  3. Controlling speed of an AC 230v FAN. Help Needed[RESOLVED]
7 Posts 5 Posters 3.6k Views 4 Watching
    mainali
    wrote on last edited by mainali
    Has anyone tried to control the speed of a fan.
    I have relay connected to a fan. Relay is triggered using RelayActuator example. How can I now control the speed of the fan which is switched on when relay is triggered.
    I tried adding a new sensor type V_FAN and I am sending MyMqtt/node_id/sensor_id/V_FAN but I am not able to receive the message type in the message at the node.
    Note : I have manually assigned the sensor Id as relay 2 is assigned sensor id 2 by the relayActuator example code.
    EDIT: It was my mistake, didn't not update the gateway code after adding a new message type. :(
    • ChaoticC
      ChaoticC
      Chaotic
      what type of data are you trying to send and is there a reason you can't use V_VAR1? or V_DIMMER?
      I believe V_DIMMER is expecting a % and I know with V_VAR you can send any type you want.
      • S
        sharath krishna
        i think V_DIMMER can be used for the purpose.. but controlling speed is not something u can do with just a relay .
          mainali
          I have a dimmer circuit with me which gives digital output. I just want to know the correct message format for the MQTT message. And how to add a new message type ?. Anyone has done this already ?
            mainali
            Help needed with adding a new message type. I want to add V_FAN to identify the fan. I am not able to send the message from gateway.
            I am trying to check message.type = V_FAN, but nothing is happening, I think this message is never arriving at the node.
            • Q
              Q
              quocanhcgd
              Can you share your code ?
              • J
                J
                jemish
                Which hardware s used for controlling a FAN?
