  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 450.5k Views 35 Watching
  • walk_portoW
    walk_portoW
    walk_porto
    Hello everybody,
    I am working with an Arduino Uno and a MQ135 module arduino : http://www.sainsmart.com/sainsmart-mq135-sensor-air-quality-sensor-hazardous-gas-detection-module-arduino.html
    I can get back data from this sensor, I got 100 ppm when I launched serial terminal after compiling and uploading this code below.
    int sensorValue;
      Serial.begin(9600);      // sets the serial port to 9600
      sensorValue = analogRead(0);       // read analog input pin 0
      Serial.println(sensorValue, DEC);  // prints the value read
      delay(100);                        // wait 100ms for next reading
    But, I would like to get back data from gases like NH3, NOx, alcohol, benzene, smoke and CO2 . I read a lot of topics and the datasheets of the sensor but I don't see how to do.
    If someone could help me, it will be great.
    Thanks.
    AtmosChemeA 1 Reply Last reply
    • walk_portoW walk_porto
      Hello everybody,
      int sensorValue;
      Thanks.
      AtmosChemeA
      AtmosChemeA
      AtmosCheme
      @walk_porto
      I think that the only way you are going to be able to distinguish between different gases is to have a known concentration of that gas and adjust load resistance. This sensor will detect all of these gase because of cross sensitivity to the gases mentioned in the filament. You can not use just one MQ135 sensor and get readings for all of the gases.
      • Thanh-VietT
        Thanh-VietT
        Thanh-Viet
        Hi Guys,
        Nice work. I'm based in Hong Kong, and what matters to us is PM2.5, NO2 and Ozone (and indoor CO2/VOC).
        Have you guys checked the laser based particle sensors like the Plantower G1-G3-G5, Innovafitness SDS011/021 ?
        http://aqicn.org/sensor
        alexsh1A 1 Reply Last reply
        • Thanh-VietT Thanh-Viet
          Hi Guys,
          alexsh1A
          alexsh1A
          alexsh1
          @Thanh-Viet Hello. Yes, I have Plantower G3 on order from Aliexpress and won't be able to test it before September. I think adopting it for MySensors is going to be easy
          • paqorP
            paqorP
            paqor
            Hello, there are statements if the values increase the MQ135 when a room ventilated, without people and is furnished? I I have several rooms here an increase over time. Perhaps this is also by the increase in temperature, sunlight or gases from the furniture. I have not found any literature on this. Is this behavior with other users as well?
            • paqorP
              paqorP
              paqor
              Has the type of installation (horizontal or vertical) have an impact on the values of MQ135? I have found no photos of built-in sensors already exist in the data sheet a statement.
              • paqorP paqor
                alexsh1A
                alexsh1A
                alexsh1
                @paqor yes, in fact my MQ-135 was so unreliable that I had to move on to a different sensor
                • paqorP
                  paqorP
                  paqor
                  wrote on last edited by paqor
                  #248
                  Those interested in a 4 sensors Sketch FHEM (CO2, Temp, Hum, Motion) has ...
                  ? 1 Reply Last reply
                  • paqorP paqor
                    A Former User
                    @paqor
                    I'm interested, but i'm using mysensors 2.0. Can you update your sketch?
                    paqorP 1 Reply Last reply
                    • ? A Former User
                      @paqor
                      paqorP
                      paqorP
                      paqor
                      @gieljnssns said:
                      @paqor
                      Yes, sure but I need time. I'm not a good programmer and need a lot of testing. My Englich is not particularly good. As some patience please, because I have to house, garden, woman and taking care of animals. :two_men_holding_hands:
                      • paqorP paqor
                        @gieljnssns said:
                        @paqor
                        paqorP
                        paqorP
                        paqor
                        #251
                        @gieljnssns said in Air Quality Sensor:
                        @paqor
                        @paqor
                        https://gleisnetze.de/2016/08/07/sensoren4sketch/
                        • v0.8 korrigierte Lib von RSTOICA
                        • EEPROM set R0Cor
                        • amended mq135.h required!
                        • Temp, Hum --> CO2Cor
                        • Api 2.0
                        • Motion is not yet tested
                        • Auto base value set r0corr if Co2cor <390
                        • R0Cor set by TextField runs (incoming message)
                        • Redesign
                        • paqorP paqor
                          @paqor
                          @paqor
                          • EEPROM set R0Cor
                          • Api 2.0
                          • Redesign
                          paqorP
                          paqorP
                          paqor
                          #252
                          @paqor
                          Probably one should not speak of a sensor CO2 value as well as responding to many other particles at the MQ135. The most accurate CO2 measurement we certainly be possible only with a MH-Z14. I now have to buy me a part and will then calibrate the MQ135 so. With the MQ135 can z. B. only say something about the air quality in relation to the outside air. It is rather a relative value.
                          Here the comparison of MH-14T (yellow) and MQ135 (red). One sees the calibration and as yet are both curves to each other.
                          [https://smarthome.gleisnetze.de/38-mhz-14-erste-erfahrungen-mit-dem-co2-sensor-fuer-mysensors-arduino-fhem]
                          Wahrscheinlich sollte man beim MQ135 nicht von einem CO2 Wert sprechen da der Sensor auch auf viele andere Partikel reagiert. Die genaueste CO2 Messung wir sicher nur mit einem MH-Z14 möglich sein. Ich habe mir jetzt so ein Teil bestellt und werde dann den MQ135 damit kalibrieren. Mit dem MQ135 lässt sich z. B. nur etwas zur Luftgüte im Verhältnis zur Außenluft sagen. Es ist also eher ein relativer Wert.
                          • tuimansoT tuimanso
                            Your previous message
                            I have a question about the MQ-8 sensor module . The potentiometer that is soldered onto the board, is it to control the sensitivity of the LED light or for the sensor itself? According to the datasheet for the sensor, the RL (load resistance) for the sensor should be at minimum 10k Ohm, yet I only see an SMD 102 resistor on the board, which is a 1K Ohm resistor. I have used a multimeter to connect the 5V pin and the AOUT pin, and I get precisely a measurement of about 1K Ohm... Does that mean that I should connect a load resistor to this?
                            This value seems very important since it is referenced in the code, the RL is part of the calculations, yet it is already pre-written 10K ohms...
                            Please Clarify
                            ysinhY
                            ysinhY
                            ysinh
                            @tuimanso
                            There seems a general misunderstanding about how those gas sensors really work: the "heater" must be switched on (5v) and "off"(1.4v) for the air sample going in and out of the sensor, when heating the air sample expands and goes out of the sensor, then in the cool down period the remaining air contracts and sucks in a new sample.
                            Those boards with mq... sensors only provide fixed 5v heating, so this can never work reliable
                            the 1.4v is needed to keep the sensor on a minimum temperature,example 40'c for the catalyst to react, the 5v will heat it up to example 80'c, to clean the catalyst and air flows out of the sensor
                            http://i49.tinypic.com/2rzdqgn.png something like this will work
                            Soon I will report my results together with a modified sketch for mysensors 2.0
                            • epierreE epierre
                              @alexsh1 said:
                              @epierre I started looking at the formula you have used in ppmv calculation. Why do you need ppmv? All values in EPA or Europe are in μg/m3.
                              because domoticz only knows ppm... and many AIQ like use only that except for particles.
                              1. temp = °C + 273.15
                                int temp=273.15 + 22;
                                22C - is a typical temp inside though the intention is to use a sensor
                              not for me ;-)
                              1. The amended ppmv equation is going to be:
                                ppmv=(((concentrationPM250.0283168)/100) * ((0.08205temp)/28.97))/1000;
                              I have not changed 0.0283168 /100 - not sure that this is. And the whole thing is divided by 1000? why?
                              was a volume conversion
                              The molecular weight is 28.97 for dry air
                              2.08 mg/m3 is equivalent to 1.74ppm for a gas with molecular weight=28.97 Pressure=1013.25, Temperature=22C
                              Success!
                              success for the mysensors value ?
                              MySensors: Unknown/Invalid sensor type (43)
                              Domoticz doesn't recognize this command... I use 1.5.x but I have my own gateway to domoticz
                              bezeeflyB
                              bezeeflyB
                              bezeefly
                              @epierre I am working on a dust sensor project using Samyoung DSM501A. I am confused with the identical calculation formula used in the Samyoung DSM501A and Shinyei PPD42NS dust sketch.
                              concentration = 1.1pow(ratio,3)-3.8pow(ratio,2)+520*ratio+0.62;
                              My understanding is that the formula is based on the specific product's data sheet curve. Is the formula for DSM501A, PPD42NS, or both?
                              • epierreE
                                epierreE
                                epierre
                                wrote on last edited by epierre
                                #255
                                This is formula for Shinyei, you're right, I'searched back but don't know if a formula was made out : https://groups.google.com/forum/#!topic/airqualityegg/A1F9padoW10
                                strangely here it is used too : http://learn.linksprite.com/arduino/shields/use-dust-sensor-dsm501-with-arduino/
                                a formula by Chris Nafis here: https://github.com/OSBSS/Samyoung_Dust_Sensor/blob/master/Samyoung_Dust_Sensor.ino
                                z-wave - Vera -> Domoticz
                                bezeeflyB 1 Reply Last reply
                                • epierreE epierre
                                  bezeeflyB
                                  bezeeflyB
                                  bezeefly
                                  @epierre I obtained the following equation by polynomial fit the low ratio vs particle (pcs/283ml) graph in the DSM501 datasheet.
                                  concentration = (0.1 * pow(ratio, 2)) + (619 * ratio) + 50;
                                  Please help to check whether the equation is correct.
                                  epierreE 1 Reply Last reply
                                  • bezeeflyB bezeefly
                                    epierreE
                                    epierreE
                                    epierre
                                    #257
                                    looks correct for the red curve
                                    using http://www.xuru.org/rt/PR.asp with:
                                    4 2500
                                    8 5000
                                    12 7500
                                    16 10000
                                    20 12500
                                    22 15000
                                    gives =7,613212955POWER(B3;2) + 467,3617082B3 + 631,9862425
                                    a bit better ;-)
                                    and on the previous one datasheet http://www.mouser.com/ds/2/744/Seeed_101020012-838657.pdf:
                                    2 1000
                                    3.9 2000
                                    5.8 3000
                                    7.2 4000
                                    9 5000
                                    10 6000
                                    11.3 7000
                                    12.6 8000
                                    y = 19.09464953 x2 + 383.1041412 x + 174.9189116
                                    • jumpingJ
                                      jumpingJ
                                      jumping
                                      I bought the classic MQ sensors (MQ2, MQ4 and MQ135) and I'm building a multisensor node with arduino nano v3:
                                      @epierre can I use sketch https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino, is it suitable?
                                      thanks
                                      Raspberrry PI3 - Domoticz
                                      ESP8266 GW - MySensors 2.1.1
                                      • jumpingJ jumping
                                        thanks
                                        epierreE
                                        epierreE
                                        epierre
                                        @jumping you will need to scale down the script obviously, in term of power it will be too short to have more than one.
                                        jumpingJ 1 Reply Last reply
                                        • epierreE epierre
                                          jumpingJ
                                          jumpingJ
                                          jumping
                                          thanks for your answer! please, can you explain how the following code in your sketch is related to datasheet?
                                          • float CO_secCurve[2] = {726.7809737, -4.040111669}; //MQ135
                                          I understand the sketch in the "Gas Detection - Example", but not the previous.
                                          sorry for my poor english :-)
