lastlux = lux; } wait(SLEEP_TIME); }The output i am receiving is 65534 LUX and it never changes..
The weird part is when i use this sketch without changing wiring i am receiving good changing data like 110 Lux etc etc
#include <Wire.h> #include <BH1750.h> BH1750 lichtMeter; void setup(){ Serial.begin(9600); lichtMeter.begin(); } void loop() { uint16_t lux = lichtMeter.readLightLevel(); Serial.print("Licht: "); Serial.print(lux); Serial.println(" lux"); delay(500); } #include <Wire.h> #include <BH1750.h> BH1750 lichtMeter; void setup(){ Serial.begin(9600); lichtMeter.begin(); } void loop() { uint16_t lux = lichtMeter.readLightLevel(); Serial.print("Licht: "); Serial.print(lux); Serial.println(" lux"); delay(500); }Hardware:
Arduino nano - Node - RS485 -
Hey Guys,
Arduino nano - Node - RS485@toine33 said in BH1750 Lux Sensor Problems:
V_LIGHT_LEVEL
Hello, do you get this with the serial print or in your controler from MySensors ?
Because the light level in Lux should be with a V_LEVEL message and not V_LIGHT_LEVEL which expects a value from 0 to 100%. This could mess with the value reported on the controller side.
I'm not familiar at all with RS485 but are your sure this is not messing up with the MY_DEBUG and the Serial.println() in the code ?
I Realy have no clue at the moment, i have tried almost everything for what i can think of.
Also removed the serial print but still no luck.
For the rest of the node's i never had issues.I have tried different sensors / Different arduino's but as soon when i am activating the mysensors part it stops responding.
I guess i found it now,
Looks like that V_LEVEL and V_LIGHT_LEVEL are both not behaving as expected,
I have changed these now to V_TEXT after that the sensors was finaly working within domoticz.Also i had some cabeling issues, looks like the sensor doesnt like an cable length off 2 meter on 4x 0,44mm2 wire..
Tommorow i am going to place the arduino closer to the weather station and i guess everything would be fine again then !Here my latest sketch:
#define MY_DEBUG #define MY_RS485 #define MY_RS485_DE_PIN 2 #define MY_RS485_BAUD_RATE 19200 #define MY_RS485_HWSERIAL Serial #define MY_NODE_ID 5 #include <MySensors.h> #include <BH1750.h> #include <Wire.h> #define CHILD_ID_LIGHT 25 unsigned long SLEEP_TIME = 25000; // Sleep time between reads (in milliseconds) BH1750 lightSensor; // V_LIGHT_LEVEL should only be used for uncalibrated light level 0-100%. // If your controller supports the new V_LEVEL variable, use this instead for // transmitting LUX light level. // MyMessage msg(CHILD_ID_LIGHT, V_LIGHT_LEVEL); MyMessage msg(CHILD_ID_LIGHT, V_TEXT); uint16_t lastlux; void setup() { lightSensor.begin(); } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo("Node 5", "1.0"); // Register all sensors to gateway (they will be created as child devices) present(CHILD_ID_LIGHT, S_BINARY); } void loop() { uint16_t lux = lightSensor.readLightLevel();// Get Lux value // Serial.println(lux); // if (lux != lastlux) { send(msg.set(lux)); // lastlux = lux; // } wait(SLEEP_TIME); }@Nca78
Thanks for your help !
