MQTT GW with RFM69 on RPi
I found the root cause: https://github.com/mysensors/MySensors/issues/1458#issuecomment-739139339
It is part of the signing code, so expected to occur on all nodes/gateways that request nonces for signing.
Currently discussing if it is a real issue or not. -
@joaoabs said in MQTT GW with RFM69 on RPi:
Also happening in nodes:
are you setting #define MY_TRANSPORT_WAIT_READY_MS ([timeout])? This causes MCO:PRO in my test cases as well.
Don't think so, unless it is set by default.
The code corresponding to the log:/* * The MySensors Arduino library handles the wireless radio link and protocol * between your home built sensors/actuators and HA controller of choice. * The sensors forms a self healing radio network with optional repeaters. Each * repeater and gateway builds a routing tables in EEPROM which keeps track of the * network topology allowing messages to be routed to nodes. * * Created by Henrik Ekblad <henrik.ekblad@mysensors.org> * Copyright (C) 2013-2019 Sensnology AB * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors * * Documentation: http://www.mysensors.org * Support Forum: http://forum.mysensors.org * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License * version 2 as published by the Free Software Foundation. * ******************************* */ /** * @ingroup MySigninggrp * @{ * @file SecureActuator.ino * @brief Example sketch showing how to securely control locks. * * This example will remember lock state even after power failure. * * REVISION HISTORY * - See git log (git log libraries/MySensors/examples/SecureActuator/SecureActuator.ino) */ /** * @example SecureActuator.ino * This example implements a secure actuator in the form of a IO controlled electrical lock.<br> * Multiple locks are supported as long as they are on subsequent IO pin indices. The first lock pin * is defined by @ref LOCK_1. The number of locks is controlled by @ref NOF_LOCKS .<br> * The sketch will require incoming messages to be signed and the use of signing backend is selected * by @ref MY_SIGNING_ATSHA204 or @ref MY_SIGNING_SOFT. Hard or soft ATSHA204 signing is supported.<br> * Whitelisting can be enabled through @ref MY_SIGNING_NODE_WHITELISTING in which case a single entry * is provided in this example which typically should map to the gateway of the network. */ #define MY_DEBUG //!< Enable debug prints to serial monitor //#define MY_NODE_LOCK_FEATURE //!< Enable lockdown of node if suspicious activity is detected // RADIO STUFF #define MY_RADIO_RFM69 //!< RFM69 radio driver #define MY_RFM69_NEW_DRIVER #define MY_RFM69_FREQUENCY RFM69_433MHZ //#define MY_IS_RFM69HW #define MY_RFM69_ENABLE_ENCRYPTION //#define MY_DEBUG_VERBOSE_RFM69 // SIGNING STUFF // Select soft/hardware signing method //#define MY_SIGNING_SOFT //!< Software signing #define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A // Enable node whitelisting //#define MY_SIGNING_NODE_WHITELISTING {{.nodeId = GATEWAY_ADDRESS,.serial = {0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x01}}} // Enable this if you want destination node to sign all messages sent to this node. #define MY_SIGNING_REQUEST_SIGNATURES //!< destination node signs all messages sent to this node // SETTINGS FOR MY_SIGNING_SOFT //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //!< Unconnected analog pin for random seed // SETTINGS FOR MY_SIGNING_ATSHA204 #ifndef MY_SIGNING_ATSHA204_PIN #define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached #endif #define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor #define MY_NODE_ID 33 #include <MySensors.h> #define LOCK_1 3 //!< Arduino Digital I/O pin number for first lock (second on pin+1 etc) #define NOF_LOCKS 2 //!< Total number of attached locks #define LOCK_LOCK 1 //!< GPIO value to write to lock attached lock #define LOCK_UNLOCK 0 //!< GPIO value to write to unlock attached lock void setup() { for (int lock=1, pin=LOCK_1; lock<=NOF_LOCKS; lock++, pin++) { // Set lock pins in output mode pinMode(pin, OUTPUT); // Set lock to last known state (using eeprom storage) digitalWrite(pin, loadState(lock)?LOCK_LOCK:LOCK_UNLOCK); } } void presentation() { // Send the sketch version information to the gateway and Controller sendSketchInfo("Secure Lock", "1.0"); // Fetch lock status for (int lock=1, pin=LOCK_1; lock<=NOF_LOCKS; lock++, pin++) { // Register all locks to gw (they will be created as child devices) present(lock, S_LOCK, "SecureActuator", false); } } /** @brief Sketch execution code */ void loop() { } /** * @brief Incoming message handler * * @param message The message to handle. */ void receive(const MyMessage &message) { // We only expect one type of message from controller. But we better check anyway. // And echoed messages are not accepted as control messages if (message.getType()==V_LOCK_STATUS && message.getSensor()<=NOF_LOCKS && !message.isEcho()) { // Change relay state digitalWrite(message.getSensor()-1+LOCK_1, message.getBool()?LOCK_LOCK:LOCK_UNLOCK); // Store state in eeprom saveState(message.getSensor(), message.getBool()); // Write some debug info Serial.print("Incoming change for lock:"); Serial.print(message.getSensor()); Serial.print(", New status: "); Serial.println(message.getBool()); } } -
