  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 450.5k Views 35 Watching
  • supersjimmieS
    supersjimmieS
    supersjimmie
    Thanks, but when calibrating something strange happens when I put the module outside:
    valr 270
    Vrl   / Rs       / ratio  / ppm
    61355 / 95673.00 / 0.00 / 399.00
    valr 265
    62928 / 98126.00 / 0.00 / 399.00
    valr 260
    64561 / 100673.00 / 0.00 / 399.00
    valr 256
    378 / 589.00 / 0.00 / 399.00
    valr 252
    1773 / 2764.00 / 0.00 / 399.00
    As you can see, the valr decreases slowly, but suddenly Vlr and Rs jump over.
    Vlr is the value of 'val', which is: uint16_t val = ((float)22000*(1023-valr)/valr);
    uint16_t is 16bit, so max 65535. It looks like my environment needs more than that?
    (in fact, your code defines the defaultro as 68550, which is also too much for a uint16?)
    epierreE 1 Reply Last reply
    • supersjimmieS supersjimmie
      valr 270
      valr 265
      valr 260
      valr 256
      valr 252
      epierreE
      epierreE
      epierre
      yes and this is why I did rewrite it to https://github.com/empierre/arduino/blob/master/AirQuality-Multiple_Gas_Sensor1_4.ino but did not updated this one...
      z-wave - Vera -> Domoticz
      supersjimmieS 1 Reply Last reply
      • epierreE epierre
        supersjimmieS
        supersjimmieS
        supersjimmie
        wrote on last edited by supersjimmie
        #143
        @epierre I striped-down that AirQuality-Multiple_Gas_Sensor1_4.ino to use only MQ135.
        When used inside, the analogRead is 473, so a reasonble value.
        But the MQCalibration function returns 0. Which means the MQResistanceCalculation also returns 0.
        MQResistenceCalculation only does one calc:
        return (long)((long)(1024 * 1000 * (long)rl_value)/raw_adc-(long)rl_value);
        rl_value = float RL4 = 0.990
        raw_adc = 473 (measured as said above)
        (1024 * 1000 * 0.990) / 473 - 0.990 = 2142.266
        I checked that raw_adc is filled with the correct value (to be sure it is not lost somewhere).
        What looks to fix this, I changed everything to float . So:
        return (float)((float)(1024 .* 1000. * (float)rl_value)/raw_adc-(float)rl_value);
        Which can be simplyfied as:
        return ((1024 * 1000*rl_value)/raw_adc-rl_value);
        I went to float, because the function is created as float MQResistenceCalculation.
        This now gives some ppm values that are within a reasonable range (about 2000 here).
        Now I have to figure out how to do calibration on this method again...
        • epierreE
          epierreE
          epierre
          looks like I have to rework something... but not in the todo list right now... Imperihome is now back on top, and Particle on lipo/solar also...
          • tantt2810T
            tantt2810T
            tantt2810
            I don't know how to calculate 3 numbers of LPGCurve[]. Can you explain clearly for me? Thank you so much !!!
            • epierreE
              epierreE
              epierre
              @tantt2810 as explained above, if the datasheet has a logarithmic scale, you can use the power regression to approximate the curve. One tool for example to do this calculus:http://www.xuru.org/rt/powr.asp
              for a sensor discussed above I read this on the datasheet:
              H2
              1.3 50
              0.8 100
              0.28 400
              0.16 1000
              0.05 4000
              The xuru website gives me this:
              y = 73.59123879 x-1.355617483
              Residual Sum of Squares: rss = 87393.44418
              and thus I have::
              H2Curve[3] = {73.5912, -1.355617};
              tantt2810T 1 Reply Last reply
              • epierreE epierre
                H2
                1.3 50
                0.8 100
                0.28 400
                0.16 1000
                0.05 4000
                and thus I have::
                tantt2810T
                tantt2810T
                tantt2810
                @epierre Thank you so much !!!
                Have a nice day =)) !!!
                • epierreE epierre
                  So tonight with these new formulae, I updated my mega sketch to get :
                   MQ2    :LPG   :0ppm    CO    :0ppm    SMOKE :0ppm
                   MQ6    :LPG   :0ppm    CH4   :0ppm
                   MQ131  :CL2   :1ppm    O3    :1ppm
                   TGS2600:H2    :0ppm    C2H5OH:0ppm    C4H10 :0ppm
                  Going through the "clean air calibation" I have:
                  float MQResistanceCalculation(int raw_adc)    {
                    return ( ((float)RL_VALUE*(1023-raw_adc)/raw_adc));
                  Here are the readings without:
                  MQ2:5.28
                  MQ6:36.94
                  MQ131:3.61
                  TGS2600:0.04
                  and with all is 0... BTW...
                  What do you think of that ? nothing indicated that MQ6 should be so big, and tgs so low... same for MQ131 that should be 100k-200k per datasheet....
                  jenbakerJ
                  jenbakerJ
                  jenbaker
                  @epierre
                  hi
                  i am new here.
                  sorry i am a little confused by with these new formulate.
                  is it the key for module?
                  • tantt2810T
                    tantt2810T
                    tantt2810
                    I'm don't understand the recipe below. Why RL_Value(Load Resistance)(1023-raw_adc)/raw_adc)? Can you explain for me?
                    ***************** MQResistanceCalculation ****************************************
                    Input: raw_adc - raw value read from adc, which represents the voltage
                    Output: the calculated sensor resistance
                    Remarks: The sensor and the load resistor forms a voltage divider. Given the voltage
                    across the load resistor and its resistance, the resistance of the sensor
                    could be derived.
                    float MQ2::MQResistanceCalculation(int raw_adc)
                    • jenbakerJ jenbaker
                      @epierre
                      hi
                      i am new here.
                      epierreE
                      epierreE
                      epierre
                      if you have a module the datasheet gives you the values, yes. Remember this is their """""generic"""" calibration, in fact they all copy the other so don't expect your MQ** would follow this by the letter...
                      • tantt2810T tantt2810
                        could be derived.
                        epierreE
                        epierreE
                        epierre
                        could be derived.
                        RL_VALUE
                        in fact it is above described, you have a voltage, you want a resistance.
                        https://learn.sparkfun.com/tutorials/voltage-dividers
                        datasheet needs a value which is the Rs/Ro (called here RL) where
                        Ro: sensor resistance at 100ppm of NH3 in the clean air.
                        Rs:sensor resistance at various concentrations of gases
                        here the formula is a simplification of this:
                        float Vrl = val * ( 5.00 / 1024.0 ); // V
                        float Rs = 20000 * ( 5.00 - Vrl) / Vrl ; // Ohm
                        int ratio = Rs/Ro;
                        ppm = 37143 * pow (ratio, -3.178);
                        tantt2810T VirV 2 Replies Last reply
                        • epierreE epierre
                          could be derived.
                          RL_VALUE
                          int ratio = Rs/Ro;
                          tantt2810T
                          tantt2810T
                          tantt2810
                          @epierre Hi you,
                          I think the Rs/Ro is not RL. In the datasheet RL=5kOhm. As I know it is a resistance on board Arduino, and we set it 5kOhm. Is it right? I also don't know why we set it equal 5kOhm. =))
                          And why 20000 is in "float Rs = 20000 * ( 5.00 - Vrl) / Vrl ; // Ohm" ?
                          Please help me clearly. Thank you so much !!!
                          • tantt2810T
                            tantt2810T
                            tantt2810
                            I have read the sensitivity characteristics curve in datasheet of MQ135 and I don't know AL R, 3/4, 1/4* and +- mean? Can you help me, please !!!
                            NH4 represent for NH3, doesn't it ?
                            • tantt2810T
                              tantt2810T
                              tantt2810
                              Hi everyone,
                              I have an CO2 MG811 sensor. I don't know where tcm pin connect with ?
                              Please help me. Thank you so much !!!!
                              0_1457101257425_F08406-CO2-Carbon-Dioxide-Sensor-Module-font-b-MG811-b-font-Voltage-0-2V-Voltage-Output.jpg
                              • TFPOK1T
                                TFPOK1T
                                TFPOK1
                                Hello, I'm working with an MQ-136 sensor, and am interested in measuring H2S and/or SO2 concentrations. I've got a simple sketch written which gives me a fairly consistent value on the serial monitor, but I've tried to run the multiple gas sensor sketch both complete and I also tried picking apart the sketch just to include MQ-136 related variables and algorithms, but I can't get it to work. It's showing too many errors to list here. Does anyone have simple conversions from the serial outputs to usable values for various gases that this sensor can measure?
                                • Joel PérezJ
                                  Joel PérezJ
                                  Joel Pérez
                                  hello, how i read co2 ppm with my mq135?
                                  helpme please
                                    Hi everyone,
                                    epierreE
                                    epierreE
                                    epierre
                                    @tantt2810 said:
                                    Hi everyone,
                                    this is an analogic sensor, so VCC/Gnd to power it, and readings on analogic Aout
                                    • epierreE
                                      epierreE
                                      epierre
                                      @tantt2810 sorry for not being more responsive, I left MQ/TGS behind me but I've not kept all my notes on mesuring this and that, that would require me to search for it again. But I appreciate if you can spot me some float/type error conversion in sketches !
                                      • epierreE
                                        epierreE
                                        epierre
                                        I was a bit disappointed when a project I contributed to on Kickstarter showed the inside of their boxes, I wonder how they will manage to satisfy customers with calibration... or their home made index as netatmo did
                                          moskovskiy82
                                          Used the air quality script for MQ7 but throwed out all the conversions and calibrations. Just reading the plain input from the analogue pin.
                                          I targeted this as a smoke detector but it seems this sensor highly depends on the humidity of the surrounding air. Are there any existing formulas to correct for the humidity of the surounding air?
                                          And on one sensor i have some irratical data as shown below (blue). I wonder if it's a power supply (black and green is DHT) or a broken sensor?
