  3. NodeManager
  4. BME280 node not sleeping
10 Posts 2 Posters 1.7k Views 2 Watching
  • G Offline
    G Offline
    ghiglie
    wrote on last edited by ghiglie
    I've build my first node with NodeManager, code is at end of post; it looks like it's not sleeping, it worn out a pair of AA in 24h.
    There's a strange half-lit LED on it: what did I do wrong? Same node with a standard hand-written sketch is working as usual.
    Thanks all!
    // General settings
    #define SKETCH_NAME "GarageLibrarySensor"
    #define SKETCH_VERSION "0.1"
    #define MY_BAUD_RATE 9600
    #define MY_NODE_ID 2
    #define MY_SIGNAL_REPORT_ENABLED
    // NRF24 radio settings
    //set how long to wait for transport ready in milliseconds
    // Optimizations when running on 2032 Coin Cell. Also set nodeManager.setSleepBetweenSend(500) and run the board at 1Mhz
    #define MY_TRANSPORT_UPLINK_CHECK_DISABLED
    #define MY_TRANSPORT_WAIT_READY_MS  5000
    #define MY_SLEEP_TRANSPORT_RECONNECT_TIMEOUT_MS 2000
    //#define MY_PARENT_NODE_ID 0
    //#define MY_PARENT_NODE_IS_STATIC
    #define NODEMANAGER_DEBUG ON
    #define NODEMANAGER_SLEEP ON
    #define NODEMANAGER_OTA_CONFIGURATION OFF
    #define NODEMANAGER_CONDITIONAL_REPORT ON
    #define NODEMANAGER_POWER_MANAGER ON
    #define NODEMANAGER_SENSOR_BOSCH_LITE ON
    #include <MySensors_NodeManager.h>
    // Sensors
    // Battery Level (default child_id 201)
    #include <sensors/SensorBattery.h>
    SensorBattery battery;
    // Radio Signal Quality (default child_id 202)
    #include <sensors/SensorSignal.h>
    SensorSignal signal;
    #include <sensors/SensorBME280.h>
    //#define CHILD_ID_AMBIENT 1
    SensorBME280 ambient;
    // before
    void before() {
         Configure your sensors
      // let controller know ambient pressure sensor reports in hPa
      ambient.children.get(3)->setUnitPrefix("hPa");
      // send unit prefixes to controller (i.e. V, A, hPa, %, etc.)
      nodeManager.setSendUnitPrefix(true);
      // report ambient measurements every 1h
      ambient.setReportIntervalMinutes(60);
      // report battery level every 60 minutes
      battery.setReportIntervalMinutes(720);
      // report radio signal level every 4h
      signal.setReportIntervalMinutes(1440);
      // only a pseudo SR_TX_RSSI and SR_UPLINK_QUALITY are available for NRF24
      // radio. All other methods return as INVALID.
      signal.setSignalCommand(SR_UPLINK_QUALITY);
      // call NodeManager before routine
      nodeManager.before();
    // presentation
    void presentation() {
      // call NodeManager presentation routine
      nodeManager.presentation();
    // setup
      // call NodeManager setup routine
      nodeManager.setup();
    // loop
      // call NodeManager loop routine
      nodeManager.loop();
    #if NODEMANAGER_RECEIVE == ON
    // receive
      // call NodeManager receive routine
      nodeManager.receive(message);
    #if NODEMANAGER_TIME == ON
    // receiveTime
    void receiveTime(unsigned long ts) {
      // call NodeManager receiveTime routine
      nodeManager.receiveTime(ts);
    atmega328p serial killer
    HomeAssistant / gateway: ESP8266 & NRF24L01+ gateway
    B 1 Reply Last reply
    • G ghiglie
      Thanks all!
      // General settings
      // Sensors
      // before
      void before() {
      // presentation
      // setup
      // loop
        nodeManager.loop();
      // receive
      // receiveTime
      B Offline
      B Offline
      bbastos
      Hi @ghiglie I'm still beginning in all this, but I think you need to call nodeManager.setSleepMinutes(minutes) otherwise the node will still awake.
      G 1 Reply Last reply
      • B bbastos
        G Offline
        G Offline
        ghiglie
        @bbastos said in BME280 node not sleeping:
        Oh... I feel so dumb! Thanks @bbastos , I didn't ... know it. I don't know why, maybe on the solder/flash/test/upload frenzy I read that part of documentation. So, as usual, I'll RTFM and report back. Thanks again!!!
        • G Offline
          G Offline
          ghiglie
          So, new message to get up a notification with my full working sketch. I'm so satisfied!
          Putting a BME280 in a garage is an overkill, but I couldn't get a decent measure from the DHTs I have. I added a PIR to it, just for a minor convenience.
          With next node I'll explore OTA features - flash and configuration.
          // General settings
          #define SKETCH_NAME "GarageLibrary"
          #define SKETCH_VERSION "2.0"
          //#define MY_TRANSPORT_UPLINK_CHECK_DISABLED
          #define NODEMANAGER_DEBUG ON //
          #define NODEMANAGER_DEBUG_VERBOSE OFF
          #define NODEMANAGER_SLEEP ON //
          #define NODEMANAGER_RECEIVE OFF
          #define NODEMANAGER_POWER_MANAGER OFF
          #define NODEMANAGER_CONDITIONAL_REPORT ON //
          #define NODEMANAGER_INTERRUPTS ON //
          #define NODEMANAGER_EEPROM OFF
          #define NODEMANAGER_TIME OFF
          #define NODEMANAGER_RTC OFF
          #define NODEMANAGER_SD OFF
          #define NODEMANAGER_HOOKING OFF
          #define NODEMANAGER_SERIAL_INPUT OFF
          // disable Forecast on BME280 - not working with OTA conf Off!
          // BME280
          #define BME280_ADDRESS (0x77)
          // PIR on D3 (optional build, PIN_PD3 is defined in MiniCore)
          #include <sensors/SensorMotion.h>
          SensorMotion pir(PIN_PD3);
          // before
          void before() {
            // battery level - BOD set to 1.8V, 2xAA = 3V max
            battery.setMinVoltage(1.8);
            battery.setMaxVoltage(3.0);
            // sleep cycle
            nodeManager.setSleepMinutes(60);
            // 500ms to let the transport send all buffer before sleeping.
            nodeManager.setSleepBetweenSend(500);
            // report freq for ambient measurements
            // report freq for battery
            battery.setReportIntervalDays(1);
            // report freq for radio signal - pseudo SR_TX_RSSI and SR_UPLINK_QUALITY are available for NRF24
            signal.setReportIntervalDays(1);
          // presentation
          // setup
          // loop
            nodeManager.loop();
          // receive
          // receiveTime
          • G ghiglie
            // General settings
            // BME280
            // before
            void before() {
              // sleep cycle
            // presentation
            // setup
            // loop
              nodeManager.loop();
            // receive
            // receiveTime
            B Offline
            B Offline
            bbastos
            @ghiglie said in BME280 node not sleeping:
            // General settings
            // BME280
            // before
            void before() {
              // sleep cycle
            // presentation
            // setup
            // loop
              nodeManager.loop();
            // receive
            // receiveTime
            Nice! Do you mind sharing a picture of your node? I've just assembled my first battery node using arduino pro mini and somehow it's working :joy:
            I'm a beginner in electronics and would like to compare, see if I did mess up something.
            • G Offline
              G Offline
              ghiglie
              Here it is:
              asd asd
              I'm using NModule with SMD nRF module - I was planning to use a CR2023 to downsize it, but I ended using this 2xAA battery holder.
              I'm a n00b too - I can say I started learning with MySensors' building motivation.
              I had a respectable cemetery:
              asd
              Mostly have corrupt booloader (update via programmer with antenna still powered) or incorrect fuses (batch production done wrong way!), but a pair got a nice polarity inversion on VCC... :D :D :D :D
              • B Offline
                B Offline
                bbastos
                Thank you! Ohh that's pretty complex for my super noob skills :grin:
                I'm on the same vibe, using mysensors to start learning about electronics and automation. My first node is still on breadboard, but alive even after desoldering led and volt. reg. :grin::
                • G Offline
                  G Offline
                  ghiglie
                  That's not a bad test bed!
                  I'm having some "headaches" still. The PIR isn't sending the V_TRIPPED 0 , so I know when there's moving but not when it stops - I can manage it via HomeAssistant anyway.
                  • G ghiglie
                    B Offline
                    B Offline
                    bbastos
                    I'm afraid I'll not be helpful now. Have you tried to update nodemanager library? I'm using the development branch from github.
                    • B bbastos
                      G Offline
                      G Offline
                      ghiglie
                      No probs, it's the PIR itself, not reporting back the "0" status. I'll manage it via HA!
