  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • petoulachiP petoulachi
    Oh and BTW, which boxes are you using with your Sensebender ? I guess it's maybe the most difficult part of the entire project, finding the perfect box :D
    tbowmoT
    tbowmoT
    tbowmo
    @petoulachi
    The sketch have improved a lot since we released the sensebender, mostly on determining when to power up the radio and transmit. This should save more power. I've got one running with latest development, without hiccups for the last couple of months (it also have Ota fw upgrade enabled by default now).
    So if you are "adventurous" I would recommend to put that into your sensebenders
    • petoulachiP
      petoulachiP
      petoulachi
      I am adventurous !
      Were can I find the beta version of the sketch ?
      • korttomaK
        korttomaK
        korttoma
        https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/SensebenderMicro
        • Tomas
        • petoulachiP
          petoulachiP
          petoulachi
          Thanks !
          I took a look at the sketch, I didn't know there was a presentation() method to implement to present the different sensor's ID; is this new ? when is it called? I guess after setup() ?
          tbowmoT 1 Reply Last reply
            Thanks !
            tbowmoT
            tbowmoT
            tbowmo
            @petoulachi
            That's a part of the development. Things are re-arranged in the sketches, to make things more configurable (from within the sketch itself).
            It will be part of the next release (I don't know when that is happening)
            • petoulachiP
              petoulachiP
              petoulachi
              Ok, related to MySensors 1.6 tehen, that explain why I never seen this !
              • magpernM
                magpernM
                magpern
                HI, I'm about to experiment with a modded version of the sensebender and I while looking at the schematics of the original sensebender, I see that the crystal does not have any pf capasitors and not connected to GND. Why is that?
                All other schematics of atmega or any microprocessor I've seen has dual 22pf caps over the crystal and connected to ground.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Magnus-Pernemark
                  The sensebender was designed to use a 32Khz oscillator for lowpower operation. According to the datasheet (page 33) it is not necessary to have external load capacitors if the crystals datasheet specifies cL below 6pF.
                  However, we decided early on that an external crystal is not necessary in our application. So that is why it is not mounted, but the pads are still there, in case someone would use it.
                  magpernM 1 Reply Last reply
                  • tbowmoT tbowmo
                    @Magnus-Pernemark
                    magpernM
                    magpernM
                    magpern
                    @tbowmo Thanks! Yes. I read that it was not needed, but since it said "if you want higher precision" I though that, higher is good, and it would not hurt to place one there. But the crystals I have are 12.5pf so I guess I can't use them, but on the other hand I don't need to buy any other
                    • nivocN
                      nivocN
                      nivoc
                      wrote on last edited by nivoc
                      #350
                      Did someone "test" the humidity precision of the Si7021on the sensbender? Of corse the datasheet says max 3% off but how reliable is that?
                      I have other sensors here and they differ by about 10%. So I did a "Salt-Calibration-Test" and there my two sensbenders or better Si7021 are 6% over the reference value. They report 81% and it should be 75%.
                      Note: It's my first time that I performed this test and I'm not 100% sure that the (water-salt-ratio) is correct - thats why I'm interested if someone else tested the values?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        #351
                        @nivoc
                        Salt and electronics isn't a good combination, it will cause corrosion of the copper tracks..
                        Just to warn you a little bit :)
                        • nivocN
                          nivocN
                          nivoc
                          @tbowmo Thanks. No worries the electronic won't touch the salt or water. The salt/water is just within the same closed container to bring the enclosed air to exactly 75.3% rel hum (at 25C).
                          I followed this howto: But there are many other similar ones.
                          http://www.kingofthehouse.com/hygrometer/
                          DwaltD 1 Reply Last reply
                          • nivocN nivoc
                            DwaltD
                            DwaltD
                            Dwalt
                            @nivoc I setup several sensebenders on battery last summer and noticed they were a few % below two dht22 I had been running for months. I did the saturated salt test on three sensebenders with one dht22 and one mechanical hygrometer and the sensebenders all read 74-75% while the DHT and hygrometer read 78-80%. Not a perfect test and i dont know which devices were correct but one thing I noticed was the sensebenders consistently provided the same result across different devices. Relative humidity is relative.
                            • nivocN
                              nivocN
                              nivoc
                              @Dwalt
                              Thanks for the info. I'm currently opening the box every several hours to test the salt soup. My room has something between 50 and 60 rel. (so below 75). And every time I open the box this (see pic). It drops and goes back up to 82 or 83. Than it stabilizes there over the next couple hours. There are two sensbenders in the box - thats what the two line are. And yes they are remarkable equal. But it always goes to 82 - i would hope for 75. But I will repeat this procedure until it starts to stabilizes after every opening a little bit below the value that was there before the opening. Because if that happens i am below the dry point and than I will test in a room with humidity higher than 80 and test if soup can do the same into the other direction and holds it stable for many openings. THAN i know that the salt is performing is job correctly and know that the test is good and the senbender is wrong :-) or hopefully I learn the opposite.
                              upload-555b12a4-6bc0-4e07-acf7-976c4122e6d6
                              • nivocN
                                nivocN
                                nivoc
                                Yes it looks like that the sensors are 8% off. I tested the other way around >opening at ~100rel and closing and same + exactly back to 82/83 and it should be 75% :-).
                                upload-e6c04b83-54d0-4e1e-aef3-a36b72c760d5
                                • nivocN
                                  nivocN
                                  nivoc
                                  In the new year I will test with "Magnesium chloride". It brings the rel humitity to exactly 32% - I will report how that goes :-)
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    #357
                                    If the Si7021 is exposed to high humidity for a prolonged period, the RH% measurement will shift upwards, according to the datasheet, page 15, section 4.3
                                    Extract from Datasheet:
                                    4.3. Prolonged Exposure to High Humidity
                                    Prolonged exposure to high humidity will result in a gradual upward drift of the RH reading. The shift in sensor
                                    reading resulting from this drift will generally disappear slowly under normal ambient conditions. The amount of
                                    shift is proportional to the magnitude of relative humidity and the length of exposure. In the case of lengthy
                                    exposure to high humidity, some of the resulting shift may persist indefinitely under typical conditions. It is generally
                                    possible to substantially reverse this affect by baking the device (see Section “4.6. Bake/Hydrate Procedure” ).
                                    nivocN 1 Reply Last reply
                                    • Z
                                      Z
                                      Zeph
                                      wrote on last edited by Zeph
                                      #358
                                      @petoulachi said:
                                      BTW, what is the F() function ? instead of Serial.print("Sensebender Micro FW "); why using Serial.print(F("Sensebender Micro FW ")); ?
                                      It's a way to save some RAM. A simple string constant like "Hello" takes up 6 bytes of RAM and also 6 bytes of Flash (program) memory (6 bytes includes a single "hidden" byte of binary zero as an end-of-text marker). At startup and before your code executes, that bit of program memory is copied to RAM. The F() thing is a "macro" which causes the compiler save only the 6 bytes of Flash (no Ram used). The print function can (through C++ typing) fetch those 6 bytes from Flash at runtime for printing. If you have long or many text constants in your program, this can add up to some useful savings,when you only have 2K of RAM.
                                      See the "F() Macro" on this page: https://www.arduino.cc/en/Reference/PROGMEM
                                      • tbowmoT tbowmo
                                        nivocN
                                        nivocN
                                        nivoc
                                        @tbowmo Good hint. But it is happening to all three sensbeners for at least one month now. (different orders). I now got 4 more so I will test again soon.
                                        Over xmas I tested also with magnesium chloride hexahydrate. magnesium chloride hexahydrate produces exactly 33%rel.
                                        All 3 sensbenders report exactly 39% or 40%. So they are also here 7% off. But almost the same value and very reproducible - so thats great!
                                        upload-6b1782fc-cf3e-45b8-ad15-890b7eef84a0
                                        • nivocN nivoc
                                          nivocN
                                          nivocN
                                          nivoc
                                          #360
                                          @tbowmo I'm now almost sure that my test-setup has no faults very reproducable and read many articles - I plan to verify my findings with someone who has a professional calibrated device.
                                          I saw in a museum nearby that they have professional calibrated devices :-)
                                          upload-4464b273-5525-48b2-a940-10826e61f030
                                          So I will test against those :-)
