  3. Array Relay Button Actuator
45 Posts 16 Posters 30.6k Views 16 Watching
  • N
    N
    niccodemi
    @martinhjelmare
    That was it. After I amended sketch according to your advise all the random state changes disappeared. I rebooted node over 20 times in various button / relay states and it always started with relays in correct position. For anyone else interested below is amended sketch.
    //MultiRelayButton Sketch, MySensors 1.6, toggle switch
    #define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    #define RELAY_ON 0                      // switch around for ACTIVE LOW / ACTIVE HIGH relay
    #define RELAY_OFF 1
    #define noRelays 2                     //2-4
    const int relayPin[] = {14,15};          //  switch around pins to your desire
    const int buttonPin[] = {3,4};      //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
    public:
      int buttonPin;                   // physical pin number of button
      int relayPin;             // physical pin number of relay
      boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
    void setup(){
        sendHeartbeat();
        wait(100);
        // Initialize Relays with corresponding buttons
        for (int i = 0; i < noRelays; i++){
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        Relays[i].relayPin = relayPin[i];
        msg[i].sensor = i;                                   // initialize messages
        msg[i].type = V_LIGHT;
        pinMode(Relays[i].buttonPin, INPUT_PULLUP);
        wait(100);
        Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF);   // and set relays accordingly
        send(msg[i].set(Relays[i].relayState? true : false));                  // make controller aware of last status
        wait(50);
        debouncer[i] = Bounce();                        // initialize debouncer
        debouncer[i].attach(buttonPin[i]);
        debouncer[i].interval(20);
        wait(50);
    void presentation()  {
          sendSketchInfo("MultiRelayButton", "0.9t");
          wait(100);
          present(i, S_LIGHT);                               // present sensor to gateway
          wait(100);
        for (byte i = 0; i < noRelays; i++) {
            if (debouncer[i].update()) {
                digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
                // save sensor state in EEPROM (location == sensor number)
                saveState( i, Relays[i].relayState );
        wait(20);
    // process incoming message
    void receive(const MyMessage &message){
       if (message.type == V_LIGHT){
       if (message.sensor <noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
       digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
       saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
      wait(20);
      moskovskiy82
      What is the simplest method to add two extra butons to this sketch not tied to the relay?
      I have a four button device. Two will work with relays and two extra utilised in openhab rules
      • korttomaK
        korttomaK
        korttoma
        Just in case someone else finds this thread and decides to use the sketch and runs in to the same issue I did.
        I was using push buttons and the sketch above, when I pushed the button the relay turned on but as soon as I let go of the button the relay turned back off. I changed the sketch like this:
              int value = debouncer[i].read();
              if ( value == LOW) {
                digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF);
                send(msg[i].set(Relays[i].relayState ? true : false));
          //wait(20);
        Now the relay changes state as soon as I push the button and keeps the state until I push the button again.
        Because my inputs for the push buttons are ground when pushed I used
        if ( value == LOW)
        This way the relay would turn on immediately when I push the button and not wait until I let go of the button.
        • Tomas
        Стоян ГеоргиевС 1 Reply Last reply
        • korttomaK korttoma
            //wait(20);
          if ( value == LOW)
          Стоян ГеоргиевС
          Стоян ГеоргиевС
          Стоян Георгиев
          @korttoma I used this sketch but my vera founds only 1 device and i have no idea why.
          korttomaK 1 Reply Last reply
          • Стоян ГеоргиевС Стоян Георгиев
            korttomaK
            korttomaK
            korttoma
            @Стоян-Георгиев please post the complete sketch along with info about MySensors library version you are using.
            • Tomas
