  3. Disable restarting arduino after connect to serial gateway.
7 Posts 3 Posters 878 Views 2 Watching
  • D Offline
    Dawidi
    Arduino is restarting after connect to controler (Serial Gateway - OpenHab). But this is not gateway issue. I think it is quite natural, because arduino had to run presentation, but I wondering is it possible to not restarting arduino? It is very important because i have to controll critical relays by it. And i wont turn it off after gateway restart by any reason.
    mfalkviddM Y 2 Replies Last reply
    • D Dawidi
      @dawidi do you mean that OpenHab sends a command to the Nodes to restart? Idon't have experience with OpenHab, but that sounds like a strange behavior. I use Domoticz and it does not send restart commands.
      D 1 Reply Last reply
      • D Dawidi
        Y Offline
        Y Offline
        @dawidi arduino hardware resets a board through the DTR signal on the serial port. You could disconnect the DTR line to prevent the reset.
          Dawidi
          @mfalkvidd I do not find any information sending by gateway to restart arduino. It looks like that:
          [log] system start
          [log] some relays state changed from null to ON (restored states)
          [log] some relays state changed from null to OFF
          [log] MySensors bridge is changed from OFFLINE (COMMUNICATION_ERROR)  to OFFLINE
          [log] MySensors bridge is changed from OFFLINE to ONLINE (finnaly)
          [log] all relays changed from OFFLINE to ONLINE
          And then arduino restarting. So if i restart OH, arduino keep states until it connect again.
          @Yveaux How can i do that?
          Y 1 Reply Last reply
          • D Dawidi
            [log] system start
            Y Offline
            Y Offline
            @dawidi to bypass it depends a lot on the actual Arduino hardware used. See here for some background info on the topic: https://rheingoldheavy.com/arduino-from-scratch-part-11-atmega328p-dtr-and-reset/
            The link describes for an Arduino Uno: "If for some reason, you wanted to disable the autoreset function, you would run a very sharp knife down between the two halves of the solder jumper at “RESET EN”, to cut the trace. "
            From software you can prevent auto reset by disabling DTR when talking to the serial port; google for it: https://www.google.com/search?q=prevent+dtr+reset+from+software
            • Y Yveaux
              Dawidi
              @yveaux Thank you man so much. I wrote topics on gateway's github, here in cotroller section, OH forum and no one knows how to fix that. I cut jumper on RESET EN and it works. TY!
              • D Dawidi
                Y Offline
                Y Offline
                @dawidi great to hear you solved it! Glad I could help.
