  3. Possible securiy breach in ESPS.
12 Posts 5 Posters 1.4k Views 5 Watching
  • T Offline
    T Offline
    TheoL
    Not sure if you guys watch or follow Kevin Darrah on YouTube but he found a way to clone the flash of the ESP, including wifi settings.
    How To Read from ESP32 - CLONE/BACKUP Everything
    He promised to post a follow up, with how to decrypt your flash.
    • alexeliteA Offline
      alexeliteA Offline
      alexelite
      I do not think it is a security breach, because ESP32 has AES256 encryption for flash data, if enabled.
      https://docs.espressif.com/projects/esp-idf/en/latest/esp32/security/flash-encryption.html
      A 1 Reply Last reply
      • alexeliteA alexelite
        A Offline
        A Offline
        Anticimex
        @alexelite they do not, however, state exactly which variant of AES they use. If they do not generate an initialization vector and are not using some block chaining variant, AES is quite weak.
        Jacky JoyJ skywatchS T 3 Replies Last reply
        • A Anticimex
          Jacky JoyJ Offline
          Jacky JoyJ Offline
          Jacky Joy
          @Anticimex said in Possible securiy breach in ESPS.:
          thanks my issue has been fixed.
          • A Anticimex
            skywatchS Offline
            skywatchS Offline
            skywatch
            @Anticimex
            AES is quite weak.
            Probably why the NSA/CIA/FBI etc all recommended it! ;)
            • A Anticimex
              T Offline
              T Offline
              TheoL
              @Anticimex Don't think they use have encryption. It's just not powerful enough for that
              • T TheoL
                A Offline
                A Offline
                Anticimex
                @TheoL AES is not complicated to implement in hardware and the docs suggest they have it but the technical detail is low.
                • skywatchS skywatch
                  @Anticimex
                  AES is quite weak.
                  A Offline
                  A Offline
                  Anticimex
                  @skywatch are you implying they recommend AES without an IV or block chaining enhancement? I don't think so ;)
                  skywatchS 1 Reply Last reply
                  • A Anticimex
                    skywatchS Offline
                    skywatchS Offline
                    skywatch
                    @Anticimex No, I am saying that they already had a way to get AES data so that is why rhey promoted it for use generally. They are always way ahead of what we are allowed to have!
                      A Offline
                      A Offline
                      Anticimex
                      @skywatch that depend on the key size you choose, and how you deploy the implementation (like block chaining and random initialization).
                      Symmetric ciphers are even quite secure in the quantum world given large enough key sizes.
                      • A Anticimex
                        skywatchS Offline
                        skywatchS Offline
                        skywatch
                        @Anticimex Surely in a quantum environment a key size is irrelevant?
                          A Offline
                          A Offline
                          Anticimex
                          @skywatch not really, depending on the algorithm
                          12.0k
