  3. Gateway doesn't receive any message from node
25 Posts 3 Posters 3.1k Views 3 Watching
  • Y
    Y
    yury
    pinout looks ok.
    btw This line from the Node log
    1269 !TSF:MSG:SEND,100-100-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
    Means node cannot send OR gateway cannot receive. may be node radio is HCW somehow?
    mysensors lib not broken\timeouts not tweaked?
    C 1 Reply Last reply
    • Y yury
      pinout looks ok.
      C
      C
      ctodor
      @yury may be node radio is HCW somehow? no, it is not.
      I'll try to create a new board and give feedback.
      • C
        C
        ctodor
        Update: it seems the problem was the DC-DC convertor. I have replace it with an extwrnal power source and now it works.
        I still don't understand what was wrong there because the voltage on the radio module was correct:3.3V
        • C ctodor
          @ctodor nice work!
          When you checked the voltage, did you use a multimeter or an oscilloscope? If you used a multimeter, maybe there was a ripple or something that wasn’t visible.
            @ctodor nice work!
            C
            C
            ctodor
            @mfalkvidd multimeter
