  3. Sensor to measure amount of dripping water?
10 Posts 7 Posters 1.9k Views 6 Watching
    3nibble
    My gas heater produces condensate. The ratio condensate per gas shows the efficiency of the combustion which is what I want to track.
    Condensate drips from the heater, i. e. no pressure, just dripping water. Volume might range from zero to maybe 10 or 15 litres a day.
    I am looking for a sensor I can hook onto an Arduino or even better a sensor which I can connect to my existing 1-wire network.
    Thanks for hints.
    3nibble
    • electrikE
      electrikE
      electrik
      wrote on last edited by electrik
      A simple solution would be to weigh the condensate, but I'm not sure whether this is possible (from a mechanical point of view)
        Maybe a tipping bucket would work?
          3nibble
          wrote on last edited by 3nibble
          Thanks,
          A 3D-printed tipping bucket would certainly be an easy solution. I wonder whether there is a sensor, which is able to somehow directly "read" the volume. I understand, there is the difficulty of heavy fluctuations in volume, which the bucket avoids. But I could imagine there are for example medical applications which have to deal with similar requirements/difficulties.
          • JodailleJ
            JodailleJ
            Jodaille
            few years ago I was searching a technic to measure water level in a small tank.
            I have read somewhere that some motorbike have a gaz tank that use a "capacitance level meter".
            I have never succeeded but you may have a try.
            I have just found an example to illustrate:
            https://www.hackster.io/team-protocentral/non-contact-capacitive-liquid-level-sensing-using-fdc1004-9333c7
            • OldSurferDudeO
              OldSurferDudeO
              OldSurferDude
              wrote on last edited by OldSurferDude
              A small flow meter with a solenoid valve. Daily, open the valve and count the counts coming from the flow meter (400 counts/L).
              A series of level sensors (~$2 ea) might work, too. Again, a solenoid valve.
              I have to admit, a tipping bucket would be cost effective because it doesn't require a solenoid valve. but it wouldn't have the accuracy of the flow meter. The level sensors is kind of kludgy.
              OSD
              • NeverDieN
                NeverDieN
                If it drips slow enough, maybe a simple photocell and led could be used to count each drip as it drops in-between. Use arduino analog input to look for a drop in the light intensity. i.e. a simple electric eye.
                • NeverDieN
                  NeverDieN
                  Some kind of through-beam sensor might work: https://www.amazon.com/Optical-Endstop-Photoelectric-Control-Printer/dp/B07MFT8NWJ/ref=asc_df_B07MFT8NWJ/?tag=hyprod-20&linkCode=df0&hvadid=241938907421&hvpos=&hvnetw=g&hvrand=9189408107204898573&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028292&hvtargid=pla-664653941028&th=1
                  I once was interested in the same sort of thing for monitoring the effluent from a reverse osmosis filter at the air-gap to confirm that it wasn't wasting a lot of water. In my case there turned out to be an easier way.
                  • J
                    J
                    JeeLet
                    Yes, the toggle system is the best.
                    Tilt
                    but be careful, the condensate is very aggressive, their pH, an acidic liquid.
                    so no metal.
                    Ph
                    Here's an info: Why condensing boilers do not guarantee an efficient operation. : a link
                    the best of all worlds : a link link
                    • NeverDieN
                      NeverDieN
                      I would think that it's the ambient air temperature that affects how much condensate you collect, together with how much fuel was burned. After the initial warm-up that gets you to steady state, wouldn't the efficiency be constant?
                      If the acidity is a problem, you can run the condensate over a bed of acid neutralizing rocks before it goes down your main drain. It's a thing.
