  3. Sensor shield for Arduino Pro Mini 3.3V with boost up regulator
39 Posts 11 Posters 31.0k Views 6 Watching
  • P Offline
    P Offline
    phil83
    @Zeph I wanted to use the internal reference as described here: http://www.mysensors.org/build/battery
    What do you think?
    Z 1 Reply Last reply
    • B Offline
      B Offline
      bjornhallberg
      Another nitpick ... there are a lot of different Pro Mini pin layouts (http://arduino-board.com/boards/arduino-pro-mini). I don't know where you buy yours and if you can be sure of a certain pin layout, but I would probably not bet on anything other than the side rows that are present on all boards. A4 and A5 are fairly certain, but other than that ....
      • P Offline
        P Offline
        phil83
        @bjornhallberg completely right - I have some here from Aliexpress and have a good and fast seller... but I asked for exactly that design before ordering...
        • P Offline
          P Offline
          phil83
          @maha I'm going to check again this weekend and then I'm going to send it to China for manufacturing, thanks for all your help!
          • P phil83
            What do you think?
            Z Offline
            Z Offline
            Zeph
            The voltage divider in that circuit diagram is for measuring an input voltage (into the regulator) higher than Vcc (out of the regulator). Bad idea without a voltage divider. Since you are instead using an up-converter and Vin < Vcc, I think you can do without the voltage divider resistors.
            As an example, suppose you used one cell at 1.5v draining to 1.ov. With a Vcc of 3.3v a direct reading would give ADC readings of 465 falling to 310. Using that voltage divider would yield 149 falling to 99. (all out of 0 to 1023). You just lose resolution by inserting the divider. (WIth two cells double these numbers).
            The caveat is that I'm uncertain about is startup transients - with Vin applied to the pin before Vcc stabilizes. Not sure if that's a real problem or not, tho - maybe somebody else would have thoughts.
            M 1 Reply Last reply
            • Z Zeph
              M Offline
              M Offline
              m26872
              @Zeph
              I think you're wrong. The divider works perfectly when measuring against internal reference like shown at the build-site. I think it's very well proven and I have never had any issues. And this is for battery voltage LOWER than Vcc.
              I think I had a link to one of my code example here as well.
              But sure, if you have a stable and known Vcc you could use that as reference instead. Without divider.
              @phil83
              Why don't you use the recommended 0.1uF capacitor in parallel with R2 ?
              • P Offline
                P Offline
                phil83
                @m26872 Thanks for reminding me of the capacitor, I added it!
                • M m26872
                  @Zeph
                  @phil83
                  Z Offline
                  Z Offline
                  Zeph
                  @m26872 As I said in the first post, if you measure against the internal 1.1v reference (rather than the more common Vcc), it can work. And I see that's in fact what you are doing, so no problem, carry on.
                  • P Offline
                    P Offline
                    phil83
                    wrote on last edited by phil83
                    #29
                    Hey folks,
                    I just received my first boards today. They really look nice, I never believed that it is so easy! Especially the manufacture in china was pretty cheap and looks really good. I had to wait four weeks, nearly perfect!
                    Now I'm waiting for two more capacitors, all the other parts were delivered already. I hope to be able to solder next week and will keep you updated afterwards!
                    I think I got infected by a virus by now since I'm already planning the next board ;-).
                    Thanks again for all your help,
                    Philipp
                    • M Offline
                      M Offline
                      Mickey
                      Very nice board.
                      Do you intend to share gerber files/eagle file?
                      • P Offline
                        P Offline
                        phil83
                        I'm going to check the board in the next few weeks, when everything is fine, I will share...
                        • P Offline
                          P Offline
                          phil83
                          This post is deleted!
                          • P Offline
                            P Offline
                            phil83
                            #33
                            • G Offline
                              G Offline
                              gloob
                              I would be interessted in the wiring diagram, as I want to build something similar but with no SMD parts.
                              Would you share your actual diagram please?
                              Thanks,
                              Stefan
                              • P Offline
                                P Offline
                                phil83
                                Hi everyone,
                                I received the last parts on monday and populated 2 boards so far. I found out, that one header for nrf24 is not working properly... most likely since the wires are too far away from the capacitor. The other header is working perfect. Here are the first pictures of the populated board:
                                Though the hand soldering of the sot23-6 was not easy at all, I managed to do it. I tested the boards with the BatteryPoweredSensor and the voltage divider is working properly. I will now start to program more and see which sensor I can build with that board.
                                Philipp
                                • P Offline
                                  P Offline
                                  phil83
                                  @gloob : The scheme shown above is still the same, I only added a capacitor in parallel to the voltage divider!
                                  • M Offline
                                    M Offline
                                    Mickey
                                    turn out very nice.
                                    are you planing to share eagle files?
                                    • B Offline
                                      B Offline
                                      bjornhallberg
                                      Great work! Really impressive!
                                      • P Offline
                                        P Offline
                                        phil83
                                        Long time no see... I had time to work on my sensors lately and here are some pictures of my humidity sensor which is running here for three months now:
                                        I left out the power regulator shown above and also desoldered the LED and voltage regulator of the Arduino to safe power. The sensor is directly powered by 3.7V of the lithium battery. The voltage is measured and the battery will be recharged when it goes down.
                                        Since I also built a 3D printer lately, I was able to put the sensor into a little box. Now I can easily measure humidity and temperature in my bath room and see it in fhem on a raspberry.
                                        Currently I'm working on my next pcb... I will show the next one when I'm finished in a new thread.
                                        12.2k
