  3. Serial Gateway not connecting - ttyUSB0 in use
30 Posts 5 Posters 3.7k Views 5 Watching
  • C CraigDubya
    I've also tried adding the user pi to the dialout and tty groups, but still I can't select any port in the arduino ide when mysgw.service and openhab2.service are stopped. It's as if the mysgw.service is creating the ttyUSB0 port (virtually?) :confused:
    C
    C
    CraigDubya
    I did a ls /dev/tty* and ttyUSB0 had disappeared...so I unplugged the gateway and plugged it back in again (all while mysgw.service is stopped) then another ls /dev/tty* and ttyUSB0 was back. I started the arduino ide and selected ttyUSB0 and in the serial monitor I now have:
    0;255;3;0;9;0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    0;255;3;0;9;5 TSM:INIT
    0;255;3;0;9;7 TSF:WUR:MS=0
    0;255;3;0;9;15 TSM:INIT:TSP OK
    0;255;3;0;9;18 TSM:INIT:GW MODE
    0;255;3;0;9;21 TSM:READY:ID=0,PAR=0,DIS=0
    0;255;3;0;9;24 MCO:REG:NOT NEEDED
    0;255;0;0;18;2.3.2
    0;255;3;0;9;28 MCO:BGN:STP
    0;255;3;0;9;35 MCO:BGN:INIT OK,TSP=1
    0;255;3;0;9;38 TSM:READY:NWD REQ
    0;255;3;0;9;45 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    C 1 Reply Last reply
    • C CraigDubya
      0;255;0;0;18;2.3.2
      C
      C
      CraigDubya
      When I restart the mysgw.service and do a ls /dev/tty* the ttyUSB0 is shown in blue as opposed to yellow as seen below.
      • C CraigDubya
        #23
        @CraigDubya mysgw.service is partly a software gateway. From earlier posts, it seems you also have a hardware gateway (based on an Arduino Nano). Is that correct?
        If so, the two gateways might conflict. Is your intention to run two gateways?
          C
          C
          CraigDubya
          @mfalkvidd Hi,
          No, my intention is not to run 2 gateways, I did a make on the mysgw.service and changed the port to ttyUSB020 in the config and restarted openhab. I now have communication with the hardware gateway. It seems it's all working properly now, but I'm a bit concerned that I may still have a software gateway running aswell.
          • C CraigDubya
            @mfalkvidd Hi,
            C
            C
            CraigDubya
            I just rebooted my pi, and whatever I did to get the bridge working has reset, and I'm not getting any node connections anymore :confused:
            • C CraigDubya
              C
              C
              CraigDubya
              If I stop the mysgw.service and restart openhab2.service the gateway works fine. So, the mysgw.service is starting on bootup, how do I remove or disable mysgw.service from bootup?
              • C CraigDubya
                C
                C
                CraigDubya
                @mfalkvidd Sorry, in answer to your earlier question, that's correct... I have an Arduino Nano connected via USB to the raspberry pi as a hardware serial gateway
                • C CraigDubya
                  C
                  C
                  CraigDubya
                  Ah I found it using:
                  sudo systemctl disable mysgw.service
                  Now when I reboot the pi the gateway is working and my sensor node is reporting correctly.
                  Thanks for everyones help, it's been 2 years since I last played with openhab and mysensors, and what I learned back then I had mostly forgotten. Also with the openhab and mysensors updates that have happened in that time it's been a struggle to get back on track :grin:
                  • C CraigDubya
                    Great work @CraigDuby, thanks for reporting back.
                    • C
                      C
                      CraigDubya
                      And so here is my serial gateway with 3d printed case:
