  3. Temperature serial sketch
13 Posts 6 Posters 1.5k Views 5 Watching
  • Olaf JacobsO
    Olaf JacobsO
    Olaf Jacobs
    Hi all,
    I'm not sure where to start this, Ill give a quick simple description of my setup.
    I have an pi4 running with domoticz as thermostat primarily.
    First I had 4x DS18B20 temperature sensors hooked up to gpio4 on the pi without the resistor, this worked fine for some time till this gave some issues, I figured out quickly what went wrong here, so I hooked those sensors up to an arduino mega 2560. After some playing around and not getting the results in to domoticz like i would like to I was pointed to MySensors and use the serial sketch, I added some lines from an DS18B20 sketch in there and uploaded this.. straight away this worked awesome!
    Till last night where it all came to an hold, the temperature data was not updating any more to domoticz and this just kept going. resulting in a kitchen floor of about 60°c
    My question, can someone check for me if the scetch I'm running is any good or does it have any flaws? I'm totally not in to programming and I'm just getting slowly in to this.
    My sketch:
    // Enable RS485 transport layer
    #define MY_RS485
    // Define this to enables DE-pin management on defined pin
    #define MY_RS485_DE_PIN 7
    // Set RS485 baud rate to use
    #define MY_RS485_BAUD_RATE 9600
    // Enable this if RS485 is connected to a hardware serial port
    //#define MY_RS485_HWSERIAL Serial1
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  5  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  6  // the PCB, on board LED
    #include <OneWire.h>
    #define ONE_WIRE_BUS 2 // Pin where dallase sensor is connected
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
    void presentation() {
      sendSketchInfo("Temp Sensor", "1");
         present(i, S_TEMP);
      //sleep(conversionTime);
      wait(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
    Thanks in advance Olaf,
    YveauxY K 2 Replies Last reply
    • Olaf JacobsO Olaf Jacobs
      Hi all,
      My sketch:
      #define MY_RS485
      int numSensors=0;
      bool metric = true;
      void before()
        sensors.begin();
           present(i, S_TEMP);
          #else
      YveauxY
      YveauxY
      @Olaf-Jacobs you seem to configure the gateway for rs485 transport, but I understand you don't have nodes at all, only the gateway. It's this correct?
      You also loop over all possible sensors in the main loop, not the actual mount detected. Not sure if that's OK...
      • Olaf JacobsO
        Olaf JacobsO
        Olaf Jacobs
        @Yveaux
        Correct I have no nodes in use, I only use this to get the data in to domoticz (what seems to work a bit)
        For looping trough sensors, I have no clou. To be honest I just get the Mysensor bit from the arduino examples and found some DS18B20 sketch and tried to combine this in to an single working sketch, as soon as i had no compiling errors I uploaded it and see that I had some working sensors added to my Domoticz.
        YveauxY G 2 Replies Last reply
          @Yveaux
          YveauxY
          YveauxY
          @Olaf-Jacobs I cleaned your sketch a little, and changed the DS18B20 code to more or less reflect the way I read these sensors in some of my nodes:
          #include <Arduino.h>
          int numSensors = 0;
          int16_t conversion_wait_time_ms;
            sendSketchInfo(F("Temp Sensor"), F("1"));
            sensors.begin();
            numSensors = min(sensors.getDeviceCount(), MAX_ATTACHED_DS18B20);
            sensors.setCheckForConversion(false);
            conversion_wait_time_ms = sensors.millisToWaitForConversion( sensors.getResolution() );
            for (int i=0; i<numSensors; i++) {
               present(i, S_TEMP);
            // sleep until conversion completed
            wait(conversion_wait_time_ms);
              if (lastTemperature[i] != temperature)
                if ((temperature > -127.) and (temperature < 85.))
          Main changes:
          • Removed the RS485 transport and any stuff you don't use/need (inclusion mode, leds, unused variables)
          • Removed before, as all initialization can be done in presentation()
          • Added setCheckForConversion() as my sketches do so too
          • Store the conversion time in a variable as it won't change at runtime. This silences the bus communication during conversion.
          • Removed the check for maximum sensors from the loops (I missed the check for numSensors in my first comment) and also calculate it only once, as these will also not change at runtime.
          • Cleaned the COMPARE_TEMP a bit and added a range check on min/max temperatures -- checking for exact floating point values is tricky, so better just check if they are in range
          Disclaimer: It compiles, but I didn't check it for correct functioning.
          All in all I didn't see any obvious reasons for a freeze in your sketch.
          If it runs ok for a while and then freezes, there could be other issues like power supply or faulty sensors.
          Capture the gateway output over time to see what happened just before the freeze.
          In any case you should always protect against missing or wrong updates!
          • Olaf JacobsO
            Olaf JacobsO
            Olaf Jacobs
            @Yveaux
            Wow I didn't expect this haha but thanks a lot. Ill give this a try and give some feedback as soon as I have some steady results.
            Dank u.
            Regards Olaf.
            • Olaf JacobsO
              Olaf JacobsO
              Olaf Jacobs
              Quick update,
              within 24hr the system already stopped it self, in my domoticz log is no error about this. If I read the arduino it shows me nothing in the serial.
              I just restart the whole system and all is back online working just like nothing happend, I did had an close look at all four sensors but all for seems to be working fine till the arduino freezes up.
              Is there a way of having an debug log?
              Cheers/thanks
                @Yveaux
                G
                G
                Grubstake
                @Olaf-Jacobs I've run DS18B20s and learned that with "1-wire" the wiring details and are important unless wire runs are short. Also, parasitic mode (2 wires only) is less stable than using three wires. The type of wire, capacitance of the cable run, interference from nearby electrical, especially high voltage AC, and the topology (with star topology being the worst). I have no idea if this could be an issue for you, but if you want to test it you could try testing with the same number of sensors with very short runs and see if that improves the instability you are seeing.
                  Quick update,
                  Cheers/thanks
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @Olaf-Jacobs DS18B20s are usually reliable, but seconded on the comment from @Grubstake regarding cable type and topography for reliability, although generally if working at the start it should continue uninterrupted.
                  To illustrate the point, all of mine are connected to a Node rather than a Gateway on a single line of Cat5e for the house, and a short length of phone wire for two on the boiler. A random weird reading on all the house sensors (not simultaneously) turned up when I'd extended the last sensor on the Cat5E with a length of phone wire until I got some more Cat5E. Uniform cable characteristics seem important.
                  You might also check the Arduino version and libraries being used, have seen strange things happen with mismatched libraries etc..
                    Hi all,
                    My sketch:
                    #define MY_RS485
                    int numSensors=0;
                    bool metric = true;
                    void before()
                      sensors.begin();
                         present(i, S_TEMP);
                        #else
                    K
                    K
                    kimot
                    @Olaf-Jacobs said in Temperature serial sketch:
                    Can you write what issues.
                    Why you connect DS18B20s to RPi without resistor ?
                    Is it some experiment?
                    • Olaf JacobsO
                      Olaf JacobsO
                      Olaf Jacobs
                      wrote on last edited by Olaf Jacobs
                      Hi all,
                      First of all I wish all an happy and healthy new year!
                      @Grubstake @zboblamont sensors hooked up only one is extended with 1,5mtr of cat5 cable. This seems to be working fine, although this is probably also the sensor that gives issues. The temperature it's measuring i from an woodstove in the kitchen and I'm not constantly using this stove and the temperature is pretty much stationary @20° so I think the system times out on this sensor because there are hardly any changes.
                      Sins the last failure what I reported here also the system is running fine/perfect without any interrupts, I do had my Pi4 freeze up couldn't do any else then rebooting the system.
                      But to make it some how workable for me I have the Pi system switching between the thermostat I'm using in Domoticz, when this goes in to any failure mode it goes in to pause and the good old honeywel is backing up the system just a couple degrees set below te regular set-point. Due to be living alone here in the middle of nowhere and working sometimes several days from home I have installed an secondary Pi in the network so I can always remotely access the system and cut the power off and reboot that way.
                      But fingers crossed the arduino with the four sensors is working top!
                      @kimot
                      No this was done by mistake, :face_palm: I have an replacment Pi ready to go but as long as the system is working fine I don't want to touch it.
                        Hi all,
                        @kimot
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @Olaf-Jacobs Good.
                        I did read short spurs CAN work and the waterproof versions are on pre-made cables, but not sure of the limit.
                        If you hit occasional problems it may be worth trying cross wiring the Cat5e to maintain a series connection and see if that fixes it, that's what I did to stitch in an intermediate sensor and it worked fine.
                        Good luck.
                        • skywatchS
                          skywatchS
                          skywatch
                          Pull up resistors might help if not already in place. Also fake ds18b20's have been found being sold so maybe get a good one from a reliable source and try again if more problems occur.
                          Olaf JacobsO 1 Reply Last reply
                          • skywatchS skywatch
                            Olaf JacobsO
                            Olaf JacobsO
                            Olaf Jacobs
                            @skywatch
                            I do have the resistor in place now, like mentioned it works and still works.:+1:
