  3. RelayWithButtonActuator Example(solved)
2 Posts 1 Posters 1.3k Views 1 Watching
  • Gutz2001G
    Gutz2001G
    Gutz2001
    wrote on last edited by Gutz2001
    I'm trying to do the simple RelayWithbuttonActuator from this homepage that Works with an MQTT gateway, I've got it working 1/10 times, by using the default code from here(the RelayWithButtonActuator Example): http://www.mysensors.org/build/relay
    When i push the button, i see the TX light on the arduino light up for a split second, and then nothing happens, the relay does not switch, then i fiddle with the button 5-10 times, then it finaly switches.
    So i checked the log from the com port, and this is what the Arduino outputs:
    send: 56-56-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:1
    send: 56-56-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:1
    read: 0-0-56 s=1,c=1,t=2,pt=2,l=2:1
    This is an ack from gateway
    Incoming change for sensor:1, New status: 1
    send: 56-56-0-0 s=1,c=1,t=2,pt=2,l=2,st=fail:0
    send: 56-56-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:0
    read: 0-0-56 s=1,c=1,t=2,pt=2,l=2:0
    Incoming change for sensor:1, New status: 0
    So now my questions:
    Am i doing something wrong to get this result?
    What does the error mean when it fails?
    Why does the OK status not do anything?
    Why is it not the primary funktion to turn on or off the relay insted of sending and reciving the info from the MQTT?
    Gutz2001G 1 Reply Last reply
    • Gutz2001G Gutz2001
      Gutz2001G
      Gutz2001G
      Gutz2001
      Update:
      I've made another board with new components, and now it Works every time, i took the old board and added a Decoupling-Capacitor, now it Works about 6/10 times.
      Edit:
      I've resawdered the Wireless chip (FK 16.ONU) and now i got it to 8/10 times.
      Edit2:
      I added a Decoupling-Capacitor of 47UF insted of the 4,7 10/10 times.
