  3. Node freezing up
Node freezing up
29 Posts 9 Posters 19.6k Views 3 Watching
  • ferpandoF ferpando
    @TimO
    Could you elaborate a bit more about the watchdog?
    MagiskeM
    MagiskeM
    Magiske
    wrote on last edited by Magiske
    #21
    @ferpando You can enable a watchdog timer on your Arduino. If your code hangs your Arduino, it should reset/reboot it. But not sure that would reset the radio.
    Found good description -> http://www.megunolink.com/how-to-detect-lockups-using-the-arduino-watchdog/
      @AWI
      Looks like it has a regulator and a 1000uF capacitor plus a smaller one.
      I'll try to add a second regulator with capacitor just for the arduino and see what happens
      vladimirV
      vladimirV
      vladimir
      @ferpando, @Magiske, You solved this problem? I realized what the problem, but unfortunately, I do not understand how to solve it. Can you explain exactly how to change node?
      • T TimO
        I have exactly the same Problem. But I'm not sure the relays are the problem.
        I've added a keep alive message to know when it stops working and implemented a watchdog.
        AWIA
        AWIA
        AWI
        That sounds like you keep the motor running and accept that the car crashes every once in a while ;) Better to find the root cause of the "freeze" and eliminate it.
        T 1 Reply Last reply
        • AWIA AWI
          TimO
          @AWI You're right of course! But ... if the Arduino is the root of all evil in this case, it will reset once in a while but still work. If it still freezes it could be the radio that crashes. So I'm still trying to solve the problem. :-)
          All parts use the same 5V source (which I already switched) but the radio of course is connected through a regulator. If the watchdog solves the problem (so the radio is not the problem) I will add a bigger capacitor which I already ordered.
          • ferpandoF
            ferpandoF
            ferpando
            I made this regulator based on this schematic to power the node independently, to see if it solves the problem.
            • RJ_MakeR
              RJ_MakeR
              RJ_Make
              Does this node by any chance have a temp. sensor also?
              My nightmare.. http://forum.mysensors.org/topic/338/reliability/3
              RJ_Make
              ferpandoF 1 Reply Last reply
              • RJ_MakeR RJ_Make
                ferpandoF
                ferpandoF
                ferpando
                Mine doesn`t at the moment, but should be easy to add.
                • NuubiN
                  NuubiN
                  Nuubi
                  Any update on this?
                  Asking since I also have a multisensor that locks up every now and then. Thinking of some way to reset the radio a couple of times per day.
                  Any suggestions how to implement this?
                  • NuubiN Nuubi
                    Any update on this?
                    ferpandoF
                    ferpandoF
                    ferpando
                    @Nuubi
                    No more node lock-ups since I installed that power supply, so it works as expected.
