  3. Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.
34 Posts 3 Posters 3.0k Views 3 Watching
  • pw44P pw44
    nothing is working :-(
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    #define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    //#define MY_IP_ADDRESS 192,168,80,15
    //#define MY_IP_GATEWAY_ADDRESS 192,168,80,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS 0x00, 0x40, 0xFD, 0xEF, 0x35, 0x75
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    serial monitor output:
    30055 TSM:FAIL:RE-INIT
    30057 TSM:INIT
    30063 !TSM:INIT:TSP FAIL
    30065 TSM:FAIL:CNT=4
    30067 TSM:FAIL:DIS
    30069 TSF:TDI:TSL
    0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    4 TSM:INIT
    5 TSF:WUR:MS=0
    11 !TSM:INIT:TSP FAIL
    13 TSM:FAIL:CNT=1
    15 TSM:FAIL:DIS
    16 TSF:TDI:TSL
    10019 TSM:FAIL:RE-INIT
    10021 TSM:INIT
    10028 !TSM:INIT:TSP FAIL
    10030 TSM:FAIL:CNT=2
    10032 TSM:FAIL:DIS
    10034 TSF:TDI:TSL
    20037 TSM:FAIL:RE-INIT
    20039 TSM:INIT
    20045 !TSM:INIT:TSP FAIL
    20047 TSM:FAIL:CNT=3
    20049 TSM:FAIL:DIS
    20051 TSF:TDI:TSL
    30057 TSM:INIT
    30067 TSM:FAIL:DIS
    30069 TSF:TDI:TSL
    40072 TSM:FAIL:RE-INIT
    40074 TSM:INIT
    40080 !TSM:INIT:TSP FAIL
    40082 TSM:FAIL:CNT=5
    40084 TSM:FAIL:DIS
    40086 TSF:TDI:TSL
    50089 TSM:FAIL:RE-INIT
    50092 TSM:INIT
    50098 !TSM:INIT:TSP FAIL
    50100 TSM:FAIL:CNT=6
    50102 TSM:FAIL:DIS
    50104 TSF:TDI:TSL
    60107 TSM:FAIL:RE-INIT
    60109 TSM:INIT
    60115 !TSM:INIT:TSP FAIL
    60118 TSM:FAIL:CNT=7
    60120 TSM:FAIL:DIS
    60122 TSF:TDI:TSL
    120125 TSM:FAIL:RE-INIT
    120127 TSM:INIT
    120133 !TSM:INIT:TSP FAIL
    120136 TSM:FAIL:CNT=7
    120138 TSM:FAIL:DIS
    120139 TSF:TDI:TSL
    180142 TSM:FAIL:RE-INIT
    180144 TSM:INIT
    180150 !TSM:INIT:TSP FAIL
    180153 TSM:FAIL:CNT=7
    180155 TSM:FAIL:DIS
    180156 TSF:TDI:TSL
    4 TSM:INIT
    5 TSF:WUR:MS=0
    13 TSM:FAIL:CNT=1
    15 TSM:FAIL:DIS
    16 TSF:TDI:TSL
    10021 TSM:INIT
    10032 TSM:FAIL:DIS
    10034 TSF:TDI:TSL
    20039 TSM:INIT
    20049 TSM:FAIL:DIS
    20051 TSF:TDI:TSL
    30057 TSM:INIT
    30067 TSM:FAIL:DIS
    30069 TSF:TDI:TSL
    there must be something i'm not being able to figure out....
    dhcp served by dnsmasq. all other devices work without problem.
    @pw44 the log shows that the gateway is unable to initialize the nrf24 radio module. This prevents the gateway code from reaching the dhcp section.
    Double-check the nrf24 wiring. If you can, replace the radio module. If that doesn't help, post detailed photos of the wiring and we'll try to spot what could be wrong.
    • mfalkviddM
      Also, are you sure the w5100 shield you are using is capable of managing the SPI_EN signal?
      • pw44P
        pw44P
        pw44
        these are the real photos of the setup.
        wire codes are the same as the build instructions ;-)
        managing the SPI_EN signal? tried with and without, no changes.
        IMG_6520.JPG IMG_6521.JPG IMG_6522.JPG IMG_6523.JPG IMG_6524.JPG IMG_6525.JPG IMG_6526.JPG
        • pw44P pw44
          #21
          @pw44 you seem to have the same w5100 shield as i have. Try removing the sd card.
          If that doesn't work, try my fix here : https://forum.mysensors.org/topic/9732/arduino-uno-with-ethernet-shield-w5100-not-working/10
          pw44P 1 Reply Last reply
          • YveauxY Yveaux
            pw44P
            pw44P
            pw44
            @Yveaux
            Thanks for the reply, removing the sd card or applying your fix did not change the problem.
            • pw44P pw44
              @Yveaux
              @pw44 why are spi clk/miso/mosi connected to A0.. 2 ¿
              • YveauxY Yveaux
                pw44P
                pw44P
                pw44
                @Yveaux
                @Yveaux said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
                as described in https://www.mysensors.org/build/ethernet_gateway
                • pw44P pw44
                  @Yveaux
                  #25
                  @pw44 said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
                  Yes, but the sketch just below it has
                  //#define MY_W5100_SPI_EN 4
                  You actually have enabled this line, which causes the arduino to use hardware spi. And hardware spi uses different pins for clk/miso/mosi.
                  You wired for software spi, so comment that line as in the example.
                  pw44P 2 Replies Last reply
                  • YveauxY Yveaux
                    pw44P
                    pw44P
                    pw44
                    @Yveaux
                    thanks man, you're right. commenting out
                    solved it.
                    now, debug shows:
                    4 MCO:BGN:BFR
                    6 TSM:INIT
                    7 TSF:WUR:MS=0
                    13 TSM:INIT:TSP OK
                    15 TSM:INIT:GW MODE
                    16 TSM:READY:ID=0,PAR=0,DIS=0
                    19 MCO:REG:NOT NEEDED
                    696 GWT:TIN:IP=192.168.80.9
                    1699 MCO:BGN:STP
                    1701 MCO:BGN:INIT OK,TSP=1
                    1703 TSM:READY:NWD REQ
                    1709 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                    just another question: does the 3.3v line from Uno R# enough power to handle the RF24 radio?
                    Thx in advance!
                    • YveauxY Yveaux
                      pw44P
                      pw44P
                      pw44
                      @Yveaux and regardin IRQ from RF24, is it necessary to connect to pin2 of UNO R3?
                      • pw44P pw44
                        @pw44 no
                        The IRQ pin is only required to be connected if the MY_RX_MESSAGE_BUFFER_FEATURE is defined in the sketch. Using this feature is recommended for high traffic nodes or gateways. Enabling it will result in better throughput but will require some additional memory to keep the message in memory before processing.
                        More information: https://www.mysensors.org/build/connect_radio and MY_RX_MESSAGE_BUFFER_FEATURE
                          @pw44 no
                          pw44P
                          pw44P
                          pw44
                          @mfalkvidd
                          thank for the answer.
                          i guess the UNO R3 is capable to do it, so, i tried
                          #define MY_RX_MESSAGE_BUFFER_FEATURE
                          #define MY_RF24_IRQ_PIN 3
                          and got the following error:
                          #error RF24 IRQ usage cannot be used with Soft SPI
                          Any hint? The idea is having something like 80 nodes when all is done.
                          Thx
                          • pw44P pw44
                            @mfalkvidd
                            Thx
                            @pw44 unless your nodes send very frequently, you probably don’t need irq.
                            If you need irq, you’ll need to use hardware spi.
                              pw44P
                              pw44P
                              pw44
                              @mfalkvidd said in Gateway Uno R3 + W5100 Ethernet Shield for Uno not working.:
                              Ok, but just in case, how to use the hardware spi in this configurartion (sorry if it seams stupid, but i'm just a very beginner on this).
                              Thx for the understanding and also for educating me,.
                              • pw44P pw44
                                @pw44 I don’t think anyone has managed to make the w5100 work on the same spi as nrf24.
                                  pw44P
                                  pw44P
                                  pw44
                                  @mfalkvidd
                                  ok, i was curious as i didn't find how to.
                                  Anyway, is it possible to have the "RF24 IRQ" used as soft?
                                  • pw44P pw44
                                    @mfalkvidd
                                    @pw44 no, mysensors doesn't need it for soft spi and won't use it
