  3. Home Assistant
  4. How I delete a node from HA and start over.
1 Posts 1 Posters 807 Views 1 Watching
  • OldSurferDudeO
    OldSurferDudeO
    OldSurferDude
    If you're here, I'm not going to preach to the choir about HA's arcane ways. This works for me
    • Stop mysgw
    • Using MQTT Explorer, remove from the topics mysensors_out and mysensors_in all vestiges of the node that is to be deleted
    • In Home Assistant (HA) delete the device
      • Settings
      • Devices and Services
      • Under MySensor, click on n Devices
      • Click on the device you want to delete.
      • Click DELETE
        • One can use use Studio Code Server to note that the device has been deleted
      • IMPORTANT! reboot Home Assistant
    • While HA is rebooting, make the changes to the code of your device
    • When you are satisfied with the changes and after HA has completely rebooted, disconnect your device from power.
    • Start mysgw
    • Apply power to your device
