  3. arduino serial monitor gateway problem
5 Posts 2 Posters 683 Views 1 Watching
  • K
    K
    kajoo
    Hello, I have a problem, I tried to connect raspberry pi with arduino in the domoticz application, I put the project on the arduino which would send information about the motion sensor, when I try to connect the arduino with domoticz after the USB gateway mysensor error pops up "
    Error: Serial Port closed ", does anyone know a solution to the problem? Please help
    • K kajoo
      @kajoo - if you are having issues on your raspberry it most likley that domoticz is not running as root or atleast have the access to the USB. Same issue occurs when you try to open a serial port with Arduino IDE in linux not run with the right access.
      K 1 Reply Last reply
      • sundberg84S sundberg84
        K
        K
        kajoo
        @sundberg84
        ie the solution is to open the serial port on the Raspberry Pi side yes?
        • K kajoo
          @sundberg84
          @kajoo - i think the resolution is to set the right permissions to the user running Domoticz.
            K
            K
            kajoo
            @sundberg84
            2020-02-27 00:33:15.512 Status: MySensors: Worker started...
            2020-02-27 00:33:16.513 Status: MySensors: Using serial port: /dev/ttyUSB0
            Does this mean that I was able to connect? However, I still have no reaction in the "devices" tab, and the status in the hardware "setup"
