  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • epierreE
    epierreE
    epierre
    wrote on last edited by epierre
    #241
    @hek
    I started it plugged to a vinduino like schema, so I had this :
    Sensebender Micro FW 1.2 - TestMode
    Testing peripherals!
    -> SI7021 : ok!
    -> Flash : failed!
    -> SHA204 : Ok (serial : 01232F36E159E8ADEE)
    Test finished
    ----> Selftest failed!
    I read your posts, replaces 1.4.1 libs by 1.5, reflashed it with the demo code and here is what I have:
    Sensebender Micro FW 1.2radio init fail
    is that because I don't have a 1.5 serial gateway ?
    I have the socket and the FTDI on the same side so I may avoid the above ?
    z-wave - Vera -> Domoticz
    epierreE 1 Reply Last reply
    • SparkmanS
      SparkmanS
      Sparkman
      wrote on last edited by Sparkman
      #242
      Finally got around to hooking one of these up last night. I soldered in the socket for the radio and the wires for my battery pack and uploaded the latest version of the sketch by just holding the FTDI connections in place. The sensor is working great. Thanks to @hek and @tbowmo for making it available!
      I'm capturing the data including battery percentage to track how long it will last. One thing is that the battery percentage is jumping around quite a bit. It started at around 93%, dropped below 90, jumped backup to 95, etc. so I'll need to do some investigation as to why. This is happening with brand-new Duracell copper-top batteries. Also, for any future enhancements to the board, I would love to see a couple of mounting holes.
      Cheers
      Al
      RJ_MakeR 1 Reply Last reply
      • SparkmanS Sparkman
        Cheers
        Al
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @Sparkman
        I wounder if that is being caused by the loading of the battery and the moment the battery info is being calculated......
        RJ_Make
        SparkmanS 2 Replies Last reply
        • RJ_MakeR RJ_Make
          @Sparkman
          SparkmanS
          SparkmanS
          Sparkman
          @ServiceXp Good point. Maybe for the low values it's transmitting the temp/humidity when it's calculating the battery level. I'll take a look at the sketch to see if that could be the case.
          Cheers
          Al
          • G
            G
            gloob
            wrote on last edited by gloob
            #245
            Hello
            I found an error in the sensebender micro sketch in the latest release.
            The calculation of the temperature change is wrong.
            float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100);
            needs to be replaced with
            float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0);
            The division with 100 needs to be 100.0 otherwise the result will be an integer instead of a float value and the difference will be the decimal places of the last temperature.
            korttomaK 1 Reply Last reply
            • AnticimexA
              AnticimexA
              Anticimex
              This should work as well and might be more clear:
              float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100f);
              But I guess it is a matter of taste :)
              • Stephan NollerS
                Stephan NollerS
                Stephan Noller
                Hi guys,
                amazing board! But i have a question: The Arduino IDE offerst two options as destination - 8MHz and 1MHz. Which one should i chose? My board seems to work in general, but not very realiable...
                SparkmanS 1 Reply Last reply
                • Stephan NollerS Stephan Noller
                  Hi guys,
                  SparkmanS
                  SparkmanS
                  Sparkman
                  @Stephan-Noller Out of the box, I had to use the 8MHz option to upload the sketch to it.
                  Cheers
                  Al
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    The sensebender is set up to run at 8Mhz. There is an option to build it for 1Mhz, but you have to switch the prescaler yourself in your sketch.
                    However I think the current consumption saved by running on 1Mhz vs 8Mhz is very limited on the sensebender, as the oscillator is shut down the majority of time (when we are sleeping the MCU).
                    . I have not made any measurements on this yet (busy with a 1000 of other projects)
                    • RJ_MakeR RJ_Make
                      @Sparkman
                      SparkmanS
                      SparkmanS
                      Sparkman
                      #250
                      @ServiceXp Your hunch was correct. I built another Sensebender that only transmitted battery levels, and it's battery levels did not vary at all:
                      I then modified the sketch to put a short wait after the temp & humidity are sent to allow the voltage level to recover and the battery levels do not fluctuate so far. However, I'm thinking it would be better to always measure right after a transmit, but not sure if that's easy to do.
                      Cheers
                      Al
                        Cheers
                        Al
                        RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        @Sparkman Thanks for the follow up.
                        RJ_Make
                        • epierreE epierre
                          @hek
                          -> SI7021 : ok!
                          -> Flash : failed!
                          Test finished
                          epierreE
                          epierreE
                          epierre
                          #252
                          @hek can anyone help me, no unit is functionnal so far...
                          @epierre said:
                          @hek
                          -> SI7021 : ok!
                          -> Flash : failed!
                          Test finished
                            Gateway version shouldn't matter if you get this message at startup of node.
                            I don't understand what you mean.
                              epierreE
                              epierreE
                              epierre
                              what should I do from there ?
                              this was related to the electric perturbation with headers close to the radio
                              • epierreE epierre
                                SparkmanS
                                SparkmanS
                                Sparkman
                                @epierre Can you confirm the settings you used in the IDE to program it? Are you sure there are no solder bridges where you soldered the radio or socket for the radio? Have you tried powering it with a couple of AA batteries after you uploaded the sketch?
                                Cheers
                                Al
                                • HeinzH
                                  HeinzH
                                  Heinz
                                  Today I integrated my first 2 sensebender micros into my homeautomation and they almost worked out of the box. I like this board really much! Good work, I will order more!
                                  Pitfall:
                                  When updating the mysensors lib from 1.4.x to 1.5 the sensor failed to get an id from the controller which btw was still running on 1.4.x.
                                  After having done all the things like "clearing eeprom", "soldering a capacitor to the radio" and so on... I noticed that I changed the RF_CHANNEL from the default 76 to some other value in MyConfig.h some months ago (probably for some paranoia reason).
                                  When updating to lib 1.5 the sensor sketch got the 76 while the gateway still used the other one and so the communication between both failed. After changing the radio channel to the one the controller uses, everything worked very quickly!
                                  Probably this post helps someother guy who fell into the same trap.
                                  • J
                                    J
                                    johnr
                                    My sense bender works perfect when sending directly data directly to serial gateway (vera 5), however when I move it out of range to the serial gateway and want it to connect to my repeater node it does not want to discover the repeater node. Anyone else had this problem?
                                    DwaltD 1 Reply Last reply
                                      Remember that it takes a few ( ~5) failed transmits until it searches for a new parent node.
                                      • J johnr
                                        DwaltD
                                        DwaltD
                                        Dwalt
                                        @johnr
                                        Is your repeater node still on MySensors 1.4? I had a similar problem and upgrading to 1.5 solved it.
                                        • J
                                          J
                                          johnr
                                          You are probably right. I did not realise sense bender was pre loaded with 1.5
                                          I think easiest for me would be to downgrade sense bender to 1.4 is it possible?
