  3. Receive Battery percentage via MQTT on OpenHab?
6 Posts 2 Posters 3.1k Views 1 Watching
  • K
    K
    kunall
    Hello
    I'm trying to receive battery percentage over MQTT on openHab. So far i'm dont have any luck. I'm confused, because there is no such V_Battery or something like that.
    I would really appreciate any help as i'm trying to finish my project before my final exam starts. :disappointed:
    Here is my serial output. I was testing the battery sketch on Nano powerd via USB 5.0v. I know i'm getting incorrect reading, but thats okay for now, I just need to receive battery percentage via MQTT first.
    • FotoFieberF
      FotoFieberF
      FotoFieber
      Which MQTT gateway do you use?
      Maybe in your gateway the battery percentage is not implemented.
      See http://forum.mysensors.org/topic/524/mqtt-client-gateway/29
      K 1 Reply Last reply
      • FotoFieberF FotoFieber
        K
        K
        kunall
        wrote on last edited by kunall
        @FotoFieber I'm using THIS MQTT Gateway. Is there a better MQTT gateway solution available? Sorry i'm new to all this.
        • FotoFieberF
          FotoFieberF
          FotoFieber
          The sketch you use doesn't support following internal messages:
          • sketchinfo
          • sketchversion
          • time
          • batterylevel
          See link above...
            • sketchinfo
            • sketchversion
            • time
            • batterylevel
            See link above...
            K
            K
            kunall
            @FotoFieber I followed the sketch that you provided in your link above called "MQTT Client Gateway". however, while compiling that sketch I'm getting following error?
            Any solution or suggestion for that?
            • FotoFieberF
              FotoFieberF
              FotoFieber
              Please try this:
              http://forum.mysensors.org/topic/524/mqtt-client-gateway/11
