  3. Shift register node
Shift register node
5 Posts 3 Posters 2.5k Views 1 Watching
  • ferpandoF
    ferpandoF
    ferpando
    wrote on last edited by ferpando
    I'll start a new topic for this as I think it is a new device type.
    How can I allow a node with a shift register to be controlled by the gateway node?
    Is there some example sketch to deal with shift registers instead of relays?
    Thanks in advance
    • ferpandoF ferpando
      Thanks in advance
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @ferpando
      What are you doing with the shift register?
      Jim
      ferpandoF 1 Reply Last reply
        @ferpando
        Jim
        ferpandoF
        ferpandoF
        ferpando
        @BulldogLowell
        I made an interface to control 3 somfi blinds using the remotes. I needed to control 9 buttons, so I used 9 optocouplers and 2 shift registers to get the outputs needed from an arduino pro mini.
        YveauxY 1 Reply Last reply
          @BulldogLowell
          YveauxY
          YveauxY
          @ferpando I guess you're using shift registers because you lack enough output pins?
          You could present the 3 blinds as e.g. 3 different childId's on the node.
          Each child then has 3 actuators: V_UP, V_DOWN, V_STOP
          When your node receives an update for one of these values, then just update the corresponding actuator and shift out the state for all 9 optocouplers, and you're done!
          No new 'shift register' type required, as I see it.
          • YveauxY Yveaux
            ferpandoF
            ferpandoF
            ferpando
            @Yveaux
            You might be right, but then again how would I learn about shift registers if I don't use them? :-)
