  3. test
test
3 Posts 2 Posters 452 Views 2 Watching
  • C Offline
    C Offline
    Clone Tv
    This post is deleted!
    Y 1 Reply Last reply
    • C Clone Tv
      Y Offline
      Y Offline
      @Clone-Tv can you break it down into separate issues? What are you trying to achieve (share your code, what platform etc)?
      Using 64bit integers on e.g. microcontrollers is non-trivial, but you don't even mention what platform you're targeting...
      Also, please change the subject of your post, 'test' doesn't seem to cover it...
      • C Offline
        C Offline
        Clone Tv
        Sorry, that was the test :) the text is irrelevant to the topic.
        But, since we are talking about 64-bit numbers on Arduino-like platforms, I'm ready to translate the code that solves this situation.
        Int64String.h
        #if !defined(INT64STRING_H)
        # define INT64STRING_H 1
        # if (defined(ARDUINO) && (ARDUINO >= 100))
        #  include "Arduino.h"
        # else
        #  include "WString.h"
        # endif
        String Int64ToString(uint64_t, uint8_t = DEC, bool = false, bool = false);
        String Int64ToString(int64_t, uint8_t = DEC, bool = false);
        uint64_t StringToInt64(String);
        uint64_t StringToInt64(const char*, uint16_t);
        Int64String.cpp
        #include "Int64String.h"
        #define base16char(A) ("0123456789ABCDEF"[A])
        String Int64ToString(uint64_t value, uint8_t base, bool prefix, bool sign) {
          if (base < 2)
            base = 2;
          else if (base > 16)
            base = 16;
          uint8_t i = 64;
          char buffer[66] = {0};
          if (value == 0)
            buffer[i--] = '0';
          else {
            uint8_t base_multiplied = 3;
            uint16_t multiplier = base * base * base;
            if (base < 16) {
              multiplier *= base;
              base_multiplied++;
            if (base < 8) {
              multiplier *= base;
              base_multiplied++;
            while (value > multiplier) {
              uint64_t q = value / multiplier;
              uint16_t r = value - q * multiplier;
              for (uint8_t j = 0; j < base_multiplied; j++) {
                uint16_t rq = r / base;
                buffer[i--] = base16char(r - rq * base);
                r = rq;
              value = q;
            uint16_t remaining = value;
            while (remaining > 0) {
              uint16_t q = remaining / base;
              buffer[i--] = base16char(remaining - q * base);
              remaining = q;
          if (base == DEC && sign)
            buffer[i--] = '-';
          else if (prefix) {
            if (base == HEX) {
              buffer[i--] = 'x';
              buffer[i--] = '0';
            else if (base == OCT)
              buffer[i--] = '0';
            else if (base == BIN)
              buffer[i--] = 'B';
          return String(&buffer[i + 1]);
        String Int64ToString(int64_t value, uint8_t base, bool prefix) {
          bool sign = base == DEC && value < 0;
          uint64_t uvalue = sign ? -value : value;
          return Int64ToString(uvalue, base, prefix, sign);
        uint64_t StringToInt64(String str) {
          return StringToInt64(str.c_str(), str.length());
        uint64_t StringToInt64(const char *s, uint16_t sz = 0U) {
          uint64_t val = 0ULL;
          if (s == nullptr)
            return val;
          if (sz <= 0)
            sz = strlen(s);
          if (sz <= 2)
            return val;
          uint16_t i = (((s[0] == '0') && ((s[1] == 'x') || (s[1] == 'X'))) ? 2U : 0U);
          for (; i < sz; i++) {
            const char c = s[i];
            if (!isxdigit(c))
              return -1ULL;
            val *= 16;
            val += (c >= '0' && c <= '9') ? c - '0' : c - 'A' + 10;
          return val;
        I gave the sources as an apology for the created topic :)
        12.2k
