  3. Home Assistant
  4. Two MySensor gateways to the same Home Assistant
2 Posts 2 Posters 406 Views 2 Watching
  • J Offline
    J Offline
    jocke4u
    HI,
    As discussed here: https://forum.mysensors.org/topic/11181/parallel-gateways/8 I am planning to upgrade the MySensors GW from Arduino to Raspberry Pi and running them in parallel.
    I suppose it is possible to have several gateways configured in HA like:
    mysensors:
      gateways:
        - device: '192.168.1.11'
          persistence_file: './mysensors.json'
          tcp_port: 5003
        - device: '192.168.1.12'
          persistence_file: './mysensors2.json'
          tcp_port: 5003
      optimistic: false
      persistence: true
      retain: true
      version: 1.5
    Right?
    Boots33B 1 Reply Last reply
    • J jocke4u
      HI,
      mysensors:
        gateways:
            tcp_port: 5003
            tcp_port: 5003
        optimistic: false
        persistence: true
        retain: true
        version: 1.5
      Right?
      Boots33B Offline
      Boots33B Offline
      Boots33
      @jocke4u yes that is correct, both gateways will also need to be using different channels as well.
