  3. Array Relay Button Actuator
45 Posts 16 Posters 30.6k Views 16 Watching
  • R
    R
    rainair
    Hello this is my first post, but i follow my sensors for about 2 months.
    Excuse my bad english.
    For those how want use a normal in wall switch
    just change the line:
    if (value != Relays[i].oldValue && value == 0){
    to
    if (value != Relays[i].oldValue){
    to
    hope this was a bit helpfully
    • jeylitesJ
      jeylitesJ
      jeylites
      wrote on last edited by jeylites
      #22
      @rainair, I tested it and it works! Thanks!!!
      • G
        G
        gonzalonal
        @jeylites said:
        Relays[i].relayState = gw.loadState(i); // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
        gw.send(msg[i].set(Relays[i].relayState? true : false)); // make controller aware of last status
        gw.present(i, S_LIGHT); // present sensor to gateway
        delay(250);
        It's my idea, or shouldn't the sensor be presented to the gateway before sending it status?
        Thanks! regards.
        • jeylitesJ
          jeylitesJ
          jeylites
          @gonzalonal
          I don't think it matters. You could try flip "gw.send & gw.present" and see how it respond to the change.
          • E
            E
            ewgor
            Wow ! this is what i was looking for ... Could anyone please share with us some Openhab settings for this wonderful Arduino sketch?
            How can we assign in OH buttons to correspond to the physical buttons on the breadboard ?
            Looking for any answer.
            Thanks all!
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              How would I update this to work with 1.6?
              N 1 Reply Last reply
                N
                N
                niccodemi
                @Cliff-Karlsson I recently started using 1.6 version, below is converted sketch. It works with momentary (pushbuttons) switches only.
                Does anyone have sketch for toggle switches?
                #define MY_REPEATER_FEATURE
                #include <Bounce2.h>
                #define RELAY_ON 0                      // switch around for relay HIGH/LOW state
                #define RELAY_OFF 1
                #define noRelays 2                     //2-4
                const int relayPin[] = {14,15};          //  switch around pins to your desire
                const int buttonPin[] = {3,4};      //  switch around pins to your desire
                class Relay             // relay class, store all relevant data (equivalent to struct)
                public:
                  int buttonPin;                   // physical pin number of button
                  int relayPin;             // physical pin number of relay
                  byte oldValue;                    // last Values for key (debounce)
                  boolean relayState;               // relay status (also stored in EEPROM)
                Relay Relays[noRelays];
                Bounce debouncer[noRelays];
                MyMessage msg[noRelays];
                void setup(){
                    sendHeartbeat();
                    wait(250);
                    // Initialize Relays with corresponding buttons
                    for (int i = 0; i < noRelays; i++){
                    Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                    Relays[i].relayPin = relayPin[i];
                    msg[i].sensor = i;                                   // initialize messages
                    msg[i].type = V_LIGHT;
                    debouncer[i] = Bounce();                        // initialize debouncer
                    debouncer[i].attach(buttonPin[i]);
                    debouncer[i].interval(5);
                    pinMode(Relays[i].buttonPin, INPUT_PULLUP);
                    //digitalWrite(Relays[i].relayPin, RELAY_OFF);
                    wait(250);
                    Relays[i].relayState = loadState(i);                               // retrieve last values from EEPROM
                    wait(250);
                void presentation()  {
                      sendSketchInfo("MultiRelayButton", "0.9f");
                      wait(250);
                    for (byte i = 0; i < noRelays; i++){
                    debouncer[i].update();
                    byte value = debouncer[i].read();
                    if (value != Relays[i].oldValue && value==0){
                    digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
                    saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                        Relays[i].oldValue = value;
                // process incoming message
                void receive(const MyMessage &message){
                   if (message.type == V_LIGHT){
                   if (message.sensor <noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                   digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
                   saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                • jeylitesJ
                  jeylitesJ
                  jeylites
                  #28
                  The following sketch has got what you're looking for. Hope that helps.
                  Relay With Actuator Switch Toggle
                  #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
                  #define RELAY_OFF 1
                  #define RADIO_ID 11                    // Radio ID, whatever channel you assigned to
                  #define noRelays 6
                  const int relayPin[] = {A0, A1, A2, A3, A4, A5};
                  const int buttonPin[] = {3, 4, 5, 6, 7, 8};
                  public:
                  void setup(){
                  	gw.begin(incomingMessage, RADIO_ID, true);
                  	delay(250);
                  	gw.sendSketchInfo("MultiRelayButton", "0.9b");
                  	delay(250);
                  	delay(250);
                  	gw.process();
                  //	if (value != Relays[i].oldValue && value == 0){
                  	gw.saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                  void incomingMessage(const MyMessage &message){
                          if (message.sensor <noRelays){ 	 // check if message is valid for relays..... previous line if [[[ (message.sensor <=noRelays){ ]]]
                          gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                  • N
                    N
                    niccodemi
                    @jeylites Thanks, toggle switch works but there is issue when node boots / restarts. On 1st restart relays stay OFF, on 2nd come ON, on 3rd again OFF and so on. It seems that whatever happens during Setup is reversed in Loop. Hopefully someone can point out what should be changed in modified sketch.
                    #define RELAY_OFF 1
                    public:
                    void setup(){
                        sendHeartbeat();
                        wait(250);
                        wait(250);
                        wait(250);
                          sendSketchInfo("MultiRelayButton", "0.9g");
                          wait(250);
                    these are screenshots from restarts
                    reboot1
                    reboot2
                    • N niccodemi
                      #define RELAY_OFF 1
                      public:
                      void setup(){
                          sendHeartbeat();
                          wait(250);
                          wait(250);
                          wait(250);
                            wait(250);
                      reboot1
                      reboot2
                      martinhjelmareM
                      martinhjelmareM
                      martinhjelmare
                      #30
                      @niccodemi
                      Hi!
                      I think the problem is you're not initializing oldValue to anything. It will then always be different than value in the loop, and state will change.
                      You should set oldValue to the same "state" as the loaded relayState in setup. Even better, only use relayState, and make it an int. You can do the same boolean evaluations anyway. 1 is true and 0 is false.
                      Edit:
                      Sorry, I forgot that this is a pushbutton, right? Then you should just make sure that oldValue and value are the same after setup is complete, ie HIGH.
                      • N
                        N
                        niccodemi
                        @martinhjelmare
                        thanks, I understand what you mean but I don't know how to write it in sketch.
                        I tried inserting
                        Relays[i].oldValue = Relays[i].relayState;
                        at the end of Void Setup section but then sketch wouldn't compile. I get "name lookup of 'i' changed 'for' ISO for scoping [-fpermissive]" error. I get same error if I substitute Relays[i].relayState with loadstate.
                        • N niccodemi
                          @martinhjelmare
                          I tried inserting
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @niccodemi
                          Put this on a line after pinMode() in setup function.
                          Relays[i].oldValue = digitalRead(Relays[i].buttonPin);
                          • N
                            N
                            niccodemi
                            @martinhjelmare
                            Ok, there is an improvement. Relays now turn to same state as they were before reboot most of the time but not always. Sometimes they inverse - the one which was OFF turns ON and vice-versa. Sometimes (1 in 3) they switch ON and OFF (only for split second) in the loop function. See below screenshots:
                            reboot3
                            reboot4
                            This sketch is used with toggle button, same as on this photo.
                            martinhjelmareM BartEB 2 Replies Last reply
                            • N niccodemi
                              @martinhjelmare
                              reboot3
                              reboot4
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @niccodemi
                              Could be the toggle is still bouncing at read time. Try increasing the debouncer interval. For example, double it until no more issues. Then decrease it in halves of what the last increase was until you see the issue again. This way you can try to find the smallest debounce time needed.
                              • N niccodemi
                                @martinhjelmare
                                reboot3
                                reboot4
                                BartEB
                                BartEB
                                BartE
                                wrote on last edited by BartE
                                #35
                                @niccodemi You can forget using the oldValue, because the debounce takes track of it's last status. When update() is called and a debounced pin-change is detect this function will return true otherwise it will send false.
                                Having a short delay each loop will stabilize the debouncers so your loop() can look like this:
                                    for (byte i = 0; i < noRelays; i++) {
                                        if (debouncer[i].update()) {
                                    wait(10);
                                • BartEB BartE
                                      wait(10);
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  #36
                                  @BartE
                                  Why do you think it's better to add the wait than to increase debounce interval? Didn't know update returns a boolean, cool.
                                  BartEB 1 Reply Last reply
                                    @BartE
                                    BartEB
                                    BartEB
                                    BartE
                                    #37
                                    @martinhjelmare there is no reason to have that many button checks per millisecond, if you "wait" each while loop the MySensors core has more time to process messages i.s.o. of reading I/O pins especially when your node acts as a repeater. (During a wait the process function is called)
                                    A person will not notices a button to take 50 i.s.o 10 milliseconds to respond.
                                    • BartEB BartE
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @BartE
                                      Yes, very good point.
                                      • N
                                        N
                                        niccodemi
                                        @martinhjelmare @BartE thank you both for trying to solve this issue but the problem is still there. On reboot relay (usually just 1 never both) gets set randomly in loop function (setup function always restores correct state). I also tried increasing debouncer up to 500 without success. And I am also sure this is not hardware related because if I load sketch which is meant for momentary switch relays work as expected (tested with 10 consecutive reboots). Just to be on the same page this is latest sketch:
                                        //MultiRelayButton Sketch, MySensors 1.6
                                        #define RELAY_OFF 1
                                        public:
                                          //byte oldValue;                    // last Values for key (debounce)
                                        void setup(){
                                            sendHeartbeat();
                                            wait(250);
                                            debouncer[i].interval(100);
                                            wait(250);
                                            //Relays[i].oldValue = digitalRead(Relays[i].buttonPin);
                                            wait(250);
                                              sendSketchInfo("MultiRelayButton", "0.9k");
                                              wait(250);
                                              wait(250);
                                            wait(50);
                                          wait(50);
                                        • N niccodemi
                                          #define RELAY_OFF 1
                                          public:
                                          void setup(){
                                              sendHeartbeat();
                                              wait(250);
                                              wait(250);
                                              wait(250);
                                                wait(250);
                                                wait(250);
                                              wait(50);
                                            wait(50);
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          #40
                                          @niccodemi
                                          I think you should setup the button first, pinMode etc, and then setup the debouncer and attach it to the button.
                                          https://github.com/thomasfredericks/Bounce2/wiki
                                          If you attach the debouncer while the pin is floating, the debouncer will probably have a hard time figuring out correct new state.
