  3. Home Assistant
  4. MQTT gateway help!
MQTT gateway help!
2 Posts 2 Posters 572 Views 2 Watching
    Multimax
    Hello, i have an serial node running via usb cable to an rpi with home assistent - it works fine, but trying to transport the data via rs485, or mqtt not working. i found an mqtt node, but wtih serveral relays and buttons - i run out of understanding... it only show one relay in homeassistant :-(. SO dos someone have an multi relay+button code as works under homeassistant - they will share, so i and find my mistake. (i use arduino mega+w5500)
    monteM 1 Reply Last reply
    • M Multimax
      monteM
      monteM
      monte
      wrote on last edited by monte
      @Multimax do you send initial states for all children for this multi relay node? HA won't show anything that hasn't sent initial data to show.
      https://www.home-assistant.io/integrations/mysensors/#presentation
