  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 450.5k Views 35 Watching
  • epierreE epierre
    I prefer the power regression than the curves.
    From your datapoints :
    1.3 200
    2.9 10
    I find:
    y = 532.6744764 x-3.73371402
    rss=0
    I don't remember where I found the datasheet with the chinese names that I translated through google.
    H
    H
    haro
    @epierre Now I see your point of view and of course it is better way to reduce the error.
    in the other hand, I found the datasheet in chinese an then a friend translate it.
    the meaning of the name of gases is for 3/4 (Alcohol), 1/4 (Tolueno) or +- (acetona)
    Thank you so much.
    • Y
      Y
      Yuki M
      wrote on last edited by Yuki M
      #102
      I've started working with an MQ135 sensor, attached to a board like the disucssion you had from a year ago. I measured some of the resistances between the Aouts and the sensor pins and seems similar with the 1kohm resistance between AO and Gnd, and the pot not changing the output.
      I was wondering if anyone managed to calibrate their board using the AO of this board, and if so how? I can't seem to get a good resolution, as it has noise of at least in the 10's of ppm.
      I'm considering whether its simpler to by pass the board and its amplifier, and directly hook set up onto the sensor itself with the correct resistors.
      epierreE 1 Reply Last reply
      • Y Yuki M
        epierreE
        epierreE
        epierre
        Calibration is not possible as it varies between the same sensors of this construction class. Check datasheet on minimal sensibility also on low and max values.
        Also without a gas concentration it is not possible to calibrate it. The best guess is that co2now.org gives you that outside (aka clean air) it is 399 for CO2, but that would be only for CO2 and not the other gases !
        z-wave - Vera -> Domoticz
        • Y
          Y
          Yuki M
          @epierre Thanks for a rapid response!
          Yes I've been trying to calibrate it assuming out door air is at 399ppm. I understand each one has variances but would like to know how you guys worked it out.
          I'm using
          ppm = 116.6020682 (Rs/Ro)^-2.769034857
          from davide's blog http://davidegironi.blogspot.ch/2014/01/cheap-co2-meter-using-mq135-sensor-with.html#.VinvWX4rIuU
          Since the board show RL, I took that to calculate Rs. This lets me calculate Ro, thus calibrate it.
          Not quite sure where I'm going wrong. I had it working 8 months ago, and came back to it and couldn't figure out how i had it working so well.. I was able to get pretty nice graphs and now its very unstable.
          I'm having a play around with it, you can see my current points here https://thingspeak.com/channels/31162
          • Y Yuki M
            I'm using
            epierreE
            epierreE
            epierre
            I'm using
            would say: let it burn for 24/48 hours to leave it clean itself ;-)
            • B
              B
              bhavika
              IN MiCS 2614 , sensitivity factor is defined by "Rs at 100 ppb of O3 divided by Rs at 50 ppb of O3". From where you measured Rs at 100 ppb or 50 ppb.???
              • HeinzH
                HeinzH
                Heinz
                wrote on last edited by Heinz
                #107
                Adjusting my mq-135 sensor took several atempts as the CO2 value of the atmosphere is not a constant value of 399ppm.
                This value is measured in Hawaii ( see http://co2now.org/ ) and is probably significantly lower than at your home. In germany for example you should calibrate your sensor when the wind comes from west over the atlantic which brings fresh air along. See http://www.donnerwetter.de/deutschland/co2.htm
                Everytime my sensor passed values below 400 I adjusted the R0 value. In the end I modified the sketch to be able to send this R0 value from FHEM to the sensor to avoid recompiling the sketch everytime.
                See
                https://github.com/windkh/mysensors/tree/master/CO2Sensor/CO2sensor.ino Line 440ff
                • HeinzH
                  HeinzH
                  Heinz
                  #108
                  The sensor is in my kitchen. The value in the screenshot is very high as I made some french fries 2 hours ago.
                  • epierreE
                    epierreE
                    epierre
                    wrote on last edited by epierre
                    #109
                    @Heinz so bad I don't have a MQ135 running anymore to compare, here are the MH-Z14 curves I have near my desk.
                    • B bhavika
                      epierreE
                      epierreE
                      epierre
                      this is just to tell you how much a double concentration scales up, here they just say it is somehow linear at ratio 2
                      • R
                        R
                        Rasenheizung
                        @Heinz very nice work :+1: (wie heisst du im FHEM Forum?)
                        Does someone have the values a MQ-07 needs to perform properly? I rally don't know how to gather the right values from the description.... :)
                        Thank you
                        • epierreE
                          epierreE
                          epierre
                          #112
                          @Rasenheizung if you base yourself on my template here https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino
                          H2
                          1.3 50
                          0.8 100
                          0.28 400
                          0.16 1000
                          0.05 4000
                          y = 73.59123879 x-1.355617483
                          Residual Sum of Squares: rss = 87393.44418
                          H2Curve[3] = {73.5912, -1.355617};
                          CO
                          1.6 50
                          1 100
                          0.39 400
                          0.21 1000
                          0.09 4000
                          y = 99.27731641 x-1.513643469
                          Residual Sum of Squares: rss = 43168.87424
                          COCurve[3] = {99.27731, -1.51364};
                          CO is a dangerous gas, the MQ7 is very sensitive to many things and no calibration too... for a serious work please think about using the MICS-6814 that is calibrated, includes 3 gases out of the box, and is very low consumption (can run on battery !)
                          https://github.com/empierre/arduino/blob/master/AirQuality-CO-NO2-NH3.ino
                          • B
                            B
                            bhavika
                            What is the pre-heating time for TGS2442???
                            • B bhavika
                              epierreE
                              epierreE
                              epierre
                              #114
                              from datasheet: "the sensor’s resistance reaches to 90% of its final value in less than one minute"
                              • B
                                B
                                bhavika
                                So what is the conditioning period for testing in it??? It is two days.. What does it mean??
                                • B bhavika
                                  epierreE
                                  epierreE
                                  epierre
                                  #116
                                  on this kind maybe to have it powered for a full two days to burn out the production "dusts" that may remain in.
                                  those sensors are not good science, see the correlation of gases they are reported for in the datasheet
                                  • epierreE
                                    epierreE
                                    epierre
                                    a very sensitive HCHO module you can see a demo here: http://www.seeedstudio.com/recipe/379-a-handheld-hcho-detector.html?utm_source=EDM&utm_medium=EDM&utm_campaign=EDM20150930
                                    https://github.com/empierre/arduino/blob/master/AirQuality-HCHO.ino
                                    • paqorP
                                      paqorP
                                      paqor
                                      I have a question for the MQ135. Do not always be above 500 ppm, the measured values? I also get values of 0. I suspect that it is due to the conversion. The values vary greatly. Is that normal? I get the values with an ordinary power supply. mq135 werte.PNG
                                      • paqorP
                                        paqorP
                                        paqor
                                        wrote on last edited by paqor
                                        #119
                                        This post is deleted!
                                        • HeinzH
                                          HeinzH
                                          Heinz
                                          Looks strange, could you supply your code?
                                          Btw the sensor draws a lot of current, the power supply should be able to deliver 1A. Did you burn in the sensor for 12-24 hours?
