  3. 433MHz amplified (>5V)
22 Posts 4 Posters 14.5k Views 3 Watching
  • S Sparkman
    @andriej Digikey has a good transistor selector. You can see the specs for the 4403 and then find something with similar specs that may be more readily available where you live.
    http://www.digikey.com/product-search/en?pv7=2&FV=fff40015%2Cfff80078%2C1140050%2C1280002%2C142c0044%2C142c02ca%2C142c1dec&k=transistor&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
    Cheers
    Al
    A Offline
    A Offline
    andriej
    @Sparkman Thank you, will find them.
    I've also ordered some 20mW modules from China manufacturer with specially-made antenna (spring-one).
    I hope I'll get better range with that, especially that they're made for 3.3V and can be powered with max 5V.
    • Yohann StreibelY Offline
      Yohann Streibel
      I create a rflink pcb with this schema rflink_schema.jpeg.
      I have an emission issue, the module RF 433Mhz Out not have 12v in VOUT+.
      What could I need to do.
      This is the pcb design, maybe it needs some improvement.
