  3. Domoticz
  4. Newbie question about network security
3 Posts 2 Posters 1.9k Views 1 Watching
  • S
    sebas
    Sorry if this a noob question but I couldn't find the answer to it using search. How are sensors added to the MySensors network? Or more specifically how do I prevent sensors being added?
    Yesterday I build my first gateway (ethernet) and sensors and after some tweaking with the pin numbers the code works and the sensor connected to the gateway and showed up in the controller (Domoticz). I'm happy it works and it's almost plug and play.
    This makes me wonder how I can secure the access to the network a bit so no-one but me can add sensors and actuators to my MySensors network. Is this in some way possible?
    • Suresh MaliS
      Suresh MaliS
      Suresh Mali
      In Domoticz if you look under settings, there is an button Add Device which works like pairing. There is also a check box to not allow any new device unless you click Add.
      • S
        sebas
        Thanks. Didn't know I had to secure that at the Domoticz end. Got it.
