  3. 433MHz amplified (>5V)
22 Posts 4 Posters 14.7k Views 3 Watching
  • A
    A
    andriej
    Hi!
    For the remote wall plugs I currently have a 433 Mhz transceiver which sends proper code and turns them on and off.
    When I've moved to new location I have problems with signal reaching the outlets as the distance went a little further (but nothing above 'normal flat' values).
    In specification of TX 433MHz (basic, cheap China one0 it's stated that it can be powered with voltage 5-12V. Now it's powered from Arduino but I'd like to connect 9V-12V power supply and feed the power staight to module.
    Unfortunately specs also say that 'HIGH" voltage value of DATA pin should be at least 1/2 of Vcc, so for 12V it's 6V, which Arduino won't supply. I've tried to connect PN2222A to drive the power exactly to pin, but I couldn't get it to work (it worked for 1 of 5 tries to send code which reached outlet).
    Any ideas/schematics how to connect and rive the module to get maximum output power while being properly sent by Arduino?
    Unfortunately, itnernet seems to be quiet about the topic and I can see a lot of experienced PCB-designers, so maybe with a little help I can finally make something more reliable...
    Regards,
    Andrew
    • BulldogLowellB
      BulldogLowellB
      BulldogLowell
      have you thought about transistor switching?
      • A
        A
        andriej
        I've thought and I've once even tried.
        I don't know if I wired it properly, but it wasn't much more reliable than it was without transistor.
        I can't find schematics including transistor and resistors how to connect it properly and how to prevent arduino resetting while TX module was transmitting (I've encountered this problem).
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          separate the power supplies and test it, powering each one separately. Use the transistor to switch the radio's Vcc (with the base of the transistor connected to your arduino's output pin).
          The signal from the arduino with this switching method can be shifted up to the voltage for the radio.
          look for a small signal NPN transistor, and google "Transistor Switching"
          • A
            A
            andriej
            I got the PN2222A but I struggle what should be connected to emitter, base and collector. What my thougt was: emitter to Data pin, collector to Vcc of 12v supply and base to arduino data pin, no resistors used.
            But should the gnd be both connected? And Vcc of 433 TX is connected to +12v power supply.
            It is Uno so I can power it with usb separately.
            • A
              A
              andriej
              SparkmanS 1 Reply Last reply
              • A andriej
                SparkmanS
                SparkmanS
                Sparkman
                wrote on last edited by Sparkman
                @andriej That's not the right way as there's nothing (other than the transistor) limiting the current between Vcc and GND. What you need to do is level shift the output of Pin 2 (0 to 5V) to the data input of the 433 module. The best way to level shift would be to do something like this:
                See http://electronics.stackexchange.com/questions/17581/best-way-to-get-5v-or-12v-or-0v-from-arduino-pin for details on this circuit.
                Cheers
                Al
                A 1 Reply Last reply
                • SparkmanS Sparkman
                  Cheers
                  Al
                  A
                  A
                  andriej
                  @Sparkman thank you for your reply!
                  So I'd need two transistors - that's ok... But how (and which one) do I connect to DATA pin (as I assume)?
                  Or i could bridge P1 and P2 mentioned on schematics above?
                  • A andriej
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @andriej P1 would connect to the data pin. Ignore P2 as it is just ground.
                    Cheers
                    Al
                      Cheers
                      Al
                      A
                      A
                      andriej
                      @Sparkman Right, now I see.
                      Will NPN (2N2222 which I have) do the job?
                      • A andriej
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @andriej It'll do the job of Q1, but Q2 is a PNP transistor. For it you would need something like the 2N2907, 2N3906 or 2N4403.
                          A
                          A
                          andriej
                          wrote on last edited by andriej
                          @Sparkman time for getting parts as I don't have PNP in house.
                          Thank you. :-) Tommorow I'll test it out.
                          Just to be 100% sure - both GND's should be connected together (Uno's and 12V supply?)
                          • A andriej
                            SparkmanS
                            SparkmanS
                            Sparkman
                            Yes, that's correct.
                            Cheers
                            Al
                              Cheers
                              Al
                              A
                              A
                              andriej
                              @Sparkman thank you very much, it worked absolutely flawless. I can now again control the switches, will test it with different voltages and antennas.
                              One more thing - I've read some time ago that it might be worth considering a capacitor (polarized one) at least 10uF conected to transmitter's Vcc and GND.
                              Do you think it could stabilize power and smooth it even more, so the quality of signal and strenght could be even better?
                              As a antenna currently I use the core from coax tv cable, 174mm long - straight without any shielding.
                              Regards
                              • A andriej
                                Regards
                                SparkmanS
                                SparkmanS
                                Sparkman
                                @andriej Glad to hear it's working. A capacitor between Vcc an GND can help smooth any ripple. It won't hurt to add it if you have one kicking around.
                                Cheers
                                Al
                                  Cheers
                                  Al
                                  A
                                  A
                                  andriej
                                  @Sparkman strange thing happened and suddenly everything stopped working.
                                  After rewiring (still leaving everything the same, just restarting of power supply) it worked for few minutes and stopped.
                                  Currently I've moved from ethernet shield to plain Uno (so only 2 pins are used: GND and D2 - TX Data) and still can't get signal out of the module...
                                  I even rewrote the code leaving everything not needed outside. Now I will be removing the cap between Vcc and GND.
                                  Hope it helps..
                                  • A
                                    A
                                    andriej
                                    The only idea I have is that it stopped working because voltage went 12,4V…
                                    But all components (except TX module?) should accept it.
                                    I've switched from LAN to serial now and back to normal 5V with special antenna.
                                    • A andriej
                                      SparkmanS
                                      SparkmanS
                                      Sparkman
                                      @andriej Have you tested each component to see if one of them has failed?
                                      Cheers
                                      Al
                                        Cheers
                                        Al
                                        A
                                        A
                                        andriej
                                        @Sparkman it will be hard for me to test now, as I've soldered everything on breadboard.
                                        What other PNP transistor would you fit instead of 2N4403?
                                        I will be buying few of them and can't exactly find the 440x's
                                        • A andriej
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          @andriej Digikey has a good transistor selector. You can see the specs for the 4403 and then find something with similar specs that may be more readily available where you live.
                                          http://www.digikey.com/product-search/en?pv7=2&FV=fff40015%2Cfff80078%2C1140050%2C1280002%2C142c0044%2C142c02ca%2C142c1dec&k=transistor&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=0&ptm=0&fid=0&pageSize=25
                                          Cheers
                                          Al
