  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.9k Views 35 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    You must not use the same serial across nodes. Serial have to be unique. HMAC have to be identical.
    • ximinezX
      ximinezX
      ximinez
      Yes, I know serial must be unique. Serials go in the whitelist for the corresponding node ID. It turned out to be the NRF24L01+-modules with antennas. Replaced it with a regular module and it worked fine.
      (Which is strange, because one of those modules worked fine on the ethernet gw. It doesn't eat that much power does it?)
      AnticimexA 1 Reply Last reply
      • ximinezX ximinez
        AnticimexA
        AnticimexA
        Anticimex
        @ximinez The signing failing is due to messages not arriving (st=fail). So it is not signing that is your problem here.
        However, with signing, messages are now "full size" which strains the RF link so if it is "weak" fewer messages get through if they are "longer". I suspect that is the problem here. Basically the usual stuff; adding caps, using a dedicated regulator and so on...
        • ximinezX
          ximinezX
          ximinez
          Looks like it works now, but what's the deal with the initial failed signs? Look at http://pastebin.ca/3585005 (GW side) and http://pastebin.ca/3585014 (Sensor side. Not the same powerup). It starts by failing a lot, then after a while everything looks OK.
          AnticimexA alexsh1A 2 Replies Last reply
          • ximinezX ximinez
            AnticimexA
            AnticimexA
            Anticimex
            @ximinez difficult to say. Maybe a long stabilization period for the regulator. You could try to add a delay in early init in the library to see if it makes a difference.
            • AnticimexA Anticimex
              AnticimexA
              AnticimexA
              Anticimex
              @Anticimex and again, it is not failed signature errors per se. It is st=fail (transmission errors) that cause the signing backend to timeout. So it is not the performance of the atsha (or sw) that cause the issue here, it is the radio.
              • tbowmoT tbowmo
                @ximinez
                For my battery reporting, I have set 1.9V as 0%, 3.3V is 100%..
                While you're at it, also power down the external flash, as it might also contribute a bit..
                ximinezX
                ximinezX
                ximinez
                @tbowmo said:
                @ximinez
                I forgot about the flash. That would require bootloader support though? Or is the OTA done by jumping to the bootloader while running, keeping pin states?
                I'm waiting for some SOIC breakouts in the mail. When I get them, I'll scavenge the ATSHA and flash module from my zombie sensor and build my own sensebender with blackjack and hookers.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @ximinez
                  Yes.. bootloader should probably by modified, if you decide to switch off the flash as well..
                  • G
                    G
                    gloob
                    wrote on last edited by gloob
                    #449
                    I did update the Arduino IDE and now I don't see the Sensebender Micro in the device list.
                    I'm using 1.6.5 and did copy the content to the boards.txt.
                    Is there something else I have to do?
                    # See: http://code.google.com/p/arduino/wiki/Platforms
                    menu.cpu=Processor
                    yun.name=Arduino Yún
                    yun.upload.via_ssh=true
                    yun.vid.0=0x2341
                    yun.pid.0=0x0041
                    yun.vid.1=0x2341
                    yun.pid.1=0x8041
                    yun.vid.2=0x2A03
                    yun.pid.2=0x0041
                    yun.vid.3=0x2A03
                    yun.pid.3=0x8041
                    yun.upload.tool=avrdude
                    yun.upload.protocol=avr109
                    yun.upload.maximum_size=28672
                    yun.upload.maximum_data_size=2560
                    yun.upload.speed=57600
                    yun.upload.disable_flushing=true
                    yun.upload.use_1200bps_touch=true
                    yun.upload.wait_for_upload_port=true
                    yun.bootloader.tool=avrdude
                    yun.bootloader.low_fuses=0xff
                    yun.bootloader.high_fuses=0xd8
                    yun.bootloader.extended_fuses=0xfb
                    yun.bootloader.file=caterina/Caterina-Yun.hex
                    yun.bootloader.unlock_bits=0x3F
                    yun.bootloader.lock_bits=0x2F
                    yun.build.mcu=atmega32u4
                    yun.build.f_cpu=16000000L
                    yun.build.vid=0x2341
                    yun.build.pid=0x8041
                    yun.build.usb_product="Arduino Yun"
                    yun.build.board=AVR_YUN
                    yun.build.core=arduino
                    yun.build.variant=yun
                    yun.build.extra_flags={build.usb_flags}
                    uno.name=Arduino/Genuino Uno
                    uno.vid.0=0x2341
                    uno.pid.0=0x0043
                    uno.vid.1=0x2341
                    uno.pid.1=0x0001
                    uno.vid.2=0x2A03
                    uno.pid.2=0x0043
                    uno.vid.3=0x2341
                    uno.pid.3=0x0243
                    uno.upload.tool=avrdude
                    uno.upload.protocol=arduino
                    uno.upload.maximum_size=32256
                    uno.upload.maximum_data_size=2048
                    uno.upload.speed=115200
                    uno.bootloader.tool=avrdude
                    uno.bootloader.low_fuses=0xFF
                    uno.bootloader.high_fuses=0xDE
                    uno.bootloader.extended_fuses=0x05
                    uno.bootloader.unlock_bits=0x3F
                    uno.bootloader.lock_bits=0x0F
                    uno.bootloader.file=optiboot/optiboot_atmega328.hex
                    uno.build.mcu=atmega328p
                    uno.build.f_cpu=16000000L
                    uno.build.board=AVR_UNO
                    uno.build.core=arduino
                    uno.build.variant=standard
                    diecimila.name=Arduino Duemilanove or Diecimila
                    diecimila.upload.tool=avrdude
                    diecimila.upload.protocol=arduino
                    diecimila.bootloader.tool=avrdude
                    diecimila.bootloader.low_fuses=0xFF
                    diecimila.bootloader.unlock_bits=0x3F
                    diecimila.bootloader.lock_bits=0x0F
                    diecimila.build.f_cpu=16000000L
                    diecimila.build.board=AVR_DUEMILANOVE
                    diecimila.build.core=arduino
                    diecimila.build.variant=standard
                    ## Arduino Duemilanove or Diecimila w/ ATmega328
                    diecimila.menu.cpu.atmega328=ATmega328
                    diecimila.menu.cpu.atmega328.upload.maximum_size=30720
                    diecimila.menu.cpu.atmega328.upload.maximum_data_size=2048
                    diecimila.menu.cpu.atmega328.upload.speed=57600
                    diecimila.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                    diecimila.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                    diecimila.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
                    diecimila.menu.cpu.atmega328.build.mcu=atmega328p
                    ## Arduino Duemilanove or Diecimila w/ ATmega168
                    diecimila.menu.cpu.atmega168=ATmega168
                    diecimila.menu.cpu.atmega168.upload.maximum_size=14336
                    diecimila.menu.cpu.atmega168.upload.maximum_data_size=1024
                    diecimila.menu.cpu.atmega168.upload.speed=19200
                    diecimila.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                    diecimila.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                    diecimila.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
                    diecimila.menu.cpu.atmega168.build.mcu=atmega168
                    nano.name=Arduino Nano
                    nano.upload.tool=avrdude
                    nano.upload.protocol=arduino
                    nano.bootloader.tool=avrdude
                    nano.bootloader.unlock_bits=0x3F
                    nano.bootloader.lock_bits=0x0F
                    nano.build.f_cpu=16000000L
                    nano.build.board=AVR_NANO
                    nano.build.core=arduino
                    nano.build.variant=eightanaloginputs
                    ## Arduino Nano w/ ATmega328
                    nano.menu.cpu.atmega328=ATmega328
                    nano.menu.cpu.atmega328.upload.maximum_size=30720
                    nano.menu.cpu.atmega328.upload.maximum_data_size=2048
                    nano.menu.cpu.atmega328.upload.speed=57600
                    nano.menu.cpu.atmega328.bootloader.low_fuses=0xFF
                    nano.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                    nano.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                    nano.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
                    nano.menu.cpu.atmega328.build.mcu=atmega328p
                    ## Arduino Nano w/ ATmega168
                    nano.menu.cpu.atmega168=ATmega168
                    nano.menu.cpu.atmega168.upload.maximum_size=14336
                    nano.menu.cpu.atmega168.upload.maximum_data_size=1024
                    nano.menu.cpu.atmega168.upload.speed=19200
                    nano.menu.cpu.atmega168.bootloader.low_fuses=0xff
                    nano.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                    nano.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                    nano.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
                    nano.menu.cpu.atmega168.build.mcu=atmega168
                    mega.name=Arduino/Genuino Mega or Mega 2560
                    mega.vid.0=0x2341
                    mega.pid.0=0x0010
                    mega.vid.1=0x2341
                    mega.pid.1=0x0042
                    mega.vid.2=0x2A03
                    mega.pid.2=0x0010
                    mega.vid.3=0x2A03
                    mega.pid.3=0x0042
                    mega.vid.4=0x2341
                    mega.pid.4=0x0210
                    mega.vid.5=0x2341
                    mega.pid.5=0x0242
                    mega.upload.tool=avrdude
                    mega.upload.maximum_data_size=8192
                    mega.bootloader.tool=avrdude
                    mega.bootloader.low_fuses=0xFF
                    mega.bootloader.unlock_bits=0x3F
                    mega.bootloader.lock_bits=0x0F
                    mega.build.f_cpu=16000000L
                    mega.build.core=arduino
                    mega.build.variant=mega
                    # default board may be overridden by the cpu menu
                    mega.build.board=AVR_MEGA2560
                    ## Arduino/Genuino Mega w/ ATmega2560
                    mega.menu.cpu.atmega2560=ATmega2560 (Mega 2560)
                    mega.menu.cpu.atmega2560.upload.protocol=wiring
                    mega.menu.cpu.atmega2560.upload.maximum_size=253952
                    mega.menu.cpu.atmega2560.upload.speed=115200
                    mega.menu.cpu.atmega2560.bootloader.high_fuses=0xD8
                    mega.menu.cpu.atmega2560.bootloader.extended_fuses=0xFD
                    mega.menu.cpu.atmega2560.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex
                    mega.menu.cpu.atmega2560.build.mcu=atmega2560
                    mega.menu.cpu.atmega2560.build.board=AVR_MEGA2560
                    ## Arduino Mega w/ ATmega1280
                    mega.menu.cpu.atmega1280=ATmega1280
                    mega.menu.cpu.atmega1280.upload.protocol=arduino
                    mega.menu.cpu.atmega1280.upload.maximum_size=126976
                    mega.menu.cpu.atmega1280.upload.speed=57600
                    mega.menu.cpu.atmega1280.bootloader.high_fuses=0xDA
                    mega.menu.cpu.atmega1280.bootloader.extended_fuses=0xF5
                    mega.menu.cpu.atmega1280.bootloader.file=atmega/ATmegaBOOT_168_atmega1280.hex
                    mega.menu.cpu.atmega1280.build.mcu=atmega1280
                    mega.menu.cpu.atmega1280.build.board=AVR_MEGA
                    megaADK.name=Arduino Mega ADK
                    megaADK.vid.0=0x2341
                    megaADK.pid.0=0x003f
                    megaADK.vid.1=0x2341
                    megaADK.pid.1=0x0044
                    megaADK.vid.2=0x2A03
                    megaADK.pid.2=0x003f
                    megaADK.vid.3=0x2A03
                    megaADK.pid.3=0x0044
                    megaADK.upload.tool=avrdude
                    megaADK.upload.protocol=wiring
                    megaADK.upload.maximum_size=253952
                    megaADK.upload.maximum_data_size=8192
                    megaADK.upload.speed=115200
                    megaADK.bootloader.tool=avrdude
                    megaADK.bootloader.low_fuses=0xFF
                    megaADK.bootloader.high_fuses=0xD8
                    megaADK.bootloader.extended_fuses=0xFD
                    megaADK.bootloader.file=stk500v2/stk500boot_v2_mega2560.hex
                    megaADK.bootloader.unlock_bits=0x3F
                    megaADK.bootloader.lock_bits=0x0F
                    megaADK.build.mcu=atmega2560
                    megaADK.build.f_cpu=16000000L
                    megaADK.build.board=AVR_ADK
                    megaADK.build.core=arduino
                    megaADK.build.variant=mega
                    leonardo.name=Arduino Leonardo
                    leonardo.vid.0=0x2341
                    leonardo.pid.0=0x0036
                    leonardo.vid.1=0x2341
                    leonardo.pid.1=0x8036
                    leonardo.vid.2=0x2A03
                    leonardo.pid.2=0x0036
                    leonardo.vid.3=0x2A03
                    leonardo.pid.3=0x8036
                    leonardo.upload.tool=avrdude
                    leonardo.upload.protocol=avr109
                    leonardo.upload.maximum_size=28672
                    leonardo.upload.maximum_data_size=2560
                    leonardo.upload.speed=57600
                    leonardo.upload.disable_flushing=true
                    leonardo.upload.use_1200bps_touch=true
                    leonardo.upload.wait_for_upload_port=true
                    leonardo.bootloader.tool=avrdude
                    leonardo.bootloader.low_fuses=0xff
                    leonardo.bootloader.high_fuses=0xd8
                    leonardo.bootloader.extended_fuses=0xcb
                    leonardo.bootloader.file=caterina/Caterina-Leonardo.hex
                    leonardo.bootloader.unlock_bits=0x3F
                    leonardo.bootloader.lock_bits=0x2F
                    leonardo.build.mcu=atmega32u4
                    leonardo.build.f_cpu=16000000L
                    leonardo.build.vid=0x2341
                    leonardo.build.pid=0x8036
                    leonardo.build.usb_product="Arduino Leonardo"
                    leonardo.build.board=AVR_LEONARDO
                    leonardo.build.core=arduino
                    leonardo.build.variant=leonardo
                    leonardo.build.extra_flags={build.usb_flags}
                    micro.name=Arduino/Genuino Micro
                    micro.vid.0=0x2341
                    micro.pid.0=0x0037
                    micro.vid.1=0x2341
                    micro.pid.1=0x8037
                    micro.vid.2=0x2A03
                    micro.pid.2=0x0037
                    micro.vid.3=0x2A03
                    micro.pid.3=0x8037
                    micro.vid.4=0x2341
                    micro.pid.4=0x0237
                    # If the board is a 2341:0237 use 2341:8237 for build and set
                    # other parameters as well
                    micro.vid.4.build.vid=0x2341
                    micro.vid.4.build.pid=0x8237
                    micro.vid.4.build.usb_product="Genuino Micro"
                    micro.vid.4.bootloader.file=caterina/Caterina-Genuino-Micro.hex
                    micro.vid.5=0x2341
                    micro.pid.5=0x8237
                    # If the board is a 2341:8237 use 2341:8237 for build and set
                    # other paramters as well
                    micro.vid.5.build.vid=0x2341
                    micro.vid.5.build.pid=0x8237
                    micro.vid.5.build.usb_product="Genuino Micro"
                    micro.vid.5.bootloader.file=caterina/Caterina-Genuino-Micro.hex
                    micro.upload.tool=avrdude
                    micro.upload.protocol=avr109
                    micro.upload.maximum_size=28672
                    micro.upload.maximum_data_size=2560
                    micro.upload.speed=57600
                    micro.upload.disable_flushing=true
                    micro.upload.use_1200bps_touch=true
                    micro.upload.wait_for_upload_port=true
                    micro.bootloader.tool=avrdude
                    micro.bootloader.low_fuses=0xff
                    micro.bootloader.high_fuses=0xd8
                    micro.bootloader.extended_fuses=0xcb
                    micro.bootloader.file=caterina/Caterina-Micro.hex
                    micro.bootloader.unlock_bits=0x3F
                    micro.bootloader.lock_bits=0x2F
                    micro.build.mcu=atmega32u4
                    micro.build.f_cpu=16000000L
                    micro.build.vid=0x2341
                    micro.build.pid=0x8037
                    micro.build.usb_product="Arduino Micro"
                    micro.build.board=AVR_MICRO
                    micro.build.core=arduino
                    micro.build.variant=micro
                    micro.build.extra_flags={build.usb_flags}
                    esplora.name=Arduino Esplora
                    esplora.vid.0=0x2341
                    esplora.pid.0=0x003C
                    esplora.vid.1=0x2341
                    esplora.pid.1=0x803C
                    esplora.vid.2=0x2A03
                    esplora.pid.2=0x003C
                    esplora.vid.3=0x2A03
                    esplora.pid.3=0x803C
                    esplora.upload.tool=avrdude
                    esplora.upload.protocol=avr109
                    esplora.upload.maximum_size=28672
                    esplora.upload.maximum_data_size=2560
                    esplora.upload.speed=57600
                    esplora.upload.disable_flushing=true
                    esplora.upload.use_1200bps_touch=true
                    esplora.upload.wait_for_upload_port=true
                    esplora.bootloader.tool=avrdude
                    esplora.bootloader.low_fuses=0xff
                    esplora.bootloader.high_fuses=0xd8
                    esplora.bootloader.extended_fuses=0xcb
                    esplora.bootloader.file=caterina/Caterina-Esplora.hex
                    esplora.bootloader.unlock_bits=0x3F
                    esplora.bootloader.lock_bits=0x2F
                    esplora.build.mcu=atmega32u4
                    esplora.build.f_cpu=16000000L
                    esplora.build.vid=0x2341
                    esplora.build.pid=0x803c
                    esplora.build.usb_product="Arduino Esplora"
                    esplora.build.board=AVR_ESPLORA
                    esplora.build.core=arduino
                    esplora.build.variant=leonardo
                    esplora.build.extra_flags={build.usb_flags}
                    mini.name=Arduino Mini
                    mini.upload.tool=avrdude
                    mini.upload.protocol=arduino
                    mini.bootloader.tool=avrdude
                    mini.bootloader.low_fuses=0xff
                    mini.bootloader.unlock_bits=0x3F
                    mini.bootloader.lock_bits=0x0F
                    mini.build.f_cpu=16000000L
                    mini.build.board=AVR_MINI
                    mini.build.core=arduino
                    mini.build.variant=eightanaloginputs
                    ## Arduino Mini w/ ATmega328
                    mini.menu.cpu.atmega328=ATmega328
                    mini.menu.cpu.atmega328.upload.maximum_size=28672
                    mini.menu.cpu.atmega328.upload.maximum_data_size=2048
                    mini.menu.cpu.atmega328.upload.speed=115200
                    mini.menu.cpu.atmega328.bootloader.high_fuses=0xd8
                    mini.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                    mini.menu.cpu.atmega328.bootloader.file=optiboot/optiboot_atmega328-Mini.hex
                    mini.menu.cpu.atmega328.build.mcu=atmega328p
                    ## Arduino Mini w/ ATmega168
                    mini.menu.cpu.atmega168=ATmega168
                    mini.menu.cpu.atmega168.upload.maximum_size=14336
                    mini.menu.cpu.atmega168.upload.maximum_data_size=1024
                    mini.menu.cpu.atmega168.upload.speed=19200
                    mini.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                    mini.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                    mini.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
                    mini.menu.cpu.atmega168.build.mcu=atmega168
                    ethernet.name=Arduino Ethernet
                    ethernet.upload.tool=avrdude
                    ethernet.upload.protocol=arduino
                    ethernet.upload.maximum_size=32256
                    ethernet.upload.maximum_data_size=2048
                    ethernet.upload.speed=115200
                    ethernet.bootloader.tool=avrdude
                    ethernet.bootloader.low_fuses=0xff
                    ethernet.bootloader.high_fuses=0xde
                    ethernet.bootloader.extended_fuses=0x05
                    ethernet.bootloader.file=optiboot/optiboot_atmega328.hex
                    ethernet.bootloader.unlock_bits=0x3F
                    ethernet.bootloader.lock_bits=0x0F
                    ethernet.build.variant=ethernet
                    ethernet.build.mcu=atmega328p
                    ethernet.build.f_cpu=16000000L
                    ethernet.build.board=AVR_ETHERNET
                    ethernet.build.core=arduino
                    fio.name=Arduino Fio
                    fio.upload.tool=avrdude
                    fio.upload.protocol=arduino
                    fio.upload.maximum_size=30720
                    fio.upload.maximum_data_size=2048
                    fio.upload.speed=57600
                    fio.bootloader.tool=avrdude
                    fio.bootloader.low_fuses=0xFF
                    fio.bootloader.high_fuses=0xDA
                    fio.bootloader.extended_fuses=0x05
                    fio.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                    fio.bootloader.unlock_bits=0x3F
                    fio.bootloader.lock_bits=0x0F
                    fio.build.mcu=atmega328p
                    fio.build.f_cpu=8000000L
                    fio.build.board=AVR_FIO
                    fio.build.core=arduino
                    fio.build.variant=eightanaloginputs
                    bt.name=Arduino BT
                    bt.upload.tool=avrdude
                    bt.upload.protocol=arduino
                    bt.upload.speed=19200
                    bt.upload.disable_flushing=true
                    bt.bootloader.tool=avrdude
                    bt.bootloader.low_fuses=0xff
                    bt.bootloader.unlock_bits=0x3F
                    bt.bootloader.lock_bits=0x0F
                    bt.build.f_cpu=16000000L
                    bt.build.board=AVR_BT
                    bt.build.core=arduino
                    bt.build.variant=eightanaloginputs
                    ## Arduino BT w/ ATmega328
                    bt.menu.cpu.atmega328=ATmega328
                    bt.menu.cpu.atmega328.upload.maximum_size=28672
                    bt.menu.cpu.atmega328.upload.maximum_data_size=2048
                    bt.menu.cpu.atmega328.bootloader.high_fuses=0xd8
                    bt.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                    bt.menu.cpu.atmega328.bootloader.file=bt/ATmegaBOOT_168_atmega328_bt.hex
                    bt.menu.cpu.atmega328.build.mcu=atmega328p
                    ## Arduino BT w/ ATmega168
                    bt.menu.cpu.atmega168=ATmega168
                    bt.menu.cpu.atmega168.upload.maximum_size=14336
                    bt.menu.cpu.atmega168.upload.maximum_data_size=1024
                    bt.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                    bt.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                    bt.menu.cpu.atmega168.bootloader.file=bt/ATmegaBOOT_168.hex
                    bt.menu.cpu.atmega168.build.mcu=atmega168
                    LilyPadUSB.name=LilyPad Arduino USB
                    LilyPadUSB.vid.0=0x1B4F
                    LilyPadUSB.pid.0=0x9207
                    LilyPadUSB.vid.1=0x1B4F
                    LilyPadUSB.pid.1=0x9208
                    LilyPadUSB.upload.tool=avrdude
                    LilyPadUSB.upload.protocol=avr109
                    LilyPadUSB.upload.maximum_size=28672
                    LilyPadUSB.upload.maximum_data_size=2560
                    LilyPadUSB.upload.speed=57600
                    LilyPadUSB.upload.disable_flushing=true
                    LilyPadUSB.upload.use_1200bps_touch=true
                    LilyPadUSB.upload.wait_for_upload_port=true
                    LilyPadUSB.bootloader.tool=avrdude
                    LilyPadUSB.bootloader.low_fuses=0xff
                    LilyPadUSB.bootloader.high_fuses=0xd8
                    LilyPadUSB.bootloader.extended_fuses=0xce
                    LilyPadUSB.bootloader.file=caterina-LilyPadUSB/Caterina-LilyPadUSB.hex
                    LilyPadUSB.bootloader.unlock_bits=0x3F
                    LilyPadUSB.bootloader.lock_bits=0x2F
                    LilyPadUSB.build.mcu=atmega32u4
                    LilyPadUSB.build.f_cpu=8000000L
                    LilyPadUSB.build.vid=0x1B4F
                    LilyPadUSB.build.pid=0x9208
                    LilyPadUSB.build.usb_product="LilyPad USB"
                    LilyPadUSB.build.board=AVR_LILYPAD_USB
                    LilyPadUSB.build.core=arduino
                    LilyPadUSB.build.variant=leonardo
                    LilyPadUSB.build.extra_flags={build.usb_flags}
                    lilypad.name=LilyPad Arduino
                    lilypad.upload.tool=avrdude
                    lilypad.upload.protocol=arduino
                    lilypad.bootloader.tool=avrdude
                    lilypad.bootloader.unlock_bits=0x3F
                    lilypad.bootloader.lock_bits=0x0F
                    lilypad.build.f_cpu=8000000L
                    lilypad.build.board=AVR_LILYPAD
                    lilypad.build.core=arduino
                    lilypad.build.variant=standard
                    ## LilyPad Arduino w/ ATmega328
                    lilypad.menu.cpu.atmega328=ATmega328
                    lilypad.menu.cpu.atmega328.upload.maximum_size=30720
                    lilypad.menu.cpu.atmega328.upload.maximum_data_size=2048
                    lilypad.menu.cpu.atmega328.upload.speed=57600
                    lilypad.menu.cpu.atmega328.bootloader.low_fuses=0xFF
                    lilypad.menu.cpu.atmega328.bootloader.high_fuses=0xDA
                    lilypad.menu.cpu.atmega328.bootloader.extended_fuses=0x05
                    lilypad.menu.cpu.atmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                    lilypad.menu.cpu.atmega328.build.mcu=atmega328p
                    ## LilyPad Arduino w/ ATmega168
                    lilypad.menu.cpu.atmega168=ATmega168
                    lilypad.menu.cpu.atmega168.upload.maximum_size=14336
                    lilypad.menu.cpu.atmega168.upload.maximum_data_size=1024
                    lilypad.menu.cpu.atmega168.upload.speed=19200
                    lilypad.menu.cpu.atmega168.bootloader.low_fuses=0xe2
                    lilypad.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                    lilypad.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                    lilypad.menu.cpu.atmega168.bootloader.file=lilypad/LilyPadBOOT_168.hex
                    lilypad.menu.cpu.atmega168.build.mcu=atmega168
                    pro.name=Arduino Pro or Pro Mini
                    pro.upload.tool=avrdude
                    pro.upload.protocol=arduino
                    pro.bootloader.tool=avrdude
                    pro.bootloader.unlock_bits=0x3F
                    pro.bootloader.lock_bits=0x0F
                    pro.build.board=AVR_PRO
                    pro.build.core=arduino
                    pro.build.variant=eightanaloginputs
                    ## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328
                    pro.menu.cpu.16MHzatmega328=ATmega328 (5V, 16 MHz)
                    pro.menu.cpu.16MHzatmega328.upload.maximum_size=30720
                    pro.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048
                    pro.menu.cpu.16MHzatmega328.upload.speed=57600
                    pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
                    pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
                    pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x05
                    pro.menu.cpu.16MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
                    pro.menu.cpu.16MHzatmega328.build.mcu=atmega328p
                    pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
                    ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
                    pro.menu.cpu.8MHzatmega328=ATmega328 (3.3V, 8 MHz)
                    pro.menu.cpu.8MHzatmega328.upload.maximum_size=30720
                    pro.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
                    pro.menu.cpu.8MHzatmega328.upload.speed=57600
                    pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
                    pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
                    pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x05
                    pro.menu.cpu.8MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                    pro.menu.cpu.8MHzatmega328.build.mcu=atmega328p
                    pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
                    ## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega168
                    pro.menu.cpu.16MHzatmega168=ATmega168 (5V, 16 MHz)
                    pro.menu.cpu.16MHzatmega168.upload.maximum_size=14336
                    pro.menu.cpu.16MHzatmega168.upload.maximum_data_size=1024
                    pro.menu.cpu.16MHzatmega168.upload.speed=19200
                    pro.menu.cpu.16MHzatmega168.bootloader.low_fuses=0xff
                    pro.menu.cpu.16MHzatmega168.bootloader.high_fuses=0xdd
                    pro.menu.cpu.16MHzatmega168.bootloader.extended_fuses=0x00
                    pro.menu.cpu.16MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
                    pro.menu.cpu.16MHzatmega168.build.mcu=atmega168
                    pro.menu.cpu.16MHzatmega168.build.f_cpu=16000000L
                    ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega168
                    pro.menu.cpu.8MHzatmega168=ATmega168 (3.3V, 8 MHz)
                    pro.menu.cpu.8MHzatmega168.upload.maximum_size=14336
                    pro.menu.cpu.8MHzatmega168.upload.maximum_data_size=1024
                    pro.menu.cpu.8MHzatmega168.upload.speed=19200
                    pro.menu.cpu.8MHzatmega168.bootloader.low_fuses=0xc6
                    pro.menu.cpu.8MHzatmega168.bootloader.high_fuses=0xdd
                    pro.menu.cpu.8MHzatmega168.bootloader.extended_fuses=0x00
                    pro.menu.cpu.8MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_pro_8MHz.hex
                    pro.menu.cpu.8MHzatmega168.build.mcu=atmega168
                    pro.menu.cpu.8MHzatmega168.build.f_cpu=8000000L
                    atmegang.name=Arduino NG or older
                    atmegang.upload.tool=avrdude
                    atmegang.upload.protocol=arduino
                    atmegang.upload.speed=19200
                    atmegang.bootloader.tool=avrdude
                    atmegang.bootloader.unlock_bits=0x3F
                    atmegang.bootloader.lock_bits=0x0F
                    atmegang.build.mcu=atmegang
                    atmegang.build.f_cpu=16000000L
                    atmegang.build.board=AVR_NG
                    atmegang.build.core=arduino
                    atmegang.build.variant=standard
                    ## Arduino NG or older w/ ATmega168
                    atmegang.menu.cpu.atmega168=ATmega168
                    atmegang.menu.cpu.atmega168.upload.maximum_size=14336
                    atmegang.menu.cpu.atmega168.upload.maximum_data_size=1024
                    atmegang.menu.cpu.atmega168.bootloader.low_fuses=0xff
                    atmegang.menu.cpu.atmega168.bootloader.high_fuses=0xdd
                    atmegang.menu.cpu.atmega168.bootloader.extended_fuses=0x00
                    atmegang.menu.cpu.atmega168.bootloader.file=atmega/ATmegaBOOT_168_ng.hex
                    atmegang.menu.cpu.atmega168.build.mcu=atmega168
                    ## Arduino NG or older w/ ATmega8
                    atmegang.menu.cpu.atmega8=ATmega8
                    atmegang.menu.cpu.atmega8.upload.maximum_size=7168
                    atmegang.menu.cpu.atmega8.upload.maximum_data_size=1024
                    atmegang.menu.cpu.atmega8.bootloader.low_fuses=0xdf
                    atmegang.menu.cpu.atmega8.bootloader.high_fuses=0xca
                    atmegang.menu.cpu.atmega8.bootloader.file=atmega8/ATmegaBOOT-prod-firmware-2009-11-07.hex
                    atmegang.menu.cpu.atmega8.build.mcu=atmega8
                    robotControl.name=Arduino Robot Control
                    robotControl.vid.0=0x2341
                    robotControl.pid.0=0x0038
                    robotControl.vid.1=0x2341
                    robotControl.pid.1=0x8038
                    robotControl.vid.2=0x2A03
                    robotControl.pid.2=0x0038
                    robotControl.vid.3=0x2A03
                    robotControl.pid.3=0x8038
                    robotControl.upload.tool=avrdude
                    robotControl.upload.protocol=avr109
                    robotControl.upload.maximum_size=28672
                    robotControl.upload.maximum_data_size=2560
                    robotControl.upload.speed=57600
                    robotControl.upload.disable_flushing=true
                    robotControl.upload.use_1200bps_touch=true
                    robotControl.upload.wait_for_upload_port=true
                    robotControl.bootloader.tool=avrdude
                    robotControl.bootloader.low_fuses=0xff
                    robotControl.bootloader.high_fuses=0xd8
                    robotControl.bootloader.extended_fuses=0xcb
                    robotControl.bootloader.file=caterina-Arduino_Robot/Caterina-Robot-Control.hex
                    robotControl.bootloader.unlock_bits=0x3F
                    robotControl.bootloader.lock_bits=0x2F
                    robotControl.build.mcu=atmega32u4
                    robotControl.build.f_cpu=16000000L
                    robotControl.build.vid=0x2341
                    robotControl.build.pid=0x8038
                    robotControl.build.usb_product="Robot Control"
                    robotControl.build.board=AVR_ROBOT_CONTROL
                    robotControl.build.core=arduino
                    robotControl.build.variant=robot_control
                    robotControl.build.extra_flags={build.usb_flags}
                    robotMotor.name=Arduino Robot Motor
                    robotMotor.vid.0=0x2341
                    robotMotor.pid.0=0x0039
                    robotMotor.vid.1=0x2341
                    robotMotor.pid.1=0x8039
                    robotMotor.vid.2=0x2A03
                    robotMotor.pid.2=0x0039
                    robotMotor.vid.3=0x2A03
                    robotMotor.pid.3=0x8039
                    robotMotor.upload.tool=avrdude
                    robotMotor.upload.protocol=avr109
                    robotMotor.upload.maximum_size=28672
                    robotMotor.upload.maximum_data_size=2560
                    robotMotor.upload.speed=57600
                    robotMotor.upload.disable_flushing=true
                    robotMotor.upload.use_1200bps_touch=true
                    robotMotor.upload.wait_for_upload_port=true
                    robotMotor.bootloader.tool=avrdude
                    robotMotor.bootloader.low_fuses=0xff
                    robotMotor.bootloader.high_fuses=0xd8
                    robotMotor.bootloader.extended_fuses=0xcb
                    robotMotor.bootloader.file=caterina-Arduino_Robot/Caterina-Robot-Motor.hex
                    robotMotor.bootloader.unlock_bits=0x3F
                    robotMotor.bootloader.lock_bits=0x2F
                    robotMotor.build.mcu=atmega32u4
                    robotMotor.build.f_cpu=16000000L
                    robotMotor.build.vid=0x2341
                    robotMotor.build.pid=0x8039
                    robotMotor.build.usb_product="Robot Motor"
                    robotMotor.build.board=AVR_ROBOT_MOTOR
                    robotMotor.build.core=arduino
                    robotMotor.build.variant=robot_motor
                    robotMotor.build.extra_flags={build.usb_flags}
                    gemma.vid.0=0x2341
                    gemma.pid.0=0x0c9f
                    gemma.name=Arduino Gemma
                    gemma.bootloader.low_fuses=0xF1
                    gemma.bootloader.high_fuses=0xD5
                    gemma.bootloader.extended_fuses=0xFE
                    gemma.bootloader.tool=avrdude
                    gemma.bootloader.lock_bits=
                    gemma.bootloader.unlock_bits=
                    gemma.bootloader.file=gemma/gemma_v1.hex
                    gemma.build.mcu=attiny85
                    gemma.build.f_cpu=8000000L
                    gemma.build.core=arduino
                    gemma.build.variant=gemma
                    gemma.build.board=AVR_GEMMA
                    gemma.upload.tool=avrdude
                    gemma.upload.maximum_size=5310
                    menu.cpu=Processor
                    ## Sensebender Micro
                    MysensorsMicro.name=Sensebender Micro
                    MysensorsMicro.upload.tool=arduino:avrdude
                    MysensorsMicro.upload.protocol=arduino
                    MysensorsMicro.upload.maximum_size=30720
                    MysensorsMicro.upload.maximum_data_size=2048
                    MysensorsMicro.upload.speed=57600
                    MysensorsMicro.bootloader.tool=arduino:avrdude
                    MysensorsMicro.bootloader.unlock_bits=0x3F
                    MysensorsMicro.bootloader.lock_bits=0x0F
                    MysensorsMicro.bootloader.low_fuses=0xE2
                    MysensorsMicro.bootloader.high_fuses=0xD2
                    MysensorsMicro.bootloader.extended_fuses=0x06
                    MysensorsMicro.bootloader.file=DualOptiboot/optiboot_atmega328_pro_8MHz.hex
                    MysensorsMicro.build.board=AVR_MICRO8
                    MysensorsMicro.build.core=arduino:arduino
                    MysensorsMicro.build.variant=micro
                    MysensorsMicro.build.mcu=atmega328p
                    #MysensorsMicro.build.f_cpu=8000000L
                    MysensorsMicro.menu.cpu.8Mhz=Atmega328 8Mhz
                    MysensorsMicro.menu.cpu.8Mhz.build.f_cpu=8000000L
                    MysensorsMicro.menu.cpu.1Mhz=Atmega328 1Mhz
                    MysensorsMicro.menu.cpu.1Mhz.build.f_cpu=1000000L
                    I'm using a Mac if it is important.
                    • A
                      A
                      alexeinz
                      Is it possible to use the ftdi or isp vcc / gnd to connect a pir ?
                      or do i need to source separate power and gnd for pir ?
                      mqtt gw 1.4 /openhab / zwave
                        @gloob
                        Maybe a little late, but the Sensebender is now available to be downloaded directly in the IDE using board manager.
                        https://github.com/mysensors/ArduinoBoards
                        @alexeinz
                        You can use the same power/ground plane (and any of the digital inputs). Also note that the pir might need to be modified to handle 3v3.
                        https://forum.mysensors.org/topic/1088/battery-powered-pir
                          @gloob
                          @alexeinz
                          A
                          A
                          alexeinz
                          @hek ...so to clarify , I can use the VCC and Ground of the ISP portion to power the sensor?
                          ( my pir already modded for 3.3 )
                            wrote on last edited by hek
                            #453
                            Yes, it doesn't matter. GND/VCC is the same no matter where you pull it on the board.
                            • ximinezX ximinez
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #454
                              @Anticimex
                              I have exactly the same problem with Ethernet GW (Mega + Ethernet shield) + Sensebender:
                              GW:
                              0;255;3;0;9;Starting gateway (RNNGAS, 2.0.0-beta)
                              0;255;3;0;9;Radio init successful.
                              IP: 0.0.0.0
                              0;255;3;0;9;Init complete, id=0, parent=0, distance=0
                              0;255;3;0;9;Skipping security for command 3 type 16
                              0;255;3;0;9;read: 3-3-0 s=255,c=3,t=16,pt=0,l=0,sg=0:
                              0;255;3;0;9;Signing backend: ATSHA204Soft
                              0;255;3;0;9;SHA256: 86DEAE1DAF50D577A4E2262B33ABF9DEE05DD8FAF84F94F50900000000000000
                              0;255;3;0;9;Transmittng nonce
                              0;255;3;0;9;Skipping security for command 3 type 17
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:86DEAE1DAF50D577A4E2262B33ABF9DEE05DD8FAF84F94F509
                              0;255;3;0;9;Message is not signed, but it should have been!
                              0;255;3;0;9;verify fail
                              0;255;3;0;9;SHA256: 5D009DC0245C411DABE519AB62E32B24333CA92BE1BA9EC1CBAAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:5D009DC0245C411DABE519AB62E32B24333CA92BE1BA9EC1CB
                              0;255;3;0;9;read: 3-3-0 s=1,c=3,t=16,pt=0,l=0,sg=0:
                              0;255;3;0;9;SHA256: EF67FAAED617A07C4EFC978F44BD41B77A4834BB83581C19FFAAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:EF67FAAED617A07C4EFC978F44BD41B77A4834BB83581C19FF
                              0;255;3;0;9;read: 3-3-0 s=2,c=3,t=16,pt=0,l=0,sg=0:
                              0;255;3;0;9;SHA256: 41D57E19D687AC4EBCC59179C6ADC1E155A252315EB1DF4F89AAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:41D57E19D687AC4EBCC59179C6ADC1E155A252315EB1DF4F89
                              0;255;3;0;9;read: 3-3-0 s=3,c=3,t=16,pt=0,l=0,sg=0:
                              0;255;3;0;9;SHA256: FEBB9B588209F4FAAB95A64FCAD9F4B0E5025356AC4E0935DDAAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:FEBB9B588209F4FAAB95A64FCAD9F4B0E5025356AC4E0935DD
                              0;255;3;0;9;Verification timeout
                              0;255;3;0;9;SHA256: B1E3C1C0EA9829F4B0240246C91DB8B7C29EBB3255D4F6117CAAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:B1E3C1C0EA9829F4B0240246C91DB8B7C29EBB3255D4F6117C
                              0;255;3;0;9;SHA256: 92BAB2A723258EA923048423F81DA245F3F932AF64F22C5F40AAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:92BAB2A723258EA923048423F81DA245F3F932AF64F22C5F40
                              0;255;3;0;9;SHA256: B5D717D5B8F0F93A030B0125F273C002AED8DB29AC175C80E4AAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:B5D717D5B8F0F93A030B0125F273C002AED8DB29AC175C80E4
                              0;255;3;0;9;SHA256: B2D64F2C3EB1CCBA1250FF88120A8877E3414546D1B209C2AEAAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=fail:B2D64F2C3EB1CCBA1250FF88120A8877E3414546D1B209C2AE
                              0;255;3;0;9;Skipping security for command 3 type 15
                              0;255;3;0;9;read: 3-3-0 s=255,c=3,t=15,pt=0,l=2,sg=0:
                              0;255;3;0;9;Mark node 3 as one that require signed messages
                              0;255;3;0;9;Mark node 3 as one that do not require whitelisting
                              0;255;3;0;9;Informing node 3 that we require signatures
                              0;255;3;0;9;Informing node 3 that we do not require whitelisting
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                              0;255;3;0;9;SHA256: 04C65FB99F798197CD5474AE7CC8625595B49655D311173412AAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:04C65FB99F798197CD5474AE7CC8625595B49655D311173412
                              0;255;3;0;9;Signature in message: 010017891177284094289CCA41F5E3
                              0;255;3;0;9;Message to process: 0300560011FF322E302E302D62657461
                              0;255;3;0;9;Current nonce: 04C65FB99F798197CD5474AE7CC8625595B49655D311173412AAAAAAAAAAAAAA
                              0;255;3;0;9;HMAC: 37A3D7AFFCD292EAFD64017F9845DD4AD49624C37348B63B87699D273CA5F27F
                              0;255;3;0;9;Signature bad: 01A3D7AFFCD292EAFD64017F9845DD
                              0;255;3;0;9;Signature verification failed!
                              0;255;3;0;9;SHA256: 66CC761B15338987ABA7DDEB567F78EFA6E32BD0A6895A8EDDAAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:66CC761B15338987ABA7DDEB567F78EFA6E32BD0A6895A8EDD
                              0;255;3;0;9;Signature in message: 0127D1050EA18AC0EE1FD1C5C1496AE3772D390F25E4D6B5
                              0;255;3;0;9;Message to process: 03000E2306FF00
                              0;255;3;0;9;Current nonce: 66CC761B15338987ABA7DDEB567F78EFA6E32BD0A6895A8EDDAAAAAAAAAAAAAA
                              0;255;3;0;9;HMAC: 69E44BF99E8E4842A47D14C11B849C059B9AD62B40FF8B3BC8F41FE419C032D8
                              0;255;3;0;9;Signature bad: 01E44BF99E8E4842A47D14C11B849C059B9AD62B40FF8B3B
                              0;255;3;0;9;SHA256: B588F20DC0FFBCCE5B40563F5618901E1F46F5996A90146687AAAAAAAAAAAAAA
                              0;255;3;0;9;send: 0-0-3-3 s=255,c=3,t=17,pt=6,l=25,sg=0,st=ok:B588F20DC0FFBCCE5B40563F5618901E1F46F5996A90146687
                              0;255;3;0;9;Signature in message: 01C32806F6BA82E2BA08D8BC47AEAE
                              0;255;3;0;9;Message to process: 030056C400FFFFFFFFFFFFFFFFFF0300
                              0;255;3;0;9;Current nonce: B588F20DC0FFBCCE5B40563F5618901E1F46F5996A90146687AAAAAAAAAAAAAA
                              0;255;3;0;9;HMAC: B532A92B09B8A52F01630B4FCD29CD4C380317D14FFCEDE34284BDF61C13953D
                              0;255;3;0;9;Signature bad: 0132A92B09B8A52F01630B4FCD29CD
                              Sensebender:
                              Starting sensor (RNONAA, 2.0.0-beta)
                              Sensebender Micro FW 1.5 - Online!
                              send: 3-3-0-0 s=255,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                              Nonce requested from 0. Waiting...
                              Timeout waiting for nonce!
                              sign fail
                              send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=17,sg=0,st=ok:Sensebender Micro
                              sign fail
                              send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.5
                              send: 3-3-0-0 s=1,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                              sign fail
                              send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                              send: 3-3-0-0 s=2,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                              sign fail
                              send: 3-3-0-0 s=2,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                              send: 3-3-0-0 s=3,c=3,t=16,pt=0,l=0,sg=0,st=ok:
                              sign fail
                              send: 3-3-0-0 s=3,c=0,t=13,pt=0,l=0,sg=0,st=ok:
                              isMetric: 1
                              TempDiff :127.32
                              HumDiff  :141.00
                              T: 27.32
                              H: 41
                              sign fail
                              send: 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:27.3
                              sign fail
                              send: 3-3-0-0 s=2,c=1,t=1,pt=2,l=2,sg=0,st=ok:41
                              sign fail
                              send: 3-3-0-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.20
                              Message to send could not be signed!
                              sign fail
                              send: 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:92
                              OTA FW update enabled
                              Signing required
                              send: 3-3-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
                              Waiting for GW to send signing preferences...
                              read: 0-0-3 s=255,c=3,t=15,pt=0,l=2,sg=0:
                              Mark node 0 as one that require signed messages
                              Mark node 0 as one that do not require whitelisting
                              read: 0-0-3 s=255,c=3,t=17,pt=6,l=25,sg=0:AC862B6EC2DC2CD7EEF32DD146F7D57DA738137D592460D5E5
                              Nonce received from 0. Proceeding with signing...
                              Current nonce: AC862B6EC2DC2CD7EEF32DD146F7D57DA738137D592460D5E5AAAAAAAAAAAAAA
                              HMAC: 65C59C709F8B194B4005D830F86D1F502C0707090C131C5A15356A26C3D72C8E
                              Signature in message: 01C59C709F8B194B4005D830F86D1F
                              Message signed
                              Message to send has been signed
                              send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=10,sg=1,st=ok:2.0.0-beta
                              read: 0-0-3 s=255,c=3,t=17,pt=6,l=25,sg=0:99C1B06E9EA6E561D7089ECA5AECAD47247C3966848FDA3669
                              Current nonce: 99C1B06E9EA6E561D7089ECA5AECAD47247C3966848FDA3669AAAAAAAAAAAAAA
                              HMAC: 357966889DA8D9414C49B4AF9AACEDF786D05722F50DEE43CE05559514938EB7
                              Signature in message: 017966889DA8D9414C49B4AF9AACEDF786D05722F50DEE43
                              Message signed
                              send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=1,st=ok:0
                              read: 0-0-3 s=255,c=3,t=17,pt=6,l=25,sg=0:A45F00D4D8F06B269F8D09928663D2088313BF36C2DCCC78B6
                              Current nonce: A45F00D4D8F06B269F8D09928663D2088313BF36C2DCCC78B6AAAAAAAAAAAAAA
                              HMAC: 3A6645A45367626C11E5FCA20C19B6430DD840300ED79CB7B25097B5FED0897D
                              Signature in message: 016645A45367626C11E5FCA20C19B6
                              Message signed
                              send: 3-3-0-0 s=255,c=4,t=0,pt=6,l=10,sg=1,st=ok:FFFFFFFFFFFFFFFF0300
                              Init complete, id=3, parent=0, distance=1
                              TempDiff :0.12
                              HumDiff  :0.50
                              TempDiff :0.00
                              HumDiff  :0.50
                              TempDiff :0.00
                              HumDiff  :0.00
                              There is a lot of "Nonce requested from 0. Waiting..."messages
                              • alexsh1A alexsh1
                                @Anticimex
                                GW:
                                IP: 0.0.0.0
                                Sensebender:
                                sign fail
                                sign fail
                                sign fail
                                sign fail
                                sign fail
                                isMetric: 1
                                TempDiff :127.32
                                HumDiff  :141.00
                                T: 27.32
                                H: 41
                                sign fail
                                sign fail
                                sign fail
                                sign fail
                                Signing required
                                Message signed
                                Message signed
                                Message signed
                                TempDiff :0.12
                                HumDiff  :0.50
                                TempDiff :0.00
                                HumDiff  :0.50
                                TempDiff :0.00
                                HumDiff  :0.00
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @alexsh1
                                I am afraid I have to repeat what I have also said to other on the forum having problems with signing;
                                you do not have problems with signing, you have problems with radio (st=fail). As long as you have st=fail, signing will not work reliably. It will not be less secure, but it will not let messages through.
                                It is easy to suspect singing, because it might very well work better with signing off, but the reason for this is that signing uses the entire maximum message payload, and this makes it "harder" for the radio to send all the bits correctly, thus increasing the chances of a st=fail in case the link is not reliable.
                                alexsh1A 1 Reply Last reply
                                  @alexsh1
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #456
                                  @Anticimex I agree with you, but I find it interesting that sending a message fails exactly 9 times every time the node starts. I have changed different nrf24l01+ modules, put the transceivers close / far - it made absolutely no influence at all. 9 times st=fail and then everything works as expected.
                                  • alexsh1A alexsh1
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @alexsh1 yes, it seem an odd coincidence. But I see nothing that signing can do about it I am afraid. st=fail means a message was not confirmed to get delivered properly and signing can't handle message drops. For security reasons, I have decided to not support retransmissions of nonces. If it can't be delivered, the entire signing session is considered compromised and have to be restarted with the exchange of a new nonce.
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      #458
                                      It is even more interesting that I have zero st=fail after nonce is received .
                                      I can probably change the GW settings and the channel to make sure this is not causing any issues, but 9 st=fail in the beginning every time is a strange coincidence.
                                      @ximinez Did you manage to get it sorted? How many st=fail do you have in the beginning?
                                      Anyone else is having similar issues?
                                      • alexsh1A alexsh1
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @alexsh1 Perhaps a long stabilization time for a power supply or clock on the node or gw cause it. You could try to add some delays and see if it is time-after-power-on that is the issue or whatever it might be. It is not signing in any case, because it is the node sending that reports st=fail. That is a rf issue. It always is. The nonce has been generated as it should, and the signing backend trusts the transport layer to handle the transmission of the databuffer, and in this case the transport layer reports back that it could not.
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Anticimex Just an idea - could it be that nonce is not generated in the beginning and requires some time? I'll do some testing tonight
