  3. Possible securiy breach in ESPS.
12 Posts 5 Posters 1.9k Views 5 Watching
  • TheoLT
    TheoLT
    TheoL
    Not sure if you guys watch or follow Kevin Darrah on YouTube but he found a way to clone the flash of the ESP, including wifi settings.
    How To Read from ESP32 - CLONE/BACKUP Everything
    He promised to post a follow up, with how to decrypt your flash.
    • alexeliteA
      alexeliteA
      alexelite
      I do not think it is a security breach, because ESP32 has AES256 encryption for flash data, if enabled.
      https://docs.espressif.com/projects/esp-idf/en/latest/esp32/security/flash-encryption.html
      AnticimexA 1 Reply Last reply
      • alexeliteA alexelite
        AnticimexA
        AnticimexA
        Anticimex
        @alexelite they do not, however, state exactly which variant of AES they use. If they do not generate an initialization vector and are not using some block chaining variant, AES is quite weak.
        Jacky JoyJ skywatchS TheoLT 3 Replies Last reply
        • AnticimexA Anticimex
          Jacky JoyJ
          Jacky JoyJ
          Jacky Joy
          @Anticimex said in Possible securiy breach in ESPS.:
          thanks my issue has been fixed.
            skywatchS
            skywatchS
            skywatch
            @Anticimex
            AES is quite weak.
            Probably why the NSA/CIA/FBI etc all recommended it! ;)
              TheoLT
              TheoLT
              TheoL
              @Anticimex Don't think they use have encryption. It's just not powerful enough for that
              • TheoLT TheoL
                AnticimexA
                AnticimexA
                Anticimex
                @TheoL AES is not complicated to implement in hardware and the docs suggest they have it but the technical detail is low.
                • skywatchS skywatch
                  @Anticimex
                  AES is quite weak.
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @skywatch are you implying they recommend AES without an IV or block chaining enhancement? I don't think so ;)
                  skywatchS 1 Reply Last reply
                    skywatchS
                    skywatchS
                    skywatch
                    @Anticimex No, I am saying that they already had a way to get AES data so that is why rhey promoted it for use generally. They are always way ahead of what we are allowed to have!
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @skywatch that depend on the key size you choose, and how you deploy the implementation (like block chaining and random initialization).
                      Symmetric ciphers are even quite secure in the quantum world given large enough key sizes.
                        skywatchS
                        skywatchS
                        skywatch
                        @Anticimex Surely in a quantum environment a key size is irrelevant?
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @skywatch not really, depending on the algorithm
