  3. Node with encryption asking for ID in loop
1 Posts 1 Posters 237 Views 1 Watching
  • AndurilA
    AndurilA
    Anduril
    Hey there,
    I hope someone can help. I have a simple test setup with only one gateway and one node at the moment. I want them to communication with encryption enabled. As one of them has no easy access to serial lines I want to first set it up with #define MY_ENCRYPTION_SIMPLE_PASSWD "Test" I have this activated in both sketches.
    The result is the node asking for an ID in loop all the time, but with different sensor numbers (why is there a sensor number in the ID_REQUEST, shouldn't it be 255?). But there is a pattern (tried multiple time with reboot on node and gateway), so it's not random... first I see 6 requests for ID with sensor 102, followed by sensor 4, 163, 67, 12, 176 (6 times each). My controller (MYSController) answers them all the time and I see the sending messages in the serial console of the gateway...
    here the complete gateway log:
    dhcp client start...
    ip:192.168.38.131,mask:255.255.255.0,gw:192.168.38.1
    7778 GWT:TIN:CONNECTING...
    7939 GWT:TIN:IP: 192.168.38.131
    7973 MCO:BGN:STP
    7991 MCO:BGN:INIT OK,TSP=1
    8019 TSM:READY:NWD REQ
    8048 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    pm open,type:2 0
    107269 GWT:TSA:C=0,CONNECTED
    186214 TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    186278 TSF:MSG:BC
    186297 TSF:MSG:FPAR REQ,ID=255
    186329 TSF:PNG:SEND,TO=0
    186355 TSF:CKU:OK
    186374 TSF:MSG:GWL OK
    186431 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    202842 TSF:MSG:READ,255-255-0,s=102,c=3,t=3,pt=0,l=0,sg=0:
    202912 GWT:RFC:C=0,MSG=255;102;3;0;4;2
    202958 ?TSF:MSG:SEND,0-0-255-255,s=102,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    204480 TSF:MSG:READ,255-255-0,s=102,c=3,t=3,pt=0,l=0,sg=0:
    204546 GWT:RFC:C=0,MSG=255;102;3;0;4;2
    204592 ?TSF:MSG:SEND,0-0-255-255,s=102,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    206120 TSF:MSG:READ,255-255-0,s=102,c=3,t=3,pt=0,l=0,sg=0:
    206187 GWT:RFC:C=0,MSG=255;102;3;0;4;2
    206233 ?TSF:MSG:SEND,0-0-255-255,s=102,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    207760 TSF:MSG:READ,255-255-0,s=102,c=3,t=3,pt=0,l=0,sg=0:
    207826 GWT:RFC:C=0,MSG=255;102;3;0;4;2
    207872 ?TSF:MSG:SEND,0-0-255-255,s=102,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    209399 TSF:MSG:READ,255-255-0,s=102,c=3,t=3,pt=0,l=0,sg=0:
    209467 GWT:RFC:C=0,MSG=255;102;3;0;4;2
    209512 ?TSF:MSG:SEND,0-0-255-255,s=102,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    211041 TSF:MSG:READ,255-255-0,s=102,c=3,t=3,pt=0,l=0,sg=0:
    211108 GWT:RFC:C=0,MSG=255;102;3;0;4;2
    211153 ?TSF:MSG:SEND,0-0-255-255,s=102,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    229260 TSF:MSG:READ,255-255-0,s=4,c=3,t=3,pt=0,l=0,sg=0:
    229325 GWT:RFC:C=0,MSG=255;4;3;0;4;2
    229369 ?TSF:MSG:SEND,0-0-255-255,s=4,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    230903 TSF:MSG:READ,255-255-0,s=4,c=3,t=3,pt=0,l=0,sg=0:
    230968 GWT:RFC:C=0,MSG=255;4;3;0;4;2
    231012 ?TSF:MSG:SEND,0-0-255-255,s=4,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    232543 TSF:MSG:READ,255-255-0,s=4,c=3,t=3,pt=0,l=0,sg=0:
    232608 GWT:RFC:C=0,MSG=255;4;3;0;4;2
    232652 ?TSF:MSG:SEND,0-0-255-255,s=4,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    234183 TSF:MSG:READ,255-255-0,s=4,c=3,t=3,pt=0,l=0,sg=0:
    234250 GWT:RFC:C=0,MSG=255;4;3;0;4;2
    234294 ?TSF:MSG:SEND,0-0-255-255,s=4,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    235823 TSF:MSG:READ,255-255-0,s=4,c=3,t=3,pt=0,l=0,sg=0:
    235890 GWT:RFC:C=0,MSG=255;4;3;0;4;2
    235934 ?TSF:MSG:SEND,0-0-255-255,s=4,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    237463 TSF:MSG:READ,255-255-0,s=4,c=3,t=3,pt=0,l=0,sg=0:
    237530 GWT:RFC:C=0,MSG=255;4;3;0;4;2
    237573 ?TSF:MSG:SEND,0-0-255-255,s=4,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    255671 TSF:MSG:READ,255-255-0,s=163,c=3,t=3,pt=0,l=0,sg=0:
    255740 GWT:RFC:C=0,MSG=255;163;3;0;4;2
    255786 ?TSF:MSG:SEND,0-0-255-255,s=163,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    257312 TSF:MSG:READ,255-255-0,s=163,c=3,t=3,pt=0,l=0,sg=0:
    257379 GWT:RFC:C=0,MSG=255;163;3;0;4;2
    257425 ?TSF:MSG:SEND,0-0-255-255,s=163,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    258952 TSF:MSG:READ,255-255-0,s=163,c=3,t=3,pt=0,l=0,sg=0:
    259022 GWT:RFC:C=0,MSG=255;163;3;0;4;2
    259067 ?TSF:MSG:SEND,0-0-255-255,s=163,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    260592 TSF:MSG:READ,255-255-0,s=163,c=3,t=3,pt=0,l=0,sg=0:
    260660 GWT:RFC:C=0,MSG=255;163;3;0;4;2
    260705 ?TSF:MSG:SEND,0-0-255-255,s=163,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    262234 TSF:MSG:READ,255-255-0,s=163,c=3,t=3,pt=0,l=0,sg=0:
    262301 GWT:RFC:C=0,MSG=255;163;3;0;4;2
    262346 ?TSF:MSG:SEND,0-0-255-255,s=163,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    263875 TSF:MSG:READ,255-255-0,s=163,c=3,t=3,pt=0,l=0,sg=0:
    263944 GWT:RFC:C=0,MSG=255;163;3;0;4;2
    263990 ?TSF:MSG:SEND,0-0-255-255,s=163,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    282098 TSF:MSG:READ,255-255-0,s=67,c=3,t=3,pt=0,l=0,sg=0:
    282165 GWT:RFC:C=0,MSG=255;67;3;0;4;2
    282210 ?TSF:MSG:SEND,0-0-255-255,s=67,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    283735 TSF:MSG:READ,255-255-0,s=67,c=3,t=3,pt=0,l=0,sg=0:
    283803 GWT:RFC:C=0,MSG=255;67;3;0;4;2
    283848 ?TSF:MSG:SEND,0-0-255-255,s=67,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    285377 TSF:MSG:READ,255-255-0,s=67,c=3,t=3,pt=0,l=0,sg=0:
    285443 GWT:RFC:C=0,MSG=255;67;3;0;4;2
    285488 ?TSF:MSG:SEND,0-0-255-255,s=67,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    287018 TSF:MSG:READ,255-255-0,s=67,c=3,t=3,pt=0,l=0,sg=0:
    287085 GWT:RFC:C=0,MSG=255;67;3;0;4;2
    287129 ?TSF:MSG:SEND,0-0-255-255,s=67,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    288659 TSF:MSG:READ,255-255-0,s=67,c=3,t=3,pt=0,l=0,sg=0:
    288725 GWT:RFC:C=0,MSG=255;67;3;0;4;2
    288770 ?TSF:MSG:SEND,0-0-255-255,s=67,c=3,t=4,pt=0,l=1,sg=0,ft=0,st=OK:2
    290300 TSF:MSG:READ,255-255-0,s=67,c=3,t=3,pt=0,l=0,sg=0:
    290366 GWT:RFC:C=0,MSG=255;67;3;0;4;2
    If I set the node ID in sketch, it seems to play "ping-pong" all the time... I don't understand why...
    953628 TSF:MSG:READ,10-10-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    953689 TSF:MSG:PINGED,ID=10,HP=1
    954954 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    955267 TSF:MSG:READ,10-10-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    955328 TSF:MSG:PINGED,ID=10,HP=1
    956593 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    956906 TSF:MSG:READ,10-10-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    956967 TSF:MSG:PINGED,ID=10,HP=1
    958232 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    958545 TSF:MSG:READ,10-10-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    958607 TSF:MSG:PINGED,ID=10,HP=1
    959871 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    976723 TSF:MSG:READ,10-10-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    976784 TSF:MSG:PINGED,ID=10,HP=1
    978048 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
    978361 TSF:MSG:READ,10-10-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    978423 TSF:MSG:PINGED,ID=10,HP=1
    979687 !TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1
