  3. MQTT GW with RFM69 on RPi
25 Posts 4 Posters 2.3k Views 4 Watching
  • fritsF frits
    same results on EthernetGateway instead of MQTT Gateway: MCO:PRO only with signing, only on gateway
    @frits ah, now I see @TimO is also using singing!
    Found the smoking :gun: !
    • YveauxY Yveaux
      @TimO @frits could one of you build & run with MY_DEBUG_VERBOSE_SIGNING defined, and post the output?
      fritsF 1 Reply Last reply
      • YveauxY Yveaux
        fritsF
        fritsF
        frits
        @Yveaux I have a raspi gw with debug signatures ready:
        pi@zerogwtest:~/MySensors $ sudo ./mysgw.nrf24
        Dec 04 05:02:10 INFO  Starting gateway...
        Dec 04 05:02:10 INFO  Protocol version - 2.3.2
        Dec 04 05:02:10 DEBUG MCO:BGN:INIT GW,CP=RNNGLS--,FQ=NA,REL=255,VER=2.3.2
        Dec 04 05:02:10 DEBUG SGN:PER:OK
        Dec 04 05:02:10 DEBUG SGN:INI:BND OK
        Dec 04 05:02:10 DEBUG TSF:LRT:OK
        Dec 04 05:02:10 DEBUG TSM:INIT
        Dec 04 05:02:10 DEBUG TSF:WUR:MS=0
        Dec 04 05:02:10 DEBUG TSM:INIT:TSP OK
        Dec 04 05:02:10 DEBUG TSM:INIT:GW MODE
        Dec 04 05:02:10 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
        Dec 04 05:02:10 DEBUG MCO:REG:NOT NEEDED
        Dec 04 05:02:10 DEBUG MCO:BGN:STP
        MY_BAUD_RATE=(115200ul)
        MY_CONTROLLER_IP_ADDRESS=127.0.0.1
        MY_DEBUG=true
        MY_DEBUG_VERBOSE_SIGNING=true
        MY_GATEWAY_LINUX=true
        MY_GATEWAY_MQTT_CLIENT=true
        MY_MQTT_CLIENT_ID="mys-nrf-gw"
        MY_MQTT_PASSWORD=__null
        MY_MQTT_PUBLISH_TOPIC_PREFIX="mys-nrf-out"
        MY_MQTT_SUBSCRIBE_TOPIC_PREFIX="mys-nrf-in"
        MY_MQTT_USER=__null
        MY_LINUX_CONFIG_FILE="/etc/mysensors.conf"
        MY_NODE_ID=((255u))
        MY_PORT=1883
        MY_RADIO_RF24=true
        MY_RF24_CE_PIN=((22))
        MY_RF24_CHANNEL=(76)
        MY_RF24_CS_PIN=((SS))
        MY_RF24_PA_LEVEL=((2))
        MY_SIGNING_REQUEST_SIGNATURES=true
        MY_SIGNING_SOFT=true
        MY_VERIFICATION_TIMEOUT_MS=(5*1000ul)
        SPI_SPIDEV_DEVICE="/dev/spidev1.1"
        Dec 04 05:02:10 DEBUG MCO:BGN:INIT OK,TSP=1
        Dec 04 05:02:10 DEBUG GWT:RMQ:CONNECTING...
        Dec 04 05:02:10 DEBUG connected to 127.0.0.1
        Dec 04 05:02:10 DEBUG GWT:RMQ:OK
        Dec 04 05:02:10 DEBUG GWT:TPS:TOPIC=mys-nrf-out/0/255/0/0/18,MSG SENT
        Dec 04 05:02:10 DEBUG TSM:READY:NWD REQ
        Dec 04 05:02:10 DEBUG SGN:SGN:NREQ=255
        Dec 04 05:02:10 DEBUG ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        Dec 04 05:02:21 DEBUG TSF:MSG:READ,123-123-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Dec 04 05:02:21 DEBUG TSF:MSG:BC
        Dec 04 05:02:21 DEBUG TSF:MSG:FPAR REQ,ID=123
        Dec 04 05:02:21 DEBUG TSF:PNG:SEND,TO=0
        Dec 04 05:02:21 DEBUG TSF:CKU:OK
        Dec 04 05:02:21 DEBUG TSF:MSG:GWL OK
        Dec 04 05:02:21 DEBUG SGN:SKP:MSG CMD=3,TYPE=8
        Dec 04 05:02:21 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=24
        Dec 04 05:02:23 DEBUG TSF:MSG:PINGED,ID=123,HP=1
        Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=25
        Dec 04 05:02:23 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
        Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=15
        Dec 04 05:02:23 DEBUG SGN:PRE:SGN REQ,FROM=123
        Dec 04 05:02:23 DEBUG SGN:PRE:SGN REQ,TO=123
        Dec 04 05:02:23 DEBUG SGN:PRE:WHI NREQ,TO=123
        Dec 04 05:02:23 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
        Dec 04 05:02:23 DEBUG SGN:PRE:XMT,TO=123
        Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
        Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:23 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:23 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
        Dec 04 05:02:23 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=0,t=17,pt=0,l=5,sg=1:2.3.2
        Dec 04 05:02:23 DEBUG SGN:BND:NONCE=4B6126A21920FCBC12BE70183533C27C49AE3CD55094914800AAAAAAAAAAAAAA
        Dec 04 05:02:23 DEBUG SGN:BND:HMAC=ECDD094309264B891BBA3E2D142B2E08B79784B79A1816D53B26361EBABCF446
        Dec 04 05:02:23 DEBUG SGN:VER:OK
        Dec 04 05:02:23 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/255/0/0/17,MSG SENT
        Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:23 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:23 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
        Dec 04 05:02:23 DEBUG SGN:BND:NONCE=F07B9A2B93327E5130177F095042D6954B202A130B2A72B9E5AAAAAAAAAAAAAA
        Dec 04 05:02:23 DEBUG SGN:BND:HMAC=C34C02E0990FE19990C11FA97D9A55931AF2D99A5890186E877C3C1669FCBDA7
        Dec 04 05:02:23 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/255/3/0/6,MSG SENT
        Dec 04 05:02:25 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:25 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:25 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:25 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:25 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=11,pt=0,l=20,sg=1:Hello MySensors 328P
        Dec 04 05:02:26 DEBUG SGN:BND:NONCE=4A08E36D23F76E6A0940B8C980652ECF7C335F4144209DF1E1AAAAAAAAAAAAAA
        Dec 04 05:02:26 DEBUG SGN:BND:HMAC=001176474590821EE608440B7639881860DC1ECA9C17868B947D06756C71B105
        Dec 04 05:02:26 DEBUG SGN:VER:OK
        Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/255/3/0/11,MSG SENT
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:26 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:26 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:26 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:26 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.3
        Dec 04 05:02:26 DEBUG SGN:BND:NONCE=A542EE79921BC3744AD323286768428EE8D7FDED63887EC112AAAAAAAAAAAAAA
        Dec 04 05:02:26 DEBUG SGN:BND:HMAC=A4E56BED2C58CA5A332B7CC03EE08556550A804F8A0F042CDB58C012779276B6
        Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/255/3/0/12,MSG SENT
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=0,c=0,t=36,pt=0,l=6,sg=1:system
        Dec 04 05:02:26 DEBUG SGN:BND:NONCE=172B88ACF73CC49618472C3A3AA83FF5A6E0D8805211F8D965AAAAAAAAAAAAAA
        Dec 04 05:02:26 DEBUG SGN:BND:HMAC=5D6E3EE95F86B335218C5FC90CB11D4EC141301DA071AEBEA16F4D6FD5038CFE
        Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/0/0/0/36,MSG SENT
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=1,c=0,t=36,pt=0,l=9,sg=1:timestamp
        Dec 04 05:02:26 DEBUG SGN:BND:NONCE=A621A9A841141437693FA157CC6D115EB1EA732165F7FF1958AAAAAAAAAAAAAA
        Dec 04 05:02:26 DEBUG SGN:BND:HMAC=42CBC8BF5AEB45E21DE5FE86482F6A9CDF5349A6960E407844BF2E06509B80A6
        Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/0/0/36,MSG SENT
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=2,c=0,t=3,pt=0,l=3,sg=1:led
        Dec 04 05:02:26 DEBUG SGN:BND:NONCE=4B1909C8A7DBDABFAF157943AB0AAB1D322123A2B8177F2732AAAAAAAAAAAAAA
        Dec 04 05:02:26 DEBUG SGN:BND:HMAC=0F31776B1B67825DA94409AF8B220FE9BCB5E4BB9FB1CD618FBD086D51C4D598
        Dec 04 05:02:26 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/2/0/0/3,MSG SENT
        Dec 04 05:02:26 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
        Dec 04 05:02:26 DEBUG SGN:SKP:MSG CMD=3,TYPE=26
        Dec 04 05:02:26 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
        Dec 04 05:02:26 DEBUG SGN:SGN:NCE REQ,TO=123
        Dec 04 05:02:26 DEBUG !MCO:PRO:RC=1
        Dec 04 05:02:27 DEBUG !MCO:PRO:RC=1
        Dec 04 05:02:27 DEBUG TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
        Dec 04 05:02:27 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:27 DEBUG SGN:NCE:FROM=123
        Dec 04 05:02:27 DEBUG SGN:BND:NONCE=E38476176C1B713F454358240E2C6B5829BAD90CAFA6338EBDAAAAAAAAAAAAAA
        Dec 04 05:02:27 DEBUG SGN:BND:HMAC=4FEBFCAC5421A7C4DEDD52420E613A7FB2A90BB1E241EF432339ADDE659E4DE3
        Dec 04 05:02:27 DEBUG SGN:SGN:SGN
        Dec 04 05:02:27 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
        Dec 04 05:02:27 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:27 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:27 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:27 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:27 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 43943
        Dec 04 05:02:27 DEBUG SGN:BND:NONCE=2FE7F6139888428C3569C3CBFE107F05BC536100175C1EAAD7AAAAAAAAAAAAAA
        Dec 04 05:02:27 DEBUG SGN:BND:HMAC=B438045B3C7E2D079455F57A41E8E4B1843E1092ABA7C5FA7EF3F41EFC839553
        Dec 04 05:02:27 DEBUG SGN:VER:OK
        Dec 04 05:02:27 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
        Dec 04 05:02:29 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:29 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:29 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:29 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:29 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:29 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 46123
        Dec 04 05:02:29 DEBUG SGN:BND:NONCE=E1F6BDB4CA7CE0D4F22C87B5048315DF07DE183E8C8D63EA75AAAAAAAAAAAAAA
        Dec 04 05:02:29 DEBUG SGN:BND:HMAC=642100E6D0897056526EC99F89D789C0484DAAAD0AF2FD5060B66F3E8F32595A
        Dec 04 05:02:29 DEBUG SGN:VER:OK
        Dec 04 05:02:29 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
        Dec 04 05:02:31 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:31 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:31 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:31 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:31 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:31 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 48289
        Dec 04 05:02:31 DEBUG SGN:BND:NONCE=412EE0D22B09C2FE6E249A6C5003C0B43EE85404CBFD8EF401AAAAAAAAAAAAAA
        Dec 04 05:02:31 DEBUG SGN:BND:HMAC=B170CB1D43214203A4EDF0AFD7BB137C7D4104E715E1A2632E79E9768FE1CBDF
        Dec 04 05:02:31 DEBUG SGN:VER:OK
        Dec 04 05:02:31 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
        Dec 04 05:02:33 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:33 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:33 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:33 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:33 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:34 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 50462
        Dec 04 05:02:34 DEBUG SGN:BND:NONCE=83B523911127AC20C1DDFAFFD9A497A55A2A6796B500696B67AAAAAAAAAAAAAA
        Dec 04 05:02:34 DEBUG SGN:BND:HMAC=D9E09B4F4075AA96C5DAAF507A59D5C9654E704081CCFFFA954B09608DA1A2CA
        Dec 04 05:02:34 DEBUG SGN:VER:OK
        Dec 04 05:02:34 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
        Dec 04 05:02:36 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:36 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:36 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:36 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:36 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:36 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 52633
        Dec 04 05:02:36 DEBUG SGN:BND:NONCE=E8082AB2925ACA106C9678E6996D6E73CF02A1774AC79B2832AAAAAAAAAAAAAA
        Dec 04 05:02:36 DEBUG SGN:BND:HMAC=743DC22EDFC15ADB6050A2DD29E011D826F2F037F531A4D656837EB1DB2294F6
        Dec 04 05:02:36 DEBUG SGN:VER:OK
        Dec 04 05:02:36 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
        Dec 04 05:02:38 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:38 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:38 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:38 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:38 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:38 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 54804
        Dec 04 05:02:38 DEBUG SGN:BND:NONCE=E7C42737D780B3319EB7819458767BFDE334A2D51F920DA0C6AAAAAAAAAAAAAA
        Dec 04 05:02:38 DEBUG SGN:BND:HMAC=1C4DECD661E66CC435798821B45994D74791AEECD0672F5CF7D84614D5A889C0
        Dec 04 05:02:38 DEBUG SGN:VER:OK
        Dec 04 05:02:38 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
        Dec 04 05:02:40 DEBUG TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
        Dec 04 05:02:40 DEBUG SGN:SKP:MSG CMD=3,TYPE=16
        Dec 04 05:02:40 DEBUG SGN:SKP:MSG CMD=3,TYPE=17
        Dec 04 05:02:40 DEBUG TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
        Dec 04 05:02:40 DEBUG SGN:NCE:XMT,TO=0
        Dec 04 05:02:40 DEBUG TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 56973
        Dec 04 05:02:40 DEBUG SGN:BND:NONCE=9C249B35BC8ADDC86AC91ACDFE417520340D6E09DE5B21C965AAAAAAAAAAAAAA
        Dec 04 05:02:40 DEBUG SGN:BND:HMAC=D213FB0411871CE08611BF608FF2A490403C2A4CDAB73D38589FC5E16CD59DA3
        Dec 04 05:02:40 DEBUG SGN:VER:OK
        Dec 04 05:02:40 DEBUG GWT:TPS:TOPIC=mys-nrf-out/123/1/1/0/2,MSG SENT
        ^CDec 04 05:02:44 NOTICE Received SIGINT
        • fritsF
          fritsF
          frits
          @frits said in MQTT GW with RFM69 on RPi:
          here's the logging on arduino hardware (both gateway and node on arduino pro micro + nrf24).
          Summary:
          • MCO:PRO on gateway only
          • only after node boot
          • or message sent from gateway to node
          gw boot:
          0 MCO:BGN:INIT GW,CP=RNNGAA--,FQ=8,REL=255,VER=2.3.2
          16 SGN:PER:OK
          40 SGN:INI:BND OK
          43 TSM:INIT
          43 TSF:WUR:MS=0
          51 TSM:INIT:TSP OK
          53 TSM:INIT:GW MODE
          55 TSM:READY:ID=0,PAR=0,DIS=0
          57 MCO:REG:NOT NEEDED
          622 GWT:TPC:IP=192.168.99.13
          1626 MCO:BGN:STP
          2127 MCO:BGN:INIT OK,TSP=1
          2129 GWT:TPC:IP=192.168.99.13
          3133 GWT:RMQ:CONNECTING...
          3342 GWT:RMQ:OK
          3344 GWT:TPS:TOPIC=mysgw1-out/0/255/0/0/18,MSG SENT
          3352 TSM:READY:NWD REQ
          3354 SGN:SGN:NREQ=255
          3360 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
          node boot (gw log):
          40278 TSF:MSG:READ,123-123-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
          40284 TSF:MSG:BC
          40286 TSF:MSG:FPAR REQ,ID=123
          40290 TSF:PNG:SEND,TO=0
          40292 TSF:CKU:OK
          40294 TSF:MSG:GWL OK
          40656 SGN:SKP:MSG CMD=3,TYPE=8
          40660 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
          42303 TSF:MSG:READ,123-123-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
          42311 SGN:SKP:MSG CMD=3,TYPE=24
          42313 TSF:MSG:PINGED,ID=123,HP=1
          42317 SGN:SKP:MSG CMD=3,TYPE=25
          42323 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
          42350 TSF:MSG:READ,123-123-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
          42356 SGN:SKP:MSG CMD=3,TYPE=15
          42360 SGN:PRE:SGN REQ,FROM=123
          42364 SGN:PRE:SGN REQ,TO=123
          42366 SGN:PRE:WHI NREQ,TO=123
          42371 SGN:SKP:MSG CMD=3,TYPE=15
          42375 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
          42383 SGN:PRE:XMT,TO=123
          42393 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
          42399 SGN:SKP:MSG CMD=3,TYPE=16
          42475 SGN:SKP:MSG CMD=3,TYPE=17
          42481 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:<NONCE>
          42491 SGN:NCE:XMT,TO=0
          42653 TSF:MSG:READ,123-123-0,s=255,c=0,t=17,pt=0,l=5,sg=1:2.3.2
          42659 SGN:BND:NONCE=5D05EE8DE2E5DB1DF14E37C1927A97E1415B5A171E0A64E5DFAAAAAAAAAAAAAA
          42774 SGN:BND:HMAC=F03795009783A00B1CBA3AB0CABCCE11BA9F5F6050B407B3B50FAADE5B558925
          42782 SGN:VER:OK
          42786 GWT:TPS:TOPIC=mysgw1-out/123/255/0/0/17,MSG SENT
          42792 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
          42801 SGN:SKP:MSG CMD=3,TYPE=16
          42878 SGN:SKP:MSG CMD=3,TYPE=17
          42885 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          42893 SGN:NCE:XMT,TO=0
          43055 TSF:MSG:READ,123-123-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
          43061 SGN:BND:NONCE=6A5BC212192AAC2D25FDAFE2B626B8216A01D1FA44E1032D42AAAAAAAAAAAAAA
          43180 SGN:BND:HMAC=FFF58B3C02F477E9ACCF36614E05769E8952C76692035368A8A41604F6459073
          43188 SGN:VER:OK
          43190 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/6,MSG SENT
          45049 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
          45056 SGN:SKP:MSG CMD=3,TYPE=16
          45131 SGN:SKP:MSG CMD=3,TYPE=17
          45137 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          45148 SGN:NCE:XMT,TO=0
          45309 TSF:MSG:READ,123-123-0,s=255,c=3,t=11,pt=0,l=20,sg=1:Hello MySensors 328P
          45318 SGN:BND:NONCE=736CF35C52747BC27A10F246D0E5162640F4843111755C3A1CAAAAAAAAAAAAAA
          45432 SGN:BND:HMAC=2D5615BD24252A9F704CE90933F7B6ED89EB891ECCC0BF7EB6021CCFB3B6432D
          45441 SGN:VER:OK
          45445 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/11,MSG SENT
          45453 TSF:MSG:READ,123-123-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
          45459 SGN:SKP:MSG CMD=3,TYPE=16
          45537 SGN:SKP:MSG CMD=3,TYPE=17
          45543 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          45551 SGN:NCE:XMT,TO=0
          45713 TSF:MSG:READ,123-123-0,s=255,c=3,t=12,pt=0,l=3,sg=1:1.3
          45721 SGN:BND:NONCE=7394AB63F58F7181E65175A747357A73B72DA775ECD44D795BAAAAAAAAAAAAAA
          45836 SGN:BND:HMAC=7913D96974B91F551F698BBAB914AE79BC871569DF05977FF18A07836CFDDA2B
          45844 SGN:VER:OK
          45848 GWT:TPS:TOPIC=mysgw1-out/123/255/3/0/12,MSG SENT
          45854 TSF:MSG:READ,123-123-0,s=0,c=3,t=16,pt=0,l=0,sg=1:
          45860 SGN:SKP:MSG CMD=3,TYPE=16
          45942 SGN:SKP:MSG CMD=3,TYPE=17
          45948 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          45957 SGN:NCE:XMT,TO=0
          46118 TSF:MSG:READ,123-123-0,s=0,c=0,t=36,pt=0,l=6,sg=1:system
          46125 SGN:BND:NONCE=369A5D4D44C839C07EF2041459B7AF64B8322FC35570B09EE2AAAAAAAAAAAAAA
          46243 SGN:BND:HMAC=2E022D2A34A359DF46021E5A7D197B92ABBA56B1B6DB1D9FC2661FFBA8B031EE
          46252 SGN:VER:OK
          46254 GWT:TPS:TOPIC=mysgw1-out/123/0/0/0/36,MSG SENT
          46262 TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
          46268 SGN:SKP:MSG CMD=3,TYPE=16
          46344 SGN:SKP:MSG CMD=3,TYPE=17
          46350 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          46360 SGN:NCE:XMT,TO=0
          46522 TSF:MSG:READ,123-123-0,s=1,c=0,t=36,pt=0,l=9,sg=1:timestamp
          46528 SGN:BND:NONCE=16E88FB58D621C0047CD38142BDCA4303719F0F8D670C6BEA5AAAAAAAAAAAAAA
          46643 SGN:BND:HMAC=1AF56FBB3CF5C705B4C3E5210DE5CB912FF25F84F8152C51CA053A78ABEA63FC
          46653 SGN:VER:OK
          46655 GWT:TPS:TOPIC=mysgw1-out/123/1/0/0/36,MSG SENT
          46663 TSF:MSG:READ,123-123-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
          46669 SGN:SKP:MSG CMD=3,TYPE=16
          46747 SGN:SKP:MSG CMD=3,TYPE=17
          46753 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          46761 SGN:NCE:XMT,TO=0
          46923 TSF:MSG:READ,123-123-0,s=2,c=0,t=3,pt=0,l=3,sg=1:led
          46931 SGN:BND:NONCE=F63BD3325089CAC4DA5F679EA9E334D19E07FB52DFC54C7901AAAAAAAAAAAAAA
          47048 SGN:BND:HMAC=CAF49ED58A0F6D78FA8E2C99C24682D83558017E56F147619CFFD5F56C4CF40C
          47056 SGN:VER:OK
          47058 GWT:TPS:TOPIC=mysgw1-out/123/2/0/0/3,MSG SENT
          47067 TSF:MSG:READ,123-123-0,s=3,c=3,t=16,pt=0,l=0,sg=1:
          47073 SGN:SKP:MSG CMD=3,TYPE=16
          47149 SGN:SKP:MSG CMD=3,TYPE=17
          47155 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          47165 SGN:NCE:XMT,TO=0
          47325 TSF:MSG:READ,123-123-0,s=3,c=0,t=3,pt=0,l=6,sg=1:button
          47333 SGN:BND:NONCE=70E6B1C050BD5A8A2F03F3C345E801FE73237CF22F11196795AAAAAAAAAAAAAA
          47448 SGN:BND:HMAC=F5202D42D87CA81DC0D0E032F54189868EEB4FE462598C6AD8B3307A4A043F4D
          47456 SGN:VER:OK
          47460 GWT:TPS:TOPIC=mysgw1-out/123/3/0/0/3,MSG SENT
          47466 TSF:MSG:READ,123-123-0,s=255,c=3,t=26,pt=1,l=1,sg=1:2
          47474 SGN:SKP:MSG CMD=3,TYPE=26
          47476 SGN:SKP:MSG CMD=3,TYPE=16
          47482 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
          47491 SGN:SGN:NCE REQ,TO=123
          47493 !MCO:PRO:RC=1
          47495 !MCO:PRO:RC=1
          47499 !MCO:PRO:RC=1
          47501 !MCO:PRO:RC=1
          47503 !MCO:PRO:RC=1
          47505 !MCO:PRO:RC=1
          47509 !MCO:PRO:RC=1
          47511 !MCO:PRO:RC=1
          47513 !MCO:PRO:RC=1
          47515 !MCO:PRO:RC=1
          47519 !MCO:PRO:RC=1
          47521 !MCO:PRO:RC=1
          47523 !MCO:PRO:RC=1
          47525 !MCO:PRO:RC=1
          47529 !MCO:PRO:RC=1
          47532 !MCO:PRO:RC=1
          47534 !MCO:PRO:RC=1
          47536 !MCO:PRO:RC=1
          47540 !MCO:PRO:RC=1
          47542 !MCO:PRO:RC=1
          47544 !MCO:PRO:RC=1
          47546 !MCO:PRO:RC=1
          47548 !MCO:PRO:RC=1
          47552 !MCO:PRO:RC=1
          47554 !MCO:PRO:RC=1
          47556 !MCO:PRO:RC=1
          47558 !MCO:PRO:RC=1
          47562 !MCO:PRO:RC=1
          47564 !MCO:PRO:RC=1
          47566 !MCO:PRO:RC=1
          47568 !MCO:PRO:RC=1
          47572 !MCO:PRO:RC=1
          47575 !MCO:PRO:RC=1
          47577 !MCO:PRO:RC=1
          47579 !MCO:PRO:RC=1
          47583 !MCO:PRO:RC=1
          47585 !MCO:PRO:RC=1
          47587 !MCO:PRO:RC=1
          47589 !MCO:PRO:RC=1
          47593 !MCO:PRO:RC=1
          47595 !MCO:PRO:RC=1
          47597 !MCO:PRO:RC=1
          47599 !MCO:PRO:RC=1
          47603 !MCO:PRO:RC=1
          47605 !MCO:PRO:RC=1
          47607 !MCO:PRO:RC=1
          47609 !MCO:PRO:RC=1
          47613 TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
          47620 SGN:SKP:MSG CMD=3,TYPE=17
          47624 SGN:NCE:FROM=123
          47626 SGN:BND:NONCE=52C791A2F3FD084BB05D52CBA6079339BCBC85FC48E952A91DAAAAAAAAAAAAAA
          47747 SGN:BND:HMAC=3CCB39326B05220FEED535CC8304FE46A6544C69ED9C2D943725F8E38FA19C50
          47755 SGN:SGN:SGN
          47761 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=27,pt=1,l=1,sg=1,ft=0,st=OK:1
          47935 TSF:MSG:READ,123-123-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
          47943 SGN:SKP:MSG CMD=3,TYPE=16
          48023 SGN:SKP:MSG CMD=3,TYPE=17
          48029 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          48037 SGN:NCE:XMT,TO=0
          48199 TSF:MSG:READ,123-123-0,s=1,c=1,t=2,pt=0,l=11,sg=1:Hello 10031
          48207 SGN:BND:NONCE=399F6855334A59FF5A2B512738EF6B8C70BB2EE4A8FAD758E8AAAAAAAAAAAAAA
          48322 SGN:BND:HMAC=6CCD4905231C9F55C61B23922DAC166A8B20610B150F491FAA11E1C4B9FBB7D4
          48332 SGN:VER:OK
          48334 GWT:TPS:TOPIC=mysgw1-out/123/1/1/0/2,MSG SENT
          node send message (node log):
          58513 SGN:SKP:MSG CMD=3,TYPE=16
          58519 TSF:MSG:SEND,123-123-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
          58525 SGN:SGN:NCE REQ,TO=0
          58650 TSF:MSG:READ,0-0-123,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
          58656 SGN:SKP:MSG CMD=3,TYPE=17
          58660 SGN:NCE:FROM=0
          58662 SGN:BND:NONCE=B06B498BB6AED7756B7C19D7D3E677464FE8E6D1823E37A818AAAAAAAAAA
          AAAA
          58779 SGN:BND:HMAC=03123A4791D8BD0DB61B6C15604A847FA875D53790F9CAED906E57CF85C95
          571
          58789 SGN:SGN:SGN
          58793 TSF:MSG:SEND,123-123-0-0,s=3,c=1,t=2,pt=2,l=2,sg=1,ft=0,st=OK:1
          button pressed
          58814 SGN:SKP:MSG CMD=3,TYPE=16
          58820 TSF:MSG:SEND,123-123-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
          58826 SGN:SGN:NCE REQ,TO=0
          59095 TSF:MSG:READ,0-0-123,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
          59101 SGN:SKP:MSG CMD=3,TYPE=17
          59105 SGN:NCE:FROM=0
          59107 SGN:BND:NONCE=24228D2780F459C3469D1BDD01BAB9128D31C32B3FF806BA2DAAAAAAAAAA
          AAAA
          59222 SGN:BND:HMAC=FF9C0AD707200F63C0A93BABF019B137C3F1FD54AD224291F83C16BFC6644
          E8C
          59232 SGN:SGN:SGN
          59236 TSF:MSG:SEND,123-123-0-0,s=3,c=1,t=2,pt=2,l=2,sg=1,ft=0,st=OK:0
          button released
          node send message (gw log):
          96430 TSF:MSG:READ,123-123-0,s=3,c=3,t=16,pt=0,l=0,sg=1:
          96436 SGN:SKP:MSG CMD=3,TYPE=16
          96512 SGN:SKP:MSG CMD=3,TYPE=17
          96518 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          96528 SGN:NCE:XMT,TO=0
          96690 TSF:MSG:READ,123-123-0,s=3,c=1,t=2,pt=2,l=2,sg=1:1
          96696 SGN:BND:NONCE=B06B498BB6AED7756B7C19D7D3E677464FE8E6D1823E37A818AAAAAAAAAAAAAA
          96811 SGN:BND:HMAC=03123A4791D8BD0DB61B6C15604A847FA875D53790F9CAED906E57CF85C95571
          96821 SGN:VER:OK
          96823 GWT:TPS:TOPIC=mysgw1-out/123/3/1/0/2,MSG SENT
          96829 TSF:MSG:READ,123-123-0,s=3,c=3,t=16,pt=0,l=0,sg=1:
          96837 SGN:SKP:MSG CMD=3,TYPE=16
          96917 SGN:SKP:MSG CMD=3,TYPE=17
          96923 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
          96931 SGN:NCE:XMT,TO=0
          97093 TSF:MSG:READ,123-123-0,s=3,c=1,t=2,pt=2,l=2,sg=1:0
          97101 SGN:BND:NONCE=24228D2780F459C3469D1BDD01BAB9128D31C32B3FF806BA2DAAAAAAAAAAAAAA
          97216 SGN:BND:HMAC=FF9C0AD707200F63C0A93BABF019B137C3F1FD54AD224291F83C16BFC6644E8C
          97224 SGN:VER:OK
          97228 GWT:TPS:TOPIC=mysgw1-out/123/3/1/0/2,MSG SENT
          gw send message (gw log):
          206145 GWT:IMQ:TOPIC=mysgw1-in/123/2/1/0/2, MSG RECEIVED
          206151 SGN:SKP:MSG CMD=3,TYPE=16
          206157 TSF:MSG:SEND,0-0-123-123,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
          206166 SGN:SGN:NCE REQ,TO=123
          206168 !MCO:PRO:RC=1
          206172 !MCO:PRO:RC=1
          206174 !MCO:PRO:RC=1
          206176 !MCO:PRO:RC=1
          206180 !MCO:PRO:RC=1
          206182 !MCO:PRO:RC=1
          206184 !MCO:PRO:RC=1
          206186 !MCO:PRO:RC=1
          206190 !MCO:PRO:RC=1
          206192 !MCO:PRO:RC=1
          206194 !MCO:PRO:RC=1
          206198 !MCO:PRO:RC=1
          206200 !MCO:PRO:RC=1
          206202 !MCO:PRO:RC=1
          206206 !MCO:PRO:RC=1
          206209 !MCO:PRO:RC=1
          206211 !MCO:PRO:RC=1
          206215 !MCO:PRO:RC=1
          206217 !MCO:PRO:RC=1
          206219 !MCO:PRO:RC=1
          206223 !MCO:PRO:RC=1
          206225 !MCO:PRO:RC=1
          206227 !MCO:PRO:RC=1
          206231 !MCO:PRO:RC=1
          206233 !MCO:PRO:RC=1
          206235 !MCO:PRO:RC=1
          206239 !MCO:PRO:RC=1
          206241 !MCO:PRO:RC=1
          206243 !MCO:PRO:RC=1
          206247 !MCO:PRO:RC=1
          206249 !MCO:PRO:RC=1
          206252 !MCO:PRO:RC=1
          206256 !MCO:PRO:RC=1
          206258 !MCO:PRO:RC=1
          206260 !MCO:PRO:RC=1
          206262 !MCO:PRO:RC=1
          206266 !MCO:PRO:RC=1
          206268 !MCO:PRO:RC=1
          206272 TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
          206278 SGN:SKP:MSG CMD=3,TYPE=17
          206282 SGN:NCE:FROM=123
          206284 SGN:BND:NONCE=40E78847070231061F13FBD56014E185E1FC7651EDC52ABFD3AAAAAAAAAAAAAA
          206399 SGN:BND:HMAC=4A48E4CF691C24205050B2ECB0C4C9B5F0CB4A67D9E9A43A5FFA03A8F7288F1A
          206409 SGN:SGN:SGN
          206415 TSF:MSG:SEND,0-0-123-123,s=2,c=1,t=2,pt=0,l=1,sg=1,ft=0,st=OK:1
          gw send message (node log):
          168019 !SGN:BND:TMR
          168024 TSF:MSG:READ,0-0-123,s=2,c=3,t=16,pt=0,l=0,sg=1:
          168030 SGN:SKP:MSG CMD=3,TYPE=16
          168085 SGN:SKP:MSG CMD=3,TYPE=17
          168091 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=1,st=OK:<NONCE>
          168101 SGN:NCE:XMT,TO=123
          168263 TSF:MSG:READ,0-0-123,s=2,c=1,t=2,pt=0,l=1,sg=1:1
          168269 SGN:BND:NONCE=40E78847070231061F13FBD56014E185E1FC7651EDC52ABFD3AAAAAAAAA
          AAAAA
          168384 SGN:BND:HMAC=4A48E4CF691C24205050B2ECB0C4C9B5F0CB4A67D9E9A43A5FFA03A8F728
          8F1A
          168394 SGN:VER:OK
          received message for sensor 2, type 2, value 1
          switching LED on
          • T
            TimO
            I've disabled the signing feature and the !MCO:PRO:RC=1 issn't occuring anymore.
            • joaoabsJ
              joaoabsJ
              joaoabs
              Also happening in nodes:
               __  __       ____
                      |___/                      2.3.2
              16 MCO:BGN:INIT NODE,CP=RPNNAA-X,FQ=8,REL=255,VER=2.3.2
              40 SGN:PER:OK
              69 SGN:INI:BND OK
              71 TSM:INIT
              71 TSF:WUR:MS=0
              75 TSM:INIT:TSP OK
              77 TSM:INIT:STATID=33
              79 TSF:SID:OK,ID=33
              81 TSM:FPAR
              83 SGN:SGN:NREQ=255
              90 ?TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              212 TSF:MSG:READ,0-0-33,s=255,c=3,t=8,pt=1,l=1,sg=1:0
              219 SGN:SKP:MSG CMD=3,TYPE=8
              221 TSF:MSG:FPAR OK,ID=0,D=1
              2099 TSM:FPAR:OK
              2099 TSM:ID
              2101 TSM:ID:OK
              2103 TSM:UPL
              2105 SGN:SKP:MSG CMD=3,TYPE=24
              3133 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
              3811 TSF:MSG:READ,0-0-33,s=255,c=3,t=25,pt=1,l=1,sg=1:1
              3817 SGN:SKP:MSG CMD=3,TYPE=25
              3821 TSF:MSG:PONG RECV,HP=1
              3823 TSM:UPL:OK
              3825 TSM:READY:ID=33,PAR=0,DIS=1
              3829 SGN:PRE:SGN REQ
              3831 SGN:PRE:WHI NREQ
              3833 SGN:SKP:MSG CMD=3,TYPE=15
              3872 TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
              3880 SGN:PRE:XMT,TO=0
              3883 SGN:PRE:WAIT GW
              4837 TSF:MSG:READ,0-0-33,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
              4843 SGN:SKP:MSG CMD=3,TYPE=15
              4847 SGN:PRE:SGN REQ,FROM=0
              4851 SGN:SKP:MSG CMD=3,TYPE=16
              4925 TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
              4933 SGN:SGN:NCE REQ,TO=0
              6141 TSF:MSG:READ,0-0-33,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
              6148 SGN:SKP:MSG CMD=3,TYPE=17
              6152 SGN:NCE:FROM=0
              6154 SGN:BND:NONCE=F1D60B20DB00FF5950A64E8FFA7DEDE90956E7505DA37EF4DBAAAAAAAAAAAAAA
              6273 SGN:BND:HMAC=FC296959CE1E51BF6EB60BD781CF1C003FA4E32AF2160D0F813160CCBF1B7095
              6283 SGN:SGN:SGN
              6404 TSF:MSG:SEND,33-33-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.3.2
              6412 SGN:SKP:MSG CMD=3,TYPE=16
              7460 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
              7467 !SGN:SGN:NCE REQ,TO=0 FAIL
              7471 !TSF:MSG:SIGN FAIL
              8058 TSF:MSG:READ,0-0-33,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
              8065 SGN:SKP:MSG CMD=3,TYPE=17
              8069 SGN:NCE:FROM=0
              8071 SGN:BND:NONCE=DE60142AA1B91F73CB35274D2B050BB8B51D4578E9F32D75CBAAAAAAAAAAAAAA
              8189 SGN:BND:HMAC=AC6BCA42658012BFD9A118AC2F347756D6EB2B3BB5EDB9D6CEE5E5271A136ACB
              8513 TSF:MSG:READ,0-0-33,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
              8519 SGN:SKP:MSG CMD=3,TYPE=17
              8523 SGN:NCE:FROM=0
              8525 SGN:BND:NONCE=DE60142AA1B91F73CB35274D2B050BB8B51D4578E9F32D75CBAAAAAAAAAAAAAA
              8644 SGN:BND:HMAC=AC6BCA42658012BFD9A118AC2F347756D6EB2B3BB5EDB9D6CEE5E5271A136ACB
              9474 SGN:SKP:MSG CMD=3,TYPE=16
              10524 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=2,st=NACK:
              10530 !SGN:SGN:NCE REQ,TO=0 FAIL
              10534 !TSF:MSG:SIGN FAIL
              10536 SGN:SKP:MSG CMD=3,TYPE=16
              11587 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=4,st=NACK:
              11593 !SGN:SGN:NCE REQ,TO=0 FAIL
              11597 !TSF:MSG:SIGN FAIL
              11599 SGN:SKP:MSG CMD=3,TYPE=16
              12650 !TSF:MSG:SEND,33-33-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=6,st=NACK:
              12656 !SGN:SGN:NCE REQ,TO=0 FAIL
              12660 !TSF:MSG:SIGN FAIL
              12662 SGN:SKP:MSG CMD=3,TYPE=16
              13713 !TSF:MSG:SEND,33-33-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=8,st=NACK:
              13719 !SGN:SGN:NCE REQ,TO=0 FAIL
              13723 !TSF:MSG:SIGN FAIL
              13725 MCO:REG:REQ
              13727 SGN:SKP:MSG CMD=3,TYPE=26
              14467 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=10,st=NACK:2
              14475 !TSM:READY:UPL FAIL,SNP
              14477 TSM:FPAR
              14479 SGN:SGN:NREQ=255
              14487 ?TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=11,st=OK:
              15235 TSF:MSG:READ,0-0-33,s=255,c=3,t=16,pt=0,l=0,sg=1:
              15241 SGN:SKP:MSG CMD=3,TYPE=16
              15321 !TSF:SND:TNR
              15323 !SGN:NCE:XMT,TO=33 FAIL
              16476 !TSF:SND:TNR
              16496 !TSM:FPAR:NO REPLY
              16498 TSM:FPAR
              16500 SGN:SGN:NREQ=255
              16508 ?TSF:MSG:SEND,33-33-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
              16805 TSF:MSG:READ,0-0-33,s=255,c=3,t=8,pt=1,l=1,sg=1:0
              16812 SGN:SKP:MSG CMD=3,TYPE=8
              16816 TSF:MSG:FPAR OK,ID=0,D=1
              18479 !TSF:SND:TNR
              18518 TSM:FPAR:OK
              18520 TSM:ID
              18520 TSM:ID:OK
              18522 TSM:UPL
              18524 SGN:SKP:MSG CMD=3,TYPE=24
              19552 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
              20289 TSF:MSG:READ,0-0-33,s=255,c=3,t=25,pt=1,l=1,sg=1:1
              20295 SGN:SKP:MSG CMD=3,TYPE=25
              20297 TSF:MSG:PONG RECV,HP=1
              20301 TSM:UPL:OK
              20303 TSM:READY:ID=33,PAR=0,DIS=1
              20307 SGN:PRE:SGN REQ
              20310 SGN:PRE:WHI NREQ
              20312 SGN:SKP:MSG CMD=3,TYPE=15
              20416 TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
              20424 SGN:PRE:XMT,TO=0
              20426 SGN:PRE:WAIT GW
              20430 !MCO:WAI:RC=1
              20432 !MCO:PRO:RC=1
              20434 !MCO:PRO:RC=1
              20436 !MCO:PRO:RC=1
              20439 !MCO:PRO:RC=1
              20441 !MCO:PRO:RC=1
              20443 !MCO:PRO:RC=1
              20445 !MCO:PRO:RC=1
              20447 !MCO:PRO:RC=1
              20449 !MCO:PRO:RC=1
              20451 !MCO:PRO:RC=1
              20455 !MCO:PRO:RC=1
              20457 !MCO:PRO:RC=1
              20459 !MCO:PRO:RC=1
              20461 !MCO:PRO:RC=1
              20463 !MCO:PRO:RC=1
              20465 !MCO:PRO:RC=1
              20467 !MCO:PRO:RC=1
              20469 !MCO:PRO:RC=1
              20471 !MCO:PRO:RC=1
              20473 !MCO:PRO:RC=1
              20477 !MCO:PRO:RC=1
              20480 !MCO:PRO:RC=1
              20482 !MCO:PRO:RC=1
              20484 !MCO:PRO:RC=1
              20486 !MCO:PRO:RC=1
              20488 !MCO:PRO:RC=1
              20490 !MCO:PRO:RC=1
              20492 !MCO:PRO:RC=1
              20494 !MCO:PRO:RC=1
              20496 !MCO:PRO:RC=1
              20498 !MCO:PRO:RC=1
              20502 !MCO:PRO:RC=1
              20504 !MCO:PRO:RC=1
              20506 !MCO:PRO:RC=1
              20508 !MCO:PRO:RC=1
              20510 !MCO:PRO:RC=1
              20512 !MCO:PRO:RC=1
              20514 !MCO:PRO:RC=1
              20516 !MCO:PRO:RC=1
              20518 !MCO:PRO:RC=1
              20520 !MCO:PRO:RC=1
              20523 !MCO:PRO:RC=1
              20527 !MCO:PRO:RC=1
              20529 !MCO:PRO:RC=1
              20531 !MCO:PRO:RC=1
              20533 !MCO:PRO:RC=1
              20535 !MCO:PRO:RC=1
              20537 !MCO:PRO:RC=1
              20539 !MCO:PRO:RC=1
              20541 !MCO:PRO:RC=1
              20543 !MCO:PRO:RC=1
              20545 !MCO:PRO:RC=1
              20549 !MCO:PRO:RC=1
              20551 !MCO:PRO:RC=1
              20553 !MCO:PRO:RC=1
              20555 !MCO:PRO:RC=1
              20557 !MCO:PRO:RC=1
              20559 !MCO:PRO:RC=1
              20561 !MCO:PRO:RC=1
              20563 !MCO:PRO:RC=1
              20566 !MCO:PRO:RC=1
              20568 !MCO:PRO:RC=1
              20570 !MCO:PRO:RC=1
              20574 !MCO:PRO:RC=1
              20576 !MCO:PRO:RC=1
              20578 !MCO:PRO:RC=1
              20580 !MCO:PRO:RC=1
              20582 !MCO:PRO:RC=1
              20584 !MCO:PRO:RC=1
              20586 !MCO:PRO:RC=1
              20588 !MCO:PRO:RC=1
              20590 !MCO:PRO:RC=1
              20592 !MCO:PRO:RC=1
              20594 !MCO:PRO:RC=1
              20598 !MCO:PRO:RC=1
              20600 !MCO:PRO:RC=1
              20602 !MCO:PRO:RC=1
              20604 !MCO:PRO:RC=1
              20606 !MCO:PRO:RC=1
              20609 !MCO:PRO:RC=1
              20611 !MCO:PRO:RC=1
              20613 !MCO:PRO:RC=1
              20615 !MCO:PRO:RC=1
              20617 !MCO:PRO:RC=1
              20621 !MCO:PRO:RC=1
              20623 !MCO:PRO:RC=1
              20625 !MCO:PRO:RC=1
              20627 !MCO:PRO:RC=1
              20629 !MCO:PRO:RC=1
              20631 !MCO:PRO:RC=1
              20633 !MCO:PRO:RC=1
              20635 !MCO:PRO:RC=1
              20637 !MCO:PRO:RC=1
              20639 !MCO:PRO:RC=1
              20641 !MCO:PRO:RC=1
              20645 !MCO:PRO:RC=1
              20647 !MCO:PRO:RC=1
              20649 !MCO:PRO:RC=1
              20652 !MCO:PRO:RC=1
              20654 !MCO:PRO:RC=1
              20656 !MCO:PRO:RC=1
              20658 !MCO:PRO:RC=1
              20660 !MCO:PRO:RC=1
              20662 !MCO:PRO:RC=1
              20664 !MCO:PRO:RC=1
              20666 !MCO:PRO:RC=1
              20670 !MCO:PRO:RC=1
              20672 !MCO:PRO:RC=1
              20674 !MCO:PRO:RC=1
              20676 !MCO:PRO:RC=1
              20678 !MCO:PRO:RC=1
              20680 !MCO:PRO:RC=1
              20682 !MCO:PRO:RC=1
              20684 !MCO:PRO:RC=1
              20686 !MCO:PRO:RC=1
              20688 !MCO:PRO:RC=1
              20692 !MCO:PRO:RC=1
              20695 !MCO:PRO:RC=1
              20697 !MCO:PRO:RC=1
              20699 !MCO:PRO:RC=1
              20701 !MCO:PRO:RC=1
              20703 !MCO:PRO:RC=1
              20705 !MCO:PRO:RC=1
              20707 !MCO:PRO:RC=1
              20709 !MCO:PRO:RC=1
              20711 !MCO:PRO:RC=1
              20713 !MCO:PRO:RC=1
              20717 !MCO:PRO:RC=1
              20719 !MCO:PRO:RC=1
              20721 !MCO:PRO:RC=1
              20723 !MCO:PRO:RC=1
              20725 !MCO:PRO:RC=1
              20727 !MCO:PRO:RC=1
              20729 !MCO:PRO:RC=1
              20731 !MCO:PRO:RC=1
              20733 !MCO:PRO:RC=1
              20736 !MCO:PRO:RC=1
              20738 !MCO:PRO:RC=1
              20742 !MCO:PRO:RC=1
              20744 !MCO:PRO:RC=1
              20746 !MCO:PRO:RC=1
              20748 !MCO:PRO:RC=1
              20750 !MCO:PRO:RC=1
              20752 !MCO:PRO:RC=1
              20754 !MCO:PRO:RC=1
              20756 !MCO:PRO:RC=1
              20758 !MCO:PRO:RC=1
              20760 !MCO:PRO:RC=1
              20764 !MCO:PRO:RC=1
              20766 !MCO:PRO:RC=1
              20768 !MCO:PRO:RC=1
              20770 !MCO:PRO:RC=1
              20772 !MCO:PRO:RC=1
              20774 !MCO:PRO:RC=1
              20776 !MCO:PRO:RC=1
              20779 !MCO:PRO:RC=1
              20781 !MCO:PRO:RC=1
              20783 !MCO:PRO:RC=1
              20785 !MCO:PRO:RC=1
              20789 !MCO:PRO:RC=1
              20791 !MCO:PRO:RC=1
              20793 !MCO:PRO:RC=1
              20795 !MCO:PRO:RC=1
              20797 !MCO:PRO:RC=1
              20799 !MCO:PRO:RC=1
              20801 !MCO:PRO:RC=1
              20803 !MCO:PRO:RC=1
              20805 !MCO:PRO:RC=1
              20807 !MCO:PRO:RC=1
              20809 !MCO:PRO:RC=1
              20813 !MCO:PRO:RC=1
              20815 !MCO:PRO:RC=1
              20817 !MCO:PRO:RC=1
              20819 !MCO:PRO:RC=1
              20822 !MCO:PRO:RC=1
              20824 !MCO:PRO:RC=1
              20826 !MCO:PRO:RC=1
              20828 !MCO:PRO:RC=1
              20830 !MCO:PRO:RC=1
              20832 !MCO:PRO:RC=1
              20836 !MCO:PRO:RC=1
              20838 !MCO:PRO:RC=1
              20840 !MCO:PRO:RC=1
              20842 !MCO:PRO:RC=1
              20844 !MCO:PRO:RC=1
              20846 !MCO:PRO:RC=1
              20848 !MCO:PRO:RC=1
              20850 !MCO:PRO:RC=1
              20852 !MCO:PRO:RC=1
              20854 !MCO:PRO:RC=1
              20856 !MCO:PRO:RC=1
              20860 !MCO:PRO:RC=1
              20862 !MCO:PRO:RC=1
              20865 !MCO:PRO:RC=1
              20867 !MCO:PRO:RC=1
              20869 !MCO:PRO:RC=1
              20871 !MCO:PRO:RC=1
              20873 !MCO:PRO:RC=1
              20875 !MCO:PRO:RC=1
              20877 !MCO:PRO:RC=1
              20879 !MCO:PRO:RC=1
              20881 !MCO:PRO:RC=1
              20885 !MCO:PRO:RC=1
              20887 !MCO:PRO:RC=1
              20889 !MCO:PRO:RC=1
              20891 !MCO:PRO:RC=1
              20893 !MCO:PRO:RC=1
              20895 !MCO:PRO:RC=1
              20897 !MCO:PRO:RC=1
              20899 !MCO:PRO:RC=1
              20901 !MCO:PRO:RC=1
              20903 !MCO:PRO:RC=1
              20908 !MCO:PRO:RC=1
              20910 !MCO:PRO:RC=1
              20912 !MCO:PRO:RC=1
              20914 !MCO:PRO:RC=1
              20916 !MCO:PRO:RC=1
              20918 !MCO:PRO:RC=1
              20920 !MCO:PRO:RC=1
              20922 !MCO:PRO:RC=1
              20924 !MCO:PRO:RC=1
              20926 !MCO:PRO:RC=1
              20928 !MCO:PRO:RC=1
              20932 !MCO:PRO:RC=1
              20934 !MCO:PRO:RC=1
              20936 !MCO:PRO:RC=1
              20938 !MCO:PRO:RC=1
              20940 !MCO:PRO:RC=1
              20942 !MCO:PRO:RC=1
              20944 !MCO:PRO:RC=1
              20946 !MCO:PRO:RC=1
              20948 !MCO:PRO:RC=1
              20951 !MCO:PRO:RC=1
              20953 !MCO:PRO:RC=1
              20957 !MCO:PRO:RC=1
              20959 !MCO:PRO:RC=1
              20961 !MCO:PRO:RC=1
              20963 !MCO:PRO:RC=1
              20965 !MCO:PRO:RC=1
              20967 !MCO:PRO:RC=1
              20969 !MCO:PRO:RC=1
              20971 !MCO:PRO:RC=1
              20973 !MCO:PRO:RC=1
              20975 !MCO:PRO:RC=1
              20979 !MCO:PRO:RC=1
              20981 !MCO:PRO:RC=1
              20983 !MCO:PRO:RC=1
              20985 !MCO:PRO:RC=1
              20987 !MCO:PRO:RC=1
              20989 !MCO:PRO:RC=1
              20992 !MCO:PRO:RC=1
              20994 !MCO:PRO:RC=1
              20996 !MCO:PRO:RC=1
              20998 !MCO:PRO:RC=1
              21000 !MCO:PRO:RC=1
              21004 !MCO:PRO:RC=1
              21006 !MCO:PRO:RC=1
              21008 !MCO:PRO:RC=1
              21010 !MCO:PRO:RC=1
              21012 !MCO:PRO:RC=1
              21014 !MCO:PRO:RC=1
              21016 !MCO:PRO:RC=1
              21018 !MCO:PRO:RC=1
              21020 !MCO:PRO:RC=1
              21022 !MCO:PRO:RC=1
              21024 !MCO:PRO:RC=1
              21028 !MCO:PRO:RC=1
              21030 !MCO:PRO:RC=1
              21032 !MCO:PRO:RC=1
              21035 !MCO:PRO:RC=1
              21037 !MCO:PRO:RC=1
              21039 !MCO:PRO:RC=1
              21041 !MCO:PRO:RC=1
              21043 !MCO:PRO:RC=1
              21045 !MCO:PRO:RC=1
              21047 !MCO:PRO:RC=1
              21051 !MCO:PRO:RC=1
              21053 !MCO:PRO:RC=1
              21055 !MCO:PRO:RC=1
              21057 !MCO:PRO:RC=1
              21059 !MCO:PRO:RC=1
              21061 !MCO:PRO:RC=1
              21063 !MCO:PRO:RC=1
              21065 !MCO:PRO:RC=1
              21067 !MCO:PRO:RC=1
              21069 !MCO:PRO:RC=1
              21071 !MCO:PRO:RC=1
              21075 !MCO:PRO:RC=1
              21078 !MCO:PRO:RC=1
              21080 !MCO:PRO:RC=1
              21082 !MCO:PRO:RC=1
              21084 !MCO:PRO:RC=1
              21086 !MCO:PRO:RC=1
              21088 !MCO:PRO:RC=1
              21090 !MCO:PRO:RC=1
              21092 !MCO:PRO:RC=1
              21094 !MCO:PRO:RC=1
              21096 !MCO:PRO:RC=1
              21100 !MCO:PRO:RC=1
              21102 !MCO:PRO:RC=1
              21104 !MCO:PRO:RC=1
              21106 !MCO:PRO:RC=1
              21108 !MCO:PRO:RC=1
              21110 !MCO:PRO:RC=1
              21112 !MCO:PRO:RC=1
              21114 !MCO:PRO:RC=1
              21116 !MCO:PRO:RC=1
              21118 !MCO:PRO:RC=1
              21123 !MCO:PRO:RC=1
              21125 !MCO:PRO:RC=1
              21127 !MCO:PRO:RC=1
              21129 !MCO:PRO:RC=1
              21131 !MCO:PRO:RC=1
              21133 !MCO:PRO:RC=1
              21135 !MCO:PRO:RC=1
              21137 !MCO:PRO:RC=1
              21139 !MCO:PRO:RC=1
              21141 !MCO:PRO:RC=1
              21143 !MCO:PRO:RC=1
              21147 !MCO:PRO:RC=1
              21149 !MCO:PRO:RC=1
              21151 !MCO:PRO:RC=1
              21153 !SGN:BND:TMR
              21161 TSF:MSG:READ,0-0-33,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
              21168 SGN:SKP:MSG CMD=3,TYPE=15
              21170 SGN:PRE:SGN REQ,FROM=0
              21174 SGN:SKP:MSG CMD=3,TYPE=16
              22130 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
              22136 !SGN:SGN:NCE REQ,TO=0 FAIL
              22140 !TSF:MSG:SIGN FAIL
              22142 SGN:SKP:MSG CMD=3,TYPE=16
              23193 !TSF:MSG:SEND,33-33-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=2,st=NACK:
              23199 !SGN:SGN:NCE REQ,TO=0 FAIL
              23203 !TSF:MSG:SIGN FAIL
              23205 !MCO:WAI:RC=1
              23207 !MCO:PRO:RC=1
              23212 !MCO:PRO:RC=1
              23214 !MCO:PRO:RC=1
              23216 !MCO:PRO:RC=1
              23218 !MCO:PRO:RC=1
              23220 !MCO:PRO:RC=1
              23222 !MCO:PRO:RC=1
              23224 !MCO:PRO:RC=1
              23226 !MCO:PRO:RC=1
              23228 !MCO:PRO:RC=1
              23230 !MCO:PRO:RC=1
              23234 !MCO:PRO:RC=1
              23236 !MCO:PRO:RC=1
              23238 !MCO:PRO:RC=1
              23240 !MCO:PRO:RC=1
              23242 !MCO:PRO:RC=1
              23244 !MCO:PRO:RC=1
              23246 !MCO:PRO:RC=1
              23248 !MCO:PRO:RC=1
              23250 !MCO:PRO:RC=1
              23252 !MCO:PRO:RC=1
              23255 !MCO:PRO:RC=1
              23259 !MCO:PRO:RC=1
              23261 !MCO:PRO:RC=1
              23263 !MCO:PRO:RC=1
              23265 !MCO:PRO:RC=1
              23267 !MCO:PRO:RC=1
              23269 !MCO:PRO:RC=1
              23271 !MCO:PRO:RC=1
              23273 !MCO:PRO:RC=1
              23275 !MCO:PRO:RC=1
              23277 !MCO:PRO:RC=1
              23279 !MCO:PRO:RC=1
              23283 !MCO:PRO:RC=1
              23285 !MCO:PRO:RC=1
              23287 !MCO:PRO:RC=1
              23289 !MCO:PRO:RC=1
              23291 !MCO:PRO:RC=1
              23293 !MCO:PRO:RC=1
              23296 !MCO:PRO:RC=1
              23298 !MCO:PRO:RC=1
              23300 !MCO:PRO:RC=1
              23302 !MCO:PRO:RC=1
              23306 !MCO:PRO:RC=1
              23308 !MCO:PRO:RC=1
              23310 !MCO:PRO:RC=1
              23312 !MCO:PRO:RC=1
              23314 !MCO:PRO:RC=1
              23316 !MCO:PRO:RC=1
              23318 !MCO:PRO:RC=1
              23320 !MCO:PRO:RC=1
              23322 !MCO:PRO:RC=1
              23324 !MCO:PRO:RC=1
              23326 !MCO:PRO:RC=1
              23330 !MCO:PRO:RC=1
              23332 !MCO:PRO:RC=1
              23334 !MCO:PRO:RC=1
              23336 !MCO:PRO:RC=1
              23339 !MCO:PRO:RC=1
              23341 !MCO:PRO:RC=1
              23343 !MCO:PRO:RC=1
              23345 !MCO:PRO:RC=1
              23347 !MCO:PRO:RC=1
              23349 !MCO:PRO:RC=1
              23353 !MCO:PRO:RC=1
              23355 !MCO:PRO:RC=1
              23357 !MCO:PRO:RC=1
              23359 !MCO:PRO:RC=1
              23361 !MCO:PRO:RC=1
              23363 !MCO:PRO:RC=1
              23365 !MCO:PRO:RC=1
              23367 !MCO:PRO:RC=1
              23369 !MCO:PRO:RC=1
              23371 !MCO:PRO:RC=1
              23373 !MCO:PRO:RC=1
              23377 !MCO:PRO:RC=1
              23379 !MCO:PRO:RC=1
              23382 !MCO:PRO:RC=1
              23384 !MCO:PRO:RC=1
              23386 !MCO:PRO:RC=1
              23388 !MCO:PRO:RC=1
              23390 !MCO:PRO:RC=1
              23392 !MCO:PRO:RC=1
              23394 !MCO:PRO:RC=1
              23396 !MCO:PRO:RC=1
              23398 !MCO:PRO:RC=1
              23402 !MCO:PRO:RC=1
              23404 !MCO:PRO:RC=1
              23406 !MCO:PRO:RC=1
              23408 !MCO:PRO:RC=1
              23410 !MCO:PRO:RC=1
              23412 !MCO:PRO:RC=1
              23414 !MCO:PRO:RC=1
              23416 !MCO:PRO:RC=1
              23418 !MCO:PRO:RC=1
              23420 !MCO:PRO:RC=1
              23425 !MCO:PRO:RC=1
              23427 !MCO:PRO:RC=1
              23429 !MCO:PRO:RC=1
              23431 !MCO:PRO:RC=1
              23433 !MCO:PRO:RC=1
              23435 !MCO:PRO:RC=1
              23437 !MCO:PRO:RC=1
              23439 !MCO:PRO:RC=1
              23441 !MCO:PRO:RC=1
              23443 !MCO:PRO:RC=1
              23445 !MCO:PRO:RC=1
              23449 !MCO:PRO:RC=1
              23451 !MCO:PRO:RC=1
              23453 !MCO:PRO:RC=1
              23455 !MCO:PRO:RC=1
              23457 !MCO:PRO:RC=1
              23459 !MCO:PRO:RC=1
              23461 !MCO:PRO:RC=1
              23463 !MCO:PRO:RC=1
              23465 !MCO:PRO:RC=1
              23468 !MCO:PRO:RC=1
              23470 !MCO:PRO:RC=1
              23474 !MCO:PRO:RC=1
              23476 !MCO:PRO:RC=1
              23478 !MCO:PRO:RC=1
              23480 !MCO:PRO:RC=1
              23482 !MCO:PRO:RC=1
              23484 !MCO:PRO:RC=1
              23486 !MCO:PRO:RC=1
              23488 !MCO:PRO:RC=1
              23490 !MCO:PRO:RC=1
              23492 !MCO:PRO:RC=1
              23496 !MCO:PRO:RC=1
              23498 !MCO:PRO:RC=1
              23500 !MCO:PRO:RC=1
              23502 !MCO:PRO:RC=1
              23504 !MCO:PRO:RC=1
              23506 !MCO:PRO:RC=1
              23508 !MCO:PRO:RC=1
              23511 !MCO:PRO:RC=1
              23513 !MCO:PRO:RC=1
              23517 !MCO:PRO:RC=1
              23519 !MCO:PRO:RC=1
              23521 !MCO:PRO:RC=1
              23523 !MCO:PRO:RC=1
              23525 !MCO:PRO:RC=1
              23527 !MCO:PRO:RC=1
              23529 !MCO:PRO:RC=1
              23531 !MCO:PRO:RC=1
              23533 !MCO:PRO:RC=1
              23535 !MCO:PRO:RC=1
              23537 !MCO:PRO:RC=1
              23541 !MCO:PRO:RC=1
              23543 !MCO:PRO:RC=1
              23545 !MCO:PRO:RC=1
              23547 !MCO:PRO:RC=1
              23549 !MCO:PRO:RC=1
              23552 !MCO:PRO:RC=1
              23554 !MCO:PRO:RC=1
              23556 !MCO:PRO:RC=1
              23558 !MCO:PRO:RC=1
              23560 !MCO:PRO:RC=1
              23564 !MCO:PRO:RC=1
              23566 !MCO:PRO:RC=1
              23568 !MCO:PRO:RC=1
              23570 !MCO:PRO:RC=1
              23572 !MCO:PRO:RC=1
              23574 !MCO:PRO:RC=1
              23576 !MCO:PRO:RC=1
              23578 !MCO:PRO:RC=1
              23580 !MCO:PRO:RC=1
              23582 !MCO:PRO:RC=1
              23584 !MCO:PRO:RC=1
              23588 !MCO:PRO:RC=1
              23590 !MCO:PRO:RC=1
              23592 !MCO:PRO:RC=1
              23595 !MCO:PRO:RC=1
              23597 !MCO:PRO:RC=1
              23599 !MCO:PRO:RC=1
              23601 !MCO:PRO:RC=1
              23603 !MCO:PRO:RC=1
              23605 !MCO:PRO:RC=1
              23607 !MCO:PRO:RC=1
              23611 !MCO:PRO:RC=1
              23613 !MCO:PRO:RC=1
              23615 !MCO:PRO:RC=1
              23617 !MCO:PRO:RC=1
              23619 !MCO:PRO:RC=1
              23621 !MCO:PRO:RC=1
              23623 !MCO:PRO:RC=1
              23625 !MCO:PRO:RC=1
              23627 !MCO:PRO:RC=1
              23629 !MCO:PRO:RC=1
              23631 !MCO:PRO:RC=1
              23635 !MCO:PRO:RC=1
              23638 !MCO:PRO:RC=1
              23640 !MCO:PRO:RC=1
              23642 !MCO:PRO:RC=1
              23644 !MCO:PRO:RC=1
              23646 !MCO:PRO:RC=1
              23648 !MCO:PRO:RC=1
              23650 !MCO:PRO:RC=1
              23652 !MCO:PRO:RC=1
              23654 !MCO:PRO:RC=1
              23656 !MCO:PRO:RC=1
              23660 !MCO:PRO:RC=1
              23662 !MCO:PRO:RC=1
              23664 !MCO:PRO:RC=1
              23666 !MCO:PRO:RC=1
              23668 !MCO:PRO:RC=1
              23670 !MCO:PRO:RC=1
              23672 !MCO:PRO:RC=1
              23674 !MCO:PRO:RC=1
              23676 !MCO:PRO:RC=1
              23678 !MCO:PRO:RC=1
              23683 !MCO:PRO:RC=1
              23685 !MCO:PRO:RC=1
              23687 !MCO:PRO:RC=1
              23689 !MCO:PRO:RC=1
              23691 !MCO:PRO:RC=1
              23693 !MCO:PRO:RC=1
              23695 !MCO:PRO:RC=1
              23697 !MCO:PRO:RC=1
              23699 !MCO:PRO:RC=1
              23701 !MCO:PRO:RC=1
              23703 !MCO:PRO:RC=1
              23707 !MCO:PRO:RC=1
              23709 !MCO:PRO:RC=1
              23711 !MCO:PRO:RC=1
              23713 !MCO:PRO:RC=1
              23715 !MCO:PRO:RC=1
              23717 !MCO:PRO:RC=1
              23719 !MCO:PRO:RC=1
              23721 !MCO:PRO:RC=1
              23724 !MCO:PRO:RC=1
              23726 !MCO:PRO:RC=1
              23730 !MCO:PRO:RC=1
              23732 !MCO:PRO:RC=1
              23734 !MCO:PRO:RC=1
              23736 !MCO:PRO:RC=1
              23738 !MCO:PRO:RC=1
              23740 !MCO:PRO:RC=1
              23742 !MCO:PRO:RC=1
              23744 !MCO:PRO:RC=1
              23746 !MCO:PRO:RC=1
              23748 !MCO:PRO:RC=1
              23750 !MCO:PRO:RC=1
              23754 !MCO:PRO:RC=1
              • joaoabsJ joaoabs
                 __  __       ____
                        |___/                      2.3.2
                40 SGN:PER:OK
                69 SGN:INI:BND OK
                71 TSM:INIT
                71 TSF:WUR:MS=0
                75 TSM:INIT:TSP OK
                79 TSF:SID:OK,ID=33
                81 TSM:FPAR
                83 SGN:SGN:NREQ=255
                2099 TSM:FPAR:OK
                2099 TSM:ID
                2101 TSM:ID:OK
                2103 TSM:UPL
                3823 TSM:UPL:OK
                6152 SGN:NCE:FROM=0
                6283 SGN:SGN:SGN
                8069 SGN:NCE:FROM=0
                8523 SGN:NCE:FROM=0
                13725 MCO:REG:REQ
                14477 TSM:FPAR
                15321 !TSF:SND:TNR
                16476 !TSF:SND:TNR
                16498 TSM:FPAR
                18479 !TSF:SND:TNR
                18518 TSM:FPAR:OK
                18520 TSM:ID
                18520 TSM:ID:OK
                18522 TSM:UPL
                20301 TSM:UPL:OK
                20430 !MCO:WAI:RC=1
                20432 !MCO:PRO:RC=1
                20434 !MCO:PRO:RC=1
                20436 !MCO:PRO:RC=1
                20439 !MCO:PRO:RC=1
                20441 !MCO:PRO:RC=1
                20443 !MCO:PRO:RC=1
                20445 !MCO:PRO:RC=1
                20447 !MCO:PRO:RC=1
                20449 !MCO:PRO:RC=1
                20451 !MCO:PRO:RC=1
                20455 !MCO:PRO:RC=1
                20457 !MCO:PRO:RC=1
                20459 !MCO:PRO:RC=1
                20461 !MCO:PRO:RC=1
                20463 !MCO:PRO:RC=1
                20465 !MCO:PRO:RC=1
                20467 !MCO:PRO:RC=1
                20469 !MCO:PRO:RC=1
                20471 !MCO:PRO:RC=1
                20473 !MCO:PRO:RC=1
                20477 !MCO:PRO:RC=1
                20480 !MCO:PRO:RC=1
                20482 !MCO:PRO:RC=1
                20484 !MCO:PRO:RC=1
                20486 !MCO:PRO:RC=1
                20488 !MCO:PRO:RC=1
                20490 !MCO:PRO:RC=1
                20492 !MCO:PRO:RC=1
                20494 !MCO:PRO:RC=1
                20496 !MCO:PRO:RC=1
                20498 !MCO:PRO:RC=1
                20502 !MCO:PRO:RC=1
                20504 !MCO:PRO:RC=1
                20506 !MCO:PRO:RC=1
                20508 !MCO:PRO:RC=1
                20510 !MCO:PRO:RC=1
                20512 !MCO:PRO:RC=1
                20514 !MCO:PRO:RC=1
                20516 !MCO:PRO:RC=1
                20518 !MCO:PRO:RC=1
                20520 !MCO:PRO:RC=1
                20523 !MCO:PRO:RC=1
                20527 !MCO:PRO:RC=1
                20529 !MCO:PRO:RC=1
                20531 !MCO:PRO:RC=1
                20533 !MCO:PRO:RC=1
                20535 !MCO:PRO:RC=1
                20537 !MCO:PRO:RC=1
                20539 !MCO:PRO:RC=1
                20541 !MCO:PRO:RC=1
                20543 !MCO:PRO:RC=1
                20545 !MCO:PRO:RC=1
                20549 !MCO:PRO:RC=1
                20551 !MCO:PRO:RC=1
                20553 !MCO:PRO:RC=1
                20555 !MCO:PRO:RC=1
                20557 !MCO:PRO:RC=1
                20559 !MCO:PRO:RC=1
                20561 !MCO:PRO:RC=1
                20563 !MCO:PRO:RC=1
                20566 !MCO:PRO:RC=1
                20568 !MCO:PRO:RC=1
                20570 !MCO:PRO:RC=1
                20574 !MCO:PRO:RC=1
                20576 !MCO:PRO:RC=1
                20578 !MCO:PRO:RC=1
                20580 !MCO:PRO:RC=1
                20582 !MCO:PRO:RC=1
                20584 !MCO:PRO:RC=1
                20586 !MCO:PRO:RC=1
                20588 !MCO:PRO:RC=1
                20590 !MCO:PRO:RC=1
                20592 !MCO:PRO:RC=1
                20594 !MCO:PRO:RC=1
                20598 !MCO:PRO:RC=1
                20600 !MCO:PRO:RC=1
                20602 !MCO:PRO:RC=1
                20604 !MCO:PRO:RC=1
                20606 !MCO:PRO:RC=1
                20609 !MCO:PRO:RC=1
                20611 !MCO:PRO:RC=1
                20613 !MCO:PRO:RC=1
                20615 !MCO:PRO:RC=1
                20617 !MCO:PRO:RC=1
                20621 !MCO:PRO:RC=1
                20623 !MCO:PRO:RC=1
                20625 !MCO:PRO:RC=1
                20627 !MCO:PRO:RC=1
                20629 !MCO:PRO:RC=1
                20631 !MCO:PRO:RC=1
                20633 !MCO:PRO:RC=1
                20635 !MCO:PRO:RC=1
                20637 !MCO:PRO:RC=1
                20639 !MCO:PRO:RC=1
                20641 !MCO:PRO:RC=1
                20645 !MCO:PRO:RC=1
                20647 !MCO:PRO:RC=1
                20649 !MCO:PRO:RC=1
                20652 !MCO:PRO:RC=1
                20654 !MCO:PRO:RC=1
                20656 !MCO:PRO:RC=1
                20658 !MCO:PRO:RC=1
                20660 !MCO:PRO:RC=1
                20662 !MCO:PRO:RC=1
                20664 !MCO:PRO:RC=1
                20666 !MCO:PRO:RC=1
                20670 !MCO:PRO:RC=1
                20672 !MCO:PRO:RC=1
                20674 !MCO:PRO:RC=1
                20676 !MCO:PRO:RC=1
                20678 !MCO:PRO:RC=1
                20680 !MCO:PRO:RC=1
                20682 !MCO:PRO:RC=1
                20684 !MCO:PRO:RC=1
                20686 !MCO:PRO:RC=1
                20688 !MCO:PRO:RC=1
                20692 !MCO:PRO:RC=1
                20695 !MCO:PRO:RC=1
                20697 !MCO:PRO:RC=1
                20699 !MCO:PRO:RC=1
                20701 !MCO:PRO:RC=1
                20703 !MCO:PRO:RC=1
                20705 !MCO:PRO:RC=1
                20707 !MCO:PRO:RC=1
                20709 !MCO:PRO:RC=1
                20711 !MCO:PRO:RC=1
                20713 !MCO:PRO:RC=1
                20717 !MCO:PRO:RC=1
                20719 !MCO:PRO:RC=1
                20721 !MCO:PRO:RC=1
                20723 !MCO:PRO:RC=1
                20725 !MCO:PRO:RC=1
                20727 !MCO:PRO:RC=1
                20729 !MCO:PRO:RC=1
                20731 !MCO:PRO:RC=1
                20733 !MCO:PRO:RC=1
                20736 !MCO:PRO:RC=1
                20738 !MCO:PRO:RC=1
                20742 !MCO:PRO:RC=1
                20744 !MCO:PRO:RC=1
                20746 !MCO:PRO:RC=1
                20748 !MCO:PRO:RC=1
                20750 !MCO:PRO:RC=1
                20752 !MCO:PRO:RC=1
                20754 !MCO:PRO:RC=1
                20756 !MCO:PRO:RC=1
                20758 !MCO:PRO:RC=1
                20760 !MCO:PRO:RC=1
                20764 !MCO:PRO:RC=1
                20766 !MCO:PRO:RC=1
                20768 !MCO:PRO:RC=1
                20770 !MCO:PRO:RC=1
                20772 !MCO:PRO:RC=1
                20774 !MCO:PRO:RC=1
                20776 !MCO:PRO:RC=1
                20779 !MCO:PRO:RC=1
                20781 !MCO:PRO:RC=1
                20783 !MCO:PRO:RC=1
                20785 !MCO:PRO:RC=1
                20789 !MCO:PRO:RC=1
                20791 !MCO:PRO:RC=1
                20793 !MCO:PRO:RC=1
                20795 !MCO:PRO:RC=1
                20797 !MCO:PRO:RC=1
                20799 !MCO:PRO:RC=1
                20801 !MCO:PRO:RC=1
                20803 !MCO:PRO:RC=1
                20805 !MCO:PRO:RC=1
                20807 !MCO:PRO:RC=1
                20809 !MCO:PRO:RC=1
                20813 !MCO:PRO:RC=1
                20815 !MCO:PRO:RC=1
                20817 !MCO:PRO:RC=1
                20819 !MCO:PRO:RC=1
                20822 !MCO:PRO:RC=1
                20824 !MCO:PRO:RC=1
                20826 !MCO:PRO:RC=1
                20828 !MCO:PRO:RC=1
                20830 !MCO:PRO:RC=1
                20832 !MCO:PRO:RC=1
                20836 !MCO:PRO:RC=1
                20838 !MCO:PRO:RC=1
                20840 !MCO:PRO:RC=1
                20842 !MCO:PRO:RC=1
                20844 !MCO:PRO:RC=1
                20846 !MCO:PRO:RC=1
                20848 !MCO:PRO:RC=1
                20850 !MCO:PRO:RC=1
                20852 !MCO:PRO:RC=1
                20854 !MCO:PRO:RC=1
                20856 !MCO:PRO:RC=1
                20860 !MCO:PRO:RC=1
                20862 !MCO:PRO:RC=1
                20865 !MCO:PRO:RC=1
                20867 !MCO:PRO:RC=1
                20869 !MCO:PRO:RC=1
                20871 !MCO:PRO:RC=1
                20873 !MCO:PRO:RC=1
                20875 !MCO:PRO:RC=1
                20877 !MCO:PRO:RC=1
                20879 !MCO:PRO:RC=1
                20881 !MCO:PRO:RC=1
                20885 !MCO:PRO:RC=1
                20887 !MCO:PRO:RC=1
                20889 !MCO:PRO:RC=1
                20891 !MCO:PRO:RC=1
                20893 !MCO:PRO:RC=1
                20895 !MCO:PRO:RC=1
                20897 !MCO:PRO:RC=1
                20899 !MCO:PRO:RC=1
                20901 !MCO:PRO:RC=1
                20903 !MCO:PRO:RC=1
                20908 !MCO:PRO:RC=1
                20910 !MCO:PRO:RC=1
                20912 !MCO:PRO:RC=1
                20914 !MCO:PRO:RC=1
                20916 !MCO:PRO:RC=1
                20918 !MCO:PRO:RC=1
                20920 !MCO:PRO:RC=1
                20922 !MCO:PRO:RC=1
                20924 !MCO:PRO:RC=1
                20926 !MCO:PRO:RC=1
                20928 !MCO:PRO:RC=1
                20932 !MCO:PRO:RC=1
                20934 !MCO:PRO:RC=1
                20936 !MCO:PRO:RC=1
                20938 !MCO:PRO:RC=1
                20940 !MCO:PRO:RC=1
                20942 !MCO:PRO:RC=1
                20944 !MCO:PRO:RC=1
                20946 !MCO:PRO:RC=1
                20948 !MCO:PRO:RC=1
                20951 !MCO:PRO:RC=1
                20953 !MCO:PRO:RC=1
                20957 !MCO:PRO:RC=1
                20959 !MCO:PRO:RC=1
                20961 !MCO:PRO:RC=1
                20963 !MCO:PRO:RC=1
                20965 !MCO:PRO:RC=1
                20967 !MCO:PRO:RC=1
                20969 !MCO:PRO:RC=1
                20971 !MCO:PRO:RC=1
                20973 !MCO:PRO:RC=1
                20975 !MCO:PRO:RC=1
                20979 !MCO:PRO:RC=1
                20981 !MCO:PRO:RC=1
                20983 !MCO:PRO:RC=1
                20985 !MCO:PRO:RC=1
                20987 !MCO:PRO:RC=1
                20989 !MCO:PRO:RC=1
                20992 !MCO:PRO:RC=1
                20994 !MCO:PRO:RC=1
                20996 !MCO:PRO:RC=1
                20998 !MCO:PRO:RC=1
                21000 !MCO:PRO:RC=1
                21004 !MCO:PRO:RC=1
                21006 !MCO:PRO:RC=1
                21008 !MCO:PRO:RC=1
                21010 !MCO:PRO:RC=1
                21012 !MCO:PRO:RC=1
                21014 !MCO:PRO:RC=1
                21016 !MCO:PRO:RC=1
                21018 !MCO:PRO:RC=1
                21020 !MCO:PRO:RC=1
                21022 !MCO:PRO:RC=1
                21024 !MCO:PRO:RC=1
                21028 !MCO:PRO:RC=1
                21030 !MCO:PRO:RC=1
                21032 !MCO:PRO:RC=1
                21035 !MCO:PRO:RC=1
                21037 !MCO:PRO:RC=1
                21039 !MCO:PRO:RC=1
                21041 !MCO:PRO:RC=1
                21043 !MCO:PRO:RC=1
                21045 !MCO:PRO:RC=1
                21047 !MCO:PRO:RC=1
                21051 !MCO:PRO:RC=1
                21053 !MCO:PRO:RC=1
                21055 !MCO:PRO:RC=1
                21057 !MCO:PRO:RC=1
                21059 !MCO:PRO:RC=1
                21061 !MCO:PRO:RC=1
                21063 !MCO:PRO:RC=1
                21065 !MCO:PRO:RC=1
                21067 !MCO:PRO:RC=1
                21069 !MCO:PRO:RC=1
                21071 !MCO:PRO:RC=1
                21075 !MCO:PRO:RC=1
                21078 !MCO:PRO:RC=1
                21080 !MCO:PRO:RC=1
                21082 !MCO:PRO:RC=1
                21084 !MCO:PRO:RC=1
                21086 !MCO:PRO:RC=1
                21088 !MCO:PRO:RC=1
                21090 !MCO:PRO:RC=1
                21092 !MCO:PRO:RC=1
                21094 !MCO:PRO:RC=1
                21096 !MCO:PRO:RC=1
                21100 !MCO:PRO:RC=1
                21102 !MCO:PRO:RC=1
                21104 !MCO:PRO:RC=1
                21106 !MCO:PRO:RC=1
                21108 !MCO:PRO:RC=1
                21110 !MCO:PRO:RC=1
                21112 !MCO:PRO:RC=1
                21114 !MCO:PRO:RC=1
                21116 !MCO:PRO:RC=1
                21118 !MCO:PRO:RC=1
                21123 !MCO:PRO:RC=1
                21125 !MCO:PRO:RC=1
                21127 !MCO:PRO:RC=1
                21129 !MCO:PRO:RC=1
                21131 !MCO:PRO:RC=1
                21133 !MCO:PRO:RC=1
                21135 !MCO:PRO:RC=1
                21137 !MCO:PRO:RC=1
                21139 !MCO:PRO:RC=1
                21141 !MCO:PRO:RC=1
                21143 !MCO:PRO:RC=1
                21147 !MCO:PRO:RC=1
                21149 !MCO:PRO:RC=1
                21151 !MCO:PRO:RC=1
                21153 !SGN:BND:TMR
                23205 !MCO:WAI:RC=1
                23207 !MCO:PRO:RC=1
                23212 !MCO:PRO:RC=1
                23214 !MCO:PRO:RC=1
                23216 !MCO:PRO:RC=1
                23218 !MCO:PRO:RC=1
                23220 !MCO:PRO:RC=1
                23222 !MCO:PRO:RC=1
                23224 !MCO:PRO:RC=1
                23226 !MCO:PRO:RC=1
                23228 !MCO:PRO:RC=1
                23230 !MCO:PRO:RC=1
                23234 !MCO:PRO:RC=1
                23236 !MCO:PRO:RC=1
                23238 !MCO:PRO:RC=1
                23240 !MCO:PRO:RC=1
                23242 !MCO:PRO:RC=1
                23244 !MCO:PRO:RC=1
                23246 !MCO:PRO:RC=1
                23248 !MCO:PRO:RC=1
                23250 !MCO:PRO:RC=1
                23252 !MCO:PRO:RC=1
                23255 !MCO:PRO:RC=1
                23259 !MCO:PRO:RC=1
                23261 !MCO:PRO:RC=1
                23263 !MCO:PRO:RC=1
                23265 !MCO:PRO:RC=1
                23267 !MCO:PRO:RC=1
                23269 !MCO:PRO:RC=1
                23271 !MCO:PRO:RC=1
                23273 !MCO:PRO:RC=1
                23275 !MCO:PRO:RC=1
                23277 !MCO:PRO:RC=1
                23279 !MCO:PRO:RC=1
                23283 !MCO:PRO:RC=1
                23285 !MCO:PRO:RC=1
                23287 !MCO:PRO:RC=1
                23289 !MCO:PRO:RC=1
                23291 !MCO:PRO:RC=1
                23293 !MCO:PRO:RC=1
                23296 !MCO:PRO:RC=1
                23298 !MCO:PRO:RC=1
                23300 !MCO:PRO:RC=1
                23302 !MCO:PRO:RC=1
                23306 !MCO:PRO:RC=1
                23308 !MCO:PRO:RC=1
                23310 !MCO:PRO:RC=1
                23312 !MCO:PRO:RC=1
                23314 !MCO:PRO:RC=1
                23316 !MCO:PRO:RC=1
                23318 !MCO:PRO:RC=1
                23320 !MCO:PRO:RC=1
                23322 !MCO:PRO:RC=1
                23324 !MCO:PRO:RC=1
                23326 !MCO:PRO:RC=1
                23330 !MCO:PRO:RC=1
                23332 !MCO:PRO:RC=1
                23334 !MCO:PRO:RC=1
                23336 !MCO:PRO:RC=1
                23339 !MCO:PRO:RC=1
                23341 !MCO:PRO:RC=1
                23343 !MCO:PRO:RC=1
                23345 !MCO:PRO:RC=1
                23347 !MCO:PRO:RC=1
                23349 !MCO:PRO:RC=1
                23353 !MCO:PRO:RC=1
                23355 !MCO:PRO:RC=1
                23357 !MCO:PRO:RC=1
                23359 !MCO:PRO:RC=1
                23361 !MCO:PRO:RC=1
                23363 !MCO:PRO:RC=1
                23365 !MCO:PRO:RC=1
                23367 !MCO:PRO:RC=1
                23369 !MCO:PRO:RC=1
                23371 !MCO:PRO:RC=1
                23373 !MCO:PRO:RC=1
                23377 !MCO:PRO:RC=1
                23379 !MCO:PRO:RC=1
                23382 !MCO:PRO:RC=1
                23384 !MCO:PRO:RC=1
                23386 !MCO:PRO:RC=1
                23388 !MCO:PRO:RC=1
                23390 !MCO:PRO:RC=1
                23392 !MCO:PRO:RC=1
                23394 !MCO:PRO:RC=1
                23396 !MCO:PRO:RC=1
                23398 !MCO:PRO:RC=1
                23402 !MCO:PRO:RC=1
                23404 !MCO:PRO:RC=1
                23406 !MCO:PRO:RC=1
                23408 !MCO:PRO:RC=1
                23410 !MCO:PRO:RC=1
                23412 !MCO:PRO:RC=1
                23414 !MCO:PRO:RC=1
                23416 !MCO:PRO:RC=1
                23418 !MCO:PRO:RC=1
                23420 !MCO:PRO:RC=1
                23425 !MCO:PRO:RC=1
                23427 !MCO:PRO:RC=1
                23429 !MCO:PRO:RC=1
                23431 !MCO:PRO:RC=1
                23433 !MCO:PRO:RC=1
                23435 !MCO:PRO:RC=1
                23437 !MCO:PRO:RC=1
                23439 !MCO:PRO:RC=1
                23441 !MCO:PRO:RC=1
                23443 !MCO:PRO:RC=1
                23445 !MCO:PRO:RC=1
                23449 !MCO:PRO:RC=1
                23451 !MCO:PRO:RC=1
                23453 !MCO:PRO:RC=1
                23455 !MCO:PRO:RC=1
                23457 !MCO:PRO:RC=1
                23459 !MCO:PRO:RC=1
                23461 !MCO:PRO:RC=1
                23463 !MCO:PRO:RC=1
                23465 !MCO:PRO:RC=1
                23468 !MCO:PRO:RC=1
                23470 !MCO:PRO:RC=1
                23474 !MCO:PRO:RC=1
                23476 !MCO:PRO:RC=1
                23478 !MCO:PRO:RC=1
                23480 !MCO:PRO:RC=1
                23482 !MCO:PRO:RC=1
                23484 !MCO:PRO:RC=1
                23486 !MCO:PRO:RC=1
                23488 !MCO:PRO:RC=1
                23490 !MCO:PRO:RC=1
                23492 !MCO:PRO:RC=1
                23496 !MCO:PRO:RC=1
                23498 !MCO:PRO:RC=1
                23500 !MCO:PRO:RC=1
                23502 !MCO:PRO:RC=1
                23504 !MCO:PRO:RC=1
                23506 !MCO:PRO:RC=1
                23508 !MCO:PRO:RC=1
                23511 !MCO:PRO:RC=1
                23513 !MCO:PRO:RC=1
                23517 !MCO:PRO:RC=1
                23519 !MCO:PRO:RC=1
                23521 !MCO:PRO:RC=1
                23523 !MCO:PRO:RC=1
                23525 !MCO:PRO:RC=1
                23527 !MCO:PRO:RC=1
                23529 !MCO:PRO:RC=1
                23531 !MCO:PRO:RC=1
                23533 !MCO:PRO:RC=1
                23535 !MCO:PRO:RC=1
                23537 !MCO:PRO:RC=1
                23541 !MCO:PRO:RC=1
                23543 !MCO:PRO:RC=1
                23545 !MCO:PRO:RC=1
                23547 !MCO:PRO:RC=1
                23549 !MCO:PRO:RC=1
                23552 !MCO:PRO:RC=1
                23554 !MCO:PRO:RC=1
                23556 !MCO:PRO:RC=1
                23558 !MCO:PRO:RC=1
                23560 !MCO:PRO:RC=1
                23564 !MCO:PRO:RC=1
                23566 !MCO:PRO:RC=1
                23568 !MCO:PRO:RC=1
                23570 !MCO:PRO:RC=1
                23572 !MCO:PRO:RC=1
                23574 !MCO:PRO:RC=1
                23576 !MCO:PRO:RC=1
                23578 !MCO:PRO:RC=1
                23580 !MCO:PRO:RC=1
                23582 !MCO:PRO:RC=1
                23584 !MCO:PRO:RC=1
                23588 !MCO:PRO:RC=1
                23590 !MCO:PRO:RC=1
                23592 !MCO:PRO:RC=1
                23595 !MCO:PRO:RC=1
                23597 !MCO:PRO:RC=1
                23599 !MCO:PRO:RC=1
                23601 !MCO:PRO:RC=1
                23603 !MCO:PRO:RC=1
                23605 !MCO:PRO:RC=1
                23607 !MCO:PRO:RC=1
                23611 !MCO:PRO:RC=1
                23613 !MCO:PRO:RC=1
                23615 !MCO:PRO:RC=1
                23617 !MCO:PRO:RC=1
                23619 !MCO:PRO:RC=1
                23621 !MCO:PRO:RC=1
                23623 !MCO:PRO:RC=1
                23625 !MCO:PRO:RC=1
                23627 !MCO:PRO:RC=1
                23629 !MCO:PRO:RC=1
                23631 !MCO:PRO:RC=1
                23635 !MCO:PRO:RC=1
                23638 !MCO:PRO:RC=1
                23640 !MCO:PRO:RC=1
                23642 !MCO:PRO:RC=1
                23644 !MCO:PRO:RC=1
                23646 !MCO:PRO:RC=1
                23648 !MCO:PRO:RC=1
                23650 !MCO:PRO:RC=1
                23652 !MCO:PRO:RC=1
                23654 !MCO:PRO:RC=1
                23656 !MCO:PRO:RC=1
                23660 !MCO:PRO:RC=1
                23662 !MCO:PRO:RC=1
                23664 !MCO:PRO:RC=1
                23666 !MCO:PRO:RC=1
                23668 !MCO:PRO:RC=1
                23670 !MCO:PRO:RC=1
                23672 !MCO:PRO:RC=1
                23674 !MCO:PRO:RC=1
                23676 !MCO:PRO:RC=1
                23678 !MCO:PRO:RC=1
                23683 !MCO:PRO:RC=1
                23685 !MCO:PRO:RC=1
                23687 !MCO:PRO:RC=1
                23689 !MCO:PRO:RC=1
                23691 !MCO:PRO:RC=1
                23693 !MCO:PRO:RC=1
                23695 !MCO:PRO:RC=1
                23697 !MCO:PRO:RC=1
                23699 !MCO:PRO:RC=1
                23701 !MCO:PRO:RC=1
                23703 !MCO:PRO:RC=1
                23707 !MCO:PRO:RC=1
                23709 !MCO:PRO:RC=1
                23711 !MCO:PRO:RC=1
                23713 !MCO:PRO:RC=1
                23715 !MCO:PRO:RC=1
                23717 !MCO:PRO:RC=1
                23719 !MCO:PRO:RC=1
                23721 !MCO:PRO:RC=1
                23724 !MCO:PRO:RC=1
                23726 !MCO:PRO:RC=1
                23730 !MCO:PRO:RC=1
                23732 !MCO:PRO:RC=1
                23734 !MCO:PRO:RC=1
                23736 !MCO:PRO:RC=1
                23738 !MCO:PRO:RC=1
                23740 !MCO:PRO:RC=1
                23742 !MCO:PRO:RC=1
                23744 !MCO:PRO:RC=1
                23746 !MCO:PRO:RC=1
                23748 !MCO:PRO:RC=1
                23750 !MCO:PRO:RC=1
                23754 !MCO:PRO:RC=1
                I found the root cause: https://github.com/mysensors/MySensors/issues/1458#issuecomment-739139339
                It is part of the signing code, so expected to occur on all nodes/gateways that request nonces for signing.
                Currently discussing if it is a real issue or not.
                T joaoabsJ 2 Replies Last reply
                • YveauxY Yveaux
                  TimO
                  @Yveaux thank you for digging in!
                  • fritsF
                    fritsF
                    frits
                    @joaoabs said in MQTT GW with RFM69 on RPi:
                    are you setting #define MY_TRANSPORT_WAIT_READY_MS ([timeout])? This causes MCO:PRO in my test cases as well.
                    joaoabsJ 1 Reply Last reply
                    • fritsF frits
                      joaoabsJ
                      joaoabsJ
                      joaoabs
                      wrote on last edited by joaoabs
                      #23
                      @frits
                      Don't think so, unless it is set by default.
                      The code corresponding to the log:
                       * Copyright (C) 2013-2019 Sensnology AB
                       * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
                       * @ingroup MySigninggrp
                       * @file SecureActuator.ino
                       * @brief Example sketch showing how to securely control locks.
                       * This example will remember lock state even after power failure.
                       *  - See git log (git log libraries/MySensors/examples/SecureActuator/SecureActuator.ino)
                       * @example SecureActuator.ino
                       * This example implements a secure actuator in the form of a IO controlled electrical lock.<br>
                       * Multiple locks are supported as long as they are on subsequent IO pin indices. The first lock pin
                       * is defined by @ref LOCK_1. The number of locks is controlled by @ref NOF_LOCKS .<br>
                       * The sketch will require incoming messages to be signed and the use of signing backend is selected
                       * by @ref MY_SIGNING_ATSHA204 or @ref MY_SIGNING_SOFT. Hard or soft ATSHA204 signing is supported.<br>
                       * Whitelisting can be enabled through @ref MY_SIGNING_NODE_WHITELISTING in which case a single entry
                       * is provided in this example which typically should map to the gateway of the network.
                      #define MY_DEBUG //!< Enable debug prints to serial monitor
                      //#define MY_NODE_LOCK_FEATURE //!< Enable lockdown of node if suspicious activity is detected
                      // RADIO STUFF
                      #define MY_RADIO_RFM69 //!< RFM69 radio driver
                      #define MY_RFM69_NEW_DRIVER
                      #define MY_RFM69_FREQUENCY RFM69_433MHZ
                      //#define MY_IS_RFM69HW
                      #define MY_RFM69_ENABLE_ENCRYPTION
                      // SIGNING STUFF
                      // Select soft/hardware signing method
                      //#define MY_SIGNING_SOFT //!< Software signing
                      #define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
                      // Enable node whitelisting
                      #define MY_SIGNING_REQUEST_SIGNATURES //!< destination node signs all messages sent to this node
                      //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7 //!< Unconnected analog pin for random seed
                      // SETTINGS FOR MY_SIGNING_ATSHA204
                      #define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached
                      #define MY_DEBUG_VERBOSE_SIGNING //!< Enable signing related debug prints to serial monitor
                      #define MY_NODE_ID 33
                      #define LOCK_1  3     //!< Arduino Digital I/O pin number for first lock (second on pin+1 etc)
                      #define NOF_LOCKS 2   //!< Total number of attached locks
                      #define LOCK_LOCK 1   //!< GPIO value to write to lock attached lock
                      #define LOCK_UNLOCK 0 //!< GPIO value to write to unlock attached lock
                      	for (int lock=1, pin=LOCK_1; lock<=NOF_LOCKS; lock++, pin++) {
                      		// Set lock pins in output mode
                      		pinMode(pin, OUTPUT);
                      		// Set lock to last known state (using eeprom storage)
                      		digitalWrite(pin, loadState(lock)?LOCK_LOCK:LOCK_UNLOCK);
                      	sendSketchInfo("Secure Lock", "1.0");
                      	// Fetch lock status
                      		// Register all locks to gw (they will be created as child devices)
                      		present(lock, S_LOCK, "SecureActuator", false);
                      /** @brief Sketch execution code */
                       * @brief Incoming message handler
                       * @param message The message to handle.
                      	// And echoed messages are not accepted as control messages
                      	if (message.getType()==V_LOCK_STATUS && message.getSensor()<=NOF_LOCKS && !message.isEcho()) {
                      		// Change relay state
                      		digitalWrite(message.getSensor()-1+LOCK_1, message.getBool()?LOCK_LOCK:LOCK_UNLOCK);
                      		// Store state in eeprom
                      		saveState(message.getSensor(), message.getBool());
                      		Serial.print("Incoming change for lock:");
                      		Serial.print(message.getSensor());
                      • YveauxY Yveaux
                        joaoabsJ
                        joaoabsJ
                        joaoabs
                        @Yveaux Hello, Any update if this is an issue or just a cosmetic log thing? Cheers
                        • joaoabsJ joaoabs
                          @joaoabs no, sorry. I didn't investigate any deeper.
