  3. Array Relay Button Actuator
45 Posts 16 Posters 30.6k Views 16 Watching
    mikemayers
    Hello everyone,
    Has anyone done an Array Relay Button Actuator?
    jeylitesJ 1 Reply Last reply
    • M mikemayers
      Hello everyone,
      jeylitesJ
      jeylitesJ
      jeylites
      wrote on last edited by jeylites
      @mikemayers
      I'm having the same issue too using Multi Button Actuator sketch. I can't figure out how to switch from Lo to Hi or Lo to Hi to drive my relays because nothing happens when I change #define. and the sketch can't seem to communicate with my Vera UI7. But when I use a single actuator sketch from My sensor library, it communicates well with Vera. So its obvious that something is not right in the sketch for it to react that way.
      Anyway, this is what I have done with the help of the community. Perhaps you or someone can make it better.
      #include <Bounce2.h>
      #define RELAY_ON 0 //switch around for realy HIGH/LOW state
      #define RELAY_OFF 1
      #define RADIO_ID 11
      #define noRelays 4
      const int relayPin[] = {3,7};
      const int buttonPin[] = {4,5};
      class Relay							// relay class, store all relevant data (equivalent to struct)
      public:
        int buttonPin;					// physical pin number of button
        int relayPin;						// physical pin number of relay
        byte oldValue;               		// last Values for key (debounce)
        boolean relayState;             	// relay status (also stored in EEPROM)
      Relay Relays[noRelays];
      Bounce debouncer[noRelays];
      MyMessage msg[noRelays];
      void setup(){
      	gw.begin(NULL, RADIO_ID, true);
      	delay(250);
      	gw.sendSketchInfo("MultiRelayButton", "0.9b");
      	delay(250);
      	// initialize Relays with corresponding buttons
      	for (int i = 0; i < noRelays; i++){
      		Relays[i].buttonPin = buttonPin[i];				// assign physical pins
      		Relays[i].relayPin = relayPin[i];
      		msg[i].sensor = i;								// initialize messages
      		msg[i].type = V_LIGHT;
      		debouncer[i] = Bounce();						// initialize debouncer
      		debouncer[i].attach(buttonPin[i]);
      		debouncer[i].interval(5);
      		pinMode(Relays[i].buttonPin, INPUT_PULLUP);
      		Relays[i].relayState = gw.loadState(i);			// retrieve last values from EEPROM
      		digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
      		gw.send(msg[i].set(Relays[i].relayState? true : false) );	// make controller aware of last status
      		gw.present(i, S_LIGHT);							// present sensor to gateway
      		delay(250);
      	gw.process();
      	for (byte i = 0; i < noRelays; i++)
      		debouncer[i].update();
      		byte value = debouncer[i].read();
      		if (value != Relays[i].oldValue && value == 0)
      			digitalWrite(Relays[i].relayPin, Relays[i].relayState);
      delay(250);
      			gw.saveState( i, Relays[i].relayState ); // save sensor state in EEPROM (location == sensor number)
      		Relays[i].oldValue = value;
      // process incoming message
      void incomingMessage(const MyMessage &message){
       delay(250);
      if (message.type == V_LIGHT){
        delay(250);
      if (message.sensor <= noRelays){ 				// check if message is valid for relays
      delay(250);
      delay(250);
      digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
      delay(250);
      gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
      • blaceyB
        blaceyB
        blacey
        @jeylites A few things to consider:
        • You have hardwired the radio id to 11 - make sure you aren't using 11 on any other sensors or actuators.
        • #define noRelays is set to 4 but you only have two relayPin and buttonPin values set. So noRelays needs to be set to 2 otherwise the setup method is going to run off the end of the arrays in the for loop that could crash the sketch/Arduino or at a minimum overwrite other memory causing unpredictable behavior.
        I would check those two things first and report back.
        • blaceyB blacey
          jeylitesJ
          jeylitesJ
          jeylites
          @blacey
          I dedicated Radio ID 11 for this sketch. I don't have any sensor or actuators on this channel. Initially, I had #define noRelays set as 4 but I changed it to 2 for testing purpose and forgot to update the sketch when I posted here. Anyway, this is the problem I'm facing.
          1. I'm unable to control the Relays from the Vera App and Web interface, but I'm able to toggle the light switch button ON / OFF on Vera App and Web from the Arduino button inputs. Basically the Button pin works, but not Relay Pin.
          2. I'm unable to switch around for realy HIGH/LOW state.
          Serial Report: Upon start up
          repeater started, id 11
          send: 11-11-0-0 s=255,c=0,t=18,pt=0,l=5,st=ok:1.4.1
          send: 11-11-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
          read: 0-0-11 s=255,c=3,t=6,pt=0,l=1:M
          send: 11-11-0-0 s=255,c=3,t=11,pt=0,l=16,st=ok:MultiRelayButton
          send: 11-11-0-0 s=255,c=3,t=12,pt=0,l=4,st=ok:0.9b
          send: 11-11-0-0 s=0,c=1,t=2,pt=2,l=2,st=ok:0
          send: 11-11-0-0 s=0,c=0,t=3,pt=0,l=5,st=ok:1.4.1
          send: 11-11-0-0 s=1,c=1,t=2,pt=2,l=2,st=ok:1
          send: 11-11-0-0 s=1,c=0,t=3,pt=0,l=5,st=ok:1.4.1
          Serial Report: When button is pressed
          send: 11-11-0-0 s=0,c=1,t=2,pt=2,l=2,st=ok:1
          #define RELAY_OFF 1
          #define RADIO_ID 11
          #define noRelays 2
          public:
          void setup(){
          	delay(250);
          	delay(250);
          		delay(250);
          	gw.process();
          delay(250);
           delay(250);
            delay(250);
          delay(250);
          delay(250);
          delay(250);
          • AWIA
            AWIA
            AWI
            Do you have messages coming in from the controller when executing commands from Vera? You should see this as 'read' in the debug output.?
            • AWIA AWI
              jeylitesJ
              jeylitesJ
              jeylites
              @AWI How do I go about doing this?
              This is the messages i get from the gateway when actuator is pressed on the sensor node.
              0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2:0
              11;0;1;0;2;0
              0;0;3;0;9;read: 11-11-0 s=0,c=1,t=2,pt=2,l=2:1
              11;0;1;0;2;1
              AWIA 2 Replies Last reply
              • jeylitesJ jeylites
                11;0;1;0;2;0
                11;0;1;0;2;1
                AWIA
                AWIA
                AWI
                @jeylites I was meaning to say.: on the node serial output. Do you see messages coming in. You can also add a print statement in the received message code.
                  11;0;1;0;2;0
                  11;0;1;0;2;1
                  AWIA
                  AWIA
                  AWI
                  @jeylites I think I found the problem. You won't receive any messages from the controller as messages are not initialized. Replace NULL in the gw. begin by the name of the incoming message routine.. Wonders will start to happen :eyes:
                  • AWIA AWI
                    jeylitesJ
                    jeylitesJ
                    jeylites
                    @AWI . OK let me try again.
                    • jeylitesJ
                      jeylitesJ
                      jeylites
                      @AWI
                      ... This is insane and it works :joy: :smiley: How do you change between HIGH/LOW state. I changed the #define settings but it's not taking effect.
                        @AWI
                        jeylitesJ
                        jeylitesJ
                        jeylites
                        @AWI
                        This is the awkward part. On the Vera App & Web, I'm able to toggle ON / OFF to the respective state of the Relay. Eg: "ON" on Vera energize the Relay and "OFF" de-energine the relay. But, when I use the actuator buttons on Arduino input , its reversed. "OFF" turns ON the Relay ...vice versa.
                        AWIA 1 Reply Last reply
                          @AWI
                          AWIA
                          AWIA
                          AWI
                          wrote on last edited by AWI
                          @jeylites I understand your Relays are active low. You have to be consequent in terminology like: on/off; true/false; RELAY_ON/RELAY_OFF. From a first glance I think you should be fine if you change the line:
                          to
                          digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
                          as things get mixed up here. i.e RELAY_ON is in fact "false" or "0"
                          • AWIA AWI
                            to
                            jeylitesJ
                            jeylitesJ
                            jeylites
                            @AWI
                            I revised the sketch based on your advice and seem to be working as we speak. I tried to make the final sketch as organized as possible, It has be copied below. Thank you everyone for making this work!!!
                            #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
                            #define RELAY_OFF 1
                            #define RADIO_ID 11                    // radio Id, whatever channel you assigned to
                            #define noRelays 2
                            const int relayPin[] = {3,7};          //  switch around pins to your desire
                            const int buttonPin[] = {4,5};      //  switch around pins to your desire
                            public:
                            void setup(){
                            	gw.begin(incomingMessage, RADIO_ID, true);
                            	delay(250);
                            	delay(250);
                            	// Initialize Relays with corresponding buttons
                            	gw.send(msg[i].set(Relays[i].relayState? true : false));	              // make controller aware of last status
                            	delay(250);
                            	gw.process();
                            	for (byte i = 0; i < noRelays; i++){
                            	if (value != Relays[i].oldValue && value == 0){
                            	gw.saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                                    if (message.sensor <noRelays){ 			  // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                            M 1 Reply Last reply
                              @AWI
                              #define RELAY_OFF 1
                              #define noRelays 2
                              public:
                              void setup(){
                              	delay(250);
                              	delay(250);
                              	delay(250);
                              	gw.process();
                              mikemayers
                              @jeylites
                              Just tested this sketch and it works. Thank for the effort.
                              • M mikemayers
                                @jeylites
                                maglo18
                                Could someone tell what i should to modify to use toggle button not flash button?
                                • jeylitesJ
                                  jeylitesJ
                                  jeylites
                                  @maglo18 what do you mean?
                                    maglo18
                                    In yours sketch state button should high next low then relay change state. I want to have possibility after button HIGH relay state change button LOW state relay change again
                                    • J
                                      J
                                      jemish
                                      yes , I have same problem.
                                      how can we use simple wall switch with relay to ON and OFF the lights.
                                      • AWIA
                                        AWIA
                                        AWI
                                        For learning purposes: Instead of coding it for you, try the line of thought:
                                        Now it changes with the toggle, so if "value" (switch) becomes high is changes the state of the relays, send the message to controller and stores it in EEPROM.
                                        If you use a normal switch, you should change the state if when the "value" changes. So remember the last state of the switch and make it happen ;-)
                                        btw :you need a variable to store the last button state and the physical position of the switch does not change if you update the relay switch from the controller..
                                        • jeylitesJ
                                          jeylitesJ
                                          jeylites
                                          Just wondering any of you guys made progress in normal switch?
