  3. Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.
34 Posts 3 Posters 2.7k Views 3 Watching
  • pw44P pw44
    these are the real photos of the setup.
    wire codes are the same as the build instructions ;-)
    managing the SPI_EN signal? tried with and without, no changes.
    IMG_6520.JPG IMG_6521.JPG IMG_6522.JPG IMG_6523.JPG IMG_6524.JPG IMG_6525.JPG IMG_6526.JPG
    YveauxY
    YveauxY
    #21
    @pw44 you seem to have the same w5100 shield as i have. Try removing the sd card.
    If that doesn't work, try my fix here : https://forum.mysensors.org/topic/9732/arduino-uno-with-ethernet-shield-w5100-not-working/10
    pw44P 1 Reply Last reply
    • YveauxY Yveaux
      pw44P
      pw44P
      pw44
      @Yveaux
      Thanks for the reply, removing the sd card or applying your fix did not change the problem.
      YveauxY 1 Reply Last reply
      • pw44P pw44
        @Yveaux
        YveauxY
        YveauxY
        @pw44 why are spi clk/miso/mosi connected to A0.. 2 ¿
        • YveauxY Yveaux
          pw44P
          pw44P
          pw44
          @Yveaux
          @Yveaux said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
          as described in https://www.mysensors.org/build/ethernet_gateway
          • pw44P pw44
            @Yveaux
            YveauxY
            YveauxY
            #25
            @pw44 said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
            Yes, but the sketch just below it has
            //#define MY_W5100_SPI_EN 4
            You actually have enabled this line, which causes the arduino to use hardware spi. And hardware spi uses different pins for clk/miso/mosi.
            You wired for software spi, so comment that line as in the example.
            pw44P 2 Replies Last reply
            • YveauxY Yveaux
              pw44P
              pw44P
              pw44
              @Yveaux
              thanks man, you're right. commenting out
              solved it.
              now, debug shows:
              0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
              4 MCO:BGN:BFR
              6 TSM:INIT
              7 TSF:WUR:MS=0
              13 TSM:INIT:TSP OK
              15 TSM:INIT:GW MODE
              16 TSM:READY:ID=0,PAR=0,DIS=0
              19 MCO:REG:NOT NEEDED
              696 GWT:TIN:IP=192.168.80.9
              1699 MCO:BGN:STP
              1701 MCO:BGN:INIT OK,TSP=1
              1703 TSM:READY:NWD REQ
              1709 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              just another question: does the 3.3v line from Uno R# enough power to handle the RF24 radio?
              Thx in advance!
              • YveauxY Yveaux
                pw44P
                pw44P
                pw44
                @Yveaux and regardin IRQ from RF24, is it necessary to connect to pin2 of UNO R3?
                • pw44P pw44
                  @pw44 no
                  The IRQ pin is only required to be connected if the MY_RX_MESSAGE_BUFFER_FEATURE is defined in the sketch. Using this feature is recommended for high traffic nodes or gateways. Enabling it will result in better throughput but will require some additional memory to keep the message in memory before processing.
                  More information: https://www.mysensors.org/build/connect_radio and MY_RX_MESSAGE_BUFFER_FEATURE
                    @pw44 no
                    pw44P
                    pw44P
                    pw44
                    @mfalkvidd
                    thank for the answer.
                    i guess the UNO R3 is capable to do it, so, i tried
                    #define MY_RX_MESSAGE_BUFFER_FEATURE
                    #define MY_RF24_IRQ_PIN 3
                    and got the following error:
                    #error RF24 IRQ usage cannot be used with Soft SPI
                    Any hint? The idea is having something like 80 nodes when all is done.
                    Thx
                    • pw44P pw44
                      @mfalkvidd
                      Thx
                      @pw44 unless your nodes send very frequently, you probably don’t need irq.
                      If you need irq, you’ll need to use hardware spi.
                        pw44P
                        pw44P
                        pw44
                        @mfalkvidd said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
                        Ok, but just in case, how to use the hardware spi in this configurartion (sorry if it seams stupid, but i'm just a very beginner on this).
                        Thx for the understanding and also for educating me,.
                        • pw44P pw44
                          @pw44 I don’t think anyone has managed to make the w5100 work on the same spi as nrf24.
                            pw44P
                            pw44P
                            pw44
                            @mfalkvidd
                            ok, i was curious as i didn't find how to.
                            Anyway, is it possible to have the "RF24 IRQ" used as soft?
                            • pw44P pw44
                              @mfalkvidd
                              YveauxY
                              YveauxY
                              @pw44 no, mysensors doesn't need it for soft spi and won't use it
