  3. Home Assistant
  4. 2x BME 280 on 2x arduino nano hangs in HomeAssistant
8 Posts 3 Posters 1.2k Views 3 Watching
  • HJ_SKH
    HJ_SKH
    HJ_SK
    Just restarting to use my arduino's with MySensors (+ NodeManager) .....
    I'm using NodeManager for this :
    I added a BME280 on a Arduino Nano with
    // General settings
    #define SKETCH_NAME "BME280_Test"
    #define SKETCH_VERSION "1.0"
    //#define MY_DEBUG
    #define MY_NODE_ID 98
    // NRF24 radio settings
    • Add your sensors
      // BME_Specific
      #include <Adafruit_BME280.h>
      // End BME_Specific
      It was picked up by homeassistant perfectly
    Then I added second BME280 on another Nano
    // General settings
    #define SKETCH_NAME "BME280_Hof67"
    //#define MY_DEBUG
    #define MY_NODE_ID 67
    It first hangs but after hours HomeAssistant did pick it up, but ......
    Both are now 'dead' (Not refereshing data) but still visiable in HomeAssistant.
    Any one an idea what is going wrong here?
    Help much preciated!
    Thx in advantage!
    Harm Jeurink
    • E
      E
      eiten
      Hello @HJ_SK
      Could you please post the whole sketch in code tags or as an attachement?
      Does it work stable with just one sensor node?
      Could you #define MY_DEBUG, attach at least one sensor to a PC and post the log after they hang?
      Regards, Edi
      • HJ_SKH
        HJ_SKH
        HJ_SK
        thx Eiten,
        Thx so much for your reaction.
        With 1 BME 280 it is stable within HomeAssistant.
        My_Debug later today is the plan
        Below ino file
        Regards,
        Harm
        [0_1722262405764_BME280_Hof67.ino](Uploading 100%)
        • HJ_SKH
          HJ_SKH
          HJ_SK
          After activate MY-DEBUG I got this error :
          Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
          text section exceeds available space in board
          Compilation error: text section exceeds available space in board
          I understand because of using NodeManager the file is bigger.
          Can I remove all // xxxsensors?
          • HJ_SKH
            HJ_SKH
            HJ_SK
            without debug is now hangs on here :
            17:16:19.825 -> 0 NM:INIT:INO=BME280_Hof67 v1.0
            17:16:19.871 -> 0 NM:INIT:LIB VER=2.3.2 CP=RNNNA---
            17:16:19.908 ->
            17:16:19.908 -> __ __ ____
            17:16:19.908 -> | / |_ / | ___ _ __ ___ ___ _ __ ___
            17:16:19.941 -> | |/| | | | _
            \ / _ \ _ \/ __|/ _ \|
            _/ __|
            17:16:20.008 -> | | | | |
            | || | / | | _ \ _ | | _
            17:16:20.074 -> |
            |_
            , |/ ___|| ||/_/|| |/
            17:16:20.108 -> |
            __/ 2.3.2
            17:16:20.174 ->
            17:16:20.174 -> 209 NM:INIT:RBT p=255
            17:16:20.174 -> 300 NM:BFR:INIT
            But last time upload after several hours it suddenly came up in HA
            • HJ_SKH
              HJ_SKH
              HJ_SK
              And now again on USB port of PC sending its info, but no response in HA
              10:51:58.958 -> 149738851 NM:LOOP:BME280(1):SET t=0 v=23.70
              10:51:58.993 -> 149738898 NM:LOOP:BME280(2):SET t=1 v=43.47
              10:51:59.062 -> 149738947 NM:LOOP:BME280(3):SET t=4 v=972.44
              10:51:59.098 -> 149738996 NM:LOOP:BME280(4):SET t=5 v=stable
              10:51:59.133 -> 149739044 NM:LOOP:BME280(1):SET t=0 v=23.70
              10:51:59.202 -> 149739092 NM:LOOP:BME280(2):SET t=1 v=43.46
              10:51:59.238 -> 149739141 NM:LOOP:BME280(3):SET t=4 v=972.45
              10:51:59.273 -> 149739190 NM:LOOP:BME280(4):SET t=5 v=stable
              HA:
              entity_id,state,last_changed
              sensor.none_67_battery,0,2024-07-31T07:00:00.000Z
              sensor.none_67_battery,0,2024-07-31T07:00:19.035Z
              sensor.bme280_5,23.41,2024-07-31T07:00:00.000Z
              sensor.bme280_6,44.89,2024-07-31T07:00:00.000Z
              sensor.bme280_7,975.22,2024-07-31T07:00:00.000Z
              sensor.bme280_8,stable,2024-07-31T07:00:00.000Z
              • E
                E
                eiten
                Well, I can only imagine that they try to send at the same time. Did you try with slightly different interval times?
                • OldSurferDudeO
                  OldSurferDudeO
                  OldSurferDude
                  @HJ_SK said in 2x BME 280 on 2x arduino nano hangs in HomeAssistant:
                  BME280
                  I had a similar situation. First you have to delete all the MySensors devices in HA. This is aggravated by HA wanting the devices to be on line before you delete them. You may have to delete the MySensors data in the HA config directory. You may even have to uninstall MySensors from HA. Then shutdown HA. Next, turn off your gateway. Are you using MQTT for messaging? You'll have delete the MySensors data from there, too. (MQTT Explorer is good for doing this)
                  Then start HA. Did your MySensors devices come back as zombies? That's the problem. Try deleting them again. Are they data still in MQTT?
                  OK, now start again.
                  I had documented how to do all this deleting in HA Forum, HA/Discord and here, but I can't find that documentation now. grrrr
                  OSD
