  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 450.5k Views 35 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    @epierre I wonder if you looked at this sensor Figaro TGS8100:
    http://www.figarosensor.com/products/entry/tgs8100.html
    Looks like it is perfect for a low-powered platform.
    epierreE R 2 Replies Last reply
    • alexsh1A alexsh1
      epierreE
      epierreE
      epierre
      wrote on last edited by epierre
      #182
      as a replacement for MQ in low power yes could be... the bad part is how to get one ?
      z-wave - Vera -> Domoticz
      alexsh1A 1 Reply Last reply
      • epierreE epierre
        alexsh1A
        alexsh1A
        alexsh1
        How about http://www.soselectronic.com/?str=371&artnum=170939&name=figaro-tgs8100 ?
        • epierreE epierre
          I'm now testing the MICS-6814 (3 sensors in one) given for :
          Carbon monoxide CO 1 -1000ppm
          **Nitrogen dioxide NO2 0.05 –10ppm **
          Ethanol C2H5OH 10 –500ppm
          Hydrogen H2 1 –1000ppm
          Ammonia NH3 1 –500ppm
          Methane CH4 >1000ppm
          Propane C3H8 >1000ppm
          Iso-butane C4H10 >1000ppm
          Datasheet maionly speaks on CO, NO2 and NH3:
          http://www.seeedstudio.com/wiki/images/1/10/MiCS-6814_Datasheet.pdf
          Here is are scripts:
          http://www.seeedstudio.com/wiki/Grove_-_Multichannel_Gas_Sensor
          Some readings:
          The concentration of NH3 is 0.99 ppm
          The concentration of CO is 1.20 ppm
          The concentration of NO2 is 0.15 ppm
          The concentration of C3H8 is 1000.04 ppm
          The concentration of C4H10 is 999.98 ppm
          The concentration of CH4 is 2991.14 ppm
          The concentration of H2 is 1.09 ppm
          The concentration of C2H5OH is 1.40 ppm
          I guess I'll make a script soon...
          VirV
          VirV
          Vir
          Hi, It all make sense, I am just confused that in your code once your multiply and once you divide...
          case CO:
          if(ratio1 < 0.01) ratio1 = 0.01;
          if(ratio1 > 3) ratio1 = 3;
          //c = pow(10, 0.6) / pow(ratio1, 1.2);
          ** c = pow(ratio1, -1.179)4.385; //mod by jack*
          break;
          case NO2:
          if(ratio2 < 0.07) ratio2 = 0.07;
          if(ratio2 > 40) ratio2 = 40;
          //c = ratio2 / pow(10, 0.8);
          ** c = pow(ratio2, 1.007)/6.855; //mod by jack**
          break;
          SO, what is the actual formula?
          Vir
          Some readings:
          • epierreE epierre
            @tantt2810 said:
            I'm don't understand the recipe below. Why RL_Value(Load Resistance)(1023-raw_adc)/raw_adc)? Can you explain for me?
            Thank you so much !!!
            Input: raw_adc - raw value read from adc, which represents the voltage
            Output: the calculated sensor resistance
            Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
            across the load resistor and its resistance, the resistance of the sensor
            could be derived.
            float MQ2::MQResistanceCalculation(int raw_adc)
            RL_VALUE
            (1023-raw_adc)/raw_adc));
            in fact it is above described, you have a voltage, you want a resistance.
            https://learn.sparkfun.com/tutorials/voltage-dividers
            datasheet needs a value which is the Rs/Ro (called here RL) where
            Ro: sensor resistance at 100ppm of NH3 in the clean air.
            Rs:sensor resistance at various concentrations of gases
            here the formula is a simplification of this:
            float Vrl = val * ( 5.00 / 1024.0 ); // V
            float Rs = 20000 * ( 5.00 - Vrl) / Vrl ; // Ohm
            int ratio = Rs/Ro;
            ppm = 37143 * pow (ratio, -3.178);
            VirV
            VirV
            Vir
            What does 37143 represents, Rs? and -3.178 is a second value from your regression method, but what about the first value?
            Can you elaborate on ppm line, please
            Vir
            int ratio = Rs/Ro;
            VirV 1 Reply Last reply
            • B bhavika
              I am confused with MiCS 4514 sensor. What I had done is :
              using MiCS quick start evaluation board, measured ADC value
              calculated Vout and from that calculated R0.
              Rs/R0 concentration gives me high value, which is not possible, My data is as follows
              clean air file is used for the purpose of R0 value
              https://drive.google.com/file/d/0B8sF8a6FHoseWjhWOHRoYzIxakk/view?usp=sharing
              and Polluted file is used to calculate the actual pollution
              https://drive.google.com/file/d/0B8sF8a6FHoseR1BnclhCUHdibEU/view?usp=sharing
              I am confused. Please help me
              VirV
              VirV
              Vir
              I am confused by the formula you are using, could you please explain?
              Pollution NO2 = (POWER((RS/R0)*(1/POWER(10,0.8068)),(1/1.01)))
              Pollution CO = POWER((RS/R0)*(1/POWER(10 , 0.5476)),(1/-0.8497)))
              is the actual formula like this?:
              pollution = POWER((ratio *(1/POWER(10, curve[0])),(1/[curve[1])))
              This is different than any other formulas discussed in this thread...
              Vir
              • VirV Vir
                Vir
                int ratio = Rs/Ro;
                VirV
                VirV
                Vir
                so does 37164 represents the scaling factor and -3.178 the exponent?
                Vir
                Vir
                int ratio = Rs/Ro;
                • alexsh1A
                  alexsh1A
                  alexsh1
                  #188
                  @epierre I have the problem with the dust sketch (shinyei ppd42ns). The following code does not work in MySensors 1.5
                  gw.send(msgPM10.set("ppm"));
                  gw.send(msgPM25.set("ppm"));
                  2016-04-24 14:44:19.438 Error: MySensors: Unknown/Invalid sensor type (43)
                  So far both PM10 and PM25 are showing zero. However, if I upload the following code, it works fine (one channel though):
                  // Watch video here: https://www.youtube.com/watch?v=a8r4CeQopfY
                   Connection:
                   JST Pin 1 (Black Wire)  => Arduino GND
                   JST Pin 3 (Red wire)    => Arduino 5VDC
                   JST Pin 4 (Yellow wire) => Arduino Digital Pin 8
                   Green Led connected to Arduino D7
                   Yellow Led connected to Arduino D6
                   Red Led connected to Arduino D5
                  Dust Sensor possible application:
                  - Applications of customer
                  - Air quality sensor
                  - Dustlessness workshop
                  - Cigarette detector
                  Sensor is to create Digital (Lo Pulse) output to Particulate Matters (PM). Lo Pulse Occupancy time (LPO time) is in proportion
                  to PM concentration. The output is for PM whose size is around 1 micro meter or larger. We can use the sensor to detect the dust in clean room.
                  Minimum detect particle: 1um
                  http://www.seeedstudio.com/wiki/Grove_-_Dust_Sensor
                   Grove - Dust Sensor Demo v1.0
                   Interface to Shinyei Model PPD42NS Particle Sensor
                   Program by Christopher Nafis
                   Written April 2012
                   http://www.seeedstudio.com/depot/grove-dust-sensor-p-1050.html
                   http://www.sca-shinyei.com/pdf/PPD42NS.pdf
                  int pin = 8;
                  unsigned long duration;
                  unsigned long starttime;
                  unsigned long sampletime_ms = 1000;//sampe 1s ;
                  unsigned long lowpulseoccupancy = 0;
                  float ratio = 0;
                  float concentration = 0;
                  int gLed = 7;
                  int yLed = 6;
                  int rLed = 5;
                    Serial.begin(9600);
                    pinMode(8,INPUT);
                    pinMode(gLed,OUTPUT);
                    pinMode(yLed,OUTPUT);
                    pinMode(rLed,OUTPUT);
                    starttime = millis();//get the current time;
                    duration = pulseIn(pin, LOW);
                    lowpulseoccupancy = lowpulseoccupancy+duration;
                    if ((millis()-starttime) > sampletime_ms)//if the sampel time == 30s
                      ratio = lowpulseoccupancy/(sampletime_ms*10.0);  // Integer percentage 0=>100
                      concentration = 1.1*pow(ratio,3)-3.8*pow(ratio,2)+520*ratio+0.62; // using spec sheet curve
                      Serial.print("concentration = ");
                      Serial.print(concentration);
                      Serial.print(" pcs/0.01cf  -  ");
                      if (concentration < 1.0) {
                       Serial.println("It's a smokeless and dustless environment");
                       digitalWrite(gLed, HIGH);
                       digitalWrite(yLed, LOW);
                       digitalWrite(rLed, LOW);
                      if (concentration > 1.0 && concentration < 20000) {
                       Serial.println("It's probably only you blowing air to the sensor :)");
                      if (concentration > 20000 && concentration < 315000) {
                       Serial.println("Smokes from matches detected!");
                       digitalWrite(gLed, LOW);
                       digitalWrite(yLed, HIGH);
                        if (concentration > 315000) {
                       Serial.println("Smokes from cigarettes detected! Or It might be a huge fire! Beware!");
                       digitalWrite(rLed, HIGH);
                  • epierreE epierre
                    sadly the discussions were lost...
                    So let's start again on the subject:
                    https://github.com/empierre/arduino
                    Here is the list of my current experimentations:
                    • MQ135.ino : for CO2/COV ... validated
                    • MQ2.ino : for ethanol... needs pre-heat : ongoing
                    • MQ6 sensor : just received
                    • MQ131 sensor : just received
                    • TGS2600 sensor : just received
                    I'm getting serious a with a mega and a sensor board, 4 of them are connected together !
                    The MQ135 is not on the list, I use it to measure CO2 in children's room...
                    Values:
                    • MQ2: 85 - Combustible gas and smoke
                    • MQ6: 25 - Isobutane, Butane, LPG
                    • MQ131: 57 - O3, CL2
                    • TGS2600: 943 - ethanol, hydrogen, iso-butane, CO, Methane
                    As discussed before, I would appreciate someone helping me reading the logarithmic curves in the datasheet (link on each sensor name above) to get the linear value based on analog reading. I need to learn reading it... thanks!
                    as an example here in sandboxelectronics we saw that several values could be read from the datasheet:
                    float           LPGCurve[3]  =  {2.3,0.21,-0.47};   //two points are taken from the curve.
        //with these two points, a line is formed which is "approximately equivalent"
        //to the original curve.
        //data format:{ x, y, slope}; point1: (lg200, 0.21), point2: (lg10000, -0.59)
                    float           COCurve[3]  =  {2.3,0.72,-0.34};    //two points are taken from the curve.
        //data format:{ x, y, slope}; point1: (lg200, 0.72), point2: (lg10000,  0.15)
                    float           SmokeCurve[3] ={2.3,0.53,-0.44};    //two points are taken from the curve.
        //data format:{ x, y, slope}; point1: (lg200, 0.53), point2: (lg10000,  -0.22)
                    float           Ro           =  10;                 //Ro is initialized to 10 kilo ohms
                    AnneFRA
                    AnneFRA
                    AnneFR
                    @epierre hi, could remove some doubts regarding the mq131 sensor?
                    thanks,
                    Anne
                    • epierreE
                      epierreE
                      epierre
                      @alexsh1 said:
                      (shinyei ppd42ns)
                      I corrected the following sketch which had bad yg/m3 to ppm conversion thanks to LouiS22 from Domoticz forum remark (type conversion errors leading to 0 values).
                      https://github.com/empierre/arduino/blob/master/DustSensor_SamYoung_DSM501.ino
                      I guess I'll have to do the same here (but I lack time...):
                      DustSensor_Shinyei_PPD42NS.ino
                      • epierreE epierre
                        @alexsh1 said:
                        (shinyei ppd42ns)
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @epierre Thanks - I'll have another go at Shinyei PPD42NS sketch once I have time. Ideally, I'd like to combine it with MH-Z14A sketch.
                        epierreE 1 Reply Last reply
                        • alexsh1A alexsh1
                          epierreE
                          epierreE
                          epierre
                          @alexsh1 which is a good idea, also a temp/him is quite usefull though I didn't added the impact in the formulas so far.
                          alexsh1A 2 Replies Last reply
                          • epierreE epierre
                            alexsh1A
                            alexsh1A
                            alexsh1
                            #193
                            @epierre I have combined the two sketches - works just fine, but need to find a spare temp sensor.The hardware setup looks messy so adding an extra i2c sensor will complicate it even more. I'll come back with the combined three-in-one sketch shortly.
                            BTW, this
                            still throws the following error. What version MySensors are you using?
                            • epierreE epierre
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #194
                              @epierre I started looking at the formula you have used in ppmv calculation. Why do you need ppmv? All values in EPA or Europe are in μg/m3.
                              The ppmv equation is:
                              ppmv = mg/m^3 * (0.08205*T)/M
                              T = atmospheric temperature in kelvins = 273.15 + °C
                              M = molecular weight of the air pollutant = 28.97
                              (http://www.engineeringtoolbox.com/molecular-mass-air-d_679.html - this is a good link)
                              0.08205 = Universal Gas Law constant in atm·l/(mol·K)
                              Your code for this equation is:
                              ppmv=(float)(((concentrationPM25*0.0283168)/100) * ((0.08205*temp)/0.01))/1000;
                              Now, I think it should be as follows:
                              1. temp = °C + 273.15
                              int temp=273.15 + 22;
                              22C - is a typical temp inside though the intention is to use a sensor
                              1. The amended ppmv equation is going to be:
                              ppmv=(((concentrationPM25*0.0283168)/100) * ((0.08205*temp)/28.97))/1000;
                              I have not changed 0.0283168 /100 - not sure that this is. And the whole thing is divided by 1000? why?
                              IMPORTANT UPDATE:
                              I have just received the following result:
                              PM10: 7373
                              send: 11-11-0-0 s=0,c=1,t=37,pt=7,l=5,sg=0,st=ok:1.744
                              If I use the following web-site http://www.herramientasingenieria.com/onlinecalc/ppm-mg_m3.php and the result is
                              mg/m3 = 7373 * 0.283168/100 = 2.08 mg/m3
                              The molecular weight is 28.97 for dry air
                              2.08 mg/m3 is equivalent to 1.74ppm for a gas with molecular weight=28.97 Pressure=1013.25, Temperature=22C
                              Success!
                              Now I have found a spare BMP280 (temp and pressure sensor) which I can use here.
                              Additionally, I need to use 24-h and 1 year averages - https://www3.epa.gov/airquality/particlepollution/2012/decfsstandards.pdf
                              Stay tuned!
                              • alexsh1A alexsh1
                                IMPORTANT UPDATE:
                                PM10: 7373
                                Success!
                                Stay tuned!
                                epierreE
                                epierreE
                                epierre
                                because domoticz only knows ppm... and many AIQ like use only that except for particles.
                                not for me ;-)
                                  ppmv=(((concentrationPM250.0283168)/100) * ((0.08205temp)/28.97))/1000;
                                was a volume conversion
                                Success!
                                success for the mysensors value ?
                                Domoticz doesn't recognize this command... I use 1.5.x but I have my own gateway to domoticz
                                alexsh1A bezeeflyB 2 Replies Last reply
                                • epierreE epierre
                                  not for me ;-)
                                  Success!
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @epierre Yes, all works fine now. I modified the combined sketch and here is the final result.
                                    moskovskiy82
                                    Which one to use for detection of fire smoke? Currently have got several MQ-7 but they don't seem so good at it
                                    • M moskovskiy82
                                      epierreE
                                      epierreE
                                      epierre
                                      as discussed just above, a particle sensor could be good for smoke is a particle concentration, coupled with heat this would be a good indicator
                                        moskovskiy82
                                        What about mq2 or mq135? Any experience? As a gas sensor will be more suitable detecting early fire
                                        • M moskovskiy82
                                          epierreE
                                          epierreE
                                          epierre
                                          please see what it does, this is not a gas sensor this only detect particle size whatever the gas...
                                          M 1 Reply Last reply
