  3. Domoticz
  4. Domoticz/Mysensors
Domoticz/Mysensors
11 Posts 4 Posters 2.0k Views 4 Watching
  • A Offline
    A Offline
    alco
    • S Offline
      Sasquatch
      interesting schematic. another way of controlling lights is:
      rewire standard light switch to low voltage input of arduino node
      use node's relay to control light, works even if you don't have neutral wire in light switch backbox.
      • A Offline
        A Offline
        alco
        Hi
        Thanks. The good thing is that the light circuit is independent from Arduino and Raspberry. That was the main reason behind it. I was supposed to add a description but something went wrong and I only published the schematic. Anyway, I have got a problem with a script for this solution.
        Anybody can help with the programming?
        S 1 Reply Last reply
        • A alco
          Hi
          Sasquatch
          @alco plenty people here ready to help
          • A Offline
            A Offline
            alco
            #define MY_GATEWAY_SERIAL
            // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
            #if F_CPU == 8000000L
            #define MY_BAUD_RATE 38400
            // Enable inclusion mode
            #define MY_INCLUSION_MODE_BUTTON_PIN 3
            #include <Bounce2.h>
            #define MY_REPEATER_FEATURE
            #define RELAY_ON 1 // GPIO value to write to turn on attached relay
            #define noLightSwitch 10 //2-11
            int relayPin[] = {2,3,4,5,6,7,8,9,10,11}; // switch around pins to your desire
            int buttonPin[] = {A0,A1,A2,A3,A4,A5,A6,A7,A8,A9}; // switch around pins to your desire
            Bounce debouncer[10];
            MyMessage msg[10];
            void before() {
            //sendHeartbeat();
            wait(100);
            // Initialize Relays with corresponding buttons
            for (int i = 0; i < noLightSwitch; i++){
            // Setup the button.
            pinMode(buttonPin[i], INPUT_PULLUP);
            wait(100);
            pinMode(relayPin[i], OUTPUT);
            wait(100);
            digitalWrite(relayPin[i], RELAY_OFF);
            msg[i].sensor = i; // initialize messages
            msg[i].type = V_LIGHT;
            //send(msg[i].set(loadState(i))); // make controller aware of last status
            //wait(100);
            // setup debouncer.
            debouncer[i] = Bounce(); // initialize debouncer
            debouncer[i].attach(buttonPin[i]);
            debouncer[i].interval(20);
            delay(100);
            presentation();
            boolean inputState;
            void presentation() {
            present(buttonPin[i], S_LIGHT);
            inputState =! digitalRead(buttonPin[i]);
            send(msg[i].set(inputState));
            wait(100);
            if (debouncer[i].update()) {
            wait(100);
            if (message.type==V_LIGHT) {
            for (int i = 0; i < noLightSwitch; i++) {
            if (i == message.sensor){
            digitalWrite(relayPin[i], RELAY_ON);
            wait(100);
            wait(100);
            • S Offline
              Sasquatch
              put your code in code tags, makes it much easier to read, use bar above text field it's </> icon.
              • J Offline
                J Offline
                JeeLet
                hello, am french.
                no answer from Alco ??
                I simplify the code to understand how it works
                and put the diagram too
                code:
                *  Alco_TL_Impuls_Light.ino
                * https://forum.mysensors.org/topic/11263/domoticz-mysensors
                * Version 1.0 - Gateway Serial par Alco
                * Version 0.0 - Node en RS485 par JeeLet
                *LA DESCRIPTION
                  * TL :Commande Impulsionnelle de TeLerupteur d'Eclairage
                  * TS :Retour d'Etat par un contact auxilaire du TL.
                  * L'installation Electrique n'est pas modifier,
                  * les bouton poussoir de l'habitat Cmd aussi le TL.
                //#define MY_DEBUG
                #define MY_NODE_ID 24           /*pour Node ID static*/
                /* ----- Module RS485 ----*/
                 #define MY_RS485
                 #define MY_RS485_DE_PIN 2
                 #define MY_RS485_BAUD_RATE 9600
                // #define MY_RS485_HWSERIAL Serial1 /* Mega2560, port Serial X? */
                #define CHILD_ID 3   /*Id du capteur (enfant)*/
                #define RELAY_PIN  4   // pin Cmd Telerupteur     "TL"
                #define BUTTON_PIN  3  // pin Contact Auxiliaire  "TS"
                #define RELAY_ON 1
                #define RELAY_OFF 0
                Bounce debouncer = Bounce();  // initialize debouncer
                MyMessage msg(CHILD_ID,V_STATUS);
                  pinMode(BUTTON_PIN,INPUT_PULLUP);
                  pinMode(RELAY_PIN , OUTPUT);
                  debouncer.attach(BUTTON_PIN);
                  debouncer.interval(20); // minimum ?
                  bool state;
                  boolean inputState;
                  sendSketchInfo("Cmd TL", "1.a");
                  present(BUTTON_PIN, S_LIGHT);
                  if (debouncer.update())
                   inputState =! digitalRead(BUTTON_PIN);
                   send(msg.set(inputState));
                  if (message.isAck())
                     Serial.println("Ceci est un accusé de réception de la passerelle");
                     Serial.println("Cmd TL 1.a");
                  if (message.type==V_STATUS) // V_STATUS pour MyS v2.0, annulé V_LIGHT.
                      //if (state = message.getBool () == true) {
                        //  state = message.getBool();
                     digitalWrite(RELAY_PIN, RELAY_ON);
                     wait(200);                          //delai On-Off Impuls
                // Write some debug info
                   Serial.print("Changement entrant pour le capteur:");
                   Serial.print(message.sensor);
                // ------------ fin Pgm -----------
                the code is not good,dialogue errors :
                error on domoticz
                Error sending switch command, check device/hardware (idx=8) !
                Log:
                Error: MySensors: Repeating previous command (2/2)
                Error: MySensors: Command not received by Node !! (node_id: 24, child_id: 3)
                thank you
                • J Offline
                  J Offline
                  JeeLet
                  ...I forgot the terminal debug
                  ...set to OFF
                  Changement entrant pour le capteur:3, New status: 0
                  36376 TSF:MSG:SEND,24-24-0-0,s=3,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:0
                  44859 TSF:MSG:READ,0-0-24,s=3,c=1,t=2,pt=0,l=1,sg=0:1
                  44864 TSF:MSG:ECHO REQ
                  44883 TSF:MSG:SEND,24-24-0-0,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:1
                  44890 !MCO:PRO:RC=1
                  5080 !MCO:PRO:RC=1
                  ....set to ON
                  5080 !MCO:PRO:RC=1
                  45082 !MCO:PRO:RC=1
                  45084 !MCO:PRO:RC=1
                  45086 !MCO:PRO:RC=1
                  45088 !MCO:PRO:RC=1
                  Changement entrant pour le capteur:3, New status: 1
                  45127 TSF:MSG:SEND,24-24-0-0,s=3,c=1,t=2,pt=1,l=1,sg=0,ft=0,st=OK:1
                  boumB 1 Reply Last reply
                  • J JeeLet
                    ...set to OFF
                    44890 !MCO:PRO:RC=1
                    5080 !MCO:PRO:RC=1
                    ....set to ON
                    5080 !MCO:PRO:RC=1
                    45082 !MCO:PRO:RC=1
                    45084 !MCO:PRO:RC=1
                    45086 !MCO:PRO:RC=1
                    45088 !MCO:PRO:RC=1
                    boumB Offline
                    boumB Offline
                    boum
                    @JeeLet Hi. First, you probably should have started another thread rather than hijacking this one since the situation is barely related.
                    Looking here, I found that !MCO:PRO:RC=1 is caused mainly by calling send() or wait() inside the receive() function.
                    I have not completely understood how things are happening but I think at best you're receiving a message while processing the current one. From several sources on this forum, you should keep your receive() function small. Process the content of the message and do all the work in loop().
                    I would probably do something like that, but ⚠ I didn't compile and test the code :
                     *LA DESCRIPTION
                     * TS :Retour d'Etat par un contact auxiliaire du TL.
                     * L'installation Electrique n'est pas modifiee,
                     * les boutons poussoir de l'habitat Cmd aussi le TL.
                    //#define MY_DEBUG
                    #define MY_RS485
                    #define STATE_CHILD_ID 0   /*Id du capteur (enfant)*/
                    #define CONTROL_INPUT_PIN  3  // pin Contact Auxiliaire  "TS"
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    MyMessage msg(STATE_CHILD_ID,V_STATUS);
                        pinMode(CONTROL_INPUT_PIN, INPUT_PULLUP);
                        pinMode(RELAY_PIN, OUTPUT);
                        debouncer.attach(CONTROL_INPUT_PIN);
                    bool currentState;
                    bool controllerState;
                        present(STATE_CHILD_ID, S_LIGHT);
                        // Send impulse if controller changed state
                        if (controllerState != currentState)
                            currentState = controllerState;
                        // Inform controller if state change from input
                            bool newState = !digitalRead(CONTROL_INPUT_PIN);
                            if (newState != currentState)
                                currentState = newState;
                                if (currentState != controllerState)
                                    send(msg.set(currentState));
                        if (message.isEcho()) // keep message.isAck() for older MySensors version
                            return;
                            controllerState = message.getBool();
                    You may have to tweak the conditions and tests so that your sensor is always in a consistent state, but that should resolve the recursion error message.
                    • J Offline
                      J Offline
                      JeeLet
                      @boum said in Domoticz/Mysensors:
                      Hello
                      I just saw your message.
                      nothing seen in my mailbox.
                      yes that's true for another post, but the quest has the same :)
                      to see if moderator or alco finds useful, is to do so.
                      Thanks for paying attention to my problem, cool.
                      I tested the sketch and the errors "MCO: PRO: RC" its part .... bingo
                      but as nature hates emptiness, something else happens (nothing serious)
                      .... a story of disregard for a local change / command / switchover of the TL
                      I look better at your modifications to understand the arduino.
                      thank you for the comments in the scketch
                      my test model
                      Well!! where is the notifications button
                      • J Offline
                        J Offline
                        JeeLet
                        Yes errors on the commands given through domoticz
                        only one in three and taken into account
                        terminal copy serial
                        ...and the local push button commands are not taken into account
                        in the loop something that dies its tail ??
                        merci Boum
                        12.2k
