  2. Feature Requests
  3. Increase VAR limit
Increase VAR limit
3 Posts 3 Posters 1.1k Views 3 Watching
  • N
    N
    NielBierman
    I've got a soil moisture probe that has 8 sensors for soil moisture and 8 for temperature. The current VAR only allows for VAR1-5. Is there a reason that this limit can not be increased to say VAR1-15? (Some soil moisture probes has up to 15 sensors)
    alexeliteA skywatchS 2 Replies Last reply
    • N NielBierman
      alexeliteA
      alexeliteA
      alexelite
      @NielBierman, the library provides 254 sensors definitions, and for each you can use types VAR1-5, that means 1270 distinct values.
      If you have 8 soil moisture and 8 temp you should define a sensor for every pair.
      Sensor 0 : VAR1 and TEMP
      Sensor 8 : VAR1 and TEMP
      • N NielBierman
        skywatchS
        skywatchS
        skywatch
        @NielBierman Why are you using VARs when there are already moisture and temperature categories available to you?
        Just give each temp and moisture sensor a unique CHILD_ID (simply by adding 1-8 in the name) and you are done!
