  3. Home Assistant
  4. Optimistic parameter in Home Assistant
8 Posts 4 Posters 1.4k Views 4 Watching
    Marek
    Hi, the HOme Assistant documentation says that for MySensors integration you can set the 'optimistic' parameter. But how to do it? I have an MQTT gateway.
    • electrikE
      electrikE
      electrik
      In your configuration.yaml add this
      mysensors:
        optimistic: true
      And restart home assistant
        Marek
        Doesn't work.
        Invalid config for [mysensors]: required key not provided @ data['mysensors']['gateways']. Got None. (See /config/configuration.yaml, line 175).
        Gateways I have defined in the integrations UI.
        BearWithBeardB 1 Reply Last reply
        • M Marek
          Doesn't work.
          BearWithBeardB
          BearWithBeardB
          BearWithBeard
          @Marek If you only copy and pasted the above two lines into your config, then you got that error message because it is an incomplete configuration for the old, YAML-based MySensors integration.
          A valid YAML configuration looks, or rather looked, like this:
          mysensors:
            gateways:
              - device: mqtt
                persistence_file: '/config/mysensors.json'
                topic_in_prefix: 'mysensors-out'
                topic_out_prefix: 'mysensors-in'
              - device: mqtt
                persistence_file: '/config/mysensors_testing.json'
                topic_in_prefix: 'mytest-out'
                topic_out_prefix: 'mytest-in'
            optimistic: true
            retain: true
            version: '2.3'
          You may be able to set the optimistic setting by adding something like this to your config and restarting Home Assistant. You may also need to delete your existing UI-based integration beforehand.
          That being said, the old YAML configurations are not recommended (and apparently neither documented) anymore. When a YAML-based MySensors configuration is detected after a HA start, it will be migrated to the new UI-based integration automatically. Subsequent changes to the YAML config will be ignored.
          AFAIK, the new UI-based intregration deprecated a bunch of configuration options and I think that the optimistic setting is one of them. I don't know of a way to set it using the UI-based integration, nor if it'll be carried over by importing an "existing" YAML config. The documentation of the MySensors integration may be incorrect / outdated here.
            Marek
            I did as you advised. I deleted Mysensors in gui. I added the configuration in configuration.yaml. After rebooting HA still does not optimistic work. There is an entry in the log: 'optimistic option for mysensors is deprecated. Please remove optimistic from your configuration file '.
            I'm afraid Home Assistant has killed the ability to use battery-operated MySensors devices.
            • BearWithBeardB
              BearWithBeardB
              BearWithBeard
              No, Home Assistant didn't render battery-powered nodes unusable.
              I have never used the optimistic mode in Home Assistant, yet I'm able to achieve uptimes of more than a year with CR2032-powered (merely ~230 mAh) MySensors nodes. See here for an example. The temperature sensor I mentioned there is still working since April 2020, reporting every 5 minutes.
              In which use case would the optimistic mode be necessary?
              I mean, you have full control over the node's behavior. If you want to go as easy on the batteries as possible, you can put a node back to sleep as soon as it has sent a new measurement once, without waiting for any feedback. For more critical sensors (i.e. security-related) and actors on the other hand, you probably want confirmation that the data was successfully received and rather replace the batteries a little bit earlier, don't you?
                Marek
                Temperature measurement is not a problem. It doesn't need optimistic mode.
                I have my DIY nodes that control heating in rooms (radiators). They are battery devices. Every 5 minutes they wake up to check if the switch (S_BINARY) is turned on or not. This switch requires optimistic mode.
                • G
                  G
                  Gibber
                  I have encountered the same situation trying to use a switch to control some blinds.
                  Has there been any update on this issue from either Home Assistant or MySensors, or any workaround developed?
