  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 452.5k Views 35 Watching
  • Y
    Y
    Yuki M
    wrote on last edited by Yuki M
    #102
    I've started working with an MQ135 sensor, attached to a board like the disucssion you had from a year ago. I measured some of the resistances between the Aouts and the sensor pins and seems similar with the 1kohm resistance between AO and Gnd, and the pot not changing the output.
    I was wondering if anyone managed to calibrate their board using the AO of this board, and if so how? I can't seem to get a good resolution, as it has noise of at least in the 10's of ppm.
    I'm considering whether its simpler to by pass the board and its amplifier, and directly hook set up onto the sensor itself with the correct resistors.
    epierreE 1 Reply Last reply
    • Y Yuki M
      epierreE
      epierreE
      epierre
      Calibration is not possible as it varies between the same sensors of this construction class. Check datasheet on minimal sensibility also on low and max values.
      Also without a gas concentration it is not possible to calibrate it. The best guess is that co2now.org gives you that outside (aka clean air) it is 399 for CO2, but that would be only for CO2 and not the other gases !
      z-wave - Vera -> Domoticz
      • Y
        Y
        Yuki M
        @epierre Thanks for a rapid response!
        Yes I've been trying to calibrate it assuming out door air is at 399ppm. I understand each one has variances but would like to know how you guys worked it out.
        I'm using
        ppm = 116.6020682 (Rs/Ro)^-2.769034857
        from davide's blog http://davidegironi.blogspot.ch/2014/01/cheap-co2-meter-using-mq135-sensor-with.html#.VinvWX4rIuU
        Since the board show RL, I took that to calculate Rs. This lets me calculate Ro, thus calibrate it.
        Not quite sure where I'm going wrong. I had it working 8 months ago, and came back to it and couldn't figure out how i had it working so well.. I was able to get pretty nice graphs and now its very unstable.
        I'm having a play around with it, you can see my current points here https://thingspeak.com/channels/31162
        • Y Yuki M
          I'm using
          epierreE
          epierreE
          epierre
          I'm using
          would say: let it burn for 24/48 hours to leave it clean itself ;-)
          • B
            B
            bhavika
            IN MiCS 2614 , sensitivity factor is defined by "Rs at 100 ppb of O3 divided by Rs at 50 ppb of O3". From where you measured Rs at 100 ppb or 50 ppb.???
            • HeinzH
              HeinzH
              Heinz
              wrote on last edited by Heinz
              #107
              Adjusting my mq-135 sensor took several atempts as the CO2 value of the atmosphere is not a constant value of 399ppm.
              This value is measured in Hawaii ( see http://co2now.org/ ) and is probably significantly lower than at your home. In germany for example you should calibrate your sensor when the wind comes from west over the atlantic which brings fresh air along. See http://www.donnerwetter.de/deutschland/co2.htm
              Everytime my sensor passed values below 400 I adjusted the R0 value. In the end I modified the sketch to be able to send this R0 value from FHEM to the sensor to avoid recompiling the sketch everytime.
              See
              https://github.com/windkh/mysensors/tree/master/CO2Sensor/CO2sensor.ino Line 440ff
              • HeinzH
                HeinzH
                Heinz
                #108
                The sensor is in my kitchen. The value in the screenshot is very high as I made some french fries 2 hours ago.
                • epierreE
                  epierreE
                  epierre
                  #109
                  @Heinz so bad I don't have a MQ135 running anymore to compare, here are the MH-Z14 curves I have near my desk.
                  • B bhavika
                    epierreE
                    epierreE
                    epierre
                    this is just to tell you how much a double concentration scales up, here they just say it is somehow linear at ratio 2
                    • R
                      R
                      Rasenheizung
                      @Heinz very nice work :+1: (wie heisst du im FHEM Forum?)
                      Does someone have the values a MQ-07 needs to perform properly? I rally don't know how to gather the right values from the description.... :)
                      Thank you
                      • epierreE
                        epierreE
                        epierre
                        #112
                        @Rasenheizung if you base yourself on my template here https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino
                        H2
                        1.3 50
                        0.8 100
                        0.28 400
                        0.16 1000
                        0.05 4000
                        y = 73.59123879 x-1.355617483
                        Residual Sum of Squares: rss = 87393.44418
                        H2Curve[3] = {73.5912, -1.355617};
                        CO
                        1.6 50
                        1 100
                        0.39 400
                        0.21 1000
                        0.09 4000
                        y = 99.27731641 x-1.513643469
                        Residual Sum of Squares: rss = 43168.87424
                        COCurve[3] = {99.27731, -1.51364};
                        CO is a dangerous gas, the MQ7 is very sensitive to many things and no calibration too... for a serious work please think about using the MICS-6814 that is calibrated, includes 3 gases out of the box, and is very low consumption (can run on battery !)
                        https://github.com/empierre/arduino/blob/master/AirQuality-CO-NO2-NH3.ino
                        • B
                          B
                          bhavika
                          What is the pre-heating time for TGS2442???
                          • B bhavika
                            epierreE
                            epierreE
                            epierre
                            #114
                            from datasheet: "the sensor’s resistance reaches to 90% of its final value in less than one minute"
                            • B
                              B
                              bhavika
                              So what is the conditioning period for testing in it??? It is two days.. What does it mean??
                              • B bhavika
                                epierreE
                                epierreE
                                epierre
                                #116
                                on this kind maybe to have it powered for a full two days to burn out the production "dusts" that may remain in.
                                those sensors are not good science, see the correlation of gases they are reported for in the datasheet
                                • epierreE
                                  epierreE
                                  epierre
                                  a very sensitive HCHO module you can see a demo here: http://www.seeedstudio.com/recipe/379-a-handheld-hcho-detector.html?utm_source=EDM&utm_medium=EDM&utm_campaign=EDM20150930
                                  https://github.com/empierre/arduino/blob/master/AirQuality-HCHO.ino
                                  • paqorP
                                    paqorP
                                    paqor
                                    I have a question for the MQ135. Do not always be above 500 ppm, the measured values? I also get values of 0. I suspect that it is due to the conversion. The values vary greatly. Is that normal? I get the values with an ordinary power supply. mq135 werte.PNG
                                    • paqorP
                                      paqorP
                                      paqor
                                      wrote on last edited by paqor
                                      #119
                                      • HeinzH
                                        HeinzH
                                        Heinz
                                        Looks strange, could you supply your code?
                                        Btw the sensor draws a lot of current, the power supply should be able to deliver 1A. Did you burn in the sensor for 12-24 hours?
                                        • paqorP
                                          paqorP
                                          paqor
                                          I have used the code from epiere. Baking I have not done. I use different power supplies (USB, Samsung and a large controllable power supply). I sometimes feel that contacts do not function properly. But the sensor draws but only about 100 mA = 0.1 A? Then it seems to be on branding. I have three new sensors. Mostly we read that it is only an attempt here is to measure the CO2 content. When I check the values with a measuring instrument with which agree the details here https://olimex.wordpress.com/2015/05/26/experimenting-with-gas-sensors-and-arduino/ Branding should work outdoors? Can you show me a chart or values?
