  3. CO2 Sensor Senseair S8 - big values read
3 Posts 3 Posters 1.2k Views 2 Watching
  • W
    W
    wasssu
    I installed a Senseair S8 senzor on a Raspberry Pi 4. In the first week it worked ok (values coming close to 400 ppm when I open the window) then it started to show big values, especially when I open the window, values like 65429 ppm. The reading interval is 15 seconds. I use this code to get the value from the sensor. Any idea what could be the problem?
        ser = serial.Serial("/dev/serial0",baudrate =9600,timeout = .5)
        ser.flushInput()
        time.sleep(1)
        ser.flushInput()
        ser.write(b"\xFE\x44\x00\x08\x02\x9F\x25")
        time.sleep(.5)
        resp = ser.read(7)
        high = resp[3]
        low = resp[4]
        co2 = (high*256) + low
    Thanks!
    • W wasssu
          ser.flushInput()
          time.sleep(1)
          ser.flushInput()
          time.sleep(.5)
          resp = ser.read(7)
          high = resp[3]
          low = resp[4]
      Thanks!
      Welcome to the forum @wasssu
      Best way to find out is probably to log the contents of the resp variable.
      • epierreE
        epierreE
        epierre
        maybe check what they did here:
        https://github.com/airgradienthq/arduino/blob/master/AirGradient.cpp
        z-wave - Vera -> Domoticz
