  3. Node freezing up
Node freezing up
29 Posts 9 Posters 20.0k Views 3 Watching
  • T
    TimO
    I have exactly the same Problem. But I'm not sure the relays are the problem.
    I've added a keep alive message to know when it stops working and implemented a watchdog.
    ferpandoF AWIA 2 Replies Last reply
    • T TimO
      ferpandoF
      ferpandoF
      ferpando
      @TimO
      Could you elaborate a bit more about the watchdog?
      MagiskeM 1 Reply Last reply
      • ferpandoF ferpando
        @TimO
        MagiskeM
        MagiskeM
        Magiske
        wrote on last edited by Magiske
        #21
        @ferpando You can enable a watchdog timer on your Arduino. If your code hangs your Arduino, it should reset/reboot it. But not sure that would reset the radio.
        Found good description -> http://www.megunolink.com/how-to-detect-lockups-using-the-arduino-watchdog/
          @AWI
          Looks like it has a regulator and a 1000uF capacitor plus a smaller one.
          I'll try to add a second regulator with capacitor just for the arduino and see what happens
          vladimirV
          vladimirV
          vladimir
          @ferpando, @Magiske, You solved this problem? I realized what the problem, but unfortunately, I do not understand how to solve it. Can you explain exactly how to change node?
          • T TimO
            AWIA
            AWIA
            AWI
            That sounds like you keep the motor running and accept that the car crashes every once in a while ;) Better to find the root cause of the "freeze" and eliminate it.
            • AWIA AWI
              TimO
              @AWI You're right of course! But ... if the Arduino is the root of all evil in this case, it will reset once in a while but still work. If it still freezes it could be the radio that crashes. So I'm still trying to solve the problem. :-)
              All parts use the same 5V source (which I already switched) but the radio of course is connected through a regulator. If the watchdog solves the problem (so the radio is not the problem) I will add a bigger capacitor which I already ordered.
              • ferpandoF
                ferpandoF
                ferpando
                I made this regulator based on this schematic to power the node independently, to see if it solves the problem.
                • RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  Does this node by any chance have a temp. sensor also?
                  My nightmare.. http://forum.mysensors.org/topic/338/reliability/3
                  RJ_Make
                  ferpandoF 1 Reply Last reply
                  • RJ_MakeR RJ_Make
                    ferpandoF
                    ferpandoF
                    ferpando
                    Mine doesn`t at the moment, but should be easy to add.
                    • NuubiN
                      NuubiN
                      Nuubi
                      Any update on this?
                      Asking since I also have a multisensor that locks up every now and then. Thinking of some way to reset the radio a couple of times per day.
                      Any suggestions how to implement this?
                      • NuubiN Nuubi
                        Any update on this?
                        ferpandoF
                        ferpandoF
                        ferpando
                        @Nuubi
                        No more node lock-ups since I installed that power supply, so it works as expected.
