  3. Node to Node Communication
36 Posts 6 Posters 24.5k Views 5 Watching
    Make sure to send the same type as you're trying to getXXX on the receiving side. No automatic conversion is done except for the getString().
    https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyMessage.cpp#L62
    C 1 Reply Last reply
      C
      C
      cleight
      wrote on last edited by cleight
      #22
      @hek This is the code I am using on the sensor side to send to LCD Node (Node 11)
      gw.send(msgHTTemp.setDestination(11).setSensor(i).set(temperature,1));
      And in serial monitor on node 11 I see the data being captured correctly, so I believe my issue still lies in my code on the LCD Screen side.
      read: 1-0-11 s=0,c=1,t=0,pt=7,l=5:66.2
      Here is my latest Sketch after I made changes again per Hek's suggestion, only thing is I couldn't use float as I am out of room in my sketch to hard to use INT instead for testTemp
      #define STATES 9
      #define HUMIDITY_SENSOR_DIGITAL_PIN 4
      #define DEBUG
      #ifdef DEBUG
      #define DEBUG_SERIAL(x) Serial.begin(x)
      #define DEBUG_PRINT(x) Serial.print(x)
      #else
      #include <avr/pgmspace.h>
      #include <Wire.h>
      #include <Time.h>
      #include <DS3232RTC.h>
      #define RADIO_ID 11
      #define CHILD_ID_SCENE 3
      #define CHILD_ID_LED 4
      #define BACKLIGHT 6 //available PWM capable pin
      //Define Additional Nodes that I would like to pull data from
      #define HOTTUB_NODE_ID 1
      LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // set the LCD address to 0x27 for a 16 chars and 2 line display
      void (*lcdDisplay[STATES])();
      byte state = 0;
      byte lastState;
      byte timeCounter = 0;
      int ledStatus = 1;// to toggle LCD backlight led
      int ledLevel = 254;
      unsigned long lastTime;
      unsigned long refreshInterval = 3000UL;
      unsigned long lastClockSet;
      boolean isMessage = false;
      float insideTemperature;
      float humidity;
      int OutdoorTemp = -99;
      int OutdoorHumidity = -99;
      int todayHigh = -99;
      int todayLow = -99;
      int HotTubTemp = -99;
      int KWH = -99;
      int testTemp = -99;
      String conditions = "Not yet Reported";
      String tomorrowWeather = "Not yet Reported";
      String messageOfTheDay = "**Hello There!**";
      String AlarmStatus = "No Data";
      unsigned long motdTimer;
      boolean buttonPushed = false;
      MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
      MyMessage msgOff(CHILD_ID_SCENE, V_SCENE_OFF);
      MyMessage msgVAR1(CHILD_ID_SCENE, V_VAR1);// outdoor temperature
      MyMessage msgVAR2(CHILD_ID_SCENE, V_VAR2);// outdoor humidity
      MyMessage msgVAR3(CHILD_ID_SCENE, V_VAR3);//today's low
      MyMessage msgVAR4(CHILD_ID_SCENE, V_VAR4);// today's high
      MyMessage msgVAR5(CHILD_ID_SCENE, V_VAR5);//conditions
      MyMessage lightMsg(CHILD_ID_LED, V_DIMMER);
      MyMessage msgMOTD(CHILD_ID_LED, V_VAR1); // Hot Tub KWH
      MyMessage msgAlarm(CHILD_ID_LED, V_VAR2); // Tomorrow Forecast
      MyMessage msgBrite(CHILD_ID_LED, V_VAR3);
      MyMessage msgHTTemp(CHILD_ID_LED, V_VAR4); // Hot Tub Temp
      MyMessage msgALARMSTATUS (CHILD_ID_LED, V_VAR5);// Alarm System Status
        DEBUG_SERIAL(115200);
        DEBUG_PRINTLN(F("Serial started"));
        lcdDisplay[0] = lcdDisplay0;
        lcdDisplay[1] = lcdDisplay1;
        lcdDisplay[2] = lcdDisplay2;
        lcdDisplay[3] = lcdDisplay3;
        lcdDisplay[4] = lcdDisplay4;
        lcdDisplay[5] = lcdDisplay5;
        lcdDisplay[6] = lcdDisplay6;
        lcdDisplay[7] = lcdDisplay7;
        lcdDisplay[8] = lcdDisplay8;
        pinMode(BACKLIGHT, OUTPUT);
        gw.begin(getVariables, RADIO_ID);
        //gw.begin(NULL, AUTO, true);
        gw.sendSketchInfo("Home Status Panel", "2.1");
        setSyncProvider (RTC.get);
        gw.present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
        gw.present( CHILD_ID_LED, S_DIMMER);
        analogWrite(BACKLIGHT, 200); //LCD Backlight
        lcd.begin(20,4);
        lcd.clear();
        lcd.backlight();
        lcd.setCursor(0, 0);
        lcd.print("Syncing Time");
        lcd.setCursor(0, 1);
        int clockCounter = 0;
        while(timeStatus() == timeNotSet && clockCounter < 60)
          gw.process();
          gw.requestTime(receiveTime);
          Serial.println("getting Time");
          delay(1000);
          lcd.print(".");
          clockCounter++;
          if (clockCounter > 16)
            lcd.clear();
            lcd.print(F("**Failed Clock**"));
            lcd.setCursor(0,1);
            lcd.print(F("*Syncronization*"));
            delay(2000);
            break;
        lcd.clear();
        lastTime = millis();
        gw.process();
        if (millis() - lastClockSet >= 60000UL)
          lastClockSet = millis();
        if (millis() - lastTime >= refreshInterval)
          state++;
          if (state > STATES - 1) state = 0;
          DEBUG_PRINTLN(F("State:"));
          DEBUG_PRINTLN(state);
          lastTime += refreshInterval;
          getTempHumidity();
        if (state != lastState)
          fastClear();
          lcdDisplay[state]();
        lastState = state;
        if (isMessage)
          if (millis() - motdTimer > 86400 * 1000UL)
            isMessage = false;
      void fastClear() //Clear LCD Screen
        lcd.setCursor(0,0);
        lcd.clear();
        lcd.setCursor(0,1);
        lcd.clear();
        lcd.setCursor(0,2);
        lcd.clear();
        lcd.setCursor(0,3);
        lcd.clear();
      void lcdDisplay0()
        lcd.setCursor(0,0);
        lcd.print(F("Time: "));
        if (hourFormat12() < 10) lcd.print("0");
        lcd.print(hourFormat12());
        lcd.print(":");
        if (minute() < 10) lcd.print("0");
        lcd.print(minute());
        if (isAM()) lcd.print(F("am"));
        else lcd.print(F("pm"));
        DEBUG_PRINT(F("Time:"));
        DEBUG_PRINTLN(hourFormat12());
        lcd.setCursor(0,1);
        lcd.print(F("Date: "));
        if (month() < 10) lcd.print("0");
        lcd.print(month());
        lcd.print("/");
        if (day() < 10) lcd.print("0");
        lcd.print(day());
        lcd.print("/");
        lcd.print(year());
        DEBUG_PRINTLN(F("Date: "));
        DEBUG_PRINT(month());
        DEBUG_PRINT("/");
        DEBUG_PRINT(day());
        DEBUG_PRINT("/");
        DEBUG_PRINTLN(year());
      void lcdDisplay1()
        lcd.setCursor(0,0);
        lcd.print(F(" Indoor Temp:"));
        lcd.print(int(round(insideTemperature)));
        lcd.print(char(223));
        DEBUG_PRINT(F("Indoor Temp:"));
        DEBUG_PRINT(int(round(insideTemperature)));
        DEBUG_PRINTLN(F("F"));
      void lcdDisplay2()
        lcd.setCursor(0,0);
        lcd.print("Outdoor Temp:");
        lcd.print(OutdoorTemp);
        DEBUG_PRINT(F("Outdoor Temp:"));
        DEBUG_PRINTLN(OutdoorTemp);
        lcd.setCursor(0,1);
        lcd.print(F("    Humidity:"));
        lcd.print(OutdoorHumidity);
        lcd.print(F("%"));
        DEBUG_PRINT(F("    Humidity:"));
        DEBUG_PRINTLN(OutdoorHumidity);
      void lcdDisplay3()
        lcd.setCursor(0,0);
        lcd.print(F("Today's High:"));
        lcd.print(todayHigh);
        DEBUG_PRINT(F("Today's High: "));
        DEBUG_PRINTLN(todayHigh);
        lcd.setCursor(0,1);
        lcd.print(F("         Low:"));
        lcd.print(todayLow);
        DEBUG_PRINT(F("Today's Low: "));
        DEBUG_PRINTLN(todayLow);
      void lcdDisplay4()
        lcd.setCursor(0,0);
        lcd.print(F("Today's Weather"));
        DEBUG_PRINTLN(F("Today's Weather: "));
        lcd.setCursor(0,1);
        lcd.print(conditions);
        DEBUG_PRINTLN(conditions);
      void lcdDisplay5()
        lcd.setCursor(0,0);
        lcd.print(F("Forcast Tomorrow"));
        DEBUG_PRINTLN(F("Tomorrow's Forecast: "));
        lcd.setCursor(0,1);
        lcd.print(tomorrowWeather);
        DEBUG_PRINTLN(tomorrowWeather);
      void lcdDisplay6()
        if (isMessage)
          lcd.setCursor(0,0);
          lcd.print(F("**NEW  MESSAGE**"));
          DEBUG_PRINTLN(F("****Message****"));
          lcd.setCursor(0,1);
          lcd.print(messageOfTheDay);
          DEBUG_PRINTLN(messageOfTheDay);
          motdTimer = millis();
        else
          lcd.setCursor(0,0);
          lcd.print(F("****Welcome!****"));
          lcd.setCursor(0,1);
          lcd.print(F("Have a Nice Day!"));
          DEBUG_PRINTLN(F("Have a Nice Day"));
      void lcdDisplay7()
        lcd.setCursor(0,1);
        lcd.print("Alarm Status:");
        DEBUG_PRINT("Alarm Status:");
        DEBUG_PRINTLN(AlarmStatus);
        lcd.setCursor(0,2);
        lcd.print(AlarmStatus);
      void lcdDisplay8()
        lcd.setCursor(0,0);
        lcd.print("Hot Tub KWH:");
        lcd.print(KWH);
        DEBUG_PRINT("Hot Tub KWH:");
        DEBUG_PRINTLN(KWH);
        lcd.setCursor(0,1);
        lcd.print(F(" Hot Tub:"));
        lcd.print(HotTubTemp);
        DEBUG_PRINT(F("Hot Tub:"));
        DEBUG_PRINT(HotTubTemp);
        DEBUG_PRINT(F("F"));
        lcd.setCursor(3,0);
        lcd.print("Test Temp:");
        lcd.print(testTemp);
        DEBUG_PRINT(F("Test Temp:"));
        DEBUG_PRINTLN(testTemp);
      void getTempHumidity()
        insideTemperature = ((RTC.temperature()/4*9/5 + 32));
        if (isnan(insideTemperature))
          DEBUG_PRINTLN(F("Failed reading temperature from RTC"));
      void receiveTime(unsigned long controllerTime)
        // Ok, set imcoming time
        DEBUG_PRINTLN(F("Time value received: "));
        DEBUG_PRINTLN(controllerTime);
        RTC.set(controllerTime);
        controllerTime = true;
      void getVariables(const MyMessage &message)
        if (message.sensor == CHILD_ID_SCENE)
          if (message.type == V_VAR1) //Outdoor temp pulled from Weather Underground Vera Plugin
            OutdoorTemp = atoi(message.data);
            DEBUG_PRINTLN(F("OutdoorTemp recieved:"));
          if (message.type == V_VAR2) //Outdoor Humidity pulled from Weather Underground Vera Plugin
            OutdoorHumidity = atoi(message.data);
            DEBUG_PRINT(F("OutdoorHumidity recieved:"));
          if (message.type == V_VAR3) //pulled from Weather Underground Vera Plugin
            todayLow = atoi(message.data);
            DEBUG_PRINT(F("Received Today's LOW:"));
          if (message.type == V_VAR4) //pulled from Weather Underground Vera Plugin
            todayHigh = atoi(message.data);
            DEBUG_PRINT(F("Received Today's HIGH:"));
          if (message.type == V_VAR5) //pulled from Weather Underground Vera Plugin
            String newMessage = String(message.data);
            int locator = newMessage.indexOf("@");
            newMessage = newMessage.substring(0, locator);
            conditions = newMessage;
            DEBUG_PRINT(F("Received today's Conditions:"));
          if (message.sensor == CHILD_ID_LED)
          if (message.type == V_DIMMER) //Set LCD Brightness from Dimmer Device in Vera
            ledLevel = message.getByte();
            		lcd.setBacklight(ledLevel);
      		Serial.print("Brightness Level recieved:");
      		Serial.println(ledLevel);
                      analogWrite(BACKLIGHT, (int)(ledLevel / 100. * 255) );
          if (message.type == V_VAR1) //Hot Tub KWN Hours
            KWH = atoi(message.data);
            DEBUG_PRINT("Hot Tub KWH recieved:");
            DEBUG_PRINTLN(KWH);
          if (message.type == V_VAR2) //pulled from Weather Underground Vera Plugin
            // Extended Forecast
            tomorrowWeather = newMessage;
            DEBUG_PRINT(F("Received Two Day Forecast:"));
          if (message.type == V_VAR3) //Not sure what this will be used for just yet
            // message of the day
            messageOfTheDay = newMessage;
            DEBUG_PRINT(F("Received Message of the Day:"));
            isMessage = true;
          if (message.type == V_VAR4) //Hot Tub Temp from Vera which comes from an Arduino
            HotTubTemp = atoi(message.data);
            DEBUG_PRINT(F("Received HotTubTemp:"));
            DEBUG_PRINTLN(HotTubTemp);
          if (message.type == V_VAR5) //Check on Alarm status
            AlarmStatus = newMessage;
            DEBUG_PRINT(F("Received Alarm Status:"));
         switch (message.sender) {
              case HOTTUB_NODE_ID:
                   testTemp = atoi(message.data);
                   break;
      Node ID 1 - Temperature Sensor that is sending to Node 11 (LCD Screen)
      #include <DHT.h>
      #include <OneWire.h>
      #define CHILD_ID_HUM 1
      #define CHILD_ID_TEMP 2
      #define CHILD_ID_HTTEMP 3
      //Waterproof Sensor addition
      #define ONE_WIRE_BUS 4 //Pin where waterproof temp sensor is connected
      OneWire oneWire(ONE_WIRE_BUS);
      DHT dht;
      int numSensors=0;
      float lastTemp;
      float lastHum;
      boolean metric = false;
      MyMessage msgHTTemp(CHILD_ID_HTTEMP, V_TEMP);
        // Startup OneWire
        sensors.begin();
        gw.begin();
        gw.sendSketchInfo("Hot Tub Monitor", "2.0");
          gw.present(i, S_TEMP);
        gw.process();
        //Fetch temperatures from Dallas sensors
        // Red temperatures and send them to the controller
          float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
          //Only send data if temperature has changed and no error
          if (lastTemperature[i] != temperature && temperature != -127.00) {
            delay(100);
            gw.send(msgHTTemp.setSensor(i).set(temperature,1));
            Serial.print("T2: ");
            Serial.println(temperature);
        //float temperature = dht.getTemperature();
        float temperature = dht.getTemperature()*9/5 + 32;
        if (isnan(temperature)) {
        else if (temperature != lastTemp) {
          lastTemp = temperature;
          if (!metric) {
            //temperature = dht.toFahrenheit(temperature);
          delay(100);
          Serial.print("T: ");
        if (isnan(humidity)) {
        else if (humidity != lastHum) {
          lastHum = humidity;
          delay(100);
          Serial.print("H: ");
          Serial.println(humidity);
        gw.sleep(SLEEP_TIME); //sleep a bit
        wrote on last edited by hek
        #23
        Forget.. looked at the wrong sketch.
          C
          C
          cleight
          #24
          @hek said:
          @cleight said:
          gw.begin();
          You forgot to initialize begin like you were told above.
          I have this in my gateway.begin
          I seem to need to have it this way or Vera doesn't get Node ID 11 anymore and it gets a random generated ID. So then I put the Case statement at the bottom of my getVariables Function.
            If you send it as a float value you must use getFloat (it is transmitted as binary data). Doing atoi will get you garbled data because it is not transmitted as ascii.
            If your memory is low, I suggest you either convert and send is as a string (char *) and do message.getString()
            or
            send it as a int and just do message.getInt() on the receiving side.
            BTW the "String" class you're using is VERY memory hungry and is probably the reason for low memory an after a while probably result in crashes (it fragments memory).
              or
              C
              C
              cleight
              @hek How do I send it as an integer?
                declare the variable you're sending as int or convert it by casting
                gw.send (msgHum.set(static_cast<int>(humidity)));
                http://www.learncpp.com/cpp-tutorial/44-type-conversion-and-casting/
                  C
                  C
                  cleight
                  @hek Converting my sensor to send the data as an Integer worked and it is now parsing correctly, however I also have a humidity child sensor on that node I would like to send to node 11 as well, how would I capture that in the case statement?
                  ChaoticC 1 Reply Last reply
                    #29
                    @cleight
                    just switch on message.sensor (should be one of CHILD_ID_HUM, CHILD_ID_TEMP)
                    • C cleight
                      ChaoticC
                      ChaoticC
                      Chaotic
                      @cleight I posted code to do just that
                      #define BEDROOM_NODE_ID 42
                      #define KITCHEN_NODE_ID 44
                      #define TEMP 0
                      #define HUM 1
                      float bdtemp = 0, bdhum =0, kntemp = 0, knhum =0;
                              case BEDROOM_NODE_ID:
                                   switch (message.sensor){
                                         case TEMP
                                               bdtemp = message.getFloat();
                                        break;
                                        case HUM
                                               bdhum = message.getFloat();
                                        break;
                                break;
                           case KITCHEN_NODE_ID:
                                        case TEMP
                                               kntemp = message.getFloat();
                                        break;
                                        case HUM
                                               knhum = message.getFloat();
                                        break;
                               break;
                       updateDisplay();
                      • ChaoticC Chaotic
                        #define TEMP 0
                        #define HUM 1
                                           case TEMP
                                          break;
                                          case HUM
                                          break;
                                  break;
                                          case TEMP
                                          break;
                                          case HUM
                                          break;
                                 break;
                         updateDisplay();
                        C
                        C
                        cleight
                        @Chaotic I missed your code earlier, thank you for this, although while compiling is it saying I am missing a colon before knhum for some reason, need to dig deeper.
                        • C cleight
                          ChaoticC
                          ChaoticC
                          Chaotic
                          @cleight that is what I get for coding on the fly
                          change
                          case TEMP
                          and
                          case HUM
                          with
                          case TEMP:
                          and
                          case HUM:
                          • ChaoticC Chaotic
                            change
                            case TEMP
                            and
                            case HUM
                            with
                            case TEMP:
                            and
                            case HUM:
                            C
                            C
                            cleight
                            @Chaotic Thank you, I knew it had to be something simple.
                            • C
                              C
                              cleight
                              Ok last issue to be worked out and I think I am good to go, thanks again to @Chaotic and @hek for there assistance with my project.
                              Last issue is with the sensor node, it sends the data to the LCD Node (node 11) but only sends the data to the gateway on boot, it will not send it to the gateway after it starts sending to Node 11. I would like it to send to both the Node and the Gateway all the time, that way Vera see the information as well as my LCD.
                              Here is the output of the Serial Monitor, also for some reason on each temp update it sends to node 11 twice for some reason:
                              sensor started, id 1
                              send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                              send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                              read: 0-0-1 s=255,c=3,t=6,pt=0,l=1:I
                              send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=15,st=ok:Hot Tub Monitor
                              send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:2.0
                              send: 1-1-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                              send: 1-1-0-0 s=1,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                              send: 1-1-0-0 s=2,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                              send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:67.2
                              send: 1-1-0-11 s=0,c=1,t=0,pt=2,l=2,st=ok:67
                              T2: 67.20
                              send: 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,st=ok:66.2
                              T: 66.20
                              send: 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,st=ok:36.0
                              send: 1-1-0-11 s=1,c=1,t=1,pt=2,l=2,st=ok:36
                              H: 36.00
                              send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:75.7
                              send: 1-1-0-11 s=0,c=1,t=0,pt=2,l=2,st=ok:75
                              T2: 75.70
                              send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:80.1
                              send: 1-1-0-11 s=0,c=1,t=0,pt=2,l=2,st=ok:80
                              T2: 80.10
                              send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:81.6
                              send: 1-1-0-11 s=0,c=1,t=0,pt=2,l=2,st=ok:81
                              T2: 81.60
                              send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:81.7
                              T2: 81.70
                              send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:79.8
                              send: 1-1-0-11 s=0,c=1,t=0,pt=2,l=2,st=ok:79
                              T2: 79.80
                              send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:78.1
                              send: 1-1-0-11 s=0,c=1,t=0,pt=2,l=2,st=ok:78
                              T2: 78.10
                              send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:76.7
                              send: 1-1-0-11 s=0,c=1,t=0,pt=2,l=2,st=ok:76
                              T2: 76.70
                              send: 1-1-0-11 s=0,c=1,t=0,pt=7,l=5,st=ok:75.5
                              T2: 75.50
                              Here is the sketch:
                              #include <DHT.h>
                              DHT dht;
                              int numSensors=0;
                              float lastTemp;
                              float lastHum;
                                // Startup OneWire
                                sensors.begin();
                                gw.begin();
                                gw.process();
                                    delay(100);
                                    gw.send(msgHTTemp.setDestination(11).set(static_cast<int>(temperature)));
                                  if (!metric) {
                                  delay(100);
                                  lastHum = humidity;
                                  delay(100);
                                  gw.send(msgHum.setDestination(11).set(static_cast<int>(humidity)));
                              • C cleight
                                T2: 67.20
                                T: 66.20
                                H: 36.00
                                T2: 75.70
                                T2: 80.10
                                T2: 81.60
                                T2: 81.70
                                T2: 79.80
                                T2: 78.10
                                T2: 76.70
                                T2: 75.50
                                Here is the sketch:
                                #include <DHT.h>
                                DHT dht;
                                int numSensors=0;
                                float lastTemp;
                                float lastHum;
                                  // Startup OneWire
                                  sensors.begin();
                                  gw.begin();
                                  gw.process();
                                      delay(100);
                                    if (!metric) {
                                    delay(100);
                                    lastHum = humidity;
                                    delay(100);
                                ChaoticC
                                ChaoticC
                                Chaotic
                                @cleight I think the easiest solution (all theory btw) would be to duplicate the message for each sensor
                                MyMessage msgHumLCD(CHILD_ID_HUM, V_HUM);
                                MyMessage msgTempLCD(CHILD_ID_TEMP, V_TEMP);
                                MyMessage msgHTTempLCD(CHILD_ID_HTTEMP, V_TEMP);
                                then in the setup()
                                msgHumLCD.setDestination(11);
                                msgTempLCD.setDestination(11);
                                msgHTTPempLCD.setDestination(11);
                                Then in the loop when you are doing the gw.send just do a second one for the LCD message (you shouldn't need the setDestination)
                                • ChaoticC Chaotic
                                  then in the setup()
                                  C
                                  C
                                  cleight
                                  @Chaotic Sorry for not getting back sooner on this, but I did confirm that your solution does indeed work and works very well. I can't wait to finish this project up and be able to post the Pictures/Sketch to share with the community.
